SOAPpy patches for paths and authorization
Ivan R. Judson
judson at mcs.anl.gov
Tue Nov 11 15:29:27 CST 2003
I said I'd do this, and I finally got to it. The diff file attached is
a cvs diff from my code as of this afternoon. The functionality
introduced by this patch includes:
- GSI Communication added
- Path mapping to namespaces added
- Authorization callback support is added
What are these things?
GSI Communication:
Using the pyGlobus project (Hi Keith!) the Globus Project's
(http://www.globus.org) GSI communication layer was added to as a
transport protocol (akin to http and https), this uses the proto httpg
by default.
To test this you can run the echoServer.py with -g and the
echoClient.py with -g, you will need pyGlobus, and a certificate, and
to generate a proxy (Keith can fill you in on that better than I can).
Path mapping to namespaces:
I've added the ability to register functions and objects with an
options path = "/foo" argument. It converts the path to a namespace and
uses the existing infrastructure for doing the registration and
retrieval.
I've added the ability (as generically as I could imagine) to have an
authorization callback registered for functions or objects. The
callback has a generic foo(*args, **kw) or Class.Method(self, *args,
**kw) signature. What's passed currently is a _SOAPContext (like the
other kw applys). This context contains the connection object which for
the GSI stuff is what i need to find out who is on the other end. If no
authorization method is registered (or found) the code is executed as
expected. If there is an authorization callback it should return 1 or
0. If it returns 0, a fault is raised with Not Authorized somewhere
inside.
Please look this patch over and let me know what you think. I'd love it
if this could be applied to the cvs repo (it would mean I could just
use a stock SOAPpy for awhile) instead of a badly maintained 0.9.7
version that's really out of date :-).
--Ivan
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20031111/699dccae/attachment.obj>
