FW: New SC Global Beacon
Terry Disz
disz at mcs.anl.gov
Tue Nov 4 13:56:31 CST 2003
-----Original Message-----
From: owner-scg03-l at bu.edu [mailto:owner-scg03-l at bu.edu] On Behalf Of
Jennifer Teig von Hoffman
Sent: Tuesday, November 04, 2003 1:52 PM
To: Scg03-Sites-L; Scg03sat-L; scg03-l
Subject: Re: New SC Global Beacon
Hi everybody,
This is very important! If your network is having problems, this can
help. If your network is not having problems, we need your site on the
beacon as a point of comparison, to help us track down where the
problems are.
This is a quick and easy install -- please do it today.
Cheers,
Jennifer
Eric Gauthier wrote:
> Hello,
> With the show only two weeks away, the SC Global committee is
finalizing
> several tools to help us debug any last-minute problem with bringing
nodes
> online as well as to troubleshoot problems during the show. If you
haven't
> already, please install the latest NLANR beacon which can be
downloaded
> from:
http://dast.nlanr.net/projects/beacon/newbeacon/beacon-0.9.06.tar.gz
> Please make sure that you install 0.9.06 and, if you happen to be
running an
> older version, please take a moment to upgrade.
> If you haven't already, please send me an email with the IP address or
the
> hostname of your audio, video, and display servers, and indicate which
one
> will be running your beacon. This information will help us help you
and
> other SC Global participants diagnose and resolve problems going
forward.
> If you have any questions, please don't hesitate to ask!
> Eric Gauthier
> Network Engineer
> 617-353-8218 ~^~ elg at bu.edu
> Boston University - Office of IT
> At 06:33 PM 10/27/2003 -0500, you wrote:
>>Hello,
>>As many of you know, the NLANR Beacon Server is an invaluable tool for
>>diagnosing and debugging multicast problems. Participating hosts
>>periodically send out multicast-based hello's and log the hello's
which
> they
>>see, then the NLANR Beacon server aggregates all of this information
and
>>presents a reachability matrix. When a node begins to have trouble
with
>>their AccessGrid streams, a quick check of the reachability matrix
helps
> to
>>determine if the cause is the multicast-enabled portion of your local
or
>>wide-area network.
>>Today, NLANR released an updated version of their second generation
Beacon
>>Server and its associated client. We'd like everyone to install the
new
>>client on one of the systems that will be used for SC Global (i.e. the
>>audio, video, or display server). The client is located at:
http://dast.nlanr.net/projects/beacon/newbeacon/beacon-0.9.05.tar.gz
>>Once you have installed and started the beacon client, you should see
your
>>host appear on the NLANR Beacon page:
>> http://beacon.dast.nlanr.net
>>After you finish installing the beacon client, please send me an email
> with
>>the IP address or the hostname of your audio, video, and display
servers,
>>and indicate which one will be running your beacon. This information
will
>>help us help you and other SC Global participants diagnose and resolve
>>problems going forward.
