Document Process Update
Ivan R. Judson
judson at mcs.anl.gov
Mon Nov 3 10:52:09 CST 2003
Are we going to see this document before you leave for vacation?
We're blocking the next cycle on the design documents, so everything is
stalled on the security design document(s) and Tom's node mgmt design
updates.
I'm anxious to have them done.
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Friday, October 31, 2003 8:16 AM
> To: judson at mcs.anl.gov; ag-dev at mcs.anl.gov
> Subject: RE: Document Process Update
> No further progress, been working on SC stuff.
> At 08:03 AM 10/31/2003, Ivan R. Judson wrote:
> >Hey,
> >What's the progress on this design document? I think it and
> tom's node
> >management updates are the only outstanding designs we have
> to finish
> >before we can start moving ahead on planning the next development
> >cycle.
> >--Ivan
> > > Sent: Thursday, October 16, 2003 12:02 AM
> > > To: judson at mcs.anl.gov; judson at mcs.anl.gov; ag-dev at mcs.anl.gov
> > > If we're looking for a comprehensive design doc for the cert mgmt
> > > stuff that isn't what is there now, it's not going to happen by
> > > friday, as I am
> > > gone friday and it needs more than a day's coverage; I don't
> > > see a reason
> > > to hold up releasing because of it. A design document in the
> > > style of the
> > > others is really a new document that I can start working up
> > > next week, in
> > > between SC demo prep and other stuff..
> > > --bob
> > > At 10:45 PM 10/15/2003 -0500, Ivan R. Judson wrote:
> > > >I've glanced over all of the documents tonight. Most of them
> > > are coming
> > > >along quite nicely. The two that look to me to need the most
> > > work are
> > > >the bridge server design and the certificate management
> design (I
> > > >believe we need a design document for the cert stuff
> since it's a
> > > >complicated enough subsystem that it warrants it). The
> > > existing design
> > > >outline is a good start at what needs to go into the
> design docs; I
> > > >notice the bridge server doc isn't using the template yet --
> > > that needs
> > > >to happen as well.
> > > >Again, I'd like to see all of these documents done by Friday
> > > morning so
> > > >that we can announce 2.1.2 Friday -- and the completion of these
> > > >documents. The goal of the current design documents is also
> > > to provide
> > > >a good basis for our next cycle, as such it should
> completely and
> > > >accurately explain what's happening in the current code base.
> > > >Thanks,
> > > >--Ivan
> > > >PS -- Please do read and comment on documents via
> ag-dev, we'll all
> > > >produce better documents as a result.
> > > > > From: owner-ag-dev at mcs.anl.gov
> > > [mailto:owner-ag-dev at mcs.anl.gov] On
> > > > > Behalf Of Ivan R. Judson
> > > > > Sent: Tuesday, October 14, 2003 2:03 PM
> > > > > To: 'Robert Olson'; ag-dev at mcs.anl.gov
> > > > > I forgot to mention that we should all be reading and
> commenting
> > > > > (via email) on each others docs so we can make them high
> > > quality as
> > > > > fast as possible.
> > > > > --Ivan
> > > > > > Sent: Tuesday, October 14, 2003 1:38 PM
> > > > > > Subject: Re: Document Process Update
> > > > > > I think I'm up to date on manuals, given that:
> > > > > > I don't see what it means for cert mgmt and access control
> > > > > > documents to be merged; they address different topics, and
> > > > > > Right now, I think it's more important to make
> headway on apps
> > > > > > stuff for SC demos than to convert over the
> datastore doc from
> > > > > > tex/pdf to word; when the programmer's manual
> activity gains
> > > > > > traction I'll get it switched over, and
> > > > > > will thus only have to reformat once.
> > > > > > --bob
> > > > > > At 05:07 PM 10/3/2003 -0500, Ivan R. Judson wrote:
> > > > > > >Howdy,
> > > > > > >We currently have a few types of documents:
> > > > > > >Architecture Documents (These should all be word docs,
> > > with visio)
> > > > > > >Design Documents (These should all be word
> > > docs, with visio)
> > > > > > > (Example Outline in
> > > > > > DesignOutline.doc and
> > > > > > >Template in AGDesign.dot)
> > > > > > >How-To Documents (These should all be
> word docs)
> > > > > > >Implementation Notes (These can be anything, they aren't
> > > > > for public
> > > > > > >consumption really,
> > > > > > > but remember, not everyone
> > > > > > has every
> > > > > > >tool...I don't have latex,
> > > > > > > I do have pdf :-)
> > > > > > >Manuals (These should all be in word)
> > > > > > >In order to close our last few issues on this cycle, I'd
> > > > > > like us to get
> > > > > > >our design documents in synch with our current code. In
> > > > > > order for that
> > > > > > >to happen, I'd like it if the following writing
> > > assignments were
> > > > > > >completed by the end of next week:
> > > > > > >Document Author Action
> > > > > > >Virtual Venues Design Ivan Incorporate
> > > > > > Event Service
> > > > > > >doc
> > > > > > >Venue Client Design Susanne
> Incorporate Personal
> > > > > > Node Design
> > > > > > >Venue Management Design Susanne
> > > > > > >Data Store Design Eric
> > > > > > >Bridge Server Design Tom
> > > > > > >Node Management Design Tom Incorporate
> > > > > > Personal Node
> > > > > > >Design
> > > > > > >Certificate Management Bob Merge
> > > > > > >and Access Control Notes
> > > > > > >Datastore Client Bob
> > > > > > Converted to word,
> > > > > > >to be part of future programmers manual.
> > > > > > >Toolkit Core Design Ivan Convert
> > > > > > Toolkit config and
> > > > > > >init doc
> > > > > > >Looking at CVS, we have more documents than this, which is
> > > > > good ;-).
> > > > > > >But, we do need to consolidate some, the documents
> > > that are being
> > > > > > >merged can be removed from cvs. If there are remaining
> > > > > > implementation
> > > > > > >details that would be lost, they should be put in an
> > > > > > >implementation notes document.
> > > > > > >Thanks, we're so close to finishing this cycle I can
> > > taste it :-)
> > > > > > >--Ivan
