[AG-TECH] Grid Certificates
Ivan R. Judson
judson at mcs.anl.gov
Fri May 16 08:05:52 CDT 2003
> >I tracked down the wierdness with the server today, things
> are working
> >for me, but this slowness is discouraging :-\.
> I also want to look into C-based XML parsers; do you know if
> the current
> install uses a default Python-based parser?
I don't know, it's the Expat parser in ActiveState on my laptop (I'm
guessing on vv2 though it's the same one you're using -- I don't know there
either :-)
> When I did some benchmarking on the XMLRPC stuff at the start
> of all this
> replacing the Python XML parser with a C-based parser made a
> big difference
> in raw message-call times.
> Can you tell if hte slowness is in call/response or elsewhere?
I can't yet, that's on today's list.
--Ivan
