FW: gcc optimization problems?
Ivan R. Judson
judson at mcs.anl.gov
Wed May 14 14:14:42 CDT 2003
I just found this again.
--ivan
> -----Original Message-----
> From: owner-openmash-developers at bmrc.berkeley.edu
> [mailto:owner-openmash-developers at bmrc.berkeley.edu] On
> Behalf Of Kun Wei
> Sent: Thursday, July 11, 2002 11:29 AM
> To: Robert Olson
> Cc: Open Mash Developers; VRVS Team
> Subject: Re: gcc optimization problems?
> Following is from VRVS README on compiling VIC. Hope it helps.
> 4) Knowning problems
> vic can be compiled successfully under Redhat 6.x, which use
> an old version of gcc.
> Under Redhat 7.x, because of gcc2.96 optimization bug, the
> compiled version will
> be very fragile. Thanks for Piers O'Hanlon pointing it out.
> To compile under gcc 2.96, you can try to compile without
> -O2 option. Or you should upgrade to gcc3.02. It can be
> download from http://gcc.gnu.org/
> To compile under new kernel, some small changes needed here:
> # add "#include <time.h>" in common/config_unix.h
> # add newline to the end of common/inet_pton.h
> # add newline to the end of common/mbus_parser.h
> # change function call "tmpnam(...)" to "mkstemp(...)"
> in tcl8.0/unix/tclUnixPipe.c
> # change "#define SIGARGS ..." to "#define SIGARGS
> int" in vic/main.cpp
> # change "strcasecomp(...)" to "strcasecomp(...) throw
> ()" in vic/config.h
> # change struct JpegEncoder::huffentry from protected
> to public in
> vic/codec/encoder-jpeg.cpp
> patch is available as vic--kernel2.4.patch.txt.
> "patch -p0 -r vic-2.9.1 < vic--kernel2.4.patch.txt"
> Cheers
> Kun
> Robert Olson wrote:
> > I'm curious if any of you have seen probelms with gcc -O2
> optimization
> > and the H261 encoder in mash. I was building the UCL/AG vic on
> > RH7.2/7.3 with gcc-2.96. When building with -O2, I got
> funky distorted
> > video with the h261 encoder and crashes after 10-20 sec of capture.
> > This didn't show up with the stock compiler on RH6.2 (looks
> like egcs
> > 2.91.66).
> > thanks,
> > --bob
> Kun Wei
> Email: weikun at caltech.edu
> Address: MC 256-48, Caltech
> Pasadena, CA 91125
> Phone: 1-626-395-8767
