Status on 2.0
Susanne Lefvert
lefvert at mcs.anl.gov
Fri May 9 15:41:24 CDT 2003
> Susanne
> - Sequence Diagrams (for enter/exit)
> - Venue Client Reliability
> - Exception Handling
> - Venue Client Usability
> - UI Improvements
My status is:
- Enter sequence diagram is done, working on exit
- I am catching exceptions as they get added to the code, a small comment
in method's doc string would be very helpful to clearify which methods
raises what exception and why.
- Current status on UI improvments from last meeting:
Finished:
* Merge node and participant heading, just participants
* Merge "Edit" and "My Node" menu items into one called "Preferences"
* Removed CTRL short cuts
* Make twist buttons show up in the tree on Windows
* Make the text field not editable, focus on message field instead
(If user tries to type in text output field the focus is moved to
text input field)
* Separate menus for headings and actual items
* Be able to double click items
* About dialog should have editable fields not just an image
Working on:
1 Clearer text to show where you are, venue name under menu over address
2 Add menu bar to Venue Management
3 Status messages
4 Services and Applications should be combined to one named services (?)
5 Personal data should be shown in a dock as well as under participants
6 The contents tree should be split up into tabs that you can tear off
7 Should be able to tear off text chat
Issues:
* Audio and video buttons instead of My Node Window (audio-start-stop etc)
Tom, let me know what you think we should do about this (?)
* Exits take up too much space.
Need to figure out a solution to this and I would like more feedback from users before I change to
something else. One thought is to add exits to the menu instead of having them in the actual window.
* Improve navigation, be able to "look ahead"
Will probably not be added to AG2.0, we need to figure out how to do this in a good way.
* Administrators for venues in VenueManagement.
Is methods for this present in Venue.py?
It would be very nice to get more feedback on the UI so I know what to
focus on and to get as many changes as possible done before the release.
/Susanne
