FW: [AVT] RTCP unicast feedback for measurement applications?
Ivan R. Judson
judson at mcs.anl.gov
Thu Mar 13 20:35:09 CST 2003
Network Monitoring reading.
> -----Original Message-----
> From: avt-admin at ietf.org [mailto:avt-admin at ietf.org] On
> Behalf Of Eve Schooler
> Sent: Thursday, March 13, 2003 1:38 PM
> To: Fiandra Riccardo; Joerg Ott; Julian Chesterfield
> Cc: avt at ietf.org
> Subject: Re: [AVT] RTCP unicast feedback for measurement applications?
> Fiandra,
> Finally, here are pointers to the paper that extends the
> ideas proposed in the I-D, and that I promised below.
> The paper analyzes the bandwidth savings of summarisation,
> and presents a couple additional techniques (biasing and
> hierarchical summarisation) that
> - combine well with unicast feedback and generic summarisation,
> - provide further rtcp scalability, and
> - offer additional application contexts for rtcp.
> http://www.research.att.com/~schooler/papers/rtcp-summary-pape
r.techreport.ps
r.techreport.pdf
> A shorter version will appear in the 2nd IEEE International
> Symposium on Network Computing and Applications, NCA-03,
> April 16-18, 2003, Cambridge, MA.
> http://www.research.att.com/~schooler/papers/rtcp-summary-paper.ps
> http://www.research.att.com/~schooler/papers/rtcp-summary-paper.pdf
> E.
> > From: Eve Schooler [mailto:schooler at research.att.com]
> > Sent: martedì 4 febbraio 2003 2.02
> > Cc: Eve Schooler; Julian Chesterfield; Joerg Ott; avt at ietf.org
> applications?
> > Fiandra Riccardo <riccardo.fiandra at fastweb.it> wrote:
> > >I was interested in the "RTCP Extensions for Single-Source
> Multicast
> > >Sessions with Unicast Feedback" draft. Actually, I was
> wondering if
> > >it is also targeted to have a very large and distribuited network
> > >measurement framework. Where multicast receivers
> (thousands) use RTCP
> > >to send report to a measurement collector about packet
> loss, jitter,
> > >or other. I see really many advantages on that for e2e
> measurements,
> > >especially in a scenario where thousands of receivers are always
> > >connected to the network and cannot send multicast (common
> scenario
> > >for an operator, even without SSM...).
> > >My questions are:
> > >-Was this a scenario of application when writing the draft?
> > Absolutely, though the primary focus of the draft was to solve the
> > problem posed by the removal/restriction of the backchannel
> caused by
> > SSM and other uni-directional or asymmetric topologies. Solving the
> > feedback problem for SSM gives us the blueprint for other
> > unicast-based feedback architectures, including ones for network
> > measurement in general.
> > >-In this case, could I use the RTCP channel multicasted to the
> > >receivers to control them?
> > Yes you could. This is certainly what we envision in the RTCP
> > context; use the multicast channel in the source-to-receiver
> > direction, and use the unicast backchannels in the
> receiver-to-source
> > direction.
> > We also propose to use the multicast channel either:
> > - to reflect receiver feedback (received on the unicast
> backchannels)
> > back out on the multicast channel to reach all receivers, or
> > - to redistribute to the receivers feedback summaries
> > (receiver feedback collected at the source and aggregated into
> > a single mathematical distribution) back out on the multicast
> > channel.
> > >-Do you see any extension possible also for ptp rtp connections
> > >(forward rtcp reports to another device?)
> > In section 10 of draft-ietf-avt-rtcpssm-02.txt, we use
> > an extension to SDP to indicate the device to which the
> feedback gets
> > reported. This is done following the proposal for SDP
> source filters
> > documented in draft-ietf-mmusic-sdp-srcfilter-00.txt.
> > We also just completed a paper that expands upon the ideas
> > in the I-D and that should provide further application scenarios.
> > I'll post it here shortly.
> > Eve
> > Eve M. Schooler Voice: 1-650-330-7913
> > AT&T Labs - Research FAX: 1-650-463-7037
> > 75 Willow Road E-mail: schooler at research.att.com
> > Menlo Park, CA, USA 94025
> Audio/Video Transport Working Group
> avt at ietf.org
> https://www1.ietf.org/mailman/listinfo/avt
