Fwd: AccessGrid/bin RunMe.py,1.1,1.2
Robert Olson
olson at mcs.anl.gov
Wed Mar 12 06:25:25 CST 2003
Ahem.
These processes are getting started asynchronously. I did not see the
problem every time with the other ordering of the lines; I posit that we
will not see the problem every time with this ordering of the lines either;
I also posit that it will not work correctly every time.
The real solution involves adding the proper interlocking so that the
process that is dependent on the other running first either waits to start
until the other is going, or that it probes more than once for the service
that it believes should be running.
Please also recall that the bugzilla archive is a public record. I do not
find the comment there regarding this bug to be at all appropriate.
>From: "Ivan R. Judson" <judson at mcs.anl.gov>
>Date: Wed, 12 Mar 2003 02:09:45 -0600
>To: ag-cvs at mcs.anl.gov
>Subject: AccessGrid/bin RunMe.py,1.1,1.2
>Sender: owner-ag-cvs at mcs.anl.gov
>X-Spam-Status: No, hits=0.5 required=5.0 tests=X_NOT_PRESENT version=2.21
>X-Spam-Level:
>X-Whitelist-by-bob: yes
>Update of /cvsroot/AccessGrid/bin
>In directory pachelbel.mcs.anl.gov:/tmp/cvs-serv22007
>Modified Files:
> RunMe.py
>Log Message:
>Fixed bug #125, it took switching two lines, big woop.
