winGlobus/pyGlobus saga
    Robert Olson
    olson at mcs.anl.gov
    Mon Mar 10 15:23:52 CST 2003
My rebuilding pyGlobus from the bob-zipfile saga, mostly for Justin and Ti.
WinProjects\SourceSolution\DebugLib\All_Libs.sln
Clean project, build project
WinProjects\SourceSolution\DebugThreadedLib\All_Libs.sln
C:\temp\newwing>cd pyGlobus
C:\temp\newwing\pyGlobus>set
GLOBUS_LOCATION=c:\temp\newwing\WinGlobus2.0_Alpha3
C:\temp\newwing\pyGlobus>python setup.py build
Checking for which modules to build
Run c:\temp\newwing\WinGlobus2.0_Alpha3\bin\globus-makefile-header.py
-flavor=gc
c32dbgpthr globus_common
globus_common_win32dbgthr.lib(globus_common.obj) : error LNK2001:
unresolved ext
ernal symbol ___security_cookie
globus_common_win32dbgthr.lib(globus_libc.obj) : error LNK2001: unresolved
exter
globus_common_win32dbgthr.lib(globus_thread_common.obj) : error LNK2001:
unresol
ved external symbol ___security_cookie
globus_common_win32dbgthr.lib(globus_print.obj) : error LNK2001: unresolved
exte
unresolved ext
ernal symbol @__security_check_cookie at 4
exter
unresol
ved external symbol @__security_check_cookie at 4
exte
then I remembered that my stystem has VS 6.0 and VS.net installed, and that
the python distutils don't pick that up properly. So I edited
\Python22\lib\distutils\msvccompiler.py added the last line below, at line 209:
     def __init__ (self,
                   verbose=0,
                   dry_run=0,
                   force=0):
         CCompiler.__init__ (self, verbose, dry_run, force)
         versions = get_devstudio_versions ()
         versions = ["7.0"]
Then I got this, which is the problem with the project files that I thought
I'd fixed in the zip:
    Creating library build\temp.win32-2.2\Release\ftpClientc.lib and object
build
\temp.win32-2.2\Release\ftpClientc.exp
globus_gssapi.lib(acquire_cred.obj) : error LNK2001: unresolved external symbol
_globus_i_gsi_gssapi_module
globus_gridftp_control_win32dbgthr.lib(globus_ftp_control.obj) : error LNK2001:
unresolved external symbol _globus_i_gsi_gssapi_module
globus_gss_assist.lib(globus_gss_assist_module.obj) : error LNK2001: unresolved
globus_gssapi.lib(init_sec_context.obj) : error LNK2019: unresolved
external sym
bol _globus_i_gsi_gssapi_module referenced in function _gss_init_sec_context at 52
globus_gssapi.lib(accept_sec_context.obj) : error LNK2001: unresolved
external s
globus_gssapi.lib(init_sec_context.obj) : error LNK2001: unresolved
external sym
bol _once_control
external s
ymbol _once_control
_once_control
build\lib.win32-2.2\pyGlobus\ftpClientc.pyd : fatal error LNK1120: 2 unresolved
externals
error: command '"C:\Program Files\Microsoft Visual Studio
.NET\VC7\BIN\link.exe"
' failed with exit status 1120
Next, I deleted the contents of the /lib dir in the winglobus tree, as I
think I had some old state there. In doing that I deleted the openssl
libraries that I now remember building. I built those from the openssl0.9.6
version taht was the latest at the time. I had built these again last week,
static linked so we didn't have to worry about DLLs, from version 0.9.6i. I
copied libeay32.lib and ssleay32.lib into the winglobus lib dir as well.
I did a rebuild solution on both the nonthreaded and threaded lib solutions.
At this point the pyGlobus build succeeded; apparently the .lib files from
the zip file were incorrect and also not getting rebuilt properly.
PYTHONPATH=c:\temp\newwing\pyGlobus\build\lib.win32
-2.2
C:\temp\newwing\pyGlobus>cd \temp
C:\temp>python
Python 2.2.2 (#37, Oct 14 2002, 17:02:34) [MSC 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
 >>> import sys
 >>> sys.path
['', 'c:\\temp\\newwing\\pyGlobus\\build\\lib.win32-2.2',
'C:\\Python22\\lib\\si
te-packages\\Pythonwin', 'C:\\Python22\\lib\\site-packages\\win32',
'C:\\Python2
2\\lib\\site-packages\\win32\\lib', 'C:\\Python22\\lib\\site-packages',
'c:\\pyt
hon22\\DLLs', 'c:\\python22\\lib', 'c:\\python22\\lib\\lib-tk', 'c:\\python22']
 >>> import pyGlobus.io
