FW: CVS repository available again
Ivan R. Judson
judson at mcs.anl.gov
Fri Jun 6 10:48:32 CDT 2003
This should be in place now, so you can make your final change over.
--Ivan
> -----Original Message-----
> From: Tisha Stacey [mailto:tstacey at mcs.anl.gov]
> Sent: Friday, June 06, 2003 10:34 AM
> To: Ivan R. Judson
> Cc: systems at mcs.anl.gov
> Subject: RE: CVS repository available again
> Alrighty -- I think this is looking more sane now. You
> should use cvs.mcs.anl.gov:/cvs/fl as your CVSROOT. (Also
> remember to set
> CVS_RSH=ssh.) ViewCVS can be found at
> http://fl-cvs.mcs.anl.gov . The actual full > URL os
> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi,
> but the "home" page at fl-cvs.mcs.anl.gov will bounce you there.
> I don't know if you wanted it or not, but I integrated
> CVSgraph with ViewCVS. (If you click on the link to one of
> the CVS directories, each document has a little graph icon
> beside its Rev. number, which you can click on to see the
> CVSGraph stuff.) If for some reason you don't want it, it's
> an easy matter to get rid of it.
> Hopefully this all makes sense. Let me know if you need
> anything else!
> - Tisha
> On Fri, 6 Jun 2003, Ivan R. Judson wrote:
> |Hey,
> |I've decided it's probably less advantageous to use the
> fl-cvs cname at
> |all. It's probably best to let cvs.mcs.anl.gov:/cvs/fl represent the
> |futures lab cvs space. With respect to the ViewCVS
> question, I'm not
> |sure the right answer, but I think I prefer:
> |> would you rather have people use
> |> cvs.mcs.anl.gov:/cvs/fl as their CVSROOT and keep
> |> fl-cvs.mcs.anl.gov/viewcvs as the URL?
> |This option. It seems more consistent with other in the
> division using
> |the shared cvs repository (ie, I could see a
> cvs.mcs.anl.gov:/cvs/bio &
> |bio-cvs.mcs.anl.gov/viewcvs, someday).
> |Let me know when you have these mods done I'll poke the fl with the
> |updates they need to make to their currently checked out code :-)
> |Thanks!
> |--Ivan
