[AG-TECH] Error installing AG 2.0 on XP . . .
Ti Leggett
leggett at mcs.anl.gov
Mon Jul 21 16:54:00 CDT 2003
No becuase I'm not sure why it's happening. I had tried to track it down
before to no avail. I think it has something to do with how windows
processes system environment variables from a process that just modified
them. That's all I can think of.
On Mon, 2003-07-21 at 16:50, Robert Olson wrote:
> Is this fixed in the CVS version yet?
> At 03:07 PM 7/21/2003 -0500, Ti Leggett wrote:
> >So if you click the setup globus check box at the end of the installer,
> >there's a known bug in that globus hasn't been fully setup yet so it
> >fails. However, if after installing, you go to Start/Programs/Windows
> >Globus and run the Globus Configuration program it should work. After
> >that's run successfully you should be able to create a certificate
> >request.
> >On Mon, 2003-07-21 at 14:22, Deb Agarwal wrote:
> > > I am trying to install AG 2.0 on win XP professional.
> > > I already have AG1.2 working and have installed the
> > > ActiveState Python and wxPython without obvious problems.
> > > DUring the install of windows Globus, I get the following
> > > error "GLOBUS_LOCATION is not set" something wrong with
> > > installation. I tried uninstalling, rebooting, and reinstalling
> > > but still got this error. I didn't see anything on AG Tech
> > > about how to solve it. Any help is appreciated. On the
> > > first attempt I plowed through and tried to get a certificate
> > > and the get a certificate utility appeared to work correctly
> > > but there was no Application Data directory in the location
> > > indicated by the script.
> > > Thanks,
> > > Deb
