[AG-TECH] Error installing AG 2.0 on XP . . .
Robert Olson
olson at mcs.anl.gov
Mon Jul 21 16:50:45 CDT 2003
Is this fixed in the CVS version yet?
At 03:07 PM 7/21/2003 -0500, Ti Leggett wrote:
>So if you click the setup globus check box at the end of the installer,
>there's a known bug in that globus hasn't been fully setup yet so it
>fails. However, if after installing, you go to Start/Programs/Windows
>Globus and run the Globus Configuration program it should work. After
>that's run successfully you should be able to create a certificate
>request.
>On Mon, 2003-07-21 at 14:22, Deb Agarwal wrote:
> > I am trying to install AG 2.0 on win XP professional.
> > I already have AG1.2 working and have installed the
> > ActiveState Python and wxPython without obvious problems.
> > DUring the install of windows Globus, I get the following
> > error "GLOBUS_LOCATION is not set" something wrong with
> > installation. I tried uninstalling, rebooting, and reinstalling
> > but still got this error. I didn't see anything on AG Tech
> > about how to solve it. Any help is appreciated. On the
> > first attempt I plowed through and tried to get a certificate
> > and the get a certificate utility appeared to work correctly
> > but there was no Application Data directory in the location
> > indicated by the script.
> > Thanks,
> > Deb
