is that doing the same thing as isinstance(obj, ServiceObject) ? At 01:32 PM 2/8/2003 -0600, Ivan R. Judson wrote: >I propose we add amethod IsValid() to the service object that returns true. >Then you can verify that your handle is good *before* you try to use it. >This makes it significantly easier to handle cases like venue entering... > >Thoughts?
