"new" requirement
Ivan R. Judson
judson at mcs.anl.gov
Sun Aug 24 06:18:17 CDT 2003
These are excellent use case scenarios. We'll be using them to generate
design goals and incorporating it into the roadmap.
--Ivan
> -----Original Message-----
> From: Rick Stevens [mailto:stevens at mcs.anl.gov]
> Sent: Saturday, August 23, 2003 5:06 PM
> To: Ivan R. Judson
> Cc: 'Terry Disz'; ag-dev at mcs.anl.gov
> Subject: RE: "new" requirement
> I might be able to help here. What I would like to see
> ideally is a folder orriented drag and drop interface to the
> venue. I note that I don't consider the venue server
> necessarily directly implementing this functionality but that
> it would be transparent to a venue user. A model would be
> something like iDisk access. one should be able to double
> click to launch apps from the venue interface in the venue
> client (ideally the venue resources would become
> transparently available to the deskop (as
> folder) on the machne running the venue client while docked
> in the venue so explicit copying would not be needed unless
> one wants to have access to the item after undocking.. For
> large things we will want a "third party" type interface to
> grid data stores.. similar to what Dennis was talking about
> at the middleware review.
> a simple use of this is putting some data and a data viewer
> to be used on the data in a meeting in the venue for others
> to gain access too.
> this is the basic functionality needed for the venue to
> beging to support "shared projects"
> another use case is I'd like to put all the presentations for
> a course in a venue along with applications and data for a
> class. I would like to get all of this built ahead of time
> and then publish the venue for the class to use. In fact if
> we can get this working this fall I'll use my systems biology
> class as a test case.
> I can easily see associating a few TBs of data to support an
> active venue. This is a model that makese sense for the CMC
> project for example.
> another variation is how we link to databases and database
> applications in a venue. I can see having databases (SQL,
> Oracle, DB2) available via the venue with various
> applications that can access them. The idea being that one
> would not have to re-authenticate to gain access to the
> databases that have been "associated" with the venue. not
> sure exactly how to do this.. but this is what we want to
> support many of the bioinformatics projects that we are
> working on or have in the pipeline.
> --Rick
> On Fri, 22 Aug 2003, Ivan R. Judson wrote:
> > It's not clear to me the details of this requirement. It'd
> be really
> > helpful if you could elaborate with use cases (even simple
> ones). If
> > this is the complete requirement I believe it's already
> been fulfilled
> > by the DataStore Client API Bob checked in and documented with the
> > attached PDF.
> > It's described this way, in mail to ag-dev (which I notice you are
> > subscribed to):
> > Within DataStoreClient is a ftp-ish command line client
> interface to
> > the
> > datastore. While useful on its own, it provides a set of
> examples of the
> > interface to the datastore. To try it out, just run
> DataStoreClient.py at
> > the command line
> > Notably, this module introduces methods that reutrn
> filehandles for reading
> > from and writing to the venue datastore. The current
> implementation does
> > this by simply downloading before read, and uploading after
> write. However,
> > they should simplify the use of a venue datastore when
> those are the
> > natural operations (for instance, with them one could
> pickle directly to
> > and from venue datafiles).
> > Is that sufficient or are you asking for something more?
> If you're asking
> > for something more, you'll have to provide more detailed
> requirements.
> > Otherwise, we'll consider this requirement fulfilled..
> > Cheers,
> > --Ivan
> > From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf
> > Of Terry Disz
> Sent: Thursday, August 21, 2003 4:35 PM
> > To: ag-dev at mcs.anl.gov
> > Subject: "new" requirement
> > I need to be able to write and retrieve directly to/from a venue.
> > Things like open, read, write.
> > Terry
