"headless" VideoProducerService
Christopher Cope
cope at mcs.anl.gov
Thu Aug 21 11:00:26 CDT 2003
yesterday when helping hiro use my script, i finally realized why it
seemed that some mash cvs snapshots worked, and some didnt. you need to
have permissions for the video devices *when* you compile mash, not just
when you use it. which shouldnt be a problem if you're installing it as
root, but i was dumbfounded.
to install mash,
set CVSROOT to
:pserver:anonymous at cvs.openmash.org:/usr/mash/src/repository
cvs login
(no password needed)
cvs checkout mash-code (any snapshot from the last 5 weeks should work.
if the current one doesnt work, try cvs checkout -D 2003-08-20 hiro got
it working yesterday)
cp -r desCore mash-code <you need to copy the DES
lib. you can find a copy in ~cope/AG/desCore>
cd mash-code
./configure --enable-des --enable-rijndael
./build
tom, ivan, is this something you were wanting to add to the next ag
release?
chris
