Replacement for --cert/--key on Venue Server
    Robert Olson
    olson at mcs.anl.gov
    Wed Aug 20 14:10:39 CDT 2003
to set up a venue server using a host/service cert, you can do the following.
Create a directory to hold the venue server's per-user state (which
includes the certificte repository)
set AGTK_USER=thatdir
Start the venue client, fill in the profile if you want, and start the cert
mgr. Import the service cert, and set it as the default.
Quit the venue client, and run the venue server (assuring that AGTK_USER is
still set).
You should see something like the following in the logging output (that
shows up with -d anwyay):
08/20/03 14:08:10 DEBUG Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=mcs.anl.gov/CN=VenueServer/vv2.mcs.anl.gov
08/20/03 14:08:10 DEBUG Initializing environment with unencrypted user cert
/O=Access
--bob
