pyGlobus/src sslutils.i,1.9,1.10 sslutils_wrap.c,1.10,1.11
    Robert Olson
    olson at mcs.anl.gov
    Wed Aug 20 13:32:07 CDT 2003
This'll require a rebuild of pyGlobus for the release. Not critical, but if
it's not fixed you get a spurious incorrect-password message if you enter
it wrong once (at the GPI window).
--bob
At 12:08 PM 8/20/2003 -0500, Robert Olson wrote:
>Update of /cvs/fl/pyGlobus/src
>In directory delta.mcs.anl.gov:/tmp/cvs-serv26021
>Modified Files:
>         sslutils.i sslutils_wrap.c
>Log Message:
>Add ERR_clear_error() call to the start of grid_proxy_init2.
>This fixes a problem where a passphrase failure on one call will cause
>the next call to fail due to leftover error state.
>Oddly, adding the clear_error call at the end of the error-case code
>didn't help.
