Roles API
Eric Olson
eolson at mcs.anl.gov
Tue Aug 12 15:16:37 CDT 2003
I thought about this a little bit, but haven't come up with a
final solution.
I'm thinking it would be nice if the role interface was more self
contained and roles could be accessed through a single Soap method in the
venue or venueserver. That method would pass on the call to an
object that processes the call and knows/is/is told about the role
manager.
I'll think about it more and write something up, but if you have
suggestions, let me know.
Eric
On Tue, 12 Aug 2003, Ivan R. Judson wrote:
> Eric,
> At first pass this looks like a good API. The only point that sprang to mind
> immediately was finding someplace in the object hierarchy these can live
> only once. The objects that need this immediately are:
> VenueServer, and
> Venue
> But I can easily see shared apps, data, services, etc all wanting to use
> these same API's.
> Have you thought about how these will get introduced?
> --Ivan
> > -----Original Message-----
> > From: owner-ag-dev at mcs.anl.gov
> > [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Eric Olson
> > Sent: Tuesday, August 12, 2003 11:24 AM
> > To: ag-dev at mcs.anl.gov
> > Subject: Roles API
> > Here is the current exposed Roles soap API for the Venue.
> > They can easily be added, removed, or renamed at this time, so take a
> > quick look if you have a minute. I beliebe you have to be an
> > Administrator to access all of them except the last one.
> > Venue.
> > AddSubjectToRole(subject, role_string)
> > RemoveSubjectFromRole(subject, role_string)
> > SetSubjectsInRole(subject_list, role_string):
> > AddRole(role_string)
> > GetUsersInRole(role_string)
> > (It seems both "Subject" and "User" are used, which is better?)
> > GetRoleNames()
> > returns list of strings
> > GetAvailableGroupRoles()
> > returns groups the venue knows about as list of strings.
> > examples include All Users or Server Administrators
> > Users also probably would like to know which roles they are in.
> > -- specifically so the venueclient can know if the user is a venue
> > administrator and if so, provide a button to administrate the venue.
> > I'm proposing something like the following:
> > DetermineRoles(subject="")
> > returns a list of role names that the user is in.
> > only authorized for this call if you are requesting your
> > own roles or
> > you are an administrator.
> > Comments requested,
> > Eric
