FW: BOUNCE ag-dev at mcs.anl.gov: Non-member submission from [Hiroyuki Komatsu <komatsu at mcs.anl.gov>]
Ivan R. Judson
judson at mcs.anl.gov
Thu Aug 7 14:51:56 CDT 2003
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov]
> Sent: Thursday, August 07, 2003 2:14 PM
> To: owner-ag-dev at mcs.anl.gov
> Subject: BOUNCE ag-dev at mcs.anl.gov: Non-member submission
> Received: from gyokuro.gyokuro.gn.taiyaki.org
> (float56087.mcs.anl-external.org [140.221.56.87])
> by mcs.anl.gov (8.11.6/8.9.3) with ESMTP id h77JEJB248198
> for <ag-dev at mcs.anl.gov>; Thu, 7 Aug 2003 14:14:19 -0500
> Received: from gyokuro.gn.taiyaki.org.taiyaki.org (localhost
> [127.0.0.1])
> by gyokuro.gyokuro.gn.taiyaki.org (Postfix) with ESMTP
> id D909D1F50E6; Fri, 8 Aug 2003 04:14:17 +0900 (JST)
> Date: Fri, 08 Aug 2003 04:14:17 +0900
> Message-ID: <87ptjh8ely.wl at gyokuro.gn.taiyaki.org.taiyaki.org>
> From: Hiroyuki Komatsu <komatsu at mcs.anl.gov>
> To: ag-dev at mcs.anl.gov
> Cc: <komatsu at taiyaki.org>
> Subject: Fwd: Re: Trouble with search engine
> In-Reply-To: <sf324736.028 at salud.unm.edu>
> References: <sf324736.028 at salud.unm.edu>
> User-Agent: Wanderlust/2.9.15 (Unchained Melody) SEMI/1.14.4
> (Hosorogi) FLIM/1.14.4
> (=?ISO-8859-4?Q?Kashiharajing=FE-mae?=) APEL/10.4 MULE
> XEmacs/21.4 (patch 8) (Honest Recruiter) (i386-debian-linux)
> MIME-Version: 1.0 (generated by SEMI 1.14.4 - "Hosorogi")
> Content-Type: text/plain; charset=US-ASCII
> X-Spam-Status: No, hits=-3.9 required=5.0
> tests=IN_REP_TO,X_NOT_PRESENT version=2.21
> X-Spam-Level:
> I have had the email below. Recently, the former serch
> engine at TITECH has stoped because of the power cut for the
> maintenance.
> So I would like us to link to new serch engine. Could anyone
> do it or add my account to the file 'draft:/etc/sudoers'?
> FYI: To add a serch form to the top page like
> 'http://www.accessgrid.org/~komatsu/', please add the following lines.
> <form method="get"
> action="http://www.accessgrid.org/~komatsu/search/namazu.cgi">
> <input type="text" name="query" size="20" value="">
> <input type="submit" name="submit" value="Search!">
> <input type="hidden" name="max" value="20">
> <input type="hidden" name="result" value="normal">
> <!-- "normal" or "short" -->
> <input type="hidden" name="sort" value="score">
> <!-- "score", "date:late", "date:early",
> "field:subject:ascending", "field:subject:descending",
> "field:from:ascending", "field:from:descending",
> "field:size:ascending", "field:size:descending",
> "field:uri:ascending" or "field:uri:descending" -->
> <input type="hidden" name="idxname" value="www.accessgrid.org">
> <input type="hidden" name="idxname" value="ag-tech_2003">
> <input type="hidden" name="idxname" value="ag-tech_2002">
> <input type="hidden" name="idxname" value="ag-tech_2001">
> <input type="hidden" name="idxname" value="ag-tech_2000">
> <input type="hidden" name="idxname" value="ag-tech_1999">
> </form>
> Thank you,
> Hiroyuki Komatsu
> At Thu, 07 Aug 2003 12:33:50 -0600,
> Edward Aalseth wrote:
> > The search engine link for the ag-tech mailing list at
> > http://www.accessgrid.org/documentation/mailinglists.html
> produces a
> > page not found. It's a great tool, I hope you can fix it.
> > Edward Aalseth
> > Technical Support Analyst II
> > Health Sciences Library & Informatics Center
> > University of New Mexico
> > Albuquerque, NM 87131-5686
> > 505.272.0650 (phone) 505.540.1684 (page) eaalseth at salud.unm.edu
