cert mgmt stufff
    Robert Olson
    olson at mcs.anl.gov
    Mon Aug  4 12:37:05 CDT 2003
For suzanne to work on testing the GUI side of the certificate request
stuff, I've commited the new repository stuff as
AccessGrid/CertificateRepository.py.  There is a trivial test code in
tests/CreateCertTest.py that creates a cert request given a set of
name/value pairs.
Attached is the latest version of the docs on the certificate interface.
Suzanne - was there something else I was going to give you? I don't recall
... oh how to use this stuf.
If you 'python CertificateRepository.py' it will create a new repo in a
directory "repo" in the current directory.  Then you should be able to run
the test app to create a repository.
--bob
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030804/2dda93f5/attachment.pdf>
