FW: BOUNCE ag-dev at mcs.anl.gov: Non-member submission from [Dave Semeraro <semeraro at ncsa.uiuc.edu>]
Ivan R. Judson
judson at mcs.anl.gov
Thu Apr 24 12:43:17 CDT 2003
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov]
> Sent: Thursday, April 24, 2003 11:21 AM
> To: owner-ag-dev at mcs.anl.gov
> Subject: BOUNCE ag-dev at mcs.anl.gov: Non-member submission
> Received: from mail.ncsa.uiuc.edu (mail.ncsa.uiuc.edu [141.142.2.28])
> by mcs.anl.gov (8.11.6/8.9.3) with ESMTP id h3OGLH5135308;
> Thu, 24 Apr 2003 11:21:17 -0500
> X-Envelope-From: semeraro at ncsa.uiuc.edu
> X-Envelope-To: ag-dev at mcs.anl.gov
> Received: from zim.ncsa.uiuc.edu (zim.ncsa.uiuc.edu [141.142.66.135])
> by mail.ncsa.uiuc.edu (8.11.6p2/8.11.6) with ESMTP id
> h3OGLHs29060;
> Message-Id: <5.1.0.14.2.20030424111716.02356f40 at mail.ncsa.uiuc.edu>
> X-Sender: semeraro at mail.ncsa.uiuc.edu (Unverified)
> X-Mailer: QUALCOMM Windows Eudora Version 5.1
> Date: Thu, 24 Apr 2003 11:19:30 -0500
> To: Thomas Uram <turam at mcs.anl.gov>
> From: Dave Semeraro <semeraro at ncsa.uiuc.edu>
> Subject: Re: [AG-TECH] AG2.0 and linux
> Cc: ag-dev at mcs.anl.gov
> In-Reply-To: <3EA80304.2080305 at mcs.anl.gov>
> References: <5.1.0.14.2.20030423142610.0230e198 at mail.ncsa.uiuc.edu>
> <5.1.0.14.2.20030424092744.02372790 at mail.ncsa.uiuc.edu>
> Mime-Version: 1.0
> Content-Type: text/plain; charset="us-ascii"; format=flowed
> X-Spam-Status: No, hits=-4.4 required=5.0 tests=IN_REP_TO version=2.21
> X-Spam-Level:
> Tom,
> Thanks for the clarification. You have been a big help and I
> appreciate it.
> I am going to have a
> look at starting a server on a machine here.
> Dave
> At 10:30 AM 4/24/2003 -0500, Thomas Uram wrote:
> >Dave:
> >CVS is our live code base, so it's always changing. It has changed
> >since
> >beta3 was released. Using CVS code has implicit caveats
> because it is
> >development code, which means it is unsupported and
> difficult to report
> >bugs against.
> >Having said that...
> >If you want to connect to the vv2:9000 server, you should
> use the venue
> >client included in the beta3 release.
> >If you want to run a venue server, you can execute
> VenueServer.py. By
> >default, it will run on hostname:8000. The venue server
> will create a
> >single venue at startup. To access this server from outside your
> >firewall, you would need to open ports 8000, 8002, 8004, and
> 8006. We are
> >working on user guide materials now, so you'll have a better
> reference in
> >the future.
> >The client/server mismatch is a problem simply because the
> venuestate
> >data
> >structure changed between beta3 and now. vv2:9000 is
> running beta3, and
> >you are running a post-beta3 client, so they each assume a
> different venue
> >state data structure.
> >I hope this helps.
> >Tom
> >Dave Semeraro wrote:
> >>Hello Tom,
> >>So I was under the impression that the CVS code was the
> latest release
> >>ie beta3). Is that not
> >>the code source that your server is running from? Randy Heiland
> >>downloaded a "beta3" rpm and
> >>keeps getting invalid URL errors when he tries to connect to the
> >>venueserver (vv2...).
> >>I am a little confused, is the client code in CVS pre beta3 or post
> >>beta3? Should the venue client
> >>expect the services and clients in the venue state or not? Is the
> >>VenueClient code or your
> >>server doing it right? Are there instructions somewhere on
> how to run a
> >>server?
> >>Dave
> >>At 05:34 PM 4/23/2003 -0500, you wrote:
> >>>Hi Dave:
> >>>>Hello AG-TECHers,
> >>>>Well after a couple of days of frustration I finally got the
> >>>>VenueClient to connect to the ANL
> >>>>venue. For reference my software state is the CVS update
> as of 5:35pm
> >>>>on April 22. I am
> >>>>sure things have changed by now.
> >>>>My problem was that under linux I could not get the
> RunMe.py script
> >>>>to
> >>>>connect. At first I
> >>>>was getting invalid url errors but that went away after a
> CVS update or
> >>>>two. Finally I was getting
> >>>>python errors saying that venueState had no attribute
> called clients.
> >>>>The VenueClient would then
> >>>>hang. I commented out the "for client in
> venueState.clients" loop and
> >>>>had to comment out the
> >>>>"for service in venueState.services" loop in the
> VenueClient.py file in the
> >>>>AccessGrid/AccessGrid directory. ( all this will make
> sense to those of
> >>>>you who have messed
> >>>>with the code). That allowed the VenueClient to
> function.. sort of. I
> >>>>had nothing under services or
> >>>>users in the gui. Probably because I commented that part
> out of the code.
> >>>>The venueState object
> >>>>gets initialized in a call to
> >>>>"Client.Handle(URL).get_proxy().Enter(self.profile)". For
> some reason
> >>>>the clients data and services data are not set as a
> result of this
> >>>>call. This call is found in the
> >>>>VenueClient.py file in the EnterVenue method. My head is
> starting to
> >>>>swim with all the code
> >>>>tracing. Can anyone give me a clue as to why I have no clients or
> >>>>services returned? I probably
> >>>>have a configuration file missing or something.
> >>>This problem is a version mismatch between the venue
> server and venue
> >>>client. The venue client code you have is expecting clients and
> >>>services in the venue state, but the server to which you
> are connecting
> >>>(presumably vv2:9000) is running beta3 code which does
> not include
> >>>these in the venue state. If you run a client and server
> from the same
> >>>version of the code (both from beta3, say), they would be
> using the same
> >>>definition of venue state, and this problem wouldn't
> occur. You could
> >>>do the same using cvs code, but then there are fewer guarantees.
> >>>>I was able to upload an image file to the venue but not
> download it.
> >>>>Anyone have any idea of what I may be facing on that problem?
> >>>If you can provide details on how to reproduce the
> problem, or text
> >>>from
> >>>exceptions that you saw, or .log files that captured
> details of the
> >>>problem, we can debug it. Ideally, of course, this info would be
> >>>included with a bug report in bugzilla.
> >>>Thanks,
> >>>Tom
> >>Dave Semeraro Ph.D.
> >>Visualization and Virtual Environments Group
> >>NCSA University of Illinois
> >>605 E. Springfield Ave.
> >>Champaign, IL 61820
> >>Semeraro at ncsa.uiuc.edu
> >>(217) 244-1852
> Dave Semeraro Ph.D.
> Champaign, IL 61820
> (217) 244-1852
