output
Ivan R. Judson
judson at mcs.anl.gov
Wed Apr 9 11:03:10 CDT 2003
U AccessGrid/packaging/windows/build_snapshot.py
cvs export: Updating AccessGrid/tests
U AccessGrid/tests/TestVenues.cfg
U AccessGrid/tests/test_VenueServer.py
U AccessGrid/tests/unittest_AGServiceManager.py
U AccessGrid/tests/unittest_Platform.py
U AccessGrid/tests/unittest_VenueServer.py
U AccessGrid/tests/unittest_all.py
cvs export: Updating AccessGrid/tests/testInstall
U AccessGrid/tests/testInstall/AGNodeService.cfg
U AccessGrid/tests/testInstall/AGServiceManager.cfg
U AccessGrid/tests/testInstall/videoresources
cvs export: Updating AccessGrid/tests/testInstall/nodeConfig
U AccessGrid/tests/testInstall/nodeConfig/defaultLinux
U AccessGrid/tests/testInstall/nodeConfig/defaultWindows
cvs export: Updating AccessGrid/tests/testInstall/services
C\:\\AccessGridBuild c:\\temp\\snap\\2003-0409-1049
Have cmd='python'
args='c:\temp\snap\2003-0409-1049\AccessGrid\packaging\makeSer
vicePackages.py c:\temp\snap\2003-0409-1049\AccessGrid\AccessGrid\services'
Have
cmd='c:\temp\snap\2003-0409-1049\AccessGrid\packaging\windows\Prebuild.cmd'
args='c:\temp\snap\2003-0409-1049\AccessGrid'
Have
cmd='c:\temp\snap\2003-0409-1049\AccessGrid\packaging\windows\BuildVic.cmd'
args='c:\AccessGridBuild\ag-vic
c:\temp\snap\2003-0409-1049\AccessGrid\Release\
bin'
Have
cmd='c:\temp\snap\2003-0409-1049\AccessGrid\packaging\windows\BuildRat.cmd'
args='c:\AccessGridBuild\ag-rat
bin'
Writing Package File: AudioService.zip
Writing Package File: VideoConsumerService.zip
Writing Package File: VideoProducerService.zip
c:\temp\snap\2003-0409-1049\AccessGrid\packaging\windows>set
VSINSTALLDIR=VERSIO
N 3.0
VSINSTALLDIR=C:\Pro
gram Files\Microsoft Visual Studio .NET\Common7\IDE\
VCINSTALLDIR=VERSIO
N 3.0
VCINSTALLDIR=C:\Pro
Setting environment for using Microsoft Visual Studio .NET tools.
(If you also have Visual C++ 6.0 installed and wish to use its tools
from the command line, run vcvars32.bat for Visual C++ 6.0.)
The system cannot find the file specified.
Building AG
running build
running build_py
creating build
creating build\lib
creating build\lib\AccessGrid
copying AccessGrid\AGNodeService.py -> build\lib\AccessGrid
copying AccessGrid\AGParameter.py -> build\lib\AccessGrid
copying AccessGrid\AGService.py -> build\lib\AccessGrid
copying AccessGrid\AGServiceManager.py -> build\lib\AccessGrid
copying AccessGrid\AppService.py -> build\lib\AccessGrid
copying AccessGrid\AuthorizationManager.py -> build\lib\AccessGrid
copying AccessGrid\CertificateManager.py -> build\lib\AccessGrid
copying AccessGrid\ClientProfile.py -> build\lib\AccessGrid
copying AccessGrid\DataStore.py -> build\lib\AccessGrid
copying AccessGrid\Descriptions.py -> build\lib\AccessGrid
copying AccessGrid\EventClient.py -> build\lib\AccessGrid
copying AccessGrid\Events.py -> build\lib\AccessGrid
copying AccessGrid\EventService.py -> build\lib\AccessGrid
copying AccessGrid\GUID.py -> build\lib\AccessGrid
copying AccessGrid\icons.py -> build\lib\AccessGrid
copying AccessGrid\MulticastAddressAllocator.py -> build\lib\AccessGrid
copying AccessGrid\NetworkLocation.py -> build\lib\AccessGrid
copying AccessGrid\NodeManagementUIClasses.py -> build\lib\AccessGrid
copying AccessGrid\PersonalNode.py -> build\lib\AccessGrid
copying AccessGrid\Platform.py -> build\lib\AccessGrid
copying AccessGrid\ProcessManagerUnix.py -> build\lib\AccessGrid
copying AccessGrid\ProcessManagerWin32.py -> build\lib\AccessGrid
copying AccessGrid\scheduler.py -> build\lib\AccessGrid
copying AccessGrid\SharedApplication.py -> build\lib\AccessGrid
copying AccessGrid\TextClient.py -> build\lib\AccessGrid
copying AccessGrid\TextService.py -> build\lib\AccessGrid
copying AccessGrid\Types.py -> build\lib\AccessGrid
copying AccessGrid\UIUtilities.py -> build\lib\AccessGrid
copying AccessGrid\Utilities.py -> build\lib\AccessGrid
copying AccessGrid\Venue.py -> build\lib\AccessGrid
copying AccessGrid\VenueClient.py -> build\lib\AccessGrid
copying AccessGrid\VenueClientUIClasses.py -> build\lib\AccessGrid
copying AccessGrid\VenueServer.py -> build\lib\AccessGrid
copying AccessGrid\VenueServerRegistry.py -> build\lib\AccessGrid
copying AccessGrid\__init__.py -> build\lib\AccessGrid
creating build\lib\AccessGrid\hosting
copying AccessGrid/hosting\AccessControl.py -> build\lib\AccessGrid/hosting
copying AccessGrid/hosting\__init__.py -> build\lib\AccessGrid/hosting
creating build\lib\AccessGrid\hosting\pyGlobus
copying AccessGrid/hosting/pyGlobus\AGGSISOAP.py ->
/pyGlobus
copying AccessGrid/hosting/pyGlobus\Client.py ->
build\lib\AccessGrid/hosting/py
Globus
copying AccessGrid/hosting/pyGlobus\runtime.py ->
yGlobus
copying AccessGrid/hosting/pyGlobus\Server.py ->
Globus
copying AccessGrid/hosting/pyGlobus\ServiceBase.py ->
ng/pyGlobus
copying AccessGrid/hosting/pyGlobus\ServiceObject.py ->
ting/pyGlobus
copying AccessGrid/hosting/pyGlobus\Utilities.py ->
/pyGlobus
copying AccessGrid/hosting/pyGlobus\__init__.py ->
pyGlobus
running build_scripts
creating build\scripts-2.2
copying and adjusting bin\VenueServer.py -> build\scripts-2.2
copying and adjusting bin\VenueClient.py -> build\scripts-2.2
copying and adjusting bin\VenueManagement.py -> build\scripts-2.2
copying and adjusting bin\SetupVideo.py -> build\scripts-2.2
copying and adjusting bin\AGNodeService.py -> build\scripts-2.2
copying and adjusting bin\AGServiceManager.py -> build\scripts-2.2
copying and adjusting bin\NodeManagement.py -> build\scripts-2.2
copying and adjusting bin\VenuesServerRegistry.py -> build\scripts-2.2
copying and adjusting bin\RunMe.py -> build\scripts-2.2
running install
running build
running build_py
not copying AccessGrid\AGNodeService.py (output up-to-date)
not copying AccessGrid\AGParameter.py (output up-to-date)
not copying AccessGrid\AGService.py (output up-to-date)
not copying AccessGrid\AGServiceManager.py (output up-to-date)
not copying AccessGrid\AppService.py (output up-to-date)
not copying AccessGrid\AuthorizationManager.py (output up-to-date)
not copying AccessGrid\CertificateManager.py (output up-to-date)
not copying AccessGrid\ClientProfile.py (output up-to-date)
not copying AccessGrid\DataStore.py (output up-to-date)
not copying AccessGrid\Descriptions.py (output up-to-date)
not copying AccessGrid\EventClient.py (output up-to-date)
not copying AccessGrid\Events.py (output up-to-date)
not copying AccessGrid\EventService.py (output up-to-date)
not copying AccessGrid\GUID.py (output up-to-date)
not copying AccessGrid\icons.py (output up-to-date)
not copying AccessGrid\MulticastAddressAllocator.py (output up-to-date)
not copying AccessGrid\NetworkLocation.py (output up-to-date)
not copying AccessGrid\NodeManagementUIClasses.py (output up-to-date)
not copying AccessGrid\PersonalNode.py (output up-to-date)
not copying AccessGrid\Platform.py (output up-to-date)
not copying AccessGrid\ProcessManagerUnix.py (output up-to-date)
not copying AccessGrid\ProcessManagerWin32.py (output up-to-date)
not copying AccessGrid\scheduler.py (output up-to-date)
not copying AccessGrid\SharedApplication.py (output up-to-date)
not copying AccessGrid\TextClient.py (output up-to-date)
not copying AccessGrid\TextService.py (output up-to-date)
not copying AccessGrid\Types.py (output up-to-date)
not copying AccessGrid\UIUtilities.py (output up-to-date)
not copying AccessGrid\Utilities.py (output up-to-date)
not copying AccessGrid\Venue.py (output up-to-date)
not copying AccessGrid\VenueClient.py (output up-to-date)
not copying AccessGrid\VenueClientUIClasses.py (output up-to-date)
not copying AccessGrid\VenueServer.py (output up-to-date)
not copying AccessGrid\VenueServerRegistry.py (output up-to-date)
not copying AccessGrid\__init__.py (output up-to-date)
not copying AccessGrid/hosting\AccessControl.py (output up-to-date)
not copying AccessGrid/hosting\__init__.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\AGGSISOAP.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\Client.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\runtime.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\Server.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\ServiceBase.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\ServiceObject.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\Utilities.py (output up-to-date)
not copying AccessGrid/hosting/pyGlobus\__init__.py (output up-to-date)
not copying bin\VenueServer.py (up-to-date)
not copying bin\VenueClient.py (up-to-date)
not copying bin\VenueManagement.py (up-to-date)
not copying bin\SetupVideo.py (up-to-date)
not copying bin\AGNodeService.py (up-to-date)
not copying bin\AGServiceManager.py (up-to-date)
not copying bin\NodeManagement.py (up-to-date)
not copying bin\VenuesServerRegistry.py (up-to-date)
not copying bin\RunMe.py (up-to-date)
running install_lib
creating c:\temp\snap\2003-0409-1049\AccessGrid\Release
creating c:\temp\snap\2003-0409-1049\AccessGrid\Release\Lib
creating c:\temp\snap\2003-0409-1049\AccessGrid\Release\Lib\site-packages
creating
c:\temp\snap\2003-0409-1049\AccessGrid\Release\Lib\site-packages\Access
Grid
copying build\lib\AccessGrid\AGNodeService.py ->
essGrid\Release\Lib\site-packages\AccessGrid
copying build\lib\AccessGrid\AGParameter.py ->
copying build\lib\AccessGrid\AGService.py ->
copying build\lib\AccessGrid\AGServiceManager.py ->
AccessGrid\Release\Lib\site-packages\AccessGrid
copying build\lib\AccessGrid\AppService.py ->
copying build\lib\AccessGrid\AuthorizationManager.py ->
049\AccessGrid\Release\Lib\site-packages\AccessGrid
copying build\lib\AccessGrid\CertificateManager.py ->
copying build\lib\AccessGrid\ClientProfile.py ->
copying build\lib\AccessGrid\DataStore.py ->
copying build\lib\AccessGrid\Descriptions.py ->
copying build\lib\AccessGrid\EventClient.py ->
copying build\lib\AccessGrid\Events.py ->
copying build\lib\AccessGrid\EventService.py ->
copying build\lib\AccessGrid\GUID.py ->
creating
Grid\hosting
copying build\lib\AccessGrid\hosting\AccessControl.py ->
1049\AccessGrid\Release\Lib\site-packages\AccessGrid\hosting
creating
copying build\lib\AccessGrid\hosting\pyGlobus\AGGSISOAP.py ->
c:\temp\snap\2003-
0409-1049\AccessGrid\Release\Lib\site-packages\AccessGrid\hosting\pyGlobus
copying build\lib\AccessGrid\hosting\pyGlobus\Client.py ->
copying build\lib\AccessGrid\hosting\pyGlobus\runtime.py ->
copying build\lib\AccessGrid\hosting\pyGlobus\Server.py ->
copying build\lib\AccessGrid\hosting\pyGlobus\ServiceBase.py ->
c:\temp\snap\200
3-0409-1049\AccessGrid\Release\Lib\site-packages\AccessGrid\hosting\pyGlobus
copying build\lib\AccessGrid\hosting\pyGlobus\ServiceObject.py ->
c:\temp\snap\2
003-0409-1049\AccessGrid\Release\Lib\site-packages\AccessGrid\hosting\pyGlob
us
copying build\lib\AccessGrid\hosting\pyGlobus\Utilities.py ->
c:\temp\snap\2003-
copying build\lib\AccessGrid\hosting\pyGlobus\__init__.py ->
c:\temp\snap\2003-0
copying build\lib\AccessGrid\hosting\__init__.py ->
copying build\lib\AccessGrid\icons.py ->
copying build\lib\AccessGrid\MulticastAddressAllocator.py ->
c:\temp\snap\2003-0
copying build\lib\AccessGrid\NetworkLocation.py ->
copying build\lib\AccessGrid\NodeManagementUIClasses.py ->
copying build\lib\AccessGrid\PersonalNode.py ->
copying build\lib\AccessGrid\Platform.py ->
copying build\lib\AccessGrid\ProcessManagerUnix.py ->
copying build\lib\AccessGrid\ProcessManagerWin32.py ->
copying build\lib\AccessGrid\scheduler.py ->
copying build\lib\AccessGrid\SharedApplication.py ->
copying build\lib\AccessGrid\TextClient.py ->
copying build\lib\AccessGrid\TextService.py ->
copying build\lib\AccessGrid\Types.py ->
copying build\lib\AccessGrid\UIUtilities.py ->
copying build\lib\AccessGrid\Utilities.py ->
copying build\lib\AccessGrid\Venue.py ->
copying build\lib\AccessGrid\VenueClient.py ->
copying build\lib\AccessGrid\VenueClientUIClasses.py ->
copying build\lib\AccessGrid\VenueServer.py ->
copying build\lib\AccessGrid\VenueServerRegistry.py ->
copying build\lib\AccessGrid\__init__.py ->
running install_scripts
creating c:\temp\snap\2003-0409-1049\AccessGrid\Release\Scripts
error: build\scripts-2.2\bin\VenueServer.py: No such file or directory
Command failed:
d.cmd c:\temp\snap\2003-0409-1049\AccessGrid
C:\Software\AccessGrid-test>cd ..
C:\Software>rd /s AccessGrid-test
AccessGrid-test, Are you sure (Y/N)? y
C:\Software>cd AccessGrid
C:\Software\AccessGrid>packaging\windows\build_snapshot.py
compiler is c:\PROGRA~1\MYINNO~1\ISCC.exe
builddir c:\temp\snap\2003-0409-1049
Traceback (most recent call last):
File "C:\Software\AccessGrid\packaging\windows\build_snapshot.py", line
54, in
os.mkdir(build_dir)
OSError: [Errno 17] File exists: 'c:\\temp\\snap\\2003-0409-1049'
