Configuration Document
Robert Olson
olson at mcs.anl.gov
Tue Apr 1 16:59:59 CST 2003
I see; is there a reason we can't use the user temp dir for everything? (it
makes sense for the things that I've poked at that use a temp dir).
Wondering if there are things that make more sense to be in the system temp
dir. (I like the default of using user temp for everything for a user
client; I guess a service might need something different)
--bob
At 04:55 PM 4/1/2003 -0600, Ivan R. Judson wrote:
>I use the user temp dir to save copys of docs that we want the client to
>open automatically; we might not want those in a global location to be left
>for anyone to peruse.
>--Ivan
> > -----Original Message-----
> > From: Robert Olson [mailto:olson at mcs.anl.gov]
> > Sent: Tuesday, April 01, 2003 4:48 PM
> > To: judson at mcs.anl.gov; 'Eric Olson'
> > Cc: 'AG Dev'
> > Subject: RE: Configuration Document
> > What is the practical difference between them?
> > At 04:38 PM 4/1/2003 -0600, Ivan R. Judson wrote:
> > >Is it possible to add two calls:
> > >GetSystemTempDir() and GetUserTempDir()?
> > >These are used by various pieces that need to deal with
> > temporary data.
> > >On linux they should probably both return /tmp, but on windows there
> > >are two
> > >temps:
> > >Windows\tmp and Documents and settings\user\temp
> > >Thanks,
> > >--Ivan
> > > > From: Eric Olson [mailto:eolson at mcs.anl.gov]
> > > > Sent: Tuesday, April 01, 2003 3:04 PM
> > > > To: Ivan R. Judson
> > > > Cc: 'AG Dev'
> > > > Subject: Re: Configuration Document
> > > > Added a small table of paths on each platform, and the
> > environment
> > > > variable that can be used to override them.
> > > > Eric
> > > > On Fri, 28 Mar 2003, Ivan R. Judson wrote:
> > > > > Here's the doc, no interface.
> > > > > -Ivan
