Configuration Document
Ivan R. Judson
judson at mcs.anl.gov
Tue Apr 1 16:55:55 CST 2003
I use the user temp dir to save copys of docs that we want the client to
open automatically; we might not want those in a global location to be left
for anyone to peruse.
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Tuesday, April 01, 2003 4:48 PM
> To: judson at mcs.anl.gov; 'Eric Olson'
> Cc: 'AG Dev'
> Subject: RE: Configuration Document
> What is the practical difference between them?
> At 04:38 PM 4/1/2003 -0600, Ivan R. Judson wrote:
> >Is it possible to add two calls:
> >GetSystemTempDir() and GetUserTempDir()?
> >These are used by various pieces that need to deal with
> temporary data.
> >On linux they should probably both return /tmp, but on windows there
> >are two
> >temps:
> >Windows\tmp and Documents and settings\user\temp
> >Thanks,
> >--Ivan
> > > From: Eric Olson [mailto:eolson at mcs.anl.gov]
> > > Sent: Tuesday, April 01, 2003 3:04 PM
> > > To: Ivan R. Judson
> > > Cc: 'AG Dev'
> > > Subject: Re: Configuration Document
> > > Added a small table of paths on each platform, and the
> environment
> > > variable that can be used to override them.
> > > Eric
> > > On Fri, 28 Mar 2003, Ivan R. Judson wrote:
> > > > Here's the doc, no interface.
> > > > -Ivan
