Drop me links to the AG 2.0 specs after the presentation please
Ivan R. Judson
judson at mcs.anl.gov
Wed Oct 9 10:30:58 CDT 2002
Hey Jay,
Thanks for the WSDL pointer.
My impression was that SASL was an abstraction layer for security APIs.
Globus has been bound into an open source SASL library. My though was
that if we bound to SASL instead of directly to Globus, the actual
security implementation could be more easily exchanged for a different
one. If passport were SASL bound, it'd be trivial to switch from globus
to passport, for example.
In terms of data store, I don't think it matters completely. I could
envision a flat file system with XML files, an SQL database, or an
in-memory structure to store all the information. Part of the challenge
is composing basic web services into more advanced services (like
Venues). Understanding the right back-end data solution that allows data
persistence and web service composition is new to me (and as far as I
can tell, everyone ;-). I'm not opposed to SQL, just want to make sure
it's the best choice.
--Ivan
-----Original Message-----
From: Jay Beavers [mailto:jbeavers at microsoft.com]
Sent: Friday, October 04, 2002 12:17 PM
To: judson at mcs.anl.gov
Cc: Todd Needham; Michael E. Papka; Ag-Dev at Mcs. Anl. Gov
Subject: RE: Drop me links to the AG 2.0 specs after the presentation
please
Our latest WSDL can be found at:
http://services.learningwebservices.com/venueservice/venueservice.asmx?W
SDL
A real brief read of SASL shows it as another authentication protocol,
not addressing authorization.
Well, you are SQL backended today and a goal I would like to reach would
be that CXP Venue Service, AG Venue Server, and NCSA Scheduler can all
run on the same box sharing the same backend data. What form of
datastore do you feel is appropriate for an AG 2.0 service if not SQL?
From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
Sent: Wednesday, October 02, 2002 7:21 PM
To: Jay Beavers
Cc: Todd Needham; 'Michael E. Papka'; 'Ag-Dev at Mcs. Anl. Gov'
please
Hey Jay,
Thanks for the feedback already. I need to read over the WS-Security
spec, I know it's been in flux lately, but I need to get more familiar
with it. Maybe while I'm home after the baby comes tomorrow (shyeah).
We do have this general problem of thinking of ACE/ACL's and enforcement
infrastructure, which i think is rich for work. We do have to leverage
Globus for our security, but I know Globus has done some work on SASL
integration. Has Passport done anything to be a SASL option? If so, we
could consider targeting SASL abstracting the actual security
implementation out of the infrastructure (which might benefit everyone).
I'll read up on SASL to see if this makes more or less sense.
We haven't specified SQL schemas yet since that assumes a SQL database
as a web service backend. I'd be happy if we get interfaces concretely
defined in WSDL, leveraging data types defined by XML Schemas. Those
map directly to SQL data structures with .Net but also leave us the
option of other implementations.
Can you remind me of where the WSDL descriptions of the components you
developed are?
--Ivan
Sent: Tuesday, October 01, 2002 1:40 PM
please
Some thoughts for you:
Authentication / Authorization
Have you looked at the WS-Security specification? It provides for
attaching X.509 certificates to SOAP messages and signing the messages.
In reviewing the Globus Toolkit 2.0's security model, it seemed that
WS-Security would be a great way of using Globus certificates with web
service calls. The "Web Services Development Kit" has a preview
implementation of WS-Security for .NET You can download the WSDK
<http://msdn.microsoft.com/downloads/default.asp?URL=/downloads/sample.a
sp?url=/MSDN-FILES/027/001/997/msdncompositedoc.xml> Preview. See Using
<http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnwsse
cur/html/wssecwithwsdk.asphttp://msdn.microsoft.com/library/default.asp?
url=/library/en-us/dnwssecur/html/wssecwithwsdk.asp> WS_Security with
the WSDK for an example with source code of how to use the WSDK to sign
and authenticate a web service call using X.509 v3 certificates.
Unfortunately, the WSDK still doesn't have ACL/ACE functionality for
authorizing users' access to objects. I'm prototyping a couple of
classes that basically mirror the ACL/ACE/group design from VMS/NT for
an unrelated project if you're interested in collaborating in this area.
The idea is to have a generic "authorization" object that you can
"attach" to an object, set the ACL, serialize the ACL for easy storage,
and perform authorization checks.
SQL Schemas
I didn't see any details on web service interfaces of SQL schema in the
discussions. I'd like to talk at this level so that we can get
interoperability going. I've done a first pass at SQL schema
synchronization with Shawn Davis and I think I should be AG Venue Server
functionality compatible with my next venue server release. I'd love to
be in a position where we (MSR) release a subset of functionality and
both ANL and NCSA are able to add on functionality to the same server by
adding additional functionality on top of the same data store.
Web Service Interfaces
I'd like to synchronize on web service interfaces too. I've provided
you guys with our WSDL and source for the web service calls used by CXP.
I'd like to get feedback and to synchronize these as well, probably
following the same pattern as above where we provide a subset of
functionality but that subset is 100% compatible.
I look forward to talking more after the retreat.
- jcb
Sent: Monday, September 30, 2002 7:57 PM
To: Jay Beavers
please
Hey Dude,
Don't worry about it; sometimes that happens.
http://www.mcs.anl.gov/fl/events/agtech/
These aren't as detailed as I'd like, but they are a start. We'll see if
things work tomorrow :-)
--Ivan
Sent: Monday, September 30, 2002 10:16 AM
To: Judson at MCS.anl.gov
Cc: Todd Needham
Subject: Drop me links to the AG 2.0 specs after the presentation please
Sorry I couldn't join you this morn Ivan. Seems technical difficulties
were to be the order of the day.
I was unable to use OpenMash instead of ddvic to enable sending of my
video. If I switched from ddvic to OpenMash, all video windows came in
as blank grey.
I was unable to send audio from rat. It would see the signal locally,
but my send indicators stayed grey instead of green.
I was unable to connect to the DPPT server. Don't ask me why, I don't
know.
So if you could, please drop me the PPT links later. I'll take a look
at them and send feedback via email.
- jcb
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20021009/a6430eec/attachment.htm>
