FW: [MMUSIC] I-D ACTION:draft-levin-mmusic-xml-media-control-00.txt
Ivan R. Judson
judson at mcs.anl.gov
Mon Oct 7 08:17:14 CDT 2002
Ivan R. Judson .~. http://www.mcs.anl.gov/~judson
Futures Laboratory .~. 630 252 0920
Argonne National Laboratory .~. 630 252 6424 Fax
> -----Original Message-----
> From: mmusic-admin at ietf.org [mailto:mmusic-admin at ietf.org] On
> Behalf Of Internet-Drafts at ietf.org
> Sent: Monday, October 07, 2002 6:18 AM
> To: IETF-Announce:
> Cc: mmusic at ietf.org
> Subject: [MMUSIC] I-D
> A New Internet-Draft is available from the on-line
> Internet-Drafts directories.
> Title : XML Schema for Media Control
> Author(s) : O. Levin, S. Olson, R. Even
> Filename : draft-levin-mmusic-xml-media-control-00.txt
> Pages : 8
> Date : 2002-10-4
> This document defines an XML Schema for Media Control in a tightly
> controlled environment. The current version includes commands for
> managing of video streams only. Implementation of this schema for
> interactive video applications in SIP environments significantly
> improves user experience.
> A URL for this Internet-Draft is:
> http://www.ietf.org/internet-drafts/draft-levin-mmusic-xml-med
ia-control-00.txt
To remove yourself from the IETF Announcement list, send a message to
ietf-announce-request with the word unsubscribe in the body of the
message.
Internet-Drafts are also available by anonymous FTP. Login with the
username "anonymous" and a password of your e-mail address. After
logging in, type "cd internet-drafts" and then
"get draft-levin-mmusic-xml-media-control-00.txt".
A list of Internet-Drafts directories can be found in
http://www.ietf.org/shadow.html
or ftp://ftp.ietf.org/ietf/1shadow-sites.txt
Internet-Drafts can also be obtained by e-mail.
Send a message to:
mailserv at ietf.org.
In the body type:
"FILE
/internet-drafts/draft-levin-mmusic-xml-media-control-00.txt".
NOTE: The mail server at ietf.org can return the document in
MIME-encoded form by using the "mpack" utility. To use this
feature, insert the command "ENCODING mime" before the "FILE"
command. To decode the response(s), you will need "munpack" or
a MIME-compliant mail reader. Different MIME-compliant mail
readers
exhibit different behavior, especially when dealing with
"multipart" MIME messages (i.e. documents which have been split
up into multiple messages), so check your local documentation on
how to manipulate these messages.
Below is the data which will enable a MIME compliant mail reader
implementation to automatically retrieve the ASCII version of the
Internet-Draft.
ENCODING mime
FILE /internet-drafts/draft-levin-mmusic-xml-media-control-00.txt
