FW: DPPT is now in cvs?
Bob Olson
olson at mcs.anl.gov
Fri Nov 8 06:51:17 CST 2002
I'll answer questions about it; at this point putting together a guide
like that isn't a priority (that dppt would not be a good starting point
for new code, esp for linux, for a number of reasons) until after the SC
panic is done, imho.
--bob
On Fri, 8 Nov 2002, Ivan R. Judson wrote:
> Bob,
> Can you write up some notes so external developers can work on the dppt
> stuff? In particular note Chris' comment below. He's working on getting
> a dppt like solution working on their all linux installations.
> Thanks,
> --Ivan
> Ivan R. Judson .~. http://www.mcs.anl.gov/~judson
> Futures Laboratory .~. 630 252 0920
> Argonne National Laboratory .~. 630 252 6424 Fax
> > -----Original Message-----
> > From: Christoph Willing [mailto:chris at vislab.usyd.edu.au]
> > Sent: Wednesday, November 06, 2002 3:32 PM
> > To: Ivan R. Judson
> > Subject: RE: DPPT is now in cvs?
> > Thanks Ivan,
> > I've downloaded it and had a browse around the code. The
> > biggest issue preventing a really quick solution looks like
> > it might be the contents of a directory named "activex". It
> > seems to be generated from some tool out of the Windows java
> > sdk - I'm not sure if that matters once the java has been
> > generated. I'll let you know as soon as (if?) I have any
> > success with it.
> > chris
> > On Wed, 2002-11-06 at 23:38, Ivan R. Judson wrote:
> > > Didja find it? Module dppt in the cvs repository.
> > > --Ivan
> > > > Sent: Wednesday, October 30, 2002 9:22 PM
> > > > To: Ivan R. Judson
> > > > Subject: DPPT not in cvs?
> > > > Hi Ivan,
> > > > The system support people fixed the anonymous cvs problem I
> > > > was having the other day. Since checking out the AG module
> > > > (in fact all the modules you announced by email a while back)
> > > > I haven't been able to find any distributed ppt source code.
> > > > Is the java source code for dppt available? I'd like to do a
> > > > version that runs on linux & uses Crossover Office or WINE to
> > > > run the powerpoint application.
> > > > Thanks,
> > > > chris
> > > > Chris Willing Telephone (61-2) 9351 3005
> > > > VisLab, A28 Facsimile (61-2) 9351 1880
> > > > University of Sydney
> > > > NSW 2006 Australia http://www.vislab.usyd.edu.au
