Oops (half my bad) (fwd)
Rick Stevens
stevens at mcs.anl.gov
Fri Aug 23 19:49:27 CDT 2002
very interesting indeed.
At 07:38 PM 8/23/2002 -0500, Bob Olson wrote:
>hm, interesting.
>---------- Forwarded message ----------
>Date: Sat, 24 Aug 2002 08:36:13 +0800
>From: Ooi Wei Tsang <ooiwt at comp.nus.edu.sg>
>To: 'Wesley Miaw' <wesley at bmrc.berkeley.edu>
>Cc: openmash-developers at openmash.org
>Subject: RE: Oops (half my bad)
>The other half is mine :)
>For those who do not know what Degas is, it is my thesis project that
>deals with mixing RTP streams using gateways. The code has a huge
>memory leak when used with mash-5.2.1 (it was coded for mash-5.0b1). To
>compile with degas, you need to specify with --enable-degas.
>Wesley, did you --enable-degas when configure? Otherwise it shouldn't
>look for any degas files.
> > -----Original Message-----
> > From: owner-openmash-developers at bmrc.berkeley.edu
> > [mailto:owner-openmash-developers at bmrc.berkeley.edu] On
> > Behalf Of Wesley Miaw
> > Sent: Saturday, August 24, 2002 4:11 AM
> > To: openmash-developers at openmash.org
> > Subject: Oops (half my bad)
> > Ack, I was looking in the wrong degas directory. I do have the degas
> > files in my local repository. It's just not finding them when
> > I compile
> > because the include paths are wrong. I guess the Makefile.in needs
> > correcting. I'll get around to that and check it back in to fix it.
> > Unless someone beats me to it.
> > Later,
> > Wes
