Oops (half my bad) (fwd)
Bob Olson
olson at mcs.anl.gov
Fri Aug 23 19:38:17 CDT 2002
hm, interesting.
---------- Forwarded message ----------
Date: Sat, 24 Aug 2002 08:36:13 +0800
To: 'Wesley Miaw' <wesley at bmrc.berkeley.edu>
Cc: openmash-developers at openmash.org
Subject: RE: Oops (half my bad)
The other half is mine :)
For those who do not know what Degas is, it is my thesis project that
deals with mixing RTP streams using gateways. The code has a huge
memory leak when used with mash-5.2.1 (it was coded for mash-5.0b1). To
compile with degas, you need to specify with --enable-degas.
Wesley, did you --enable-degas when configure? Otherwise it shouldn't
look for any degas files.
> -----Original Message-----
> From: owner-openmash-developers at bmrc.berkeley.edu
> [mailto:owner-openmash-developers at bmrc.berkeley.edu] On
> Behalf Of Wesley Miaw
> Sent: Saturday, August 24, 2002 4:11 AM
> To: openmash-developers at openmash.org
> Subject: Oops (half my bad)
> Ack, I was looking in the wrong degas directory. I do have the degas
> files in my local repository. It's just not finding them when
> I compile
> because the include paths are wrong. I guess the Makefile.in needs
> correcting. I'll get around to that and check it back in to fix it.
> Unless someone beats me to it.
> Later,
> Wes
