FW: Multi-device vic
Ivan R. Judson
judson at mcs.anl.gov
Thu Aug 22 14:07:49 CDT 2002
With a 5th capture card this lookslike a very nice thing.
--Ivan
-----Original Message-----
From: Nolan, Kevin [NCSUS] [mailto:knolan at ncsus.jnj.com]
Sent: Thursday, August 22, 2002 2:01 PM
To: 'judson at mcs.anl.gov'
Subject: RE: Multi-device vic
4200.00 - there are more models but they cost more.
From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
Sent: Thursday, August 22, 2002 2:18 PM
To: 'Nolan, Kevin [NCSUS]'
Where did you get the extron box? How much did it cost?
--ivan
Sent: Thursday, August 22, 2002 9:31 AM
On another note - here is the hardware we use to configure our PIG's.
It allows us to include many video sources into the session outside of
two camera's.
1.Workstation:
Compaq Evo W8000 Workstation with a single 2.2 GHz Intel Xeon Processor
1 GB RAM 17GB SCSI hard drive 1 Standard 3.5" Floppy Drive 1 IDE DVD Rom
Drive 1 IDE 40x CD-RW Drive 1 nVidia Quadro4 750 XGL display adaptor 1
100 Mb Intel Ethernet adapter 2 Osprey-100 Video Capture cards
2. Additional Hardware:
1 17" Flat Screen Monitor
1 Sony EVI-D30 or EVI-D100 video camera
1 Polycom Soundstation Premier
1 Polycom Digital Video Interconnect
1 Keyboard/Mouse
1 Extron USP 405 Scan Converter
2 Power strip surge protectors
3. Additional Wiring:
2 12' S-Video cable (for Sony video camera and scan converter)
2 3.5 mini-male to 3.5 mini-male cables
1 VGA cable (for scan converter)
Sent: Thursday, August 22, 2002 9:26 AM
Cc: 'White, Derek [NCSUS Non J&J]'; 'Milinowicz, Anthony [NCSUS]'
The video tool is vic. Audio should be using rat or vat, I'm not sure
which one you guys are using (probably rat). There is a known problem
with rat "falling behind" on windows. A patch was submitted to the rat
folks and the cvs copy has it applied. It minimized the problem but
it's not entirely fixed yet.
Does that sound like what you're seeing?
--Ivan
Sent: Thursday, August 22, 2002 7:41 AM
Cc: White, Derek [NCSUS Non J&J]; Milinowicz, Anthony [NCSUS]
Audio Sync -
I thought I would send this to you but will also send it to the
newsgroup. We are seeing audio drop out of synch when we use it locally
between six machines. These are on our versions of PIG but use VIC
v2.8nlsde-2.1.3-114. Do you think this has to do with the timing
server, the version of vic?
Kevin
Sent: Tuesday, August 20, 2002 4:48 PM
The deal is this:
TTL is the # of Router hops that the data is valid for. The routers
enforce (ie, decrement the number and when it gets to 0 drop the
packets). But the application sets the number in the first place. The
app is the only one who knows what the user wants, so that's where the
ttl has to get set. Everyone else just plays the ttl game.
--Ivan
Sent: Tuesday, August 20, 2002 3:00 PM
Ivan,
My guys have been asking me to explain in detial the TTL settings for
both VIC and RAT. Why would the application require this, if the
network routers can handle it? How does this interact with the
application? Why would you need to increase the ttl? It seems that if
we leave it at default we have a hard time with remote sites in Belgium
for Audio and Video....
Kevin
Sent: Friday, August 16, 2002 11:48 AM
To: knolan at ncsus.jnj.com
Subject: Multi-device vic
Hey Kevin,
You mentioned having a vic that could send from multiple devices. Can
you give me a pointer to this? It'd be interesting to roll that into OM
vic, since we're moving forward with that version. Then everyone could
have a big win of only having to run one vic per machine :-)
--Ivan
Ivan R. Judson .~. http://www.mcs.anl.gov/~judson
Futures Laboratory .~. 630 252 0920
Argonne National Laboratory .~. 630 252 6424 Fax
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20020822/02f67c38/attachment.htm>
