Fwd: Small patch for agib-1-glue
Robert Olson
olson at mcs.anl.gov
Fri Aug 16 07:44:22 CDT 2002
I thought I forwarded these, but in case I didn't.
>X-Sender: randy at redwood.rt.cs.boeing.com
>X-Mailer: QUALCOMM Windows Eudora Version 5.1.1
>Date: Wed, 24 Jul 2002 16:35:09 -0700
>To: Robert Olson <olson at mcs.anl.gov>
>From: Randy Groves <randy.groves at boeing.com>
>Subject: Small patch for agib-1-glue
>X-Spam-Status: No, hits=0.0 required=5.0 tests= version=2.21
>X-Spam-Level:
>I've been trying to get the PIG working on XP, and after finally figuring
>out the video-config file, I could get the vrm-eventlistener to come up
>with the appropriate devices, but the vic process kept dying. I finally
>realized that the vrm-eventlistener was trying to start up 'vic.exe'
>rather than 'mash.exe' for the local captures. It all hinged on the
>version of the OS, which in the case of XP is '5.1' rather than
>'5.0'. This patch to ConfigUtilsImplWin32.java fixes it, although since
>I'm pretty much of a Java newbie, it might not be the best:
>diff ConfigUtilsImplWin32.java*
>60c60
>< if (version_.startsWith("5."))
> > if (version_.equals("5.0"))
>Actually, the same problem exists with the config for DRM, so I presume
>the following makes more sense:
>60c60
>77c77
>-randy
