FW: [AG-TECH] PIG Video Work Around
Michael E. Papka
papka at mcs.anl.gov
Thu Aug 15 20:54:52 CDT 2002
Justin,
Did we get these patches in the current release?
Mike
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Randy Groves
Sent: Thursday, August 15, 2002 6:42 PM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] PIG Video Work Around
There's a bug in the PIG on XP - (patch for which I sent to Bob) - the
VRM
starts up the old vic and not the mash vic. That's why you have to do
the
workaround. The bug affects the DRM as well - it starts up the non-dd
vic
for display.
-randy
At 05:40 PM 8/15/2002 -0500, Eric Hepburn wrote:
>Yeah, I've been able to get PIG working with my firewire camera...
>Thanks to some help from Robert Olson... Unfortunately, I can't get it
>working with the automated venue (java
>scripted) process...
>However, I can get a session going manually... this workaround should
>be
>effective for many of the alternative configurations out there...
>Here's how it goes:
>1. Point your Virtual Venue browser to a conference room (Test Room for
>example)
>2. If you have PIG running it will pull up a VIC window that will allow
>you to view the video streams from the other participants and a RAT
window
>for the audio.
>3. Your RAT audio connection should work, however, if you don't have an
>osprey capture card you cannot send video only view the existing video
streams.
>4. Close down the VIC window that PIG started automatically and open a
>command prompt.
>5. Change directories to c:\ag\agapps\bin or add c:\ag\agapps\bin to
your
>path.
>6. Type the following command: mash vic <address>/<port>/<ttl>
>7. For test room this would be: mash vic 233.2.171.38/42002/127
>8. This will open a VIC window, once again showing you the video of the
>people already connected to the venue. The difference is that now you
can
>select your Encoding device from the VIC settings menu if VIC
recognizes
>your device.
>9. If you can see your device in the 'encoder'->'device' section, you
can
>select it, then select your transmission settings, and select
>transmit. If it works you will see your own video with everyone elses
in
>the VIC window.
>Notes: I am using a Sony firewire camera on a Dell Precision
>Workstation
>running Windows XP Pro. In the VIC window my firewire camera shows up
as
>"Microsoft WDM Image Capture (Win32)", with input "external-in".
>I've got a Logitech Quickcam 3000 laying around, I'll test and see if
>this
>workaround works for that also, and I'll let you know.
>Hope this is helpful,
>Eric
>Eric Hepburn
>Coordinator, Network Services
>A.C.E.S. IT Group
>Applied Computational Engineering & Sciences Bldg.
>The University of Texas at Austin
>Office: ACES 4.142
>Ph: (512) 232-9089 Fax: (512) 232-9084
>Mobile: (512) 413-9380
>DP (On Campus): 6-2045
>DP (Off Campus): (512) 478-4388 ext 2045
>Email: eric at mail.aces.utexas.edu
>From: Darin Oman [mailto:darin at ucar.edu]
>Sent: Thursday, August 15, 2002 4:12 PM
>Subject: [AG-TECH] PIG video
>Hi,
>Has anybody had any luck with getting a USB and/or firewire camera to
>work with the PIG?
>Thanks,
>Darin
