[Ad-dev] Thoughts on partial separability implementation
Sri Hari Krishna Narayanan snarayan at mcs.anl.gov
Mon Feb 27 11:54:07 CST 2012
During our intermittent discussions about the partial separability
work, both before
the submission and during the AMR proposal writing we floated the idea
of eliminating
a loop that was considered wasteful by you, but convenient from an
implementation
standpoint by me.
Specifically:
The statements:
   #pragma $adic_partiallyseparable, fquad, flin
	*f = area*(p5*fquad+flin);
were converted originally to:
  ADIC_SPARSE_Create1DimArray(&__adic_temp_f, ad_var_max);
  for (__adic_temp0 = 0; __adic_temp0 < ad_var_max; __adic_temp0++) {
     __adic_temp_f[__adic_temp0] = (area * ((p5 * fquad[__adic_temp0])
                                       + flin[__adic_temp0]));
   ADIC_SPARSE_Summation(f,__adic_temp_f,ad_var_max);
where the grad_array of f is dense and large in size. f is an object
of the class SparseDerivSeparable.
The grad_array of __adic_temp_f, fquad, and  flin
are of size p, where p is the number of colors used by ColPack to
compress the sparse elemental Jacobian.
These variables are objects of the class SparseDeriv. DERIV_TYPE is
typedeffed to SparseDeriv
SparseDerivSeparable is a child of SparseDeriv.SparseDeriv
contains a static array:
double grad[ADIC_GRADVEC_LENGTH];
and SparseDerivSeparable contains a dynamically allocated array:
   double *grad;.
The only location where a SparseDeriv object is used to compute a
object is in the ADIC_SPARSE_Summation function.  In the
sparsity detection mode ADIC_SPARSE_Summation registers the sparsity
patterns of __adic_temp_f.
In the computation mode,  uses the registered patterns along with the
ColPack routines to
compute f from __adic_temp_f.
I went ahead an implemented a version that did not require a loop that
calculates each element of  __adic_temp_f.
The output is given below:
   DERIV_TYPE *__adic_temp_flin;
   DERIV_TYPE *__adic_temp_fquad;
   ad_var_26 = ADIC_SPARSE_max(ad_var_0,ad_var_1);
   ADIC_SPARSE_Summation(__adic_temp_fquad,ad_fquad,ad_var_26);
   ad_var_27 = ADIC_SPARSE_max(ad_var_0,ad_var_1);
   ADIC_SPARSE_Summation(__adic_temp_flin,ad_flin,ad_var_27);
   ad_TempVartmp_7 = DERIV_val(ad_p5) * DERIV_val( *__adic_temp_fquad)
+ DERIV_val( *__adic_temp_flin);
   ad_TempVarSymbol_12 = DERIV_val(ad_area) * ad_TempVartmp_7;
   ad_TempVarlin_30 = ad_TempVartmp_7;
   ad_TempVarlin_32 = DERIV_val( *__adic_temp_fquad);
   ad_TempVarlin_33 = DERIV_val(ad_p5);
   ad_TempVarlin_31 = DERIV_val(ad_area);
   ADIC_SetValue( *f,ad_TempVarSymbol_12);
ADIC_SetDeriv
(DERIV_TYPE_ref(ad_area),DERIV_TYPE_ref(ad_TempVarprop_55));
ADIC_SetDeriv(DERIV_TYPE_ref(ad_p5),DERIV_TYPE_ref(ad_TempVarprop_56));
ADIC_SetDeriv
(DERIV_TYPE_ref( *__adic_temp_fquad),DERIV_TYPE_ref(ad_TempVarprop_57));
ADIC_SetDeriv
(DERIV_TYPE_ref( *__adic_temp_flin),DERIV_TYPE_ref(ad_TempVarprop_58));
ADIC_Sax_3
(1
,DERIV_TYPE_ref
(ad_TempVarprop_58
),ad_TempVarlin_32
,DERIV_TYPE_ref
(ad_TempVarprop_56
),ad_TempVarlin_33
,DERIV_TYPE_ref(ad_TempVarprop_57),DERIV_TYPE_ref(ad_TempVarprop_59));
ADIC_Sax_2
(ad_TempVarlin_30
,DERIV_TYPE_ref
(ad_TempVarprop_55
),ad_TempVarlin_31
,DERIV_TYPE_ref(ad_TempVarprop_59),DERIV_TYPE_ref( *f));
Right now, all temporary variables are objects of SparseDeriv.
There are two calls to ADIC_SPARSE_Summation
that assign values to the temporary variables __adic_temp_flin and
__adic_temp_fquad
These variables will be defined as  SparseDerivSeparable
within ADIC_SPARSE_Summation.
Here begins the problem, the XAIFBooster output for the statement
requires ADIC_Sax_# and SetDeriv calls which causes
assignments of SparseDeriv to SparseDerivSeparable
and vice-versa.
Statements such as:
ADIC_SetDeriv
can probably be handled by intelligent declaration of temporaries.
However, the statement
ADIC_Sax_3
(1
,DERIV_TYPE_ref
(ad_TempVarprop_58
),ad_TempVarlin_32
,DERIV_TYPE_ref
(ad_TempVarprop_56
),ad_TempVarlin_33
is trickier to handle as it requires us to define the computation
between  a SparseDeriv type and a SparseDerivSeparable type.
ad_TempVarprop_56 is just a temporary holding the grad_arrary of ad_area
which is  a SparseDeriv object.
What can be noted is that ad_area is a non_elemental value that is
also in effect inactive.
So if we integrate ActivityAnalysis, we should be able to keep ad_area
inactive (double type) and so
the above situation should not occur.
Are there any thoughts on this?
I have not yet talked about possibly using f later on in the code in
this email. I am assuming that
the succeeding code is all SparseDerivSeparable.
We will have to work out how to have different types and variables
declaration co-existing harmoniously.
Krishna
URL: <http://lists.mcs.anl.gov/pipermail/ad-dev/attachments/20120227/0b61a14f/attachment.htm>
More information about the Ad-dev mailing list
