[Swift-commit] r8449 - www/Swift-T
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon May 4 11:33:46 CDT 2015
Author: ketan
Date: 2015-05-04 11:33:46 -0500 (Mon, 04 May 2015)
New Revision: 8449
Modified:
   www/Swift-T/turbine-sites.html
Log:
minor
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2015-05-04 16:14:08 UTC (rev 8448)
+++ www/Swift-T/turbine-sites.html	2015-05-04 16:33:46 UTC (rev 8449)
@@ -2483,7 +2483,8 @@
 </div>
 <div class="sect3">
 <h4 id="_a_second_example">A second example</h4>
-<div class="paragraph"><p>The following example joins multiple files using the Unix <code>cat</code> utility:</p></div>
+<div class="paragraph"><p>The following example joins multiple files (n times in parallel) using the Unix
+<code>cat</code> utility:</p></div>
 <div class="listingblock">
 <div class="content">
 <pre><code>import files;
@@ -2515,7 +2516,7 @@
 <pre><code>swift-t -m "cray" catsn.swift</code></pre>
 </div></div>
-<div class="paragraph"><p>On successful compilation and job submission, the following output will be produced:</p></div>
+<div class="paragraph"><p>On successful compilation and job submission, output similar to the following will be produced:</p></div>
 <pre><code>TURBINE_OUTPUT=/scratch2/scratchdirs/ketan/ATPESC_2014-08-14/swift-t/examples/catsn/turbine.work
@@ -2662,7 +2663,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.8.0<br />
-Last updated 2015-05-04 11:13:05 CDT
+Last updated 2015-05-04 11:33:06 CDT
 </div>
 </div>
 </body>
