[Swift-commit] r8448 - www/Swift-T
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon May 4 11:14:09 CDT 2015
Author: ketan
Date: 2015-05-04 11:14:08 -0500 (Mon, 04 May 2015)
New Revision: 8448
Modified:
   www/Swift-T/turbine-sites.html
Log:
minor
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2015-05-04 16:00:50 UTC (rev 8447)
+++ www/Swift-T/turbine-sites.html	2015-05-04 16:14:08 UTC (rev 8448)
@@ -2444,7 +2444,7 @@
 </div>
 <div class="paragraph"><p>A Turbine Intermediate Code (.tic) file will be generated on successful compilation.
 The <code>swift-t</code> command builds a job specification script and submits it to the
-scheduler:</p></div>
+scheduler.</p></div>
 <div class="paragraph"><p>Output from the above command will be similar to the following:</p></div>
 <div class="listingblock">
 <div class="content">
@@ -2518,16 +2518,16 @@
 <div class="paragraph"><p>On successful compilation and job submission, the following output will be produced:</p></div>
-<pre><code>TURBINE_OUTPUT=/global/homes/k/ketan/turbine-output/2015/05/01/09/44/14
-`./swift-t-catsn.Tgs.tic' -> `/global/homes/k/ketan/turbine-output/2015/05/01/09/44/14/swift-t-catsn.Tgs.tic'
-SCRIPT=./swift-t-catsn.Tgs.tic
+<pre><code>TURBINE_OUTPUT=/scratch2/scratchdirs/ketan/ATPESC_2014-08-14/swift-t/examples/catsn/turbine.work
+`./swift-t-catsn.hzS.tic' -> `/scratch2/scratchdirs/ketan/ATPESC_2014-08-14/swift-t/examples/catsn/turbine.work/swift-t-catsn.hzS.tic'
+SCRIPT=./swift-t-catsn.hzS.tic
 PPN=1
-TURBINE_OUTPUT=/global/homes/k/ketan/turbine-output/2015/05/01/09/44/14
+TURBINE_OUTPUT=/scratch2/scratchdirs/ketan/ATPESC_2014-08-14/swift-t/examples/catsn/turbine.work
 WALLTIME=00:15:00
 PROCS=2
 NODES=2
-wrote: /global/homes/k/ketan/turbine-output/2015/05/01/09/44/14/turbine-cray.sh
-JOB_ID=2821464.edique02</code></pre>
+wrote: /scratch2/scratchdirs/ketan/ATPESC_2014-08-14/swift-t/examples/catsn/turbine.work/turbine-cray.sh
+JOB_ID=2835290.edique02</code></pre>
 </div></div>
 <div class="paragraph"><p>Inspect one of the output files <code>joined<n>.txt</code> produced in the $TURBINE_OUTPUT directory:</p></div>
@@ -2662,7 +2662,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.8.0<br />
-Last updated 2015-05-04 10:58:39 CDT
+Last updated 2015-05-04 11:13:05 CDT
 </div>
 </div>
 </body>
