[Swift-commit] cog r4034
swift at ci.uchicago.edu swift at ci.uchicago.edu
Thu Jul 24 17:40:03 CDT 2014
r4034 | timgarmstrong | 2014-07-24 17:39:37 -0500 (Thu, 24 Jul 2014) | 1 line
Throw exception on empty settings key
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java	(revision 4033)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java	(working copy)
@@ -58,7 +58,7 @@
     private int slots = 20;
     private int jobsPerNode = 1;
      * TODO: clarify what this does
@@ -119,7 +119,7 @@
     private SecurityContext securityContext;
     private boolean remoteMonitorEnabled;
 	 * Adjusts the metric used for block sizes.
@@ -160,9 +160,9 @@
     private String directory = null;
     private String useHashBang = null;
     private String perfTraceWorker = "false";
     private int perfTraceInterval = -1;
     private final Map<String, String> attributes;
@@ -320,23 +320,23 @@
     public String getPerfTraceWorker() {
         return perfTraceWorker;
     public void setPerfTraceWorker(String perfTraceWorker) {
         this.perfTraceWorker = perfTraceWorker;
     public int getPerfTraceInterval() {
         return perfTraceInterval;
     public void setPerfTraceInterval(int perfTraceInterval) {
         this.perfTraceInterval = perfTraceInterval;
      * The following values are considered valid:
      * <dl>
@@ -494,7 +494,7 @@
     public String getCoresPerNode() {
         return coresPerNode;
     public void setCoresPerNode(String coresPerNode) {
         this.coresPerNode=coresPerNode;
@@ -551,7 +551,7 @@
     public void setUseHashBang(String uhb) {
         this.useHashBang = uhb;
     public void setAttribute(String name, String value) {
     	attributes.put(name, value);
@@ -569,6 +569,11 @@
         if (logger.isDebugEnabled()) {
             logger.debug("Setting " + name + " to " + value);
+        if (name.length() == 0) {
+            throw new IllegalArgumentException("Empty string Settings key "
+                                            + "(value was \"" + value + "\"");
         boolean complete = false;
         Method[] methods = getClass().getMethods();
         String setterName = "set" +
