[Swift-commit] r8065 - trunk/docs/userguide
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu Jul 24 15:59:42 CDT 2014
Author: hategan
Date: 2014-07-24 15:59:41 -0500 (Thu, 24 Jul 2014)
New Revision: 8065
Modified:
   trunk/docs/userguide/configuration.new
Log:
proper spelling of overridden
Modified: trunk/docs/userguide/configuration.new
--- trunk/docs/userguide/configuration.new	2014-07-24 20:57:44 UTC (rev 8064)
+++ trunk/docs/userguide/configuration.new	2014-07-24 20:59:41 UTC (rev 8065)
@@ -138,11 +138,11 @@
 . User Configuration (*[U]*): +${env.HOME}/.swift/swift.conf+ (if present)
 . Run Configiuration (*[R]*): +${env.PWD}/swift.conf+ (if present)
-In addition, a number of configuration properties can be overriden individually on the
+In addition, a number of configuration properties can be overridden individually on the
 Swift command line. For a list of such configuration properties, please use +swift -help+
 or refer to the <<??, Running Swift>> Section in this document.
-The run configuration can be overriden on the Swift command line using the +-config+
+The run configuration can be overridden on the Swift command line using the +-config+
 argument. If +-config+ is specified, Swift will not attempt to load +swift.conf+ from
 the current directory.
