[Swift-commit] r7951 - trunk/src/org/griphyn/vdl/karajan
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Jul 4 01:33:48 CDT 2014
Author: hategan
Date: 2014-07-04 01:33:48 -0500 (Fri, 04 Jul 2014)
New Revision: 7951
Removed:
   trunk/src/org/griphyn/vdl/karajan/TCCache.java
Log:
removed tc cache since tc.data is not used any more
Deleted: trunk/src/org/griphyn/vdl/karajan/TCCache.java
--- trunk/src/org/griphyn/vdl/karajan/TCCache.java	2014-07-04 06:32:22 UTC (rev 7950)
+++ trunk/src/org/griphyn/vdl/karajan/TCCache.java	2014-07-04 06:33:48 UTC (rev 7951)
@@ -1,119 +0,0 @@
- * Copyright 2012 University of Chicago
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- * Created on Jan 5, 2007
-package org.griphyn.vdl.karajan;
-import java.util.HashMap;
-import java.util.List;
-import java.util.Map;
-import org.globus.swift.catalog.TCEntry;
-import org.globus.swift.catalog.TransformationCatalog;
-import org.globus.swift.catalog.types.TCType;
-import org.griphyn.vdl.util.FQN;
-public class TCCache {
-	private TransformationCatalog tc;
-	private Map<Entry, List<TCEntry>> cache;
-	private Entry entry;
-	public TCCache(TransformationCatalog tc) {
-		this.tc = tc;
-		cache = new HashMap<Entry, List<TCEntry>>();
-		entry = new Entry();
-	public static final FQN ANY_APP = new FQN("*");
-	public synchronized List<TCEntry> getTCEntries(FQN tr, String host, TCType tctype) throws Exception {
-		List<TCEntry> l;
-		// try exact entry
-		entry.set(tr, host, tctype);
-		l = getTCEntries_(entry);
-		if (l != null) {
-			return l;
-		// try app wildcard on this host
-		entry.set(ANY_APP, host, tctype);
-		if (l != null) {
-			return l;
-		// try this app on wildcard host
-		entry.set(tr, "*", tctype);
-		if (l != null) {
-			return l;
-		// finally try app wildcard on wildcard host
-		entry.set(ANY_APP, "*", tctype);
-		return l;
-	private List<TCEntry> getTCEntries_(Entry e) throws Exception {
-		List<TCEntry> l = cache.get(e);
-        if (l == null && !cache.containsKey(e)) {
-            l = tc.getTCEntries(e.tr.getNamespace(), e.tr.getName(), e.tr.getVersion(), e.host, e.tctype);
-            cache.put(new Entry(e), l);
-        return l;
-    private class Entry {
-		public FQN tr;
-		public String host;
-		public TCType tctype;
-		public Entry() {
-		public Entry(FQN tr, String host, TCType tctype) {
-			set(tr, host, tctype);
-		public Entry(Entry e) {
-            set(e.tr, e.host, e.tctype);
-		public void set(FQN tr, String host, TCType tctype) {
-			this.tr = tr;
-			this.host = host;
-			this.tctype = tctype;
-		public boolean equals(Object obj) {
-			if (obj instanceof Entry) {
-				Entry other = (Entry) obj;
-				return tr.equals(other.tr) && host.equals(other.host) && tctype.equals(other.tctype);
-			else {
-				return false;
-		public int hashCode() {
-			return tr.hashCode() + host.hashCode() + tctype.hashCode();
