[Swift-commit] r7950 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Jul 4 01:32:22 CDT 2014
Author: hategan
Date: 2014-07-04 01:32:22 -0500 (Fri, 04 Jul 2014)
New Revision: 7950
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/Executable.java
   trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
   trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java
   trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java
   trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
   trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
Log:
new sites spec
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Executable.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Executable.java	2014-07-04 06:24:42 UTC (rev 7949)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Executable.java	2014-07-04 06:32:22 UTC (rev 7950)
@@ -24,15 +24,13 @@
 import org.globus.cog.karajan.analyzer.ArgRef;
 import org.globus.cog.karajan.analyzer.Signature;
-import org.globus.cog.karajan.util.BoundContact;
-import org.globus.swift.catalog.TCEntry;
-import org.griphyn.vdl.karajan.TCCache;
-import org.griphyn.vdl.util.FQN;
+import org.globus.swift.catalog.site.Application;
+import org.globus.swift.catalog.site.SwiftContact;
 public class Executable extends SwiftFunction {
     private ArgRef<String> tr;
-    private ArgRef<BoundContact> host;
+    private ArgRef<SwiftContact> host;
 	@Override
@@ -42,21 +40,16 @@
     public Object function(Stack stack) {
-		TCCache tc = getTC(stack);
 		String tr = this.tr.getValue(stack);
-		BoundContact bc = this.host.getValue(stack);
-		TCEntry tce = getTCE(tc, new FQN(tr), bc);
-		if (tce == null) {
+		SwiftContact bc = this.host.getValue(stack);
+		// at this point, a host has been allocated, so we already
+		// know that the app is available on it
+		Application app = bc.findApplication(tr);
+		if (app.executableIsWildcard()) {
 			return tr;
 		else {
-			String pt = tce.getPhysicalTransformation();
-			if ("*".equals(pt)) {
-			    return tr;
-			else {
-			    return pt;
+			return app.getExecutable();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Execute.java	2014-07-04 06:24:42 UTC (rev 7949)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Execute.java	2014-07-04 06:32:22 UTC (rev 7950)
@@ -24,6 +24,7 @@
 import java.util.HashSet;
 import java.util.Iterator;
 import java.util.List;
+import java.util.Map;
 import java.util.Set;
 import k.rt.Abort;
@@ -35,6 +36,8 @@
 import org.apache.log4j.Logger;
 import org.globus.cog.abstraction.impl.common.StatusEvent;
+import org.globus.cog.abstraction.impl.common.task.JobSpecificationImpl;
+import org.globus.cog.abstraction.interfaces.JobSpecification;
 import org.globus.cog.abstraction.interfaces.Status;
 import org.globus.cog.abstraction.interfaces.Task;
@@ -58,6 +61,7 @@
 	private ArgRef<Channel<Object>> replicationChannel;
 	private ArgRef<String> jobid;
 	private ArgRef<ProgressState> progress;
+	private ArgRef<Map<String, String>> environment;
 	private VarRef<Context> context;
@@ -73,7 +77,8 @@
 	    params.add(optional("jobid", null));
 	    removeParams(params, "stdout", "stderr", "stdoutLocation", "stderrLocation",
 	        "stdin", "provider", "securityContext", "nativespec",
-	        "delegation", "batch");
+	        "delegation", "batch", "environment");
+	    params.add(optional("environment", null));
 	    return sig;
@@ -103,6 +108,11 @@
     @Override
+    protected void addEnvironment(Stack stack, JobSpecificationImpl js) throws ExecutionException {
+        js.setEnvironmentVariables(environment.getValue(stack));
+    @Override
     public void submitScheduled(Scheduler scheduler, Task task, Stack stack, Object constraints) {
 		try {
 		    setTaskIdentity(stack, task);
@@ -129,12 +139,28 @@
 	        logger.debug("Submitting task " + task);
 	    String jobid = this.jobid.getValue(stack);
-	    if (logger.isDebugEnabled()) {
-	        logger.debug("jobid=" + jobid + " task=" + task);
+	    if (logger.isInfoEnabled()) {
+	        JobSpecification spec = (JobSpecification) task.getSpecification();
+	        logger.info(buildTaskInfoString(task, spec));
-	protected void registerReplica(Stack stack, Task task) throws CanceledReplicaException {
+	private String buildTaskInfoString(Task task, JobSpecification spec) {
+        StringBuilder sb = new StringBuilder();
+        sb.append("JOB_TASK jobid=");
+        sb.append(jobid);
+        sb.append(" taskid=");
+        sb.append(task.getIdentity());
+        sb.append(" exec=");
+        sb.append(spec.getExecutable());
+        sb.append(" dir=");
+        sb.append(spec.getDirectory());
+        sb.append(" args=");
+        sb.append(spec.getArguments());
+        return sb.toString();
+    protected void registerReplica(Stack stack, Task task) throws CanceledReplicaException {
 		String rg = this.replicationGroup.getValue(stack);
 		if (rg != null) {
 			getReplicationManager(stack).register(rg, task);
@@ -152,12 +178,22 @@
     		Stack stack = getStack();
     		try {
     			if (stack != null) {
-    				int c = e.getStatus().getStatusCode();
+    			    Status s = e.getStatus();
+    				int c = s.getStatusCode();
+    				    if (s.getMessage() == null) {
+    				        logger.info("TASK_STATUS_CHANGE taskid=" + e.getSource().getIdentity() + " status=" + c);
+    				    else {
+    				        logger.info("TASK_STATUS_CHANGE taskid=" + e.getSource().getIdentity() + " status=" + c +
+    				            " " + s.getMessage());
     				ProgressState ps = progress.getValue(stack);
     				if (c == Status.SUBMITTED) {
     				    ps.setState("Submitted");
     				    if (replicationEnabled) {
-    				        getReplicationManager(stack).submitted(task, e.getStatus().getTime());
+    				        getReplicationManager(stack).submitted(task, s.getTime());
     				else if (c == Status.STAGE_IN) {
@@ -169,7 +205,7 @@
     				else if (c == Status.ACTIVE) {
     					ps.setState("Active");
-    					    getReplicationManager(stack).active(task, e.getStatus().getTime());
+    					    getReplicationManager(stack).active(task, s.getTime());
     					    Execute.this.replicationChannel.getValue(stack).close();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java
--- trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java	2014-07-04 06:24:42 UTC (rev 7949)
+++ trunk/src/org/griphyn/vdl/karajan/lib/JobConstraints.java	2014-07-04 06:32:22 UTC (rev 7950)
@@ -33,7 +33,6 @@
 import org.globus.cog.karajan.scheduler.TaskConstraints;
 import org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter;
 import org.griphyn.vdl.mapping.DSHandle;
 public class JobConstraints extends CacheFunction {
@@ -53,7 +52,7 @@
 		String[] filenames = null;
 		Collection<DSHandle> stageins = this.stagein.getValue(stack);
-		SwiftTaskConstraints tc = new SwiftTaskConstraints(tr, new FQN(tr));
+		SwiftTaskConstraints tc = new SwiftTaskConstraints(tr);
 		if (stageins != null) {
 		    tc.setStageins(stageins);
 		    tc.setFilecache(new CacheMapAdapter(getCache(stack)));
@@ -67,13 +66,11 @@
 	private static class SwiftTaskConstraints implements TaskConstraints {
 	    private final String tr;
-	    private final FQN trfqn;
 	    private Collection<DSHandle> stageins;
 	    private CacheMapAdapter filecache;
-	    public SwiftTaskConstraints(String tr, FQN trfqn) {
+	    public SwiftTaskConstraints(String tr) {
 	        this.tr = tr;
-	        this.trfqn = trfqn;
         public Collection<DSHandle> getStageins() {
@@ -98,9 +95,6 @@
             if ("tr".equals(name)) {
                 return tr;
-            else if ("trfqn".equals(name)) {
-                return trfqn;
             else if ("stageins".equals(name)) {
                 return stageins;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java	2014-07-04 06:24:42 UTC (rev 7949)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java	2014-07-04 06:32:22 UTC (rev 7950)
@@ -9,6 +9,9 @@
 package org.griphyn.vdl.karajan.lib;
+import java.util.ArrayList;
+import java.util.List;
 import k.rt.ExecutionException;
 import k.rt.Stack;
@@ -24,11 +27,10 @@
 import org.globus.cog.karajan.analyzer.Param;
 import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
-import org.globus.cog.karajan.util.ContactSet;
 import org.globus.swift.catalog.site.SiteCatalogParser;
+import org.globus.swift.catalog.site.SwiftContactSet;
 import org.w3c.dom.Document;
 import org.w3c.dom.NamedNodeMap;
 import org.w3c.dom.Node;
@@ -36,10 +38,6 @@
 public class SiteCatalog extends AbstractSingleValuedFunction {
     private ArgRef<String> fileName;
-    private enum Version {
-        V1, V2;
     @Override
     protected Param[] getParams() {
@@ -58,48 +56,59 @@
             throw new ExecutionException(this, "Failed to parse site catalog", e);
+    private static class KVPair {
+        public final String key;
+        public final String value;
+        public KVPair(String key, String value) {
+            this.key = key;
+            this.value = value;
     private Object buildResources(Document doc) {
         Node root = getRoot(doc);
         if (root.getLocalName().equals("config")) {
-            return parse(root, Version.V1);
+            throw new IllegalArgumentException("Old sites file format. Please upgrade your sites file to the new format.");
         else if (root.getLocalName().equals("sites")) {
+            return parse(root);
         else {
             throw new IllegalArgumentException("Illegal sites file root node: " + root.getLocalName());
-    private Object parse(Node config, Version v) {
-        ContactSet cs = new ContactSet();
+    private Object parse(Node config) {
+        SwiftContactSet cs = new SwiftContactSet();
         NodeList pools = config.getChildNodes();
         for (int i = 0; i < pools.getLength(); i++) {
             Node n = pools.item(i);
             if (n.getNodeType() == Node.ELEMENT_NODE) {
-                try {
-                    BoundContact bc = pool(n, v);
-                    if (bc != null) {
-                        cs.addContact(bc);
+                String ctype = n.getNodeName();
+                if (ctype.equals("site")) {
+                    try {
+                        SwiftContact bc = pool(n);
+                        if (bc != null) {
+                            cs.addContact(bc);
+                    catch (Exception e) {
+                        throw new ExecutionException(this, "Invalid site entry '" + poolName(n) + "': ", e);
-                catch (Exception e) {
-                    throw new ExecutionException(this, "Invalid site entry '" + poolName(n, v) + "': ", e);
+                else if (ctype.equals("application")) {
+                    cs.addApplication(application(n));
         return cs;
-    private String poolName(Node site, Version v) {
-       if (site.getLocalName().equals("pool")) {
-           return attr(site, "handle");
-       else if (site.getLocalName().equals("site")) {
+    private String poolName(Node site) {
+       if (site.getLocalName().equals("site")) {
            return attr(site, "name");
        else {
@@ -117,18 +126,18 @@
         throw new IllegalArgumentException("Missing root element");
-    private BoundContact pool(Node n, Version v) throws InvalidProviderException, ProviderMethodException {
+    private SwiftContact pool(Node n) throws InvalidProviderException, ProviderMethodException {
         if (n.getNodeType() != Node.ELEMENT_NODE) {
             return null;
-        String name = poolName(n, v);
+        String name = poolName(n);
         SwiftContact bc = new SwiftContact(name);
         String sysinfo = attr(n, "sysinfo", null);
         if (sysinfo != null) {
-            bc.addProperty("sysinfo", sysinfo);
+            bc.setProperty("sysinfo", sysinfo);
         NodeList cs = n.getChildNodes();
         for (int i = 0; i < cs.getLength(); i++) {
@@ -138,33 +147,24 @@
             String ctype = c.getNodeName();
-            if (v == Version.V1 && ctype.equals("gridftp")) {
-                bc.addService(gridftp(c));
-            else if (v == Version.V1 && ctype.equals("jobmanager")) {
-                bc.addService(jobmanager(c));
-            else if (ctype.equals("execution")) {
+            if (ctype.equals("execution")) {
                 bc.addService(execution(c));
             else if (ctype.equals("filesystem")) {
                 bc.addService(filesystem(c));
             else if (ctype.equals("workdirectory")) {
-                bc.addProperty("workdir", text(c));
+                bc.setProperty("workdir", text(c));
             else if (ctype.equals("scratch")) {
-                bc.addProperty("scratch", text(c));
+                bc.setProperty("scratch", text(c));
-            else if (ctype.equals("env")) {
-                env(bc, c);
+            else if (ctype.equals("property")) {
+                bc.setProperty(attr(c, "name"), text(c));
-            else if (ctype.equals("profile")) {
-                profile(bc, c);
+            else if (ctype.equals("apps")) {
+                apps(bc, c);
-            else if (v == Version.V2 && ctype.equals("application")) {
-                application(bc, c);
             else {
                 throw new IllegalArgumentException("Unknown node type: " + ctype);
@@ -172,44 +172,85 @@
         return bc;
-    private void application(BoundContact bc, Node c) {
+    private void apps(SwiftContact bc, Node n) {
+        NodeList cs = n.getChildNodes();
+        List<KVPair> envs = new ArrayList<KVPair>();
+        List<KVPair> props = new ArrayList<KVPair>();
+        for (int i = 0; i < cs.getLength(); i++) {
+            Node c = cs.item(i);
+            if (c.getNodeType() != Node.ELEMENT_NODE) {
+                continue;
+            String ctype = c.getNodeName();
+            if (ctype.equals("app")) {
+                bc.addApplication(application(c));
+            else if (ctype.equals("env")) {
+                envs.add(env(c));
+                props.add(this.property(c));
+            else {
+                throw new IllegalArgumentException("Unknown node type: " + ctype);
+        mergeEnvsToApps(bc, envs);
+        mergePropsToApps(bc, props);
-    private Service jobmanager(Node n) throws InvalidProviderException, ProviderMethodException {
-        String provider;
-        String url = attr(n, "url");
-        String major = attr(n, "major");
-        if (url.equals("local://localhost")) {
-            provider = "local";
+    private void mergeEnvsToApps(SwiftContact bc, List<KVPair> envs) {
+        for (Application app : bc.getApplications()) {
+            for (KVPair kvp : envs) {
+                if (!app.getEnv().containsKey(kvp.key)) {
+                    // only merge if app does not override
+                    app.setEnv(kvp.key, kvp.value);
-        else if (url.equals("pbs://localhost")) {
-            provider = "pbs";
+    private void mergePropsToApps(SwiftContact bc, List<KVPair> props) {
+            for (KVPair kvp : props) {
+                if (!app.getProperties().containsKey(kvp.key)) {
+                    app.addProperty(kvp.key, kvp.value);
-        else if ("2".equals(major)) {
-            provider = "gt2";
-        else if ("4".equals(major)) {
-            provider = "gt4";
-        else {
-            throw new IllegalArgumentException("Unknown job manager version: " + major + ", url = '" + url + "'");
-        ServiceContact contact = new ServiceContactImpl(url);
-            return new ServiceImpl(provider, Service.EXECUTION,
-                contact, AbstractionFactory.newSecurityContext(provider, contact));
-    private Service gridftp(Node n) throws InvalidProviderException, ProviderMethodException {
-            return new ServiceImpl("local", Service.FILE_OPERATION, new ServiceContactImpl("localhost"), null);
+    private Application application(Node n) {
+        Application app = new Application();
+        app.setName(attr(n, "name"));
+        app.setExecutable(attr(n, "executable"));
+                continue;
+            if (ctype.equals("env")) {
+                KVPair env = env(c);
+                app.setEnv(env.key, env.value);
+                KVPair prop = property(c);
+                app.addProperty(prop.key, prop.value);
+            else {
-        else {
-            return new ServiceImpl("gsiftp", Service.FILE_OPERATION,
-                contact, AbstractionFactory.newSecurityContext("gsiftp", contact));
+        return app;
     private Service execution(Node n) throws InvalidProviderException, ProviderMethodException {
@@ -233,9 +274,39 @@
             s.setJobManager(jobManager);
+        properties(s, n);
         return s;
+    private void properties(Service s, Node n) {
+                continue;
+            if (ctype.equals("property")) {
+                property(s, c);
+            else {
+    private void property(Service s, Node c) {
+        s.setAttribute(attr(c, "name"), text(c));
+    private KVPair property(Node c) {
+        return new KVPair(attr(c, "name"), text(c));
     private Service filesystem(Node n) throws InvalidProviderException, ProviderMethodException {
         String provider = attr(n, "provider");
         String url = attr(n, "url", null);
@@ -251,32 +322,18 @@
             s.setSecurityContext(AbstractionFactory.newSecurityContext(provider, contact));
+        properties(s, n);
         return s;
-    private void env(SwiftContact bc, Node n) {
-        String key = attr(n, "key");
+    private KVPair env(Node n) {
+        String key = attr(n, "name");
         String value = text(n);
-        bc.addProfile(new FQN("env", key), value);
+        return new KVPair(key, value);
-    private void profile(SwiftContact bc, Node n) {
-        String ns = attr(n, "namespace");
-        String value = text(n);
-        if (value == null) {
-            throw new IllegalArgumentException("No value for profile " + ns + ":" + key);
-        if (ns.equals("karajan")) {
-            bc.addProperty(key, value);
-        else {
-        	bc.addProfile(new FQN(ns, key), value);
     private String text(Node n) {
         if (n.getFirstChild() != null) {
             return n.getFirstChild().getNodeValue();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-07-04 06:24:42 UTC (rev 7949)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-07-04 06:32:22 UTC (rev 7950)
@@ -21,11 +21,8 @@
 import java.util.Collection;
 import java.util.Collections;
-import java.util.HashSet;
-import java.util.LinkedList;
-import java.util.Set;
 import k.rt.Channel;
 import k.rt.Context;
@@ -41,14 +38,8 @@
 import org.globus.cog.karajan.compiled.nodes.Node;
 import org.globus.cog.karajan.compiled.nodes.functions.AbstractFunction;
 import org.globus.cog.karajan.parser.WrapperNode;
 import org.globus.cog.karajan.util.TypeUtil;
-import org.globus.swift.catalog.transformation.File;
-import org.globus.swift.catalog.types.TCType;
 import org.griphyn.vdl.karajan.AssertFailedException;
-import org.griphyn.vdl.karajan.functions.ConfigProperty;
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.DependentException;
@@ -65,9 +56,7 @@
 import org.griphyn.vdl.type.Field;
 import org.griphyn.vdl.type.Type;
 import org.griphyn.vdl.type.Types;
 import org.griphyn.vdl.util.VDL2Config;
-import org.griphyn.vdl.util.VDL2ConfigProperties;
 public abstract class SwiftFunction extends AbstractFunction {
 	public static final Logger logger = Logger.getLogger(SwiftFunction.class);
@@ -386,50 +375,7 @@
 			return Path.parse((String) o);
-	private static Set<List<Object>> warnset = new HashSet<List<Object>>();
-	protected TCEntry getTCE(TCCache tc, FQN fqn, BoundContact bc) {
-		List<TCEntry> l;
-		try {
-			l = tc.getTCEntries(fqn, bc.getHost(), TCType.INSTALLED);
-			throw new ExecutionException(this, e);
-		if (l == null || l.isEmpty()) {
-			return null;
-		if (l.size() > 1) {
-			synchronized (warnset) {
-				LinkedList<Object> wl = new LinkedList<Object>();
-				wl.add(fqn);
-				wl.add(bc);
-				if (!warnset.contains(wl)) {
-					logger.warn("Multiple entries found for " + fqn + " on " + bc
-							+ ". Using the first one");
-					warnset.add(wl);
-		return l.get(0);
-	public static final String TC = "vdl:TC";
-	public TCCache getTC(Stack stack) throws ExecutionException {
-	    Context c = this.context.getValue(stack);
-		synchronized (c) {
-			TCCache tc = (TCCache) c.getAttribute(TC);
-			if (tc == null) {
-				String prop = ConfigProperty.getProperty(VDL2ConfigProperties.TC_FILE, (VDL2Config) c.getAttribute("SWIFT:CONFIG"));
-				tc = new TCCache(File.getNonSingletonInstance(prop));
-				c.setAttribute(TC, tc);
-			return tc;
 	private static int provenanceIDCount = 451000;
 	public static synchronized int nextProvenanceID() {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
--- trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2014-07-04 06:24:42 UTC (rev 7949)
+++ trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2014-07-04 06:32:22 UTC (rev 7950)
@@ -21,11 +21,7 @@
 import java.util.HashMap;
-import java.util.Iterator;
-import java.util.List;
 import k.rt.Stack;
@@ -33,15 +29,11 @@
 import org.globus.cog.abstraction.impl.common.execution.WallTime;
-import org.globus.cog.karajan.analyzer.ChannelRef;
 import org.globus.cog.karajan.analyzer.VarRef;
-import org.globus.cog.karajan.compiled.nodes.functions.Map.Entry;
-import org.globus.swift.catalog.util.Profile;
+import org.griphyn.vdl.engine.Warnings;
 public class TCProfile extends SwiftFunction {
     public static final Logger logger = Logger.getLogger(TCProfile.class);
@@ -58,7 +50,7 @@
     private VarRef<Object> r_count;
     private VarRef<Object> r_jobType;
     private VarRef<Object> r_attributes;
-    private ChannelRef<Map.Entry<Object, Object>> cr_environment;
+    private VarRef<Map<String, String>> r_environment;
     private enum Attr {
         COUNT, JOB_TYPE;
@@ -77,66 +69,67 @@
         return new Signature(
             params("host", optional("attributes", null), optional("tr", null)),
             returns("count", "jobType",
-                "attributes", channel("environment", DYNAMIC))
+                "attributes", "environment")
-		Map<String, Object> dynamicAttributes = readDynamicAttributes(stack);
-		Map<String, Object> attrs = null;
-		attrs = attributesFromHost(bc, attrs, stack);
-		TCEntry tce = null;
-		if (tr != null) {
-		    tce = getTCE(tc, new FQN(tr), bc);
+		if (app == null) {
+		    throw new RuntimeException("Application '" + tr + "' not found on site '" + bc.getName() + "'");
-		if (tce != null) {
-			addEnvironment(stack, tce);
-			addEnvironment(stack, bc);
-			attrs = attributesFromTC(tce, attrs, stack);
-		attrs = addDynamicAttributes(attrs, dynamicAttributes);
-		checkWalltime(attrs, tr, stack);
-		addAttributes(attrs, stack);
+		addEnvironment(stack, app.getEnv());
+		Map<String, Object> dynamicAttributes = this.attributes.getValue(stack);
+		Map<String, Object> attrs = null;
+		attrs = combineAttributes(stack, attrs, app.getProperties());
+		attrs = combineAttributes(stack, attrs, dynamicAttributes);
+		checkWalltime(stack, attrs, tr);
+		setAttributes(stack, attrs);
 		return null;
+	private void addEnvironment(Stack stack, Map<String, String> env) {
+	    r_environment.setValue(stack, env);
 	   Bring in the dynamic attributes from the Karajan stack
 	   @return Map, may be null
 	private Map<String, Object> readDynamicAttributes(Stack stack) {
 		return this.attributes.getValue(stack);
-       Store dynamic attributes into returned attributes,
-       overwriting if necessary
-       @param result Attributes so far known, may be null
-       @param dynamicAttributes Attributes to insert, may be null
-       @result Combination, may be null
+	 * Combine attributes creating result as necessary
-	private Map<String, Object>
-	addDynamicAttributes(Map<String, Object> result,
-	                     Map<String, Object> dynamicAttributes) {
-		if (result == null && dynamicAttributes == null)
-			return null;
-		if (result == null)
-			return dynamicAttributes;
-		if (dynamicAttributes == null)
-			return result;
-		result.putAll(dynamicAttributes);
+	private Map<String, Object>	combineAttributes(Stack stack, Map<String, Object> result, Map<String, Object> src) {
+	    if (src == null || src.isEmpty()) {
+	        return result;
+		for (Map.Entry<String, Object> e : src.entrySet()) {
+		    Attr a = ATTR_TYPES.get(e.getKey());
+            if (a != null) {
+                setAttr(a, stack, e.getValue());
+            else {
+                if (result == null) {
+                    result = new HashMap<String, Object>();
+                result.put(e.getKey(), e.getValue());
 		return result;
-	private void checkWalltime(Map<String, Object> attrs, String tr, Stack stack) {
+	private void checkWalltime(Stack stack, Map<String, Object> attrs, String tr) {
 		if (attrs == null) {
 			return;
@@ -149,113 +142,15 @@
             WallTime.timeToSeconds(walltime.toString());
         catch (ExecutionException e) {
-            warn(tr, "Warning: invalid walltime specification for \"" + tr
+            Warnings.warn(Warnings.Type.SITE, "Invalid walltime specification for \"" + tr
                     + "\" (" + walltime + ").");
-	private static final Set<String> warnedAboutWalltime =
-	    new HashSet<String>();
-	private void warn(String tr, String message) {
-        synchronized (warnedAboutWalltime) {
-            if (warnedAboutWalltime.add(tr)) {
-                System.out.println(message);
-	private void addEnvironment(Stack stack, TCEntry tce) {
-		List<Profile> list = tce.getProfiles(Profile.ENV);
-		if (list != null) {
-			for (Profile p : list) {
-			    cr_environment.append(stack, new Entry(p.getProfileKey(), p.getProfileValue()));
-	public static final String PROFILE_GLOBUS_PREFIX = (Profile.GLOBUS + "::").toLowerCase();
-	private void addEnvironment(Stack stack, SwiftContact bc) {
-		Map<FQN, Object> profiles = bc.getProfiles();
-		if (profiles != null) {
-    		for (Map.Entry<FQN, Object> e : profiles.entrySet()) {
-    			FQN fqn = e.getKey();
-    			String value = (String) e.getValue();
-    			if (Profile.ENV.equalsIgnoreCase(fqn.getNamespace())) {
-    			    cr_environment.append(stack, new Entry(fqn.getName(), value));
-	private void addAttributes(Map<String,Object> attrs, Stack stack) {
-	        logger.debug("Attributes: " + attrs);
-	    if (attrs == null) {
-	        return;
-	    Iterator<Map.Entry<String, Object>> i = attrs.entrySet().iterator();
-	    while (i.hasNext()) {
-	        Map.Entry<String, Object> e = i.next();
-	        Attr a = ATTR_TYPES.get(e.getKey());
-	        if (a != null) {
-	            setAttr(a, stack, e.getValue());
-	            i.remove();
-	    if (attrs.size() == 0) {
-	        return;
+	private void setAttributes(Stack stack, Map<String, Object> attrs) {
 	    this.r_attributes.setValue(stack, attrs);
-	private Map<String,Object> attributesFromTC(TCEntry tce, Map<String,Object> attrs, Stack stack) {
-	    List<Profile> list = tce.getProfiles(Profile.GLOBUS);
-				Attr a = ATTR_TYPES.get(p.getProfileKey());
-				if (a == null) {
-				        attrs = new HashMap<String,Object>();
-				    attrs.put(p.getProfileKey(), p.getProfileValue());
-				else {
-				    setAttr(a, stack, p.getProfileValue());
-		return attrs;
-	   Inserts namespace=globus attributes from BoundContact bc
-	   into given attrs
-	private Map<String,Object> attributesFromHost(SwiftContact bc, Map<String, Object> attrs, Stack stack) {
-		        if (Profile.GLOBUS.equalsIgnoreCase(fqn.getNamespace())) {
-		            Attr a = ATTR_TYPES.get(fqn.getName());
-		            if (a == null) {
-		                attrs.put(fqn.getName(), e.getValue());
-		            else {
-		return attrs;
     private void setAttr(Attr a, Stack stack, Object value) {
         switch (a) {
             case COUNT:
