[Swift-commit] r7948 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Jul 4 01:24:18 CDT 2014
Author: hategan
Date: 2014-07-04 01:24:18 -0500 (Fri, 04 Jul 2014)
New Revision: 7948
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java
Removed:
   trunk/src/org/griphyn/vdl/karajan/lib/SiteProfile.java
Log:
renamed SiteProfile to SiteProperty
Deleted: trunk/src/org/griphyn/vdl/karajan/lib/SiteProfile.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SiteProfile.java	2014-07-04 06:23:06 UTC (rev 7947)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SiteProfile.java	2014-07-04 06:24:18 UTC (rev 7948)
@@ -1,156 +0,0 @@
- * Copyright 2012 University of Chicago
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- * Created on Dec 26, 2006
-package org.griphyn.vdl.karajan.lib;
-import java.util.HashMap;
-import java.util.HashSet;
-import java.util.Map;
-import java.util.Set;
-import k.rt.ExecutionException;
-import k.rt.Stack;
-import org.apache.log4j.Logger;
-import org.globus.cog.karajan.analyzer.ArgRef;
-import org.globus.cog.karajan.analyzer.ChannelRef;
-import org.globus.cog.karajan.analyzer.Signature;
-import org.globus.cog.karajan.util.BoundContact;
-import org.globus.swift.catalog.types.Os;
-import org.griphyn.vdl.util.FQN;
-public class SiteProfile extends SwiftFunction {
-    public static final Logger logger = Logger.getLogger(SiteProfile.class);
-    private ArgRef<BoundContact> host;
-    private ArgRef<String> fqn;
-    private ArgRef<Object> _default;
-    private ChannelRef<Object> cr_vargs;
-	@Override
-    protected Signature getSignature() {
-        return new Signature(params("host", "fqn", optional("default", null)), returns(channel("...", 1)));
-	public Object function(Stack stack) throws ExecutionException {
-		BoundContact bc = host.getValue(stack);
-		return getSingle(bc, new FQN(fqn.getValue(stack)), _default.getValue(stack));
-	public static final FQN SWIFT_WRAPPER_INTERPRETER = new FQN("swift:wrapperInterpreter");
-	public static final FQN SWIFT_WRAPPER_INTERPRETER_OPTIONS = new FQN("swift:wrapperInterpreterOptions");
-	public static final FQN SWIFT_WRAPPER_SCRIPT = new FQN("swift:wrapperScript");
-	public static final FQN SWIFT_CLEANUP_COMMAND = new FQN("swift:cleanupCommand");
-	public static final FQN SWIFT_CLEANUP_COMMAND_OPTIONS = new FQN("swift:cleanupCommandOptions");
-	public static final FQN SYSINFO_OS = new FQN("SYSINFO:OS");
-	private static final Map<Os, Map<FQN,Object>> DEFAULTS;
-	private static final Set<FQN> DEFAULTS_NAMES;
-	private static void addDefault(Os os, FQN fqn, Object value) {
-		DEFAULTS_NAMES.add(fqn);
-		Map<FQN,Object> osm = DEFAULTS.get(os);
-		if (osm == null) {
-			osm = new HashMap<FQN,Object>();
-			DEFAULTS.put(os, osm);
-		osm.put(fqn, value);
-	private static boolean hasDefault(Os os, FQN fqn) {
-			return false;
-		else {
-			return osm.containsKey(fqn);
-	private static Object getDefault(Os os, FQN fqn) {
-			osm = DEFAULTS.get(null);
-		return osm.get(fqn);
-	static {
-		DEFAULTS = new HashMap<Os,Map<FQN,Object>>();
-		DEFAULTS_NAMES = new HashSet<FQN>();
-		addDefault(Os.WINDOWS, SWIFT_WRAPPER_INTERPRETER, "cscript.exe");
-		addDefault(Os.WINDOWS, SWIFT_WRAPPER_SCRIPT, "_swiftwrap.vbs");
-		addDefault(Os.WINDOWS, SWIFT_WRAPPER_INTERPRETER_OPTIONS, new String[] {"//Nologo"});
-		addDefault(Os.WINDOWS, SWIFT_CLEANUP_COMMAND, "cmd.exe");
-		addDefault(Os.WINDOWS, SWIFT_CLEANUP_COMMAND_OPTIONS, new String[] {"/C", "del", "/Q"});
-		addDefault(null, SWIFT_WRAPPER_INTERPRETER, "/bin/bash");
-		addDefault(null, SWIFT_WRAPPER_SCRIPT, "_swiftwrap");
-		addDefault(null, SWIFT_WRAPPER_INTERPRETER_OPTIONS, null);
-		addDefault(null, SWIFT_CLEANUP_COMMAND, "/bin/rm");
-		addDefault(null, SWIFT_CLEANUP_COMMAND_OPTIONS, new String[] {"-rf"});
-	private Object getSingle(BoundContact bc, FQN fqn, Object defval)
-	    throws ExecutionException {
-            String value = getProfile(bc, fqn);
-            if (value == null) {
-            	Os os = getOS(bc);
-            	if (DEFAULTS_NAMES.contains(fqn)) {
-            		return getDefault(os, fqn);
-                else if (SYSINFO_OS.equals(fqn)) {
-                	return os;
-                else if (defval != null) {
-                    return defval;
-                else {
-                	throw new ExecutionException(this, "Missing profile: " + fqn);
-            else {
-            	return value;
-    private String getProfile(BoundContact bc, FQN fqn) {
-        Object o = bc.getProperty(fqn.toString());
-        if (o == null) {
-            return null;
-        else {
-            return o.toString();
-    private Os getOS(BoundContact bc) {
-    	Object o = bc.getProperty("sysinfo");
-    	if (o == null) {
-    		return Os.LINUX;
-    	else {
-    		String[] p = o.toString().split("::");
-    		if (p.length < 2) {
-    			throw new ExecutionException("Invalid sysinfo for " + bc + ": " + o);
-    		return Os.fromString(p[1]);
Copied: trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java (from rev 7921, trunk/src/org/griphyn/vdl/karajan/lib/SiteProfile.java)
--- trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java	2014-07-04 06:24:18 UTC (rev 7948)
@@ -0,0 +1,152 @@
+ * Copyright 2012 University of Chicago
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+ * Created on Dec 26, 2006
+package org.griphyn.vdl.karajan.lib;
+import java.util.HashMap;
+import java.util.HashSet;
+import java.util.Map;
+import java.util.Set;
+import k.rt.ExecutionException;
+import k.rt.Stack;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.ChannelRef;
+import org.globus.cog.karajan.analyzer.Signature;
+import org.globus.swift.catalog.site.SwiftContact;
+import org.globus.swift.catalog.types.Os;
+import org.globus.swift.catalog.types.SysInfo;
+public class SiteProperty extends SwiftFunction {
+    public static final Logger logger = Logger.getLogger(SiteProperty.class);
+    private ArgRef<SwiftContact> host;
+    private ArgRef<String> name;
+    private ArgRef<Object> _default;
+    private ChannelRef<Object> cr_vargs;
+	@Override
+    protected Signature getSignature() {
+        return new Signature(params("host", "name", optional("default", null)), returns(channel("...", 1)));
+	public Object function(Stack stack) throws ExecutionException {
+		SwiftContact bc = host.getValue(stack);
+		return getSingle(bc, name.getValue(stack), _default.getValue(stack));
+	public static final String SWIFT_WRAPPER_INTERPRETER = "wrapperInterpreter";
+	public static final String SWIFT_WRAPPER_INTERPRETER_OPTIONS = "wrapperInterpreterOptions";
+	public static final String SWIFT_WRAPPER_SCRIPT = "wrapperScript";
+	public static final String SWIFT_CLEANUP_COMMAND = "cleanupCommand";
+	public static final String SWIFT_CLEANUP_COMMAND_OPTIONS = "cleanupCommandOptions";
+	public static final String SYSINFO_OS = "OS";
+	private static final Map<Os, Map<String, Object>> DEFAULTS;
+	private static final Set<String> DEFAULTS_NAMES;
+	private static void addDefault(Os os, String name, Object value) {
+		DEFAULTS_NAMES.add(name);
+		Map<String, Object> osm = DEFAULTS.get(os);
+		if (osm == null) {
+			osm = new HashMap<String, Object>();
+			DEFAULTS.put(os, osm);
+		osm.put(name, value);
+	private static boolean hasDefault(Os os, String name) {
+			return false;
+		else {
+			return osm.containsKey(name);
+	private static Object getDefault(Os os, String name) {
+			osm = DEFAULTS.get(null);
+		return osm.get(name);
+	static {
+		DEFAULTS = new HashMap<Os, Map<String, Object>>();
+		DEFAULTS_NAMES = new HashSet<String>();
+		addDefault(Os.WINDOWS, SWIFT_WRAPPER_INTERPRETER, "cscript.exe");
+		addDefault(Os.WINDOWS, SWIFT_WRAPPER_SCRIPT, "_swiftwrap.vbs");
+		addDefault(Os.WINDOWS, SWIFT_WRAPPER_INTERPRETER_OPTIONS, new String[] {"//Nologo"});
+		addDefault(Os.WINDOWS, SWIFT_CLEANUP_COMMAND, "cmd.exe");
+		addDefault(Os.WINDOWS, SWIFT_CLEANUP_COMMAND_OPTIONS, new String[] {"/C", "del", "/Q"});
+		addDefault(null, SWIFT_WRAPPER_INTERPRETER, "/bin/bash");
+		addDefault(null, SWIFT_WRAPPER_SCRIPT, "_swiftwrap");
+		addDefault(null, SWIFT_WRAPPER_INTERPRETER_OPTIONS, null);
+		addDefault(null, SWIFT_CLEANUP_COMMAND, "/bin/rm");
+		addDefault(null, SWIFT_CLEANUP_COMMAND_OPTIONS, new String[] {"-rf"});
+	private Object getSingle(SwiftContact bc, String name, Object defval)
+	    throws ExecutionException {
+            String value = getProperty(bc, name);
+            if (value == null) {
+            	Os os = getOS(bc);
+            	if (DEFAULTS_NAMES.contains(name)) {
+            		return getDefault(os, name);
+                else if (SYSINFO_OS.equals(name)) {
+                	return os;
+                else if (defval != null) {
+                    return defval;
+                else {
+                	throw new ExecutionException(this, "Missing profile: " + name);
+            else {
+            	return value;
+    private String getProperty(SwiftContact bc, String name) {
+        Object o = bc.getProperty(name);
+        if (o == null) {
+            return null;
+        else {
+            return o.toString();
+    private Os getOS(SwiftContact bc) {
+    	Object o = bc.getProperty("sysinfo");
+    	if (o == null) {
+    		return Os.LINUX;
+    	else {
+    		return SysInfo.fromString(o.toString()).getOs();
