[Swift-commit] r7947 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Jul 4 01:23:08 CDT 2014
Author: hategan
Date: 2014-07-04 01:23:06 -0500 (Fri, 04 Jul 2014)
New Revision: 7947
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/XS.java
Log:
added java version of the type builder
Added: trunk/src/org/griphyn/vdl/karajan/lib/XS.java
--- trunk/src/org/griphyn/vdl/karajan/lib/XS.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/XS.java	2014-07-04 06:23:06 UTC (rev 7947)
@@ -0,0 +1,250 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Jun 1, 2014
+package org.griphyn.vdl.karajan.lib;
+import java.util.Arrays;
+import java.util.List;
+import k.thr.LWThread;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.ChannelRef;
+import org.globus.cog.karajan.analyzer.CompilationException;
+import org.globus.cog.karajan.analyzer.Scope;
+import org.globus.cog.karajan.analyzer.Signature;
+import org.globus.cog.karajan.analyzer.Var;
+import org.globus.cog.karajan.compiled.nodes.InternalFunction;
+import org.globus.cog.karajan.compiled.nodes.Node;
+import org.globus.cog.karajan.parser.WrapperNode;
+import org.griphyn.vdl.type.DuplicateFieldException;
+import org.griphyn.vdl.type.NoSuchTypeException;
+import org.griphyn.vdl.type.Type;
+import org.griphyn.vdl.type.Types;
+import org.griphyn.vdl.type.impl.TypeImpl;
+import org.griphyn.vdl.type.impl.UnresolvedType;
+ * Type declarations in Swift have no dynamic components. So
+ * everything can be done at compile time
+public class XS {
+    public static class Schema extends InternalFunction {
+        @Override
+        protected Signature getSignature() {
+            return new Signature(params());
+        @Override
+        protected void runBody(LWThread thr) {
+            // do nothing
+        @Override
+        protected Node compileBody(WrapperNode w, Scope argScope, Scope scope) throws CompilationException {
+            try {
+                Types.resolveTypes();
+            catch (NoSuchTypeException e) {
+                throw new CompilationException(w, "Cannot resolve types", e);
+            return null;
+    public static class SimpleType extends InternalFunction {
+        private ArgRef<String> name;
+        private ArgRef<String> type;
+        @Override
+            return new Signature(params("name", "type"));
+        @Override
+            // do nothing
+        @Override
+            Type t = new TypeImpl(name.getValue());
+            try {
+                t.setBaseType(Types.getType(type.getValue()));
+                throw new CompilationException(w, "Unknown type: '" + type.getValue() + "'");
+            Types.addType(t);
+            return null;
+    public static class Restriction extends InternalFunction {
+        private ArgRef<String> base;
+        @Override
+            return new Signature(params("base"));
+        @Override
+            // do nothing
+         * type = last(split(base, ":"))
+        @Override
+            String base = this.base.getValue();
+            int ix = base.lastIndexOf(':');
+            Var ret = scope.parent.lookupParam("type");
+            ret.setValue(base.substring(ix + 1));
+            return null;
+    public static class ComplexType extends InternalFunction {
+        private ChannelRef<Object> c_vargs;
+        @Override
+            return new Signature(params("name", "..."));
+        @Override
+            // do nothing
+         * node := newComplexNode(name)
+         *   for(field, ...) {
+         *       (name, type) := each(field)
+         *       addField(node, name, type)
+         *   addNode(node)
+        @Override
+            List<Object> args = argScope.lookupChannel("...").getAll();
+            for (Object o : args) {
+                @SuppressWarnings("unchecked")
+                List<Object> l = (List<Object>) o;
+                String fname = (String) l.get(0);
+                Type type = (Type) l.get(1);
+                try {
+                    t.addField(fname, type);
+                catch (DuplicateFieldException e) {
+                    throw new CompilationException(w, "Field '" + fname + "' is alread defined for type '" + name + "'");
+            Types.addType(t);
+            return null;
+    public static class Sequence extends InternalFunction {
+        private ArgRef<String> minOccurs;
+        private ArgRef<String> maxOccurs;
+        @Override
+            return new Signature(params(optional("minOccurs", "0"), optional("maxOccurs", "0"), "..."));
+        @Override
+            // do nothing
+         * (name, type) := each(first(...))
+         *   if (maxOccurs == "unbounded") {
+         *       list(name, UnresolvedType(type, true))
+         *   else {
+         *       each(...)
+        @Override
+            Var.Channel crv = scope.parent.lookupChannel("...");
+            if (maxOccurs.getValue().equals("unbounded")) {
+                List<Object> first = (List<Object>) args.get(0);
+                String name = (String) first.get(0);
+                String type = (String) first.get(1);
+                crv.append(Arrays.asList(name, new UnresolvedType(type)));
+            else {
+                    crv.append(o);
+            return null;
+    public static class Element extends InternalFunction {
+        @Override
+        @Override
+            // do nothing
+         * type := last(split(type, ":"))
+         * list(name, UnresolvedType(type, false))
+        @Override
+            String type = this.type.getValue();
+            String name = this.name.getValue();
+            int ix = type.lastIndexOf(':');
+            crv.append(Arrays.asList(name, new UnresolvedType(type.substring(ix + 1))));
+            return null;
