[Swift-commit] r7754 - in trunk: libexec src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib/swiftscript
yadunandb at ci.uchicago.edu yadunandb at ci.uchicago.edu
Thu Apr 3 16:32:19 CDT 2014
Author: yadunandb
Date: 2014-04-03 16:32:18 -0500 (Thu, 03 Apr 2014)
New Revision: 7754
Modified:
   trunk/libexec/swift-lib.k
   trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
Committing changes for system built-in command.
Allows for easy specification of files to mappers using common unix commands.
Tested with "ls" and "find <dir> -type f"
Tests in next commit
Modified: trunk/libexec/swift-lib.k
--- trunk/libexec/swift-lib.k	2014-04-02 22:04:22 UTC (rev 7753)
+++ trunk/libexec/swift-lib.k	2014-04-03 21:32:18 UTC (rev 7754)
@@ -9,6 +9,7 @@
 	export(strcut, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$StrCut"))
 	export(strstr, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$StrStr"))
 	export(strsplit, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$StrSplit"))
+	export(system, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$ExecSystem"))
     export(strjoin, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$StrJoin"))
 	export(regexp, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$Regexp"))
 	export(toInt, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$ToInt"))
@@ -21,7 +22,7 @@
 	export(trace, def("org.griphyn.vdl.karajan.lib.swiftscript.Misc$Trace"))
 	export(tracef, def("org.griphyn.vdl.karajan.lib.swiftscript.Tracef"))
 	export(fprintf, def("org.griphyn.vdl.karajan.lib.swiftscript.Fprintf"))
 	/* included for backwards compatibility */
 	export(readdata, def("org.griphyn.vdl.karajan.lib.swiftscript.ReadData"))
 	export(readdata2, def("org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"))
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2014-04-02 22:04:22 UTC (rev 7753)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2014-04-03 21:32:18 UTC (rev 7754)
@@ -197,6 +197,7 @@
 		add(functionsMap, "strcut", returns(STRING), args(STRING, STRING));
 		add(functionsMap, "strstr", returns(INT), args(STRING, STRING));
 		add(functionsMap, "strsplit", returns(STRING_ARRAY), args(STRING, STRING));
+		add(functionsMap, "system", returns(STRING_ARRAY), args(STRING));
 		add(functionsMap, "strjoin", returns(STRING), args(ANY, STRING));
 		add(functionsMap, "toInt", returns(INT), args(ANY));
 		add(functionsMap, "toFloat", returns(FLOAT), args(ANY));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-04-02 22:04:22 UTC (rev 7753)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-04-03 21:32:18 UTC (rev 7754)
@@ -18,6 +18,9 @@
 package org.griphyn.vdl.karajan.lib.swiftscript;
 import java.io.IOException;
+import java.io.InputStreamReader;
+import java.io.BufferedReader;
 import java.util.Map;
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -277,6 +280,51 @@
+    public static class ExecSystem extends AbstractSingleValuedFunction {
+        private ArgRef<AbstractDataNode> input;
+        //private ArgRef<AbstractDataNode> pattern;
+        @Override
+	    protected Signature getSignature() {
+            return new Signature(params("input"));
+        @Override
+	    public Object function(Stack stack) {
+		AbstractDataNode hinput = this.input.getValue(stack);
+		String input     = SwiftFunction.unwrap(this, hinput);
+		DSHandle handle  = new RootArrayDataNode(Types.STRING.arrayType());
+		StringBuffer out = new StringBuffer();
+		Process p;
+		int i = 0;
+		try {
+		    p = Runtime.getRuntime().exec(input);
+		    p.waitFor();
+		    BufferedReader reader = new BufferedReader( new InputStreamReader(p.getInputStream()));
+		    String line = "";
+		while ( (line = reader.readLine()) != null ) {
+		    DSHandle el;
+		    el = handle.getField(i++);
+		    el.setValue(line);
+		    //out.append(line + "\n");
+		} catch (Exception e) {
+		    e.printStackTrace();
+		handle.closeDeep();
+		if (PROVENANCE_ENABLED) {
+		    int provid = SwiftFunction.nextProvenanceID();
+		    SwiftFunction.logProvenanceResult(provid, handle, "system");
+		    SwiftFunction.logProvenanceParameter(provid, hinput, "input");
+		return handle;
 	public static class StrSplit extends AbstractSingleValuedFunction {
@@ -601,7 +649,7 @@
             return handle;
 	public static class Length extends AbstractSingleValuedFunction {
         private ArgRef<AbstractDataNode> array;
