[Swift-commit] r7753 - trunk/docs/userguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Apr 2 17:04:22 CDT 2014
Author: davidk
Date: 2014-04-02 17:04:22 -0500 (Wed, 02 Apr 2014)
New Revision: 7753
Modified:
   trunk/docs/userguide/configuration
Log:
Fix formatting
Modified: trunk/docs/userguide/configuration
--- trunk/docs/userguide/configuration	2014-03-28 18:10:53 UTC (rev 7752)
+++ trunk/docs/userguide/configuration	2014-04-02 22:04:22 UTC (rev 7753)
@@ -318,9 +318,9 @@
 |true, false
 |true
 |By default, Swift will generate a run directory that contains logs, scheduler submit scripts,
-|debug directories, and other files associated with a particular Swift run. Setting this value
-|to false disables the creation of run directories and causes all logs and directories to be
-|created in the current working directory.
+debug directories, and other files associated with a particular Swift run. Setting this value
+to false disables the creation of run directories and causes all logs and directories to be
+created in the current working directory.
 |execution.retries
 |Positive integer
