[Swift-commit] cog r3831
swift at ci.uchicago.edu swift at ci.uchicago.edu
Thu Nov 14 13:30:24 CST 2013
r3831 | yadunand | 2013-11-14 13:29:00 -0600 (Thu, 14 Nov 2013) | 3 lines
Minor changes
Index: modules/provider-coaster-c-client/tests/coasters/coaster-service.conf
--- modules/provider-coaster-c-client/tests/coasters/coaster-service.conf	(revision 3830)
+++ modules/provider-coaster-c-client/tests/coasters/coaster-service.conf	(working copy)
@@ -12,7 +12,7 @@
 export WORKER_USERNAME=$USER
 # Worker host names for ssh
-export WORKER_HOSTS="crush.mcs.anl.gov grind.mcs.anl.gov"
+export WORKER_HOSTS="crush.mcs.anl.gov grind.mcs.anl.gov steamroller.mcs.anl.gov crank.mcs.anl.gov thwomp.mcs.anl.gov"
 # Directory to keep log files, relative to working directory when launching start-coaster-service
 export LOG_DIR=logs
Index: modules/provider-coaster-c-client/tests/coasters/start-coaster-service.log
--- modules/provider-coaster-c-client/tests/coasters/start-coaster-service.log	(revision 3830)
+++ modules/provider-coaster-c-client/tests/coasters/start-coaster-service.log	(working copy)
@@ -1,129118 +0,0 @@
-Running /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/coaster-service -nosec -portfile /tmp/tmp.bWAGiTa8uX -localportfile /tmp/tmp.IumeBPaF2V -passive
-Switching log to: cps-2013-11-05_20-20-02.log
-2013-11-05 20:20:02,502-0600 WARN  CoasterPersistentService Switching log to: cps-2013-11-05_20-20-02.log
-Local contacts: [http://140.221.8.81:45138]
-2013-11-05 20:20:02,528-0600 INFO  Settings Local contacts: [http://140.221.8.81:45138]
-Starting... id=1105-2008020
-2013-11-05 20:20:02,541-0600 INFO  BlockQueueProcessor Starting... id=1105-2008020
-Started local service: http://140.221.8.81:45138
-2013-11-05 20:20:02,542-0600 INFO  CoasterService Started local service: http://140.221.8.81:45138
-Started coaster service: http://140.221.8.81:45699
-2013-11-05 20:20:02,542-0600 INFO  CoasterService Started coaster service: http://140.221.8.81:45699
-Worker connection URL: http://140.221.8.81:45138
-Running ssh yadunand at crush.mcs.anl.gov mkdir -p /homes/yadunand
-Running scp /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/worker.pl yadunand at crush.mcs.anl.gov:/homes/yadunand
-Running ssh yadunand at crush.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:45138 crush.mcs.anl.gov /homes/yadunand/logs
-Running ssh yadunand at grind.mcs.anl.gov mkdir -p /homes/yadunand
-Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-11-05 20:20:05,243-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.62:51960]
-2013-11-05 20:20:05,248-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.62:51960]
-Received registration: blockid = crush.mcs.anl.gov, url = crush
-2013-11-05 20:20:05,253-0600 INFO  LocalTCPService Received registration: blockid = crush.mcs.anl.gov, url = crush
-MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:51960]
-2013-11-05 20:20:05,264-0600 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:51960]
-2013-11-05 20:20:05,267-0600 DEBUG Cpu worker started: block=crush.mcs.anl.gov host=crush id=0
-2013-11-05 20:20:05,268-0600 DEBUG Cpu ready for work: block=crush.mcs.anl.gov id=0
-Started CPU 0:1383704405s
-2013-11-05 20:20:05,269-0600 INFO  Block Started CPU 0:1383704405s
-Started worker crush.mcs.anl.gov:000000
-2013-11-05 20:20:05,269-0600 INFO  Block Started worker crush.mcs.anl.gov:000000
-2013-11-05 20:20:05,269-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-05 20:20:05,269-0600 INFO  AbstractStreamCoasterChannel Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-05 20:20:05,270-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-Handler(tag: 7420, REGISTER) unregistering (send)
-2013-11-05 20:20:05,273-0600 INFO  RequestHandler Handler(tag: 7420, REGISTER) unregistering (send)
-Running scp /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/worker.pl yadunand at grind.mcs.anl.gov:/homes/yadunand
-Running ssh yadunand at grind.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:45138 grind.mcs.anl.gov /homes/yadunand/logs
-Adjusting buffer size to 8650752 for 2 sockets
-2013-11-05 20:20:06,395-0600 INFO  TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
-2013-11-05 20:20:06,395-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.74:48379]
-2013-11-05 20:20:06,395-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.74:48379]
-Received registration: blockid = grind.mcs.anl.gov, url = grind
-2013-11-05 20:20:06,396-0600 INFO  LocalTCPService Received registration: blockid = grind.mcs.anl.gov, url = grind
-MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:48379]
-2013-11-05 20:20:06,396-0600 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:48379]
-2013-11-05 20:20:06,396-0600 DEBUG Cpu worker started: block=grind.mcs.anl.gov host=grind id=0
-2013-11-05 20:20:06,396-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Started CPU 0:1383704406s
-2013-11-05 20:20:06,396-0600 INFO  Block Started CPU 0:1383704406s
-2013-11-05 20:20:06,396-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Started worker grind.mcs.anl.gov:000000
-2013-11-05 20:20:06,396-0600 INFO  Block Started worker grind.mcs.anl.gov:000000
-2013-11-05 20:20:06,397-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Handler(tag: 7297, REGISTER) unregistering (send)
-2013-11-05 20:20:06,397-0600 INFO  RequestHandler Handler(tag: 7297, REGISTER) unregistering (send)
-Shutting down service...
-Shutting down blocks
-2013-11-05 20:20:15,583-0600 INFO  BlockQueueProcessor Shutting down blocks
-Shutting down block Block crush.mcs.anl.gov (1x4611686018427388.000s)
-2013-11-05 20:20:15,583-0600 INFO  Block Shutting down block Block crush.mcs.anl.gov (1x4611686018427388.000s)
-Adding short shutdown watchdog: count = 1, workers = 1, now = true
-2013-11-05 20:20:15,585-0600 INFO  Block Adding short shutdown watchdog: count = 1, workers = 1, now = true
-Shutting down block Block grind.mcs.anl.gov (1x4611686018427388.000s)
-2013-11-05 20:20:15,585-0600 INFO  Block Shutting down block Block grind.mcs.anl.gov (1x4611686018427388.000s)
-Node [crush] 0 shut down successfully
-2013-11-05 20:20:15,586-0600 INFO  Node Node [crush] 0 shut down successfully
-Shutdown sequence completed
-2013-11-05 20:20:15,586-0600 INFO  CoasterService Shutdown sequence completed
-crush.mcs.anl.gov-000000: Channel shut down
-2013-11-05 20:20:15,586-0600 INFO  AbstractTCPChannel crush.mcs.anl.gov-000000: Channel shut down
-MetaChannel [context: worker-1, boundTo: TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]] binding to NullChannel
-2013-11-05 20:20:15,586-0600 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]] binding to NullChannel
-Using threaded sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-05 20:20:15,587-0600 INFO  AbstractStreamCoasterChannel Using threaded sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-05 20:20:15,587-0600 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]] binding to NullChannel
-crush.mcs.anl.gov-000000: Channel terminated
-2013-11-05 20:20:15,587-0600 INFO  AbstractTCPChannel crush.mcs.anl.gov-000000: Channel terminated
-Node [grind] 0 shut down successfully
-2013-11-05 20:20:15,587-0600 INFO  Node Node [grind] 0 shut down successfully
-grind.mcs.anl.gov-000000: Channel shut down
-2013-11-05 20:20:15,588-0600 INFO  AbstractTCPChannel grind.mcs.anl.gov-000000: Channel shut down
-MetaChannel [context: worker-2, boundTo: TCPChannel [type: server, contact: grind.mcs.anl.gov-000000]] binding to NullChannel
-2013-11-05 20:20:15,588-0600 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: TCPChannel [type: server, contact: grind.mcs.anl.gov-000000]] binding to NullChannel
-grind.mcs.anl.gov-000000: Channel terminated
-2013-11-05 20:20:15,588-0600 INFO  AbstractTCPChannel grind.mcs.anl.gov-000000: Channel terminated
-Running /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/coaster-service -nosec -portfile /tmp/tmp.8oWuk6Txou -localportfile /tmp/tmp.n9OHUNSS2t -passive
-Switching log to: cps-2013-11-05_20-20-53.log
-2013-11-05 20:20:53,320-0600 WARN  CoasterPersistentService Switching log to: cps-2013-11-05_20-20-53.log
-Local contacts: [http://140.221.8.81:57384]
-2013-11-05 20:20:53,346-0600 INFO  Settings Local contacts: [http://140.221.8.81:57384]
-Starting... id=1105-2008530
-2013-11-05 20:20:53,359-0600 INFO  BlockQueueProcessor Starting... id=1105-2008530
-Started local service: http://140.221.8.81:57384
-2013-11-05 20:20:53,359-0600 INFO  CoasterService Started local service: http://140.221.8.81:57384
-Started coaster service: http://140.221.8.81:59330
-2013-11-05 20:20:53,360-0600 INFO  CoasterService Started coaster service: http://140.221.8.81:59330
-Worker connection URL: http://140.221.8.81:57384
-Running ssh yadunand at crush.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:57384 crush.mcs.anl.gov /homes/yadunand/logs
-2013-11-05 20:20:56,215-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.62:45374]
-2013-11-05 20:20:56,220-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.62:45374]
-2013-11-05 20:20:56,225-0600 INFO  LocalTCPService Received registration: blockid = crush.mcs.anl.gov, url = crush
-MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:45374]
-2013-11-05 20:20:56,235-0600 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:45374]
-2013-11-05 20:20:56,238-0600 DEBUG Cpu worker started: block=crush.mcs.anl.gov host=crush id=0
-2013-11-05 20:20:56,239-0600 DEBUG Cpu ready for work: block=crush.mcs.anl.gov id=0
-Started CPU 0:1383704456s
-2013-11-05 20:20:56,240-0600 INFO  Block Started CPU 0:1383704456s
-2013-11-05 20:20:56,240-0600 INFO  Block Started worker crush.mcs.anl.gov:000000
-2013-11-05 20:20:56,240-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-05 20:20:56,240-0600 INFO  AbstractStreamCoasterChannel Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-05 20:20:56,241-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-Handler(tag: 1498, REGISTER) unregistering (send)
-2013-11-05 20:20:56,244-0600 INFO  RequestHandler Handler(tag: 1498, REGISTER) unregistering (send)
-Running ssh yadunand at grind.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:57384 grind.mcs.anl.gov /homes/yadunand/logs
-2013-11-05 20:20:57,075-0600 INFO  TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
-2013-11-05 20:20:57,076-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.74:49786]
-2013-11-05 20:20:57,076-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.74:49786]
-2013-11-05 20:20:57,076-0600 INFO  LocalTCPService Received registration: blockid = grind.mcs.anl.gov, url = grind
-MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:49786]
-2013-11-05 20:20:57,076-0600 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:49786]
-2013-11-05 20:20:57,077-0600 DEBUG Cpu worker started: block=grind.mcs.anl.gov host=grind id=0
-2013-11-05 20:20:57,077-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Started CPU 0:1383704457s
-2013-11-05 20:20:57,077-0600 INFO  Block Started CPU 0:1383704457s
-2013-11-05 20:20:57,077-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-05 20:20:57,077-0600 INFO  Block Started worker grind.mcs.anl.gov:000000
-2013-11-05 20:20:57,077-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Handler(tag: 9070, REGISTER) unregistering (send)
-2013-11-05 20:20:57,077-0600 INFO  RequestHandler Handler(tag: 9070, REGISTER) unregistering (send)
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:21:32,190-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:21:33,524-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:21:41,681-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Multiplexer 0 started
-2013-11-05 20:21:41,684-0600 INFO  Multiplexer Multiplexer 0 started
-Multiplexer 1 started
-2013-11-05 20:21:41,684-0600 INFO  Multiplexer Multiplexer 1 started
-(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:58556] for addition
-2013-11-05 20:21:41,684-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:58556] for addition
-Channel started: TCPChannel [type: server, contact: 140.221.8.81:58556]
-2013-11-05 20:21:41,685-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:58556]
-Channel id: channel-1-u612953fc-1422b371dca--8000
-2013-11-05 20:21:41,706-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u612953fc-1422b371dca--8000
-MetaChannel [context: cps-58556, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:58556]
-2013-11-05 20:21:41,706-0600 INFO  MetaChannel MetaChannel [context: cps-58556, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:58556]
-Using threaded sender for TCPChannel [type: server, contact: 140.221.8.81:58556]
-2013-11-05 20:21:41,707-0600 INFO  AbstractStreamCoasterChannel Using threaded sender for TCPChannel [type: server, contact: 140.221.8.81:58556]
-Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-2013-11-05 20:21:41,707-0600 INFO  RequestHandler Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
-2013-11-05 20:21:41,749-0600 INFO  RequestHandler Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
-Handler(tag: 17769, SUBMITJOB) unregistering (send)
-2013-11-05 20:21:41,842-0600 INFO  RequestHandler Handler(tag: 17769, SUBMITJOB) unregistering (send)
-Handler(tag: 17770, SUBMITJOB) unregistering (send)
-2013-11-05 20:21:41,843-0600 INFO  RequestHandler Handler(tag: 17770, SUBMITJOB) unregistering (send)
-2013-11-05 20:21:41,883-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-crush.mcs.anl.gov:0 (quality: 1.0) submitting urn:job-0-1383704501835-1383704501836: /bin/bash /homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/wrapper.sh
-2013-11-05 20:21:41,884-0600 INFO  Cpu crush.mcs.anl.gov:0 (quality: 1.0) submitting urn:job-0-1383704501835-1383704501836: /bin/bash /homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/wrapper.sh
-2013-11-05 20:21:41,929-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 1.0) submitting urn:job-1-1383704501838-1383704501839: /bin/bash /homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/wrapper.sh
-2013-11-05 20:21:41,929-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 1.0) submitting urn:job-1-1383704501838-1383704501839: /bin/bash /homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/wrapper.sh
-LOG: /homes/yadunand/logs/worker-crush.mcs.anl.gov.log
-LOG: /homes/yadunand/logs/worker-grind.mcs.anl.gov.log
-2013-11-05 20:21:41,937-0600 DEBUG Cpu Active workerid=crush.mcs.anl.gov:000000
-Handler(tag: 1499, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:41,939-0600 INFO  RequestHandler Handler(tag: 1499, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:41,939-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 9071, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:41,939-0600 INFO  RequestHandler Handler(tag: 9071, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:46,980-0600 DEBUG Cpu Completed
-grind.mcs.anl.gov:0 jobTerminated
-2013-11-05 20:21:46,980-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-05 20:21:46,980-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 9072, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:46,980-0600 INFO  RequestHandler Handler(tag: 9072, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:46,981-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-05 20:21:46,981-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-05 20:21:46,983-0600 DEBUG Cpu Completed
-crush.mcs.anl.gov:0 jobTerminated
-2013-11-05 20:21:46,983-0600 INFO  Cpu crush.mcs.anl.gov:0 jobTerminated
-2013-11-05 20:21:46,984-0600 DEBUG Cpu ready for work: block=crush.mcs.anl.gov id=0
-Handler(tag: 1500, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:46,984-0600 INFO  RequestHandler Handler(tag: 1500, JOBSTATUS) unregistering (send)
-2013-11-05 20:21:46,984-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-05 20:21:46,984-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-05 20:21:51,695-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-05 20:22:01,707-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:22:05,847-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:22:07,798-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-05 20:22:11,721-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-05 20:22:21,734-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-05 20:22:31,748-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-05 20:22:38,170-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-05 20:22:41,760-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-05 20:22:43,408-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-05 20:22:51,772-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-05 20:23:01,784-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-05 20:23:10,493-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-05 20:23:11,796-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-05 20:23:19,018-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-05 20:23:21,807-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-05 20:23:31,818-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-05 20:23:41,829-0600 INFO  Multiplexer Avg stream buf: 0
-Notifying commands and handlers about exception
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131105-202141.842, now=131105-202342.681, channel=TCPChannel [type: server, contact: 140.221.8.81:58556]
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
-	at java.util.TimerThread.mainLoop(Timer.java:534)
-	at java.util.TimerThread.run(Timer.java:484)
-2013-11-05 20:23:42,684-0600 INFO  ChannelContext Notifying commands and handlers about exception
-=> Command(tag: 1, RLOG)
-2013-11-05 20:23:42,687-0600 INFO  ChannelContext => Command(tag: 1, RLOG)
-=> Command(tag: 2, JOBSTATUS)
-2013-11-05 20:23:42,687-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-Client could not properly process notification: null
-2013-11-05 20:23:42,687-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 3, JOBSTATUS)
-2013-11-05 20:23:42,687-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-=> Command(tag: 4, JOBSTATUS)
-2013-11-05 20:23:42,687-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-05 20:23:42,688-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 5, JOBSTATUS)
-2013-11-05 20:23:42,688-0600 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
-=> Command(tag: 6, JOBSTATUS)
-2013-11-05 20:23:42,688-0600 INFO  ChannelContext => Command(tag: 6, JOBSTATUS)
-=> Command(tag: 7, JOBSTATUS)
-2013-11-05 20:23:42,689-0600 INFO  ChannelContext => Command(tag: 7, JOBSTATUS)
-2013-11-05 20:23:42,689-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 8, JOBSTATUS)
-2013-11-05 20:23:42,689-0600 INFO  ChannelContext => Command(tag: 8, JOBSTATUS)
-=> Command(tag: 9, JOBSTATUS)
-2013-11-05 20:23:42,689-0600 INFO  ChannelContext => Command(tag: 9, JOBSTATUS)
-Channel config: null -> {keepalive=null}
-2013-11-05 20:23:42,690-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 140.221.8.81:58556] handling channel exception
-2013-11-05 20:23:42,690-0600 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:58556] handling channel exception
-null: Channel shut down
-2013-11-05 20:23:42,690-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-58556, boundTo: TCPChannel [type: server, contact: 140.221.8.81:58556]] binding to NullChannel
-2013-11-05 20:23:42,691-0600 INFO  MetaChannel MetaChannel [context: cps-58556, boundTo: TCPChannel [type: server, contact: 140.221.8.81:58556]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:58556]
-2013-11-05 20:23:42,691-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:58556]
-2013-11-05 20:23:42,691-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-05 20:23:42,691-0600 INFO  ChannelContext => Command(tag: 1, RLOG)
-Channel is closed. Removing.
-2013-11-05 20:23:42,691-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-05 20:23:42,692-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-Exception in channel step
-java.io.IOException: Stream closed.
-	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
-	at java.net.SocketInputStream.available(SocketInputStream.java:234)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
-	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
-2013-11-05 20:23:42,692-0600 INFO  Multiplexer Exception in channel step
-2013-11-05 20:23:42,692-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-05 20:23:42,692-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-05 20:23:42,693-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-05 20:23:42,693-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-05 20:23:42,693-0600 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
-2013-11-05 20:23:42,693-0600 INFO  ChannelContext => Command(tag: 6, JOBSTATUS)
-2013-11-05 20:23:42,694-0600 INFO  ChannelContext => Command(tag: 7, JOBSTATUS)
-2013-11-05 20:23:42,694-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-05 20:23:42,694-0600 INFO  ChannelContext => Command(tag: 8, JOBSTATUS)
-2013-11-05 20:23:42,694-0600 INFO  ChannelContext => Command(tag: 9, JOBSTATUS)
-Channel exception handled
-2013-11-05 20:23:42,694-0600 INFO  ChannelManager Channel exception handled
-2013-11-05 20:23:42,695-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-05 20:23:42,695-0600 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:58556] handling channel exception
-Channel already shut down
-2013-11-05 20:23:42,695-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:58556]
-2013-11-05 20:23:42,695-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:58556]
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 20:23:42,816-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:23:51,842-0600 INFO  Multiplexer No streams
-2013-11-05 20:23:54,628-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:24:01,850-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:24:11,861-0600 INFO  Multiplexer No streams
-2013-11-05 20:24:15,140-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:24:21,870-0600 INFO  Multiplexer No streams
-2013-11-05 20:24:30,238-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:24:31,878-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:24:41,885-0600 INFO  Multiplexer No streams
-2013-11-05 20:24:47,463-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:24:51,893-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:25:01,901-0600 INFO  Multiplexer No streams
-2013-11-05 20:25:05,848-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:25:11,909-0600 INFO  Multiplexer No streams
-2013-11-05 20:25:19,786-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:25:21,916-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:25:31,924-0600 INFO  Multiplexer No streams
-2013-11-05 20:25:41,458-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:25:41,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:25:51,939-0600 INFO  Multiplexer No streams
-2013-11-05 20:25:52,109-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:26:01,946-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:26:11,954-0600 INFO  Multiplexer No streams
-2013-11-05 20:26:17,068-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:26:21,961-0600 INFO  Multiplexer No streams
-2013-11-05 20:26:24,431-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:26:31,969-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:26:41,976-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:26:51,983-0600 INFO  Multiplexer No streams
-2013-11-05 20:26:52,678-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:26:56,755-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:27:01,990-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:27:11,997-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:27:22,005-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 20:27:28,287-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 20:27:29,078-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:27:32,012-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:27:42,020-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:27:52,028-0600 INFO  Multiplexer No streams
-2013-11-05 20:28:01,401-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:28:02,036-0600 INFO  Multiplexer No streams
-2013-11-05 20:28:03,898-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:28:12,044-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:28:22,052-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:28:32,059-0600 INFO  Multiplexer No streams
-2013-11-05 20:28:33,724-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:28:39,508-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:28:42,067-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:28:52,075-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:29:02,083-0600 INFO  Multiplexer No streams
-2013-11-05 20:29:06,047-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:29:12,091-0600 INFO  Multiplexer No streams
-2013-11-05 20:29:15,117-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:29:22,098-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:29:32,106-0600 INFO  Multiplexer No streams
-2013-11-05 20:29:38,370-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:29:42,114-0600 INFO  Multiplexer No streams
-2013-11-05 20:29:50,728-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:29:52,122-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:30:02,130-0600 INFO  Multiplexer No streams
-2013-11-05 20:30:10,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:30:12,138-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:30:22,145-0600 INFO  Multiplexer No streams
-2013-11-05 20:30:26,338-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:30:32,153-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:30:42,161-0600 INFO  Multiplexer No streams
-2013-11-05 20:30:43,016-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:30:52,169-0600 INFO  Multiplexer No streams
-2013-11-05 20:31:01,947-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:31:02,177-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:31:12,184-0600 INFO  Multiplexer No streams
-2013-11-05 20:31:15,339-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:31:22,192-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:31:32,200-0600 INFO  Multiplexer No streams
-2013-11-05 20:31:37,558-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:31:42,208-0600 INFO  Multiplexer No streams
-2013-11-05 20:31:47,661-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:31:52,216-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:32:02,223-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:32:12,231-0600 INFO  Multiplexer No streams
-2013-11-05 20:32:13,168-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:32:19,985-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:32:22,239-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:32:32,247-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:32:42,255-0600 INFO  Multiplexer No streams
-2013-11-05 20:32:48,778-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:32:52,262-0600 INFO  Multiplexer No streams
-2013-11-05 20:32:52,308-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:33:02,270-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:33:12,278-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:33:22,286-0600 INFO  Multiplexer No streams
-2013-11-05 20:33:24,388-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:33:24,631-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:33:32,293-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:33:42,301-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:33:52,309-0600 INFO  Multiplexer No streams
-2013-11-05 20:33:56,954-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:33:59,997-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:34:02,317-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:34:12,325-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:34:22,333-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-05 20:34:29,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-05 20:34:32,340-0600 INFO  Multiplexer No streams
-2013-11-05 20:34:35,608-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:34:42,348-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:34:52,356-0600 INFO  Multiplexer No streams
-2013-11-05 20:35:01,600-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:35:02,364-0600 INFO  Multiplexer No streams
-2013-11-05 20:35:11,218-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:35:12,371-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:35:22,379-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:35:32,387-0600 INFO  Multiplexer No streams
-2013-11-05 20:35:33,923-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:35:42,395-0600 INFO  Multiplexer No streams
-2013-11-05 20:35:46,828-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:35:52,402-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:36:02,410-0600 INFO  Multiplexer No streams
-2013-11-05 20:36:06,246-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:36:12,418-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:36:22,425-0600 INFO  Multiplexer No streams
-2013-11-05 20:36:22,438-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:36:32,433-0600 INFO  Multiplexer No streams
-2013-11-05 20:36:38,570-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:36:42,441-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:36:52,448-0600 INFO  Multiplexer No streams
-2013-11-05 20:36:58,048-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:37:02,456-0600 INFO  Multiplexer No streams
-2013-11-05 20:37:10,893-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:37:12,463-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:37:22,471-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:37:32,479-0600 INFO  Multiplexer No streams
-2013-11-05 20:37:33,658-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:37:42,487-0600 INFO  Multiplexer No streams
-2013-11-05 20:37:43,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:37:52,494-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:38:02,502-0600 INFO  Multiplexer No streams
-2013-11-05 20:38:09,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:38:12,510-0600 INFO  Multiplexer No streams
-2013-11-05 20:38:15,539-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:38:22,518-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:38:32,526-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:38:42,534-0600 INFO  Multiplexer No streams
-2013-11-05 20:38:44,878-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:38:47,862-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:38:52,541-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:39:02,549-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:39:12,557-0600 INFO  Multiplexer No streams
-2013-11-05 20:39:20,185-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:39:20,488-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:39:22,565-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:39:32,572-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:39:42,580-0600 INFO  Multiplexer No streams
-2013-11-05 20:39:52,508-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:39:52,588-0600 INFO  Multiplexer No streams
-2013-11-05 20:39:56,098-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:40:02,596-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:40:12,604-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:40:22,611-0600 INFO  Multiplexer No streams
-2013-11-05 20:40:24,831-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:40:31,708-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:40:32,619-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:40:42,627-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:40:52,635-0600 INFO  Multiplexer No streams
-2013-11-05 20:40:57,154-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:41:02,642-0600 INFO  Multiplexer No streams
-2013-11-05 20:41:07,318-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:41:12,650-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:41:22,658-0600 INFO  Multiplexer No streams
-2013-11-05 20:41:29,477-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:41:32,666-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:41:42,673-0600 INFO  Multiplexer No streams
-2013-11-05 20:41:42,928-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:41:52,681-0600 INFO  Multiplexer No streams
-2013-11-05 20:42:01,800-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:42:02,689-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:42:12,697-0600 INFO  Multiplexer No streams
-2013-11-05 20:42:18,538-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:42:22,704-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:42:32,712-0600 INFO  Multiplexer No streams
-2013-11-05 20:42:34,123-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:42:42,720-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:42:52,728-0600 INFO  Multiplexer No streams
-2013-11-05 20:42:54,148-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:43:02,735-0600 INFO  Multiplexer No streams
-2013-11-05 20:43:06,446-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:43:12,743-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:43:22,751-0600 INFO  Multiplexer No streams
-2013-11-05 20:43:29,758-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:43:32,759-0600 INFO  Multiplexer No streams
-2013-11-05 20:43:38,769-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:43:42,766-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:43:52,774-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:44:02,782-0600 INFO  Multiplexer No streams
-2013-11-05 20:44:05,368-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:44:11,092-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:44:12,789-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:44:22,797-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:44:32,805-0600 INFO  Multiplexer No streams
-2013-11-05 20:44:40,978-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:44:42,813-0600 INFO  Multiplexer No streams
-2013-11-05 20:44:43,415-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:44:52,820-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:45:02,829-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:45:12,837-0600 INFO  Multiplexer No streams
-2013-11-05 20:45:15,738-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:45:16,588-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:45:22,845-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:45:32,853-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:45:42,860-0600 INFO  Multiplexer No streams
-2013-11-05 20:45:48,061-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:45:52,198-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:45:52,868-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:46:02,876-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:46:12,884-0600 INFO  Multiplexer No streams
-2013-11-05 20:46:20,384-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:46:22,892-0600 INFO  Multiplexer No streams
-2013-11-05 20:46:27,808-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:46:32,899-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:46:42,907-0600 INFO  Multiplexer No streams
-2013-11-05 20:46:52,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:46:52,915-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:47:02,923-0600 INFO  Multiplexer No streams
-2013-11-05 20:47:03,418-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:47:12,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:47:22,938-0600 INFO  Multiplexer No streams
-2013-11-05 20:47:25,030-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:47:32,946-0600 INFO  Multiplexer No streams
-2013-11-05 20:47:39,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:47:42,954-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:47:52,962-0600 INFO  Multiplexer No streams
-2013-11-05 20:47:57,353-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:48:02,970-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:48:12,977-0600 INFO  Multiplexer No streams
-2013-11-05 20:48:14,638-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:48:22,985-0600 INFO  Multiplexer No streams
-2013-11-05 20:48:29,676-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:48:32,993-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:48:43,001-0600 INFO  Multiplexer No streams
-2013-11-05 20:48:50,248-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:48:53,008-0600 INFO  Multiplexer No streams
-2013-11-05 20:49:01,999-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:49:03,017-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:49:13,025-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:49:23,034-0600 INFO  Multiplexer No streams
-2013-11-05 20:49:25,858-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:49:33,042-0600 INFO  Multiplexer No streams
-2013-11-05 20:49:34,322-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:49:43,050-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:49:53,058-0600 INFO  Multiplexer No streams
-2013-11-05 20:50:01,468-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:50:03,067-0600 INFO  Multiplexer No streams
-2013-11-05 20:50:06,645-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:50:13,075-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:50:23,082-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:50:33,090-0600 INFO  Multiplexer No streams
-2013-11-05 20:50:37,078-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:50:38,968-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:50:43,098-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:50:53,106-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:51:03,113-0600 INFO  Multiplexer No streams
-2013-11-05 20:51:11,291-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 20:51:12,687-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:51:13,121-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:51:23,128-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:51:33,136-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:51:43,144-0600 INFO  Multiplexer No streams
-2013-11-05 20:51:43,613-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 20:51:48,298-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:51:53,151-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:52:03,159-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:52:13,167-0600 INFO  Multiplexer No streams
-2013-11-05 20:52:15,937-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:52:23,174-0600 INFO  Multiplexer No streams
-2013-11-05 20:52:23,908-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:52:33,182-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:52:43,190-0600 INFO  Multiplexer No streams
-2013-11-05 20:52:48,260-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:52:53,198-0600 INFO  Multiplexer No streams
-2013-11-05 20:52:59,518-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:53:03,206-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:53:13,214-0600 INFO  Multiplexer No streams
-2013-11-05 20:53:20,584-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-05 20:53:23,222-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:53:33,230-0600 INFO  Multiplexer No streams
-2013-11-05 20:53:35,129-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:53:43,238-0600 INFO  Multiplexer No streams
-2013-11-05 20:53:52,906-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:53:53,246-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:54:03,254-0600 INFO  Multiplexer No streams
-2013-11-05 20:54:10,739-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:54:13,262-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:54:23,269-0600 INFO  Multiplexer No streams
-2013-11-05 20:54:25,229-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:54:33,277-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:54:43,285-0600 INFO  Multiplexer No streams
-2013-11-05 20:54:46,348-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:54:53,293-0600 INFO  Multiplexer No streams
-2013-11-05 20:54:57,552-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:55:03,301-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:55:13,309-0600 INFO  Multiplexer No streams
-2013-11-05 20:55:21,959-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:55:23,316-0600 INFO  Multiplexer No streams
-2013-11-05 20:55:29,875-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:55:33,324-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:55:43,332-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:55:53,340-0600 INFO  Multiplexer No streams
-2013-11-05 20:55:57,569-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:56:02,198-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:56:03,348-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:56:13,356-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:56:23,364-0600 INFO  Multiplexer No streams
-2013-11-05 20:56:33,179-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:56:33,372-0600 INFO  Multiplexer No streams
-2013-11-05 20:56:34,522-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:56:43,380-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:56:53,388-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:57:03,396-0600 INFO  Multiplexer No streams
-2013-11-05 20:57:06,845-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 20:57:08,789-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:57:13,404-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:57:23,411-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:57:33,419-0600 INFO  Multiplexer No streams
-2013-11-05 20:57:39,168-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:57:43,427-0600 INFO  Multiplexer No streams
-2013-11-05 20:57:44,399-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:57:53,435-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:58:03,443-0600 INFO  Multiplexer No streams
-2013-11-05 20:58:11,491-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:58:13,451-0600 INFO  Multiplexer No streams
-2013-11-05 20:58:20,009-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:58:23,459-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:58:33,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:58:43,475-0600 INFO  Multiplexer No streams
-2013-11-05 20:58:43,814-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 20:58:53,484-0600 INFO  Multiplexer No streams
-2013-11-05 20:58:55,619-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:59:03,492-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:59:13,500-0600 INFO  Multiplexer No streams
-2013-11-05 20:59:16,137-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:59:23,508-0600 INFO  Multiplexer No streams
-2013-11-05 20:59:31,229-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 20:59:33,516-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 20:59:43,524-0600 INFO  Multiplexer No streams
-2013-11-05 20:59:48,461-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 20:59:53,533-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:00:03,541-0600 INFO  Multiplexer No streams
-2013-11-05 21:00:06,840-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:00:13,549-0600 INFO  Multiplexer No streams
-2013-11-05 21:00:20,784-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:00:23,557-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:00:33,566-0600 INFO  Multiplexer No streams
-2013-11-05 21:00:42,450-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:00:43,574-0600 INFO  Multiplexer No streams
-2013-11-05 21:00:53,107-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:00:53,582-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:01:03,590-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:01:13,598-0600 INFO  Multiplexer No streams
-2013-11-05 21:01:18,060-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:01:23,607-0600 INFO  Multiplexer No streams
-2013-11-05 21:01:25,430-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:01:33,615-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:01:43,623-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:01:53,631-0600 INFO  Multiplexer No streams
-2013-11-05 21:01:53,670-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:01:57,753-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:02:03,639-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:02:13,647-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:02:23,656-0600 INFO  Multiplexer No streams
-2013-11-05 21:02:29,280-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 21:02:30,075-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:02:33,664-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:02:43,672-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:02:53,680-0600 INFO  Multiplexer No streams
-2013-11-05 21:03:02,399-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:03:03,688-0600 INFO  Multiplexer No streams
-2013-11-05 21:03:04,891-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:03:13,696-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:03:23,704-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:03:33,713-0600 INFO  Multiplexer No streams
-2013-11-05 21:03:34,722-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:03:40,501-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:03:43,721-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:03:53,729-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:04:03,737-0600 INFO  Multiplexer No streams
-2013-11-05 21:04:07,045-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:04:13,745-0600 INFO  Multiplexer No streams
-2013-11-05 21:04:16,111-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:04:23,753-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:04:33,761-0600 INFO  Multiplexer No streams
-2013-11-05 21:04:39,368-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:04:43,769-0600 INFO  Multiplexer No streams
-2013-11-05 21:04:51,721-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:04:53,778-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:05:03,786-0600 INFO  Multiplexer No streams
-2013-11-05 21:05:11,691-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:05:13,794-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:05:23,802-0600 INFO  Multiplexer No streams
-2013-11-05 21:05:27,331-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:05:33,810-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:05:43,818-0600 INFO  Multiplexer No streams
-2013-11-05 21:05:44,014-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:05:53,826-0600 INFO  Multiplexer No streams
-2013-11-05 21:06:02,941-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:06:03,835-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:06:13,843-0600 INFO  Multiplexer No streams
-2013-11-05 21:06:16,337-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:06:23,851-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:06:33,859-0600 INFO  Multiplexer No streams
-2013-11-05 21:06:38,551-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:06:43,867-0600 INFO  Multiplexer No streams
-2013-11-05 21:06:48,660-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:06:53,875-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:07:03,883-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:07:13,891-0600 INFO  Multiplexer No streams
-2013-11-05 21:07:14,161-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:07:20,983-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:07:23,899-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:07:33,907-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:07:43,915-0600 INFO  Multiplexer No streams
-2013-11-05 21:07:49,771-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:07:53,305-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:07:53,923-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:08:03,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:08:13,939-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:08:23,947-0600 INFO  Multiplexer No streams
-2013-11-05 21:08:25,381-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:08:25,629-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:08:33,955-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:08:43,963-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:08:53,971-0600 INFO  Multiplexer No streams
-2013-11-05 21:08:57,952-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:09:00,991-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:09:03,980-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:09:13,988-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:09:23,996-0600 INFO  Multiplexer No streams
-2013-11-05 21:09:30,275-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:09:34,004-0600 INFO  Multiplexer No streams
-2013-11-05 21:09:36,601-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:09:44,012-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:09:54,020-0600 INFO  Multiplexer No streams
-2013-11-05 21:10:02,598-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:10:04,028-0600 INFO  Multiplexer No streams
-2013-11-05 21:10:12,211-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:10:14,036-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:10:24,044-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:10:34,052-0600 INFO  Multiplexer No streams
-2013-11-05 21:10:34,921-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:10:44,060-0600 INFO  Multiplexer No streams
-2013-11-05 21:10:47,821-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:10:54,068-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:11:04,076-0600 INFO  Multiplexer No streams
-2013-11-05 21:11:07,243-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:11:14,084-0600 INFO  Multiplexer No streams
-2013-11-05 21:11:23,431-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:11:24,092-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:11:34,100-0600 INFO  Multiplexer No streams
-2013-11-05 21:11:39,567-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:11:44,108-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:11:54,116-0600 INFO  Multiplexer No streams
-2013-11-05 21:11:59,041-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:12:04,124-0600 INFO  Multiplexer No streams
-2013-11-05 21:12:11,890-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:12:14,132-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:12:24,140-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:12:34,148-0600 INFO  Multiplexer No streams
-2013-11-05 21:12:34,651-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:12:44,157-0600 INFO  Multiplexer No streams
-2013-11-05 21:12:44,213-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:12:54,164-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:13:04,172-0600 INFO  Multiplexer No streams
-2013-11-05 21:13:10,261-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:13:14,180-0600 INFO  Multiplexer No streams
-2013-11-05 21:13:16,536-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:13:24,188-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:13:34,197-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:13:44,205-0600 INFO  Multiplexer No streams
-2013-11-05 21:13:45,871-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:13:48,859-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:13:54,213-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:14:04,221-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:14:14,229-0600 INFO  Multiplexer No streams
-2013-11-05 21:14:21,182-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:14:21,481-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:14:24,237-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:14:34,246-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:14:44,254-0600 INFO  Multiplexer No streams
-2013-11-05 21:14:53,505-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:14:54,262-0600 INFO  Multiplexer No streams
-2013-11-05 21:14:57,091-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:15:04,270-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:15:14,278-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:15:24,287-0600 INFO  Multiplexer No streams
-2013-11-05 21:15:25,829-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:15:32,701-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:15:34,295-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:15:44,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:15:54,312-0600 INFO  Multiplexer No streams
-2013-11-05 21:15:58,151-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:16:04,320-0600 INFO  Multiplexer No streams
-2013-11-05 21:16:08,311-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:16:14,327-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:16:24,335-0600 INFO  Multiplexer No streams
-2013-11-05 21:16:30,474-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:16:34,343-0600 INFO  Multiplexer No streams
-2013-11-05 21:16:43,921-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:16:44,351-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:16:54,359-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:17:02,797-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:17:04,366-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:17:14,374-0600 INFO  Multiplexer No streams
-2013-11-05 21:17:19,532-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:17:24,382-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:17:34,390-0600 INFO  Multiplexer No streams
-2013-11-05 21:17:35,120-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:17:44,398-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:17:54,405-0600 INFO  Multiplexer No streams
-2013-11-05 21:17:55,141-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:18:04,413-0600 INFO  Multiplexer No streams
-2013-11-05 21:18:07,443-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:18:14,421-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:18:24,428-0600 INFO  Multiplexer No streams
-2013-11-05 21:18:30,752-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:18:34,436-0600 INFO  Multiplexer No streams
-2013-11-05 21:18:39,766-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:18:44,444-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:18:54,452-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:19:04,459-0600 INFO  Multiplexer No streams
-2013-11-05 21:19:06,362-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:19:12,089-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:19:14,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:19:24,475-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:19:34,483-0600 INFO  Multiplexer No streams
-2013-11-05 21:19:41,972-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:19:44,412-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:19:44,490-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:19:54,498-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:20:04,506-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:20:14,514-0600 INFO  Multiplexer No streams
-2013-11-05 21:20:16,736-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:20:17,582-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:20:24,522-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:20:34,530-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:20:44,538-0600 INFO  Multiplexer No streams
-2013-11-05 21:20:49,060-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:20:53,192-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:20:54,546-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:21:04,553-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:21:14,561-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:21:21,383-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:21:24,569-0600 INFO  Multiplexer No streams
-2013-11-05 21:21:28,801-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:21:34,577-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:21:44,585-0600 INFO  Multiplexer No streams
-2013-11-05 21:21:53,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:21:54,593-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:22:04,412-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:22:04,601-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:22:14,609-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:22:24,617-0600 INFO  Multiplexer No streams
-2013-11-05 21:22:26,029-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:22:34,625-0600 INFO  Multiplexer No streams
-2013-11-05 21:22:40,021-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:22:44,633-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:22:54,641-0600 INFO  Multiplexer No streams
-2013-11-05 21:22:58,352-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:23:04,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:23:14,657-0600 INFO  Multiplexer No streams
-2013-11-05 21:23:15,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:23:24,664-0600 INFO  Multiplexer No streams
-2013-11-05 21:23:30,675-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:23:34,672-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:23:44,680-0600 INFO  Multiplexer No streams
-2013-11-05 21:23:51,241-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:23:54,688-0600 INFO  Multiplexer No streams
-2013-11-05 21:24:02,998-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:24:04,696-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:24:14,704-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:24:24,712-0600 INFO  Multiplexer No streams
-2013-11-05 21:24:26,852-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:24:34,720-0600 INFO  Multiplexer No streams
-2013-11-05 21:24:35,321-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:24:44,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:24:54,736-0600 INFO  Multiplexer No streams
-2013-11-05 21:25:02,462-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:25:04,744-0600 INFO  Multiplexer No streams
-2013-11-05 21:25:07,644-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:25:14,752-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:25:24,760-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:25:34,768-0600 INFO  Multiplexer No streams
-2013-11-05 21:25:38,073-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:25:39,967-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:25:44,776-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:25:54,784-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:26:04,792-0600 INFO  Multiplexer No streams
-2013-11-05 21:26:12,290-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:26:13,683-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:26:14,800-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:26:24,808-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:26:34,816-0600 INFO  Multiplexer No streams
-2013-11-05 21:26:44,613-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:26:44,824-0600 INFO  Multiplexer No streams
-2013-11-05 21:26:49,293-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:26:54,833-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:27:04,841-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:27:14,849-0600 INFO  Multiplexer No streams
-2013-11-05 21:27:16,936-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:27:24,857-0600 INFO  Multiplexer No streams
-2013-11-05 21:27:24,904-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:27:34,865-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:27:44,873-0600 INFO  Multiplexer No streams
-2013-11-05 21:27:49,259-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:27:54,881-0600 INFO  Multiplexer No streams
-2013-11-05 21:28:00,514-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:28:04,890-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:28:14,898-0600 INFO  Multiplexer No streams
-2013-11-05 21:28:21,582-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:28:24,906-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:28:34,914-0600 INFO  Multiplexer No streams
-2013-11-05 21:28:36,125-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:28:44,922-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 21:28:53,904-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:28:54,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:29:04,939-0600 INFO  Multiplexer No streams
-2013-11-05 21:29:11,735-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:29:14,947-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:29:24,955-0600 INFO  Multiplexer No streams
-2013-11-05 21:29:26,228-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:29:34,963-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:29:44,972-0600 INFO  Multiplexer No streams
-2013-11-05 21:29:47,345-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:29:54,980-0600 INFO  Multiplexer No streams
-2013-11-05 21:29:58,550-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:30:04,988-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:30:14,996-0600 INFO  Multiplexer No streams
-2013-11-05 21:30:22,956-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:30:25,004-0600 INFO  Multiplexer No streams
-2013-11-05 21:30:30,874-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:30:35,012-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:30:45,020-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:30:55,028-0600 INFO  Multiplexer No streams
-2013-11-05 21:30:58,566-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:31:03,197-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:31:05,037-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:31:15,045-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:31:25,053-0600 INFO  Multiplexer No streams
-2013-11-05 21:31:34,176-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:31:35,061-0600 INFO  Multiplexer No streams
-2013-11-05 21:31:35,519-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:31:45,069-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:31:55,077-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:32:05,085-0600 INFO  Multiplexer No streams
-2013-11-05 21:32:07,843-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 21:32:09,786-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:32:15,093-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:32:25,101-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:32:35,110-0600 INFO  Multiplexer No streams
-2013-11-05 21:32:40,166-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:32:45,118-0600 INFO  Multiplexer No streams
-2013-11-05 21:32:45,396-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:32:55,126-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:33:05,134-0600 INFO  Multiplexer No streams
-2013-11-05 21:33:12,489-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:33:15,142-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 21:33:21,006-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:33:25,150-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:33:35,158-0600 INFO  Multiplexer No streams
-2013-11-05 21:33:44,812-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:33:45,166-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:33:55,174-0600 INFO  Multiplexer No streams
-2013-11-05 21:33:56,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:34:05,182-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:34:15,190-0600 INFO  Multiplexer No streams
-2013-11-05 21:34:17,135-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:34:25,198-0600 INFO  Multiplexer No streams
-2013-11-05 21:34:32,227-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:34:35,206-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:34:45,215-0600 INFO  Multiplexer No streams
-2013-11-05 21:34:49,458-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:34:55,223-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:35:05,231-0600 INFO  Multiplexer No streams
-2013-11-05 21:35:07,837-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:35:15,239-0600 INFO  Multiplexer No streams
-2013-11-05 21:35:21,781-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:35:25,247-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:35:35,255-0600 INFO  Multiplexer No streams
-2013-11-05 21:35:43,447-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:35:45,263-0600 INFO  Multiplexer No streams
-2013-11-05 21:35:54,104-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:35:55,271-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:36:05,279-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:36:15,287-0600 INFO  Multiplexer No streams
-2013-11-05 21:36:19,057-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:36:25,295-0600 INFO  Multiplexer No streams
-2013-11-05 21:36:26,427-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:36:35,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:36:45,311-0600 INFO  Multiplexer No streams
-2013-11-05 21:36:54,667-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:36:55,319-0600 INFO  Multiplexer No streams
-2013-11-05 21:36:58,750-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:37:05,327-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:37:15,335-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:37:25,343-0600 INFO  Multiplexer No streams
-2013-11-05 21:37:30,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:37:31,073-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:37:35,352-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:37:45,360-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:37:55,368-0600 INFO  Multiplexer No streams
-2013-11-05 21:38:03,396-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:38:05,376-0600 INFO  Multiplexer No streams
-2013-11-05 21:38:05,887-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:38:15,384-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:38:25,392-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:38:35,400-0600 INFO  Multiplexer No streams
-2013-11-05 21:38:35,719-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:38:41,498-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:38:45,408-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:38:55,416-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:39:05,424-0600 INFO  Multiplexer No streams
-2013-11-05 21:39:08,042-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:39:15,432-0600 INFO  Multiplexer No streams
-2013-11-05 21:39:17,108-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:39:25,440-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:39:35,449-0600 INFO  Multiplexer No streams
-2013-11-05 21:39:40,365-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:39:45,457-0600 INFO  Multiplexer No streams
-2013-11-05 21:39:52,718-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:39:55,465-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:40:05,473-0600 INFO  Multiplexer No streams
-2013-11-05 21:40:12,688-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:40:15,481-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:40:25,489-0600 INFO  Multiplexer No streams
-2013-11-05 21:40:28,328-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:40:35,498-0600 INFO  Multiplexer No streams
-2013-11-05 21:40:45,011-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:40:45,506-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:40:55,514-0600 INFO  Multiplexer No streams
-2013-11-05 21:41:03,938-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:41:05,522-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:41:15,530-0600 INFO  Multiplexer No streams
-2013-11-05 21:41:17,334-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:41:25,538-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:41:35,546-0600 INFO  Multiplexer No streams
-2013-11-05 21:41:39,548-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:41:45,554-0600 INFO  Multiplexer No streams
-2013-11-05 21:41:49,657-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:41:55,563-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:42:05,571-0600 INFO  Multiplexer No streams
-2013-11-05 21:42:15,158-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:42:15,579-0600 INFO  Multiplexer No streams
-2013-11-05 21:42:21,980-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:42:25,587-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:42:35,596-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:42:45,604-0600 INFO  Multiplexer No streams
-2013-11-05 21:42:50,768-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:42:54,303-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:42:55,612-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:43:05,621-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:43:15,629-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:43:25,637-0600 INFO  Multiplexer No streams
-2013-11-05 21:43:26,378-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:43:26,626-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:43:35,646-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:43:45,654-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:43:55,662-0600 INFO  Multiplexer No streams
-2013-11-05 21:43:58,949-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:44:01,988-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:44:05,671-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:44:15,679-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:44:25,687-0600 INFO  Multiplexer No streams
-2013-11-05 21:44:31,272-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:44:35,695-0600 INFO  Multiplexer No streams
-2013-11-05 21:44:37,598-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:44:45,703-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:44:55,711-0600 INFO  Multiplexer No streams
-2013-11-05 21:45:03,595-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:45:05,720-0600 INFO  Multiplexer No streams
-2013-11-05 21:45:13,208-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:45:15,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:45:25,736-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:45:35,744-0600 INFO  Multiplexer No streams
-2013-11-05 21:45:35,918-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:45:45,753-0600 INFO  Multiplexer No streams
-2013-11-05 21:45:48,818-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:45:55,761-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:46:05,769-0600 INFO  Multiplexer No streams
-2013-11-05 21:46:08,241-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:46:15,777-0600 INFO  Multiplexer No streams
-2013-11-05 21:46:24,429-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:46:25,785-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:46:35,794-0600 INFO  Multiplexer No streams
-2013-11-05 21:46:40,564-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:46:45,802-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:46:55,810-0600 INFO  Multiplexer No streams
-2013-11-05 21:47:00,039-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:47:05,818-0600 INFO  Multiplexer No streams
-2013-11-05 21:47:12,887-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:47:15,826-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:47:25,834-0600 INFO  Multiplexer No streams
-2013-11-05 21:47:35,649-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:47:35,843-0600 INFO  Multiplexer No streams
-2013-11-05 21:47:45,210-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:47:45,851-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:47:55,859-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:48:05,867-0600 INFO  Multiplexer No streams
-2013-11-05 21:48:11,259-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:48:15,875-0600 INFO  Multiplexer No streams
-2013-11-05 21:48:17,533-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:48:25,883-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:48:35,892-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:48:45,900-0600 INFO  Multiplexer No streams
-2013-11-05 21:48:46,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:48:49,856-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:48:55,908-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:49:05,916-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:49:15,925-0600 INFO  Multiplexer No streams
-2013-11-05 21:49:22,179-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:49:22,479-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:49:25,933-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:49:35,941-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:49:45,949-0600 INFO  Multiplexer No streams
-2013-11-05 21:49:54,502-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:49:55,957-0600 INFO  Multiplexer No streams
-2013-11-05 21:49:58,089-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:50:05,965-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:50:15,974-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:50:25,982-0600 INFO  Multiplexer No streams
-2013-11-05 21:50:26,825-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:50:33,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:50:35,990-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:50:45,998-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:50:56,006-0600 INFO  Multiplexer No streams
-2013-11-05 21:50:59,148-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:51:06,014-0600 INFO  Multiplexer No streams
-2013-11-05 21:51:09,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:51:16,022-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:51:26,029-0600 INFO  Multiplexer No streams
-2013-11-05 21:51:31,471-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:51:36,037-0600 INFO  Multiplexer No streams
-2013-11-05 21:51:44,920-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:51:46,044-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:51:56,051-0600 INFO  Multiplexer No streams
-2013-11-05 21:52:03,794-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:52:06,058-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:52:16,065-0600 INFO  Multiplexer No streams
-2013-11-05 21:52:20,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:52:26,073-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:52:36,082-0600 INFO  Multiplexer No streams
-2013-11-05 21:52:36,117-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:52:46,090-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:52:56,098-0600 INFO  Multiplexer No streams
-2013-11-05 21:52:56,140-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:53:06,106-0600 INFO  Multiplexer No streams
-2013-11-05 21:53:08,440-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:53:16,114-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:53:26,122-0600 INFO  Multiplexer No streams
-2013-11-05 21:53:31,750-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:53:36,130-0600 INFO  Multiplexer No streams
-2013-11-05 21:53:40,763-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:53:46,139-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:53:56,147-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:54:06,155-0600 INFO  Multiplexer No streams
-2013-11-05 21:54:07,360-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:54:13,086-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:54:16,162-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:54:26,170-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:54:36,178-0600 INFO  Multiplexer No streams
-2013-11-05 21:54:42,970-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:54:45,409-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:54:46,186-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:54:56,194-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:55:06,202-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:55:16,209-0600 INFO  Multiplexer No streams
-2013-11-05 21:55:17,732-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:55:18,580-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:55:26,217-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:55:36,225-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:55:46,233-0600 INFO  Multiplexer No streams
-2013-11-05 21:55:50,055-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 21:55:54,190-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:55:56,241-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:56:06,249-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:56:16,257-0600 INFO  Multiplexer No streams
-2013-11-05 21:56:22,377-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:56:26,264-0600 INFO  Multiplexer No streams
-2013-11-05 21:56:29,800-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:56:36,272-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:56:46,280-0600 INFO  Multiplexer No streams
-2013-11-05 21:56:54,700-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:56:56,288-0600 INFO  Multiplexer No streams
-2013-11-05 21:57:05,411-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:57:06,296-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:57:16,304-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:57:26,312-0600 INFO  Multiplexer No streams
-2013-11-05 21:57:27,024-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:57:36,319-0600 INFO  Multiplexer No streams
-2013-11-05 21:57:41,022-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 21:57:46,327-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:57:56,335-0600 INFO  Multiplexer No streams
-2013-11-05 21:57:59,347-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:58:06,343-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:58:16,351-0600 INFO  Multiplexer No streams
-2013-11-05 21:58:16,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:58:26,359-0600 INFO  Multiplexer No streams
-2013-11-05 21:58:31,670-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:58:36,367-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:58:46,375-0600 INFO  Multiplexer No streams
-2013-11-05 21:58:52,241-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 21:58:56,383-0600 INFO  Multiplexer No streams
-2013-11-05 21:59:03,993-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:59:06,391-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:59:16,399-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:59:26,407-0600 INFO  Multiplexer No streams
-2013-11-05 21:59:27,852-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 21:59:36,316-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 21:59:36,415-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:59:46,423-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 21:59:56,431-0600 INFO  Multiplexer No streams
-2013-11-05 22:00:03,462-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:00:06,439-0600 INFO  Multiplexer No streams
-2013-11-05 22:00:08,639-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:00:16,446-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:00:26,454-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:00:36,462-0600 INFO  Multiplexer No streams
-2013-11-05 22:00:39,072-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:00:40,962-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:00:46,470-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:00:56,479-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:01:06,486-0600 INFO  Multiplexer No streams
-2013-11-05 22:01:13,285-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:01:14,682-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:01:16,494-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:01:26,502-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:01:36,510-0600 INFO  Multiplexer No streams
-2013-11-05 22:01:45,608-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:01:46,519-0600 INFO  Multiplexer No streams
-2013-11-05 22:01:50,293-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:01:56,527-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:02:06,535-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:02:16,543-0600 INFO  Multiplexer No streams
-2013-11-05 22:02:17,931-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:02:25,903-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:02:26,551-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:02:36,559-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:02:46,567-0600 INFO  Multiplexer No streams
-2013-11-05 22:02:50,254-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:02:56,575-0600 INFO  Multiplexer No streams
-2013-11-05 22:03:01,513-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:03:06,582-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:03:16,590-0600 INFO  Multiplexer No streams
-2013-11-05 22:03:22,577-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:03:26,598-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:03:36,606-0600 INFO  Multiplexer No streams
-2013-11-05 22:03:37,123-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:03:46,614-0600 INFO  Multiplexer No streams
-2013-11-05 22:03:54,900-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:03:56,622-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:04:06,630-0600 INFO  Multiplexer No streams
-2013-11-05 22:04:12,732-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:04:16,638-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:04:26,646-0600 INFO  Multiplexer No streams
-2013-11-05 22:04:27,223-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:04:36,654-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:04:46,662-0600 INFO  Multiplexer No streams
-2013-11-05 22:04:48,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:04:56,669-0600 INFO  Multiplexer No streams
-2013-11-05 22:04:59,547-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:05:06,677-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:05:16,685-0600 INFO  Multiplexer No streams
-2013-11-05 22:05:23,954-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:05:26,693-0600 INFO  Multiplexer No streams
-2013-11-05 22:05:31,871-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:05:36,701-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:05:46,709-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:05:56,717-0600 INFO  Multiplexer No streams
-2013-11-05 22:05:59,563-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:06:04,194-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:06:06,725-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:06:16,733-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:06:26,741-0600 INFO  Multiplexer No streams
-2013-11-05 22:06:35,173-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 22:06:36,517-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:06:36,749-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:06:46,757-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:06:56,765-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:07:06,772-0600 INFO  Multiplexer No streams
-2013-11-05 22:07:08,839-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 22:07:10,784-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:07:16,780-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:07:26,788-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:07:36,796-0600 INFO  Multiplexer No streams
-2013-11-05 22:07:41,163-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:07:46,394-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:07:46,804-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:07:56,812-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:08:06,820-0600 INFO  Multiplexer No streams
-2013-11-05 22:08:13,486-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:08:16,828-0600 INFO  Multiplexer No streams
-2013-11-05 22:08:22,005-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:08:26,836-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:08:36,844-0600 INFO  Multiplexer No streams
-2013-11-05 22:08:45,809-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:08:46,852-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:08:56,860-0600 INFO  Multiplexer No streams
-2013-11-05 22:08:57,615-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:09:06,868-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:09:16,876-0600 INFO  Multiplexer No streams
-2013-11-05 22:09:18,132-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:09:26,884-0600 INFO  Multiplexer No streams
-2013-11-05 22:09:33,225-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:09:36,892-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:09:46,900-0600 INFO  Multiplexer No streams
-2013-11-05 22:09:50,455-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:09:56,908-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:10:06,916-0600 INFO  Multiplexer No streams
-2013-11-05 22:10:08,835-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:10:16,924-0600 INFO  Multiplexer No streams
-2013-11-05 22:10:22,778-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:10:26,933-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:10:36,941-0600 INFO  Multiplexer No streams
-2013-11-05 22:10:44,445-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:10:46,949-0600 INFO  Multiplexer No streams
-2013-11-05 22:10:55,101-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:10:56,957-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:11:06,966-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:11:16,974-0600 INFO  Multiplexer No streams
-2013-11-05 22:11:20,055-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:11:26,982-0600 INFO  Multiplexer No streams
-2013-11-05 22:11:27,424-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:11:36,990-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:11:46,999-0600 INFO  Multiplexer No streams
-2013-11-05 22:11:55,665-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:11:57,007-0600 INFO  Multiplexer No streams
-2013-11-05 22:11:59,747-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:12:07,015-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:12:17,024-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:12:27,032-0600 INFO  Multiplexer No streams
-2013-11-05 22:12:31,275-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:12:32,070-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:12:37,040-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:12:47,048-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:12:57,056-0600 INFO  Multiplexer No streams
-2013-11-05 22:13:04,393-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:13:06,885-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:13:07,065-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:13:17,073-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:13:27,081-0600 INFO  Multiplexer No streams
-2013-11-05 22:13:36,716-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:13:37,089-0600 INFO  Multiplexer No streams
-2013-11-05 22:13:42,495-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:13:47,098-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:13:57,106-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:14:07,114-0600 INFO  Multiplexer No streams
-2013-11-05 22:14:09,039-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:14:17,122-0600 INFO  Multiplexer No streams
-2013-11-05 22:14:18,105-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:14:27,130-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:14:37,138-0600 INFO  Multiplexer No streams
-2013-11-05 22:14:41,362-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:14:47,146-0600 INFO  Multiplexer No streams
-2013-11-05 22:14:53,715-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:14:57,155-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:15:07,163-0600 INFO  Multiplexer No streams
-2013-11-05 22:15:13,685-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:15:17,171-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:15:27,179-0600 INFO  Multiplexer No streams
-2013-11-05 22:15:29,325-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:15:37,187-0600 INFO  Multiplexer No streams
-2013-11-05 22:15:46,008-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:15:47,195-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:15:57,203-0600 INFO  Multiplexer No streams
-2013-11-05 22:16:04,935-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:16:07,212-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:16:17,220-0600 INFO  Multiplexer No streams
-2013-11-05 22:16:18,331-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:16:27,228-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:16:37,236-0600 INFO  Multiplexer No streams
-2013-11-05 22:16:40,545-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:16:47,244-0600 INFO  Multiplexer No streams
-2013-11-05 22:16:50,654-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:16:57,252-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:17:07,260-0600 INFO  Multiplexer No streams
-2013-11-05 22:17:16,155-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:17:17,268-0600 INFO  Multiplexer No streams
-2013-11-05 22:17:22,977-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:17:27,276-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:17:37,284-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:17:47,292-0600 INFO  Multiplexer No streams
-2013-11-05 22:17:51,765-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:17:55,300-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:17:57,300-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:18:07,308-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:18:17,316-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:18:27,324-0600 INFO  Multiplexer No streams
-2013-11-05 22:18:27,375-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:18:27,623-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:18:37,332-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:18:47,340-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:18:57,348-0600 INFO  Multiplexer No streams
-2013-11-05 22:18:59,946-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:19:02,985-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:19:07,356-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:19:17,365-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:19:27,373-0600 INFO  Multiplexer No streams
-2013-11-05 22:19:32,269-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:19:37,381-0600 INFO  Multiplexer No streams
-2013-11-05 22:19:38,595-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:19:47,389-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:19:57,397-0600 INFO  Multiplexer No streams
-2013-11-05 22:20:04,592-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:20:07,406-0600 INFO  Multiplexer No streams
-2013-11-05 22:20:14,205-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:20:17,414-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:20:27,422-0600 INFO  Multiplexer No streams
-2013-11-05 22:20:36,915-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:20:37,430-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:20:47,439-0600 INFO  Multiplexer No streams
-2013-11-05 22:20:49,815-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:20:57,447-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:21:07,455-0600 INFO  Multiplexer No streams
-2013-11-05 22:21:09,238-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:21:17,463-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:21:25,425-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:21:27,471-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:21:37,480-0600 INFO  Multiplexer No streams
-2013-11-05 22:21:41,561-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:21:47,488-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:21:57,496-0600 INFO  Multiplexer No streams
-2013-11-05 22:22:01,035-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:22:07,504-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:22:13,884-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:22:17,512-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:22:27,520-0600 INFO  Multiplexer No streams
-2013-11-05 22:22:36,645-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:22:37,528-0600 INFO  Multiplexer No streams
-2013-11-05 22:22:46,207-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:22:47,536-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:22:57,544-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:23:07,552-0600 INFO  Multiplexer No streams
-2013-11-05 22:23:12,255-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:23:17,560-0600 INFO  Multiplexer No streams
-2013-11-05 22:23:18,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:23:27,568-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:23:37,575-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:23:47,583-0600 INFO  Multiplexer No streams
-2013-11-05 22:23:47,865-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:23:50,853-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:23:57,591-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:24:07,599-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:24:17,607-0600 INFO  Multiplexer No streams
-2013-11-05 22:24:23,176-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:24:23,475-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:24:27,615-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:24:37,623-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:24:47,631-0600 INFO  Multiplexer No streams
-2013-11-05 22:24:55,499-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:24:57,639-0600 INFO  Multiplexer No streams
-2013-11-05 22:24:59,085-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:25:07,647-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:25:17,655-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:25:27,663-0600 INFO  Multiplexer No streams
-2013-11-05 22:25:27,822-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:25:34,695-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:25:37,671-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:25:47,679-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:25:57,687-0600 INFO  Multiplexer No streams
-2013-11-05 22:26:00,145-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:26:07,695-0600 INFO  Multiplexer No streams
-2013-11-05 22:26:10,305-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:26:17,703-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:26:27,711-0600 INFO  Multiplexer No streams
-2013-11-05 22:26:32,468-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:26:37,718-0600 INFO  Multiplexer No streams
-2013-11-05 22:26:45,915-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:26:47,726-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:26:57,734-0600 INFO  Multiplexer No streams
-2013-11-05 22:27:04,791-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:27:07,742-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:27:17,750-0600 INFO  Multiplexer No streams
-2013-11-05 22:27:21,525-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:27:27,758-0600 INFO  Multiplexer No streams
-2013-11-05 22:27:37,114-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:27:37,766-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:27:47,774-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:27:57,135-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:27:57,782-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:28:07,790-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:28:09,437-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:28:17,797-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:28:27,805-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-05 22:28:32,746-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-05 22:28:37,813-0600 INFO  Multiplexer No streams
-2013-11-05 22:28:41,759-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:28:47,821-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:28:57,829-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:29:07,837-0600 INFO  Multiplexer No streams
-2013-11-05 22:29:08,355-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:29:14,082-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:29:17,845-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:29:27,853-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:29:37,861-0600 INFO  Multiplexer No streams
-2013-11-05 22:29:43,965-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:29:46,405-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:29:47,868-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:29:57,876-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:30:07,884-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:30:17,892-0600 INFO  Multiplexer No streams
-2013-11-05 22:30:18,729-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 22:30:19,575-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:30:27,900-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:30:37,908-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:30:47,916-0600 INFO  Multiplexer No streams
-2013-11-05 22:30:51,053-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:30:55,185-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:30:57,923-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:31:07,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:31:17,939-0600 INFO  Multiplexer No streams
-2013-11-05 22:31:23,374-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:31:27,947-0600 INFO  Multiplexer No streams
-2013-11-05 22:31:30,795-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:31:37,955-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:31:47,963-0600 INFO  Multiplexer No streams
-2013-11-05 22:31:55,698-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:31:57,971-0600 INFO  Multiplexer No streams
-2013-11-05 22:32:06,405-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:32:07,979-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:32:17,987-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:32:27,995-0600 INFO  Multiplexer No streams
-2013-11-05 22:32:28,021-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:32:38,003-0600 INFO  Multiplexer No streams
-2013-11-05 22:32:42,016-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:32:48,011-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:32:58,019-0600 INFO  Multiplexer No streams
-2013-11-05 22:33:00,344-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:33:08,027-0600 INFO  Multiplexer No streams
-2013-11-05 22:33:17,626-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:33:18,035-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:33:28,043-0600 INFO  Multiplexer No streams
-2013-11-05 22:33:32,667-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:33:38,052-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:33:48,060-0600 INFO  Multiplexer No streams
-2013-11-05 22:33:53,236-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:33:58,068-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 22:34:04,990-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:34:08,076-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:34:18,084-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:34:28,092-0600 INFO  Multiplexer No streams
-2013-11-05 22:34:28,846-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:34:37,313-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:34:38,100-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:34:48,108-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:34:58,116-0600 INFO  Multiplexer No streams
-2013-11-05 22:35:04,456-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:35:08,124-0600 INFO  Multiplexer No streams
-2013-11-05 22:35:09,636-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:35:18,132-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:35:28,140-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:35:38,148-0600 INFO  Multiplexer No streams
-2013-11-05 22:35:40,067-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-05 22:35:41,959-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:35:48,156-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:35:58,164-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:36:08,172-0600 INFO  Multiplexer No streams
-2013-11-05 22:36:14,282-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:36:15,676-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:36:18,180-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:36:28,188-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:36:38,196-0600 INFO  Multiplexer No streams
-2013-11-05 22:36:46,605-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:36:48,204-0600 INFO  Multiplexer No streams
-2013-11-05 22:36:51,286-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:36:58,212-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:37:08,220-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:37:18,228-0600 INFO  Multiplexer No streams
-2013-11-05 22:37:18,928-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:37:26,896-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:37:28,236-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:37:38,244-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:37:48,252-0600 INFO  Multiplexer No streams
-2013-11-05 22:37:51,251-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:37:58,260-0600 INFO  Multiplexer No streams
-2013-11-05 22:38:02,506-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:38:08,268-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:38:18,276-0600 INFO  Multiplexer No streams
-2013-11-05 22:38:23,574-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:38:28,284-0600 INFO  Multiplexer No streams
-2013-11-05 22:38:38,116-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:38:38,292-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:38:48,300-0600 INFO  Multiplexer No streams
-2013-11-05 22:38:55,896-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:38:58,308-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:39:08,316-0600 INFO  Multiplexer No streams
-2013-11-05 22:39:13,726-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:39:18,324-0600 INFO  Multiplexer No streams
-2013-11-05 22:39:28,220-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:39:28,332-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:39:38,340-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:39:48,348-0600 INFO  Multiplexer No streams
-2013-11-05 22:39:49,336-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:39:58,356-0600 INFO  Multiplexer No streams
-2013-11-05 22:40:00,542-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:40:08,364-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:40:18,372-0600 INFO  Multiplexer No streams
-2013-11-05 22:40:24,947-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-05 22:40:28,380-0600 INFO  Multiplexer No streams
-2013-11-05 22:40:32,866-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:40:38,388-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:40:48,396-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:40:58,404-0600 INFO  Multiplexer No streams
-2013-11-05 22:41:00,556-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:41:05,188-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:41:08,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:41:18,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:41:28,428-0600 INFO  Multiplexer No streams
-2013-11-05 22:41:36,166-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:41:37,511-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:41:38,436-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:41:48,443-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:41:58,451-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:42:08,459-0600 INFO  Multiplexer No streams
-2013-11-05 22:42:09,835-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:42:11,776-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:42:18,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:42:28,475-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:42:38,483-0600 INFO  Multiplexer No streams
-2013-11-05 22:42:42,158-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:42:47,386-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:42:48,491-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:42:58,499-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:43:08,507-0600 INFO  Multiplexer No streams
-2013-11-05 22:43:14,481-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:43:18,515-0600 INFO  Multiplexer No streams
-2013-11-05 22:43:22,997-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:43:28,523-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:43:38,531-0600 INFO  Multiplexer No streams
-2013-11-05 22:43:46,804-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:43:48,539-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:43:58,547-0600 INFO  Multiplexer No streams
-2013-11-05 22:43:58,607-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:44:08,555-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:44:18,563-0600 INFO  Multiplexer No streams
-2013-11-05 22:44:19,127-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:44:28,571-0600 INFO  Multiplexer No streams
-2013-11-05 22:44:34,217-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:44:38,579-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:44:48,587-0600 INFO  Multiplexer No streams
-2013-11-05 22:44:51,450-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:44:58,595-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:45:08,603-0600 INFO  Multiplexer No streams
-2013-11-05 22:45:09,827-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:45:18,611-0600 INFO  Multiplexer No streams
-2013-11-05 22:45:23,773-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:45:28,619-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:45:38,627-0600 INFO  Multiplexer No streams
-2013-11-05 22:45:45,437-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:45:48,635-0600 INFO  Multiplexer No streams
-2013-11-05 22:45:56,096-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:45:58,643-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:46:08,651-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:46:18,659-0600 INFO  Multiplexer No streams
-2013-11-05 22:46:21,047-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:46:28,420-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 22:46:28,667-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:46:38,675-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:46:48,683-0600 INFO  Multiplexer No streams
-2013-11-05 22:46:56,657-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:46:58,684-0600 INFO  Multiplexer No streams
-2013-11-05 22:47:00,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:47:08,692-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:47:18,700-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:47:28,708-0600 INFO  Multiplexer No streams
-2013-11-05 22:47:32,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:47:33,066-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:47:38,716-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:47:48,724-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:47:58,732-0600 INFO  Multiplexer No streams
-2013-11-05 22:48:05,389-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:48:07,877-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:48:08,740-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:48:18,748-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:48:28,756-0600 INFO  Multiplexer No streams
-2013-11-05 22:48:37,712-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:48:38,764-0600 INFO  Multiplexer No streams
-2013-11-05 22:48:43,487-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:48:48,772-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:48:58,780-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:49:08,788-0600 INFO  Multiplexer No streams
-2013-11-05 22:49:10,035-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:49:18,796-0600 INFO  Multiplexer No streams
-2013-11-05 22:49:19,097-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:49:28,804-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:49:38,816-0600 INFO  Multiplexer No streams
-2013-11-05 22:49:42,358-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:49:48,824-0600 INFO  Multiplexer No streams
-2013-11-05 22:49:54,707-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:49:58,832-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:50:08,840-0600 INFO  Multiplexer No streams
-2013-11-05 22:50:14,681-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:50:18,848-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:50:28,856-0600 INFO  Multiplexer No streams
-2013-11-05 22:50:30,317-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:50:38,864-0600 INFO  Multiplexer No streams
-2013-11-05 22:50:47,004-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:50:48,872-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:50:58,880-0600 INFO  Multiplexer No streams
-2013-11-05 22:51:05,927-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:51:08,887-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:51:18,895-0600 INFO  Multiplexer No streams
-2013-11-05 22:51:19,327-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:51:28,903-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:51:38,911-0600 INFO  Multiplexer No streams
-2013-11-05 22:51:41,537-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:51:48,919-0600 INFO  Multiplexer No streams
-2013-11-05 22:51:51,650-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:51:58,927-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:52:08,935-0600 INFO  Multiplexer No streams
-2013-11-05 22:52:17,147-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:52:18,943-0600 INFO  Multiplexer No streams
-2013-11-05 22:52:23,973-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:52:28,951-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:52:38,959-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:52:48,966-0600 INFO  Multiplexer No streams
-2013-11-05 22:52:52,757-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 22:52:56,296-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:52:58,974-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:53:08,982-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:53:18,990-0600 INFO  Multiplexer No streams
-2013-11-05 22:53:28,367-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:53:28,619-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:53:28,998-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:53:39,006-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:53:49,014-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:53:59,022-0600 INFO  Multiplexer No streams
-2013-11-05 22:54:00,942-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:54:03,977-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:54:09,030-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:54:19,038-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:54:29,046-0600 INFO  Multiplexer No streams
-2013-11-05 22:54:33,265-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:54:39,054-0600 INFO  Multiplexer No streams
-2013-11-05 22:54:39,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:54:49,062-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:54:59,070-0600 INFO  Multiplexer No streams
-2013-11-05 22:55:05,588-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:55:09,078-0600 INFO  Multiplexer No streams
-2013-11-05 22:55:15,197-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:55:19,086-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:55:29,094-0600 INFO  Multiplexer No streams
-2013-11-05 22:55:37,911-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:55:39,102-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:55:49,110-0600 INFO  Multiplexer No streams
-2013-11-05 22:55:50,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:55:59,118-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:56:09,126-0600 INFO  Multiplexer No streams
-2013-11-05 22:56:10,234-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:56:19,134-0600 INFO  Multiplexer No streams
-2013-11-05 22:56:26,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:56:29,142-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:56:39,150-0600 INFO  Multiplexer No streams
-2013-11-05 22:56:42,557-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:56:49,158-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:56:59,166-0600 INFO  Multiplexer No streams
-2013-11-05 22:57:02,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:57:09,174-0600 INFO  Multiplexer No streams
-2013-11-05 22:57:14,880-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:57:19,182-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:57:29,190-0600 INFO  Multiplexer No streams
-2013-11-05 22:57:37,637-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 22:57:39,198-0600 INFO  Multiplexer No streams
-2013-11-05 22:57:47,203-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:57:49,206-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:57:59,214-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:58:09,222-0600 INFO  Multiplexer No streams
-2013-11-05 22:58:13,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:58:19,230-0600 INFO  Multiplexer No streams
-2013-11-05 22:58:19,526-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:58:29,238-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:58:39,246-0600 INFO  Multiplexer No streams
-2013-11-05 22:58:48,857-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:58:49,255-0600 INFO  Multiplexer No streams
-2013-11-05 22:58:51,849-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:58:59,263-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:59:09,271-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:59:19,279-0600 INFO  Multiplexer No streams
-2013-11-05 22:59:24,172-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 22:59:24,467-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:59:29,288-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:59:39,296-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 22:59:49,304-0600 INFO  Multiplexer No streams
-2013-11-05 22:59:56,495-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 22:59:59,312-0600 INFO  Multiplexer No streams
-2013-11-05 23:00:00,077-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:00:09,320-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:00:19,329-0600 INFO  Multiplexer No streams
-2013-11-05 23:00:28,818-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:00:29,337-0600 INFO  Multiplexer No streams
-2013-11-05 23:00:35,687-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:00:39,345-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:00:49,353-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:00:59,362-0600 INFO  Multiplexer No streams
-2013-11-05 23:01:01,141-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:01:09,370-0600 INFO  Multiplexer No streams
-2013-11-05 23:01:11,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:01:19,378-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:01:29,386-0600 INFO  Multiplexer No streams
-2013-11-05 23:01:33,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:01:39,394-0600 INFO  Multiplexer No streams
-2013-11-05 23:01:46,907-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:01:49,403-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:01:59,411-0600 INFO  Multiplexer No streams
-2013-11-05 23:02:05,787-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:02:09,419-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:02:19,427-0600 INFO  Multiplexer No streams
-2013-11-05 23:02:22,517-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:02:29,435-0600 INFO  Multiplexer No streams
-2013-11-05 23:02:38,110-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:02:39,444-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:02:49,452-0600 INFO  Multiplexer No streams
-2013-11-05 23:02:58,127-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:02:59,460-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:03:09,468-0600 INFO  Multiplexer No streams
-2013-11-05 23:03:10,433-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:03:19,476-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:03:29,485-0600 INFO  Multiplexer No streams
-2013-11-05 23:03:33,737-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:03:39,493-0600 INFO  Multiplexer No streams
-2013-11-05 23:03:42,756-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:03:49,500-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:03:59,508-0600 INFO  Multiplexer No streams
-2013-11-05 23:04:09,347-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:04:09,516-0600 INFO  Multiplexer No streams
-2013-11-05 23:04:15,079-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:04:19,524-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:04:29,532-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:04:39,540-0600 INFO  Multiplexer No streams
-2013-11-05 23:04:44,957-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:04:47,402-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:04:49,548-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:04:59,556-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:05:09,564-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:05:19,572-0600 INFO  Multiplexer No streams
-2013-11-05 23:05:19,725-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:05:20,567-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:05:29,580-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:05:39,587-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:05:49,595-0600 INFO  Multiplexer No streams
-2013-11-05 23:05:52,048-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:05:56,177-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:05:59,603-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:06:09,611-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:06:19,619-0600 INFO  Multiplexer No streams
-2013-11-05 23:06:24,371-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:06:29,627-0600 INFO  Multiplexer No streams
-2013-11-05 23:06:31,787-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:06:39,635-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:06:49,643-0600 INFO  Multiplexer No streams
-2013-11-05 23:06:56,694-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:06:59,651-0600 INFO  Multiplexer No streams
-2013-11-05 23:07:07,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:07:09,658-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:07:19,666-0600 INFO  Multiplexer No streams
-2013-11-05 23:07:29,017-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:07:29,674-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:07:39,682-0600 INFO  Multiplexer No streams
-2013-11-05 23:07:43,007-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:07:49,690-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:07:59,698-0600 INFO  Multiplexer No streams
-2013-11-05 23:08:01,340-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:08:09,706-0600 INFO  Multiplexer No streams
-2013-11-05 23:08:18,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:08:19,714-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:08:29,721-0600 INFO  Multiplexer No streams
-2013-11-05 23:08:33,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:08:39,729-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:08:49,737-0600 INFO  Multiplexer No streams
-2013-11-05 23:08:54,227-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:08:59,746-0600 INFO  Multiplexer No streams
-2013-11-05 23:09:05,986-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:09:09,754-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:09:19,762-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:09:29,770-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 23:09:29,837-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 23:09:38,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:09:39,778-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:09:49,786-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:09:59,794-0600 INFO  Multiplexer No streams
-2013-11-05 23:10:05,447-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:10:09,802-0600 INFO  Multiplexer No streams
-2013-11-05 23:10:10,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:10:19,810-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:10:29,818-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:10:39,827-0600 INFO  Multiplexer No streams
-2013-11-05 23:10:41,058-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-05 23:10:42,955-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:10:49,835-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:10:59,843-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:11:09,851-0600 INFO  Multiplexer No streams
-2013-11-05 23:11:15,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:11:16,667-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:11:19,859-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:11:29,867-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:11:39,875-0600 INFO  Multiplexer No streams
-2013-11-05 23:11:47,601-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:11:49,883-0600 INFO  Multiplexer No streams
-2013-11-05 23:11:52,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:11:59,892-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:12:09,900-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:12:19,908-0600 INFO  Multiplexer No streams
-2013-11-05 23:12:19,924-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:12:27,887-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:12:29,916-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:12:39,924-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:12:49,932-0600 INFO  Multiplexer No streams
-2013-11-05 23:12:52,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:12:59,940-0600 INFO  Multiplexer No streams
-2013-11-05 23:13:03,497-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:13:09,949-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:13:19,957-0600 INFO  Multiplexer No streams
-2013-11-05 23:13:24,570-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:13:29,965-0600 INFO  Multiplexer No streams
-2013-11-05 23:13:39,107-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:13:39,973-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:13:49,981-0600 INFO  Multiplexer No streams
-2013-11-05 23:13:56,892-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:13:59,989-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:14:09,997-0600 INFO  Multiplexer No streams
-2013-11-05 23:14:14,718-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:14:20,005-0600 INFO  Multiplexer No streams
-2013-11-05 23:14:29,215-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:14:30,013-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:14:40,021-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:14:50,029-0600 INFO  Multiplexer No streams
-2013-11-05 23:14:50,328-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:15:00,038-0600 INFO  Multiplexer No streams
-2013-11-05 23:15:01,538-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:15:10,046-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:15:20,054-0600 INFO  Multiplexer No streams
-2013-11-05 23:15:25,939-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:15:30,062-0600 INFO  Multiplexer No streams
-2013-11-05 23:15:33,862-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:15:40,071-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:15:50,079-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:16:00,087-0600 INFO  Multiplexer No streams
-2013-11-05 23:16:01,549-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:16:06,185-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:16:10,095-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:16:20,104-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:16:30,112-0600 INFO  Multiplexer No streams
-2013-11-05 23:16:37,159-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:16:38,507-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:16:40,120-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:16:50,129-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:17:00,137-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:17:10,145-0600 INFO  Multiplexer No streams
-2013-11-05 23:17:10,831-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 23:17:12,769-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:17:20,153-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:17:30,162-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:17:40,170-0600 INFO  Multiplexer No streams
-2013-11-05 23:17:43,156-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:17:48,379-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:17:50,178-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:18:00,187-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:18:10,195-0600 INFO  Multiplexer No streams
-2013-11-05 23:18:15,479-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:18:20,203-0600 INFO  Multiplexer No streams
-2013-11-05 23:18:23,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:18:30,211-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:18:40,219-0600 INFO  Multiplexer No streams
-2013-11-05 23:18:47,803-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:18:50,228-0600 INFO  Multiplexer No streams
-2013-11-05 23:18:59,599-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:19:00,236-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:19:10,244-0600 INFO  Multiplexer No streams
-2013-11-05 23:19:20,126-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:19:20,252-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:19:30,261-0600 INFO  Multiplexer No streams
-2013-11-05 23:19:35,209-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:19:40,269-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:19:50,277-0600 INFO  Multiplexer No streams
-2013-11-05 23:19:52,450-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:20:00,285-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:20:10,293-0600 INFO  Multiplexer No streams
-2013-11-05 23:20:10,819-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:20:20,302-0600 INFO  Multiplexer No streams
-2013-11-05 23:20:24,775-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:20:30,310-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:20:40,318-0600 INFO  Multiplexer No streams
-2013-11-05 23:20:46,429-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:20:50,326-0600 INFO  Multiplexer No streams
-2013-11-05 23:20:57,097-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:21:00,334-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:21:10,342-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:21:20,350-0600 INFO  Multiplexer No streams
-2013-11-05 23:21:22,040-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 23:21:29,420-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:21:30,357-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:21:40,365-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:21:50,373-0600 INFO  Multiplexer No streams
-2013-11-05 23:21:57,649-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:22:00,381-0600 INFO  Multiplexer No streams
-2013-11-05 23:22:01,744-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:22:10,389-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:22:20,396-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:22:30,404-0600 INFO  Multiplexer No streams
-2013-11-05 23:22:33,259-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:22:34,067-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:22:40,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:22:50,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:23:00,428-0600 INFO  Multiplexer No streams
-2013-11-05 23:23:06,390-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:23:08,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:23:10,435-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:23:20,443-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:23:30,451-0600 INFO  Multiplexer No streams
-2013-11-05 23:23:38,713-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:23:40,459-0600 INFO  Multiplexer No streams
-2013-11-05 23:23:44,479-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:23:50,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:24:00,474-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:24:10,482-0600 INFO  Multiplexer No streams
-2013-11-05 23:24:11,036-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:24:20,089-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:24:20,490-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:24:30,498-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:24:40,506-0600 INFO  Multiplexer No streams
-2013-11-05 23:24:43,359-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:24:50,514-0600 INFO  Multiplexer No streams
-2013-11-05 23:24:55,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:25:00,521-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:25:10,529-0600 INFO  Multiplexer No streams
-2013-11-05 23:25:15,682-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:25:20,537-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:25:30,545-0600 INFO  Multiplexer No streams
-2013-11-05 23:25:31,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:25:40,552-0600 INFO  Multiplexer No streams
-2013-11-05 23:25:48,005-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:25:50,560-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:26:00,568-0600 INFO  Multiplexer No streams
-2013-11-05 23:26:06,919-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:26:10,576-0600 INFO  Multiplexer No streams
-2013-11-05 23:26:20,328-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:26:20,584-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:26:30,592-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:26:40,599-0600 INFO  Multiplexer No streams
-2013-11-05 23:26:42,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:26:50,607-0600 INFO  Multiplexer No streams
-2013-11-05 23:26:52,651-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:27:00,615-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:27:10,623-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:27:18,140-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:27:20,631-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:27:24,974-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:27:30,639-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:27:40,646-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:27:50,654-0600 INFO  Multiplexer No streams
-2013-11-05 23:27:53,750-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 23:27:57,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:28:00,662-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:28:10,670-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:28:20,678-0600 INFO  Multiplexer No streams
-2013-11-05 23:28:29,361-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:28:29,620-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:28:30,686-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:28:40,694-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:28:50,702-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:29:00,710-0600 INFO  Multiplexer No streams
-2013-11-05 23:29:01,943-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:29:04,971-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:29:10,717-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:29:20,725-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:29:30,733-0600 INFO  Multiplexer No streams
-2013-11-05 23:29:34,266-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:29:40,580-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:29:40,741-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:29:50,749-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:30:00,757-0600 INFO  Multiplexer No streams
-2013-11-05 23:30:06,589-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:30:10,766-0600 INFO  Multiplexer No streams
-2013-11-05 23:30:16,191-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:30:20,774-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:30:30,782-0600 INFO  Multiplexer No streams
-2013-11-05 23:30:38,912-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:30:40,790-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:30:50,798-0600 INFO  Multiplexer No streams
-2013-11-05 23:30:51,801-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:31:00,806-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:31:10,814-0600 INFO  Multiplexer No streams
-2013-11-05 23:31:11,235-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:31:20,823-0600 INFO  Multiplexer No streams
-2013-11-05 23:31:27,411-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:31:30,831-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:31:40,839-0600 INFO  Multiplexer No streams
-2013-11-05 23:31:43,558-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:31:50,847-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:32:00,855-0600 INFO  Multiplexer No streams
-2013-11-05 23:32:03,021-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:32:10,862-0600 INFO  Multiplexer No streams
-2013-11-05 23:32:15,881-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:32:20,870-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:32:30,878-0600 INFO  Multiplexer No streams
-2013-11-05 23:32:38,631-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:32:40,886-0600 INFO  Multiplexer No streams
-2013-11-05 23:32:48,203-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:32:50,893-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:33:00,901-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:33:10,909-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:33:14,241-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:33:20,526-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:33:20,917-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:33:30,924-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:33:40,932-0600 INFO  Multiplexer No streams
-2013-11-05 23:33:49,851-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:33:50,940-0600 INFO  Multiplexer No streams
-2013-11-05 23:33:52,850-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:34:00,948-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:34:10,955-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:34:20,963-0600 INFO  Multiplexer No streams
-2013-11-05 23:34:25,174-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:34:25,461-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:34:30,971-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:34:40,979-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:34:50,986-0600 INFO  Multiplexer No streams
-2013-11-05 23:34:57,497-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:35:00,994-0600 INFO  Multiplexer No streams
-2013-11-05 23:35:01,072-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:35:11,002-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:35:21,009-0600 INFO  Multiplexer No streams
-2013-11-05 23:35:29,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:35:31,017-0600 INFO  Multiplexer No streams
-2013-11-05 23:35:36,682-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:35:41,025-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:35:51,033-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:36:01,040-0600 INFO  Multiplexer No streams
-2013-11-05 23:36:02,143-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:36:11,048-0600 INFO  Multiplexer No streams
-2013-11-05 23:36:12,293-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:36:21,056-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:36:31,064-0600 INFO  Multiplexer No streams
-2013-11-05 23:36:34,466-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:36:41,072-0600 INFO  Multiplexer No streams
-2013-11-05 23:36:47,903-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:36:51,079-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:37:01,087-0600 INFO  Multiplexer No streams
-2013-11-05 23:37:06,789-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:37:11,095-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:37:21,103-0600 INFO  Multiplexer No streams
-2013-11-05 23:37:23,513-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:37:31,110-0600 INFO  Multiplexer No streams
-2013-11-05 23:37:39,112-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:37:41,118-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:37:51,126-0600 INFO  Multiplexer No streams
-2013-11-05 23:37:59,123-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:38:01,134-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:38:11,142-0600 INFO  Multiplexer No streams
-2013-11-05 23:38:11,435-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:38:21,149-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:38:31,157-0600 INFO  Multiplexer No streams
-2013-11-05 23:38:34,733-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:38:41,165-0600 INFO  Multiplexer No streams
-2013-11-05 23:38:43,758-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:38:51,173-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:39:01,180-0600 INFO  Multiplexer No streams
-2013-11-05 23:39:10,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:39:11,188-0600 INFO  Multiplexer No streams
-2013-11-05 23:39:16,081-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:39:21,196-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:39:31,204-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:39:41,212-0600 INFO  Multiplexer No streams
-2013-11-05 23:39:45,953-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:39:48,404-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:39:51,219-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:40:01,227-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:40:11,235-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-05 23:40:20,727-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:40:21,243-0600 INFO  Multiplexer No streams
-2013-11-05 23:40:21,563-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:40:31,251-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:40:41,259-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:40:51,266-0600 INFO  Multiplexer No streams
-2013-11-05 23:40:53,051-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:40:57,173-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:41:01,274-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:41:11,282-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:41:21,290-0600 INFO  Multiplexer No streams
-2013-11-05 23:41:25,373-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:41:31,298-0600 INFO  Multiplexer No streams
-2013-11-05 23:41:32,784-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:41:41,306-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:41:51,313-0600 INFO  Multiplexer No streams
-2013-11-05 23:41:57,697-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:42:01,321-0600 INFO  Multiplexer No streams
-2013-11-05 23:42:08,393-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:42:11,329-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:42:21,337-0600 INFO  Multiplexer No streams
-2013-11-05 23:42:30,020-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:42:31,345-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:42:41,352-0600 INFO  Multiplexer No streams
-2013-11-05 23:42:44,003-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:42:51,360-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:43:01,368-0600 INFO  Multiplexer No streams
-2013-11-05 23:43:02,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:43:11,376-0600 INFO  Multiplexer No streams
-2013-11-05 23:43:19,613-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:43:21,384-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:43:31,392-0600 INFO  Multiplexer No streams
-2013-11-05 23:43:34,666-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:43:41,399-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:43:51,407-0600 INFO  Multiplexer No streams
-2013-11-05 23:43:55,223-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:44:01,415-0600 INFO  Multiplexer No streams
-2013-11-05 23:44:06,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:44:11,423-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:44:21,431-0600 INFO  Multiplexer No streams
-2013-11-05 23:44:30,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:44:31,439-0600 INFO  Multiplexer No streams
-2013-11-05 23:44:39,312-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:44:41,447-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:44:51,455-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:45:01,463-0600 INFO  Multiplexer No streams
-2013-11-05 23:45:06,443-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:45:11,471-0600 INFO  Multiplexer No streams
-2013-11-05 23:45:11,635-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:45:21,479-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:45:31,486-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:45:41,494-0600 INFO  Multiplexer No streams
-2013-11-05 23:45:42,053-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:45:43,958-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:45:51,502-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:46:01,510-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:46:11,518-0600 INFO  Multiplexer No streams
-2013-11-05 23:46:16,281-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:46:17,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:46:21,525-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:46:31,533-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:46:41,541-0600 INFO  Multiplexer No streams
-2013-11-05 23:46:48,604-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:46:51,549-0600 INFO  Multiplexer No streams
-2013-11-05 23:46:53,273-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:47:01,556-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:47:11,564-0600 INFO  Multiplexer No streams
-2013-11-05 23:47:20,927-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:47:21,572-0600 INFO  Multiplexer No streams
-2013-11-05 23:47:28,883-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:47:31,580-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:47:41,588-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:47:51,595-0600 INFO  Multiplexer No streams
-2013-11-05 23:47:53,250-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:48:01,603-0600 INFO  Multiplexer No streams
-2013-11-05 23:48:04,493-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:48:11,611-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:48:21,619-0600 INFO  Multiplexer No streams
-2013-11-05 23:48:25,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:48:31,627-0600 INFO  Multiplexer No streams
-2013-11-05 23:48:40,103-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:48:41,635-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:48:51,642-0600 INFO  Multiplexer No streams
-2013-11-05 23:48:57,895-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:49:01,650-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:49:11,658-0600 INFO  Multiplexer No streams
-2013-11-05 23:49:15,713-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:49:21,666-0600 INFO  Multiplexer No streams
-2013-11-05 23:49:30,218-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:49:31,674-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:49:41,681-0600 INFO  Multiplexer No streams
-2013-11-05 23:49:51,323-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:49:51,689-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:50:01,697-0600 INFO  Multiplexer No streams
-2013-11-05 23:50:02,542-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:50:11,705-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:50:21,713-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-05 23:50:26,934-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-05 23:50:31,720-0600 INFO  Multiplexer No streams
-2013-11-05 23:50:34,866-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:50:41,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:50:51,736-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:51:01,744-0600 INFO  Multiplexer No streams
-2013-11-05 23:51:02,543-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:51:07,190-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:51:11,752-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:51:21,759-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:51:31,767-0600 INFO  Multiplexer No streams
-2013-11-05 23:51:38,153-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:51:39,513-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:51:41,775-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:51:51,783-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:52:01,791-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:52:11,798-0600 INFO  Multiplexer No streams
-2013-11-05 23:52:11,836-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:52:13,763-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:52:21,806-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:52:31,814-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:52:41,822-0600 INFO  Multiplexer No streams
-2013-11-05 23:52:44,159-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:52:49,373-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:52:51,830-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:53:01,837-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:53:11,845-0600 INFO  Multiplexer No streams
-2013-11-05 23:53:16,482-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:53:21,853-0600 INFO  Multiplexer No streams
-2013-11-05 23:53:24,983-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:53:31,861-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:53:41,868-0600 INFO  Multiplexer No streams
-2013-11-05 23:53:48,805-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:53:51,876-0600 INFO  Multiplexer No streams
-2013-11-05 23:54:00,593-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:54:01,884-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:54:11,892-0600 INFO  Multiplexer No streams
-2013-11-05 23:54:21,128-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:54:21,900-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:54:31,907-0600 INFO  Multiplexer No streams
-2013-11-05 23:54:36,203-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:54:41,915-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:54:51,923-0600 INFO  Multiplexer No streams
-2013-11-05 23:54:53,451-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:55:01,931-0600 INFO  Multiplexer No streams
-2013-11-05 23:55:11,813-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:55:11,939-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:55:21,946-0600 INFO  Multiplexer No streams
-2013-11-05 23:55:25,774-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:55:31,954-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:55:41,962-0600 INFO  Multiplexer No streams
-2013-11-05 23:55:47,423-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-05 23:55:51,970-0600 INFO  Multiplexer No streams
-2013-11-05 23:55:58,097-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:56:01,977-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:56:11,985-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:56:21,993-0600 INFO  Multiplexer No streams
-2013-11-05 23:56:23,033-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:56:30,420-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:56:32,001-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:56:42,009-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:56:52,016-0600 INFO  Multiplexer No streams
-2013-11-05 23:56:58,643-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:57:02,024-0600 INFO  Multiplexer No streams
-2013-11-05 23:57:02,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:57:12,032-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:57:22,040-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:57:32,047-0600 INFO  Multiplexer No streams
-2013-11-05 23:57:34,253-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-05 23:57:35,066-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:57:42,055-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:57:52,063-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:58:02,071-0600 INFO  Multiplexer No streams
-2013-11-05 23:58:07,389-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-05 23:58:09,863-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:58:12,079-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:58:22,087-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:58:32,095-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-05 23:58:39,711-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-05 23:58:42,103-0600 INFO  Multiplexer No streams
-2013-11-05 23:58:45,473-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-05 23:58:52,111-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:59:02,119-0600 INFO  Multiplexer No streams
-2013-11-05 23:59:12,035-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:59:12,127-0600 INFO  Multiplexer No streams
-2013-11-05 23:59:21,084-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:59:22,135-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:59:32,143-0600 INFO  Multiplexer No streams
-No streams
-2013-11-05 23:59:42,151-0600 INFO  Multiplexer No streams
-2013-11-05 23:59:44,358-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-05 23:59:52,159-0600 INFO  Multiplexer No streams
-2013-11-05 23:59:56,694-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:00:02,166-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:00:12,174-0600 INFO  Multiplexer No streams
-2013-11-06 00:00:16,681-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:00:22,182-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:00:32,190-0600 INFO  Multiplexer No streams
-2013-11-06 00:00:32,304-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:00:42,198-0600 INFO  Multiplexer No streams
-2013-11-06 00:00:49,004-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:00:52,206-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:01:02,214-0600 INFO  Multiplexer No streams
-2013-11-06 00:01:07,914-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:01:12,222-0600 INFO  Multiplexer No streams
-2013-11-06 00:01:21,327-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:01:22,230-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:01:32,238-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:01:42,248-0600 INFO  Multiplexer No streams
-2013-11-06 00:01:43,524-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:01:52,260-0600 INFO  Multiplexer No streams
-2013-11-06 00:01:53,650-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:02:02,273-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:02:12,283-0600 INFO  Multiplexer No streams
-2013-11-06 00:02:19,134-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:02:22,293-0600 INFO  Multiplexer No streams
-2013-11-06 00:02:25,973-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:02:32,302-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:02:42,313-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:02:52,322-0600 INFO  Multiplexer No streams
-2013-11-06 00:02:54,745-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 00:02:58,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:03:02,332-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:03:12,345-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:03:22,355-0600 INFO  Multiplexer No streams
-2013-11-06 00:03:30,355-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 00:03:30,619-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:03:32,366-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:03:42,378-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:03:52,390-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:04:02,403-0600 INFO  Multiplexer No streams
-2013-11-06 00:04:02,942-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:04:05,965-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:04:12,415-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:04:22,425-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:04:32,438-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 00:04:35,266-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 00:04:41,574-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:04:42,448-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:04:52,458-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:05:02,468-0600 INFO  Multiplexer No streams
-2013-11-06 00:05:07,589-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:05:12,478-0600 INFO  Multiplexer No streams
-2013-11-06 00:05:17,185-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:05:22,487-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:05:32,497-0600 INFO  Multiplexer No streams
-2013-11-06 00:05:39,912-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:05:42,507-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:05:52,517-0600 INFO  Multiplexer No streams
-2013-11-06 00:05:52,794-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:06:02,527-0600 INFO  Multiplexer No streams
-2013-11-06 00:06:12,235-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:06:12,537-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:06:22,546-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 00:06:28,405-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 00:06:32,556-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:06:42,566-0600 INFO  Multiplexer No streams
-2013-11-06 00:06:44,559-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:06:52,576-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:07:02,587-0600 INFO  Multiplexer No streams
-2013-11-06 00:07:04,015-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:07:12,597-0600 INFO  Multiplexer No streams
-2013-11-06 00:07:16,882-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 00:07:22,605-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:07:32,613-0600 INFO  Multiplexer No streams
-2013-11-06 00:07:39,624-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:07:42,622-0600 INFO  Multiplexer No streams
-2013-11-06 00:07:49,204-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:07:52,630-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:08:02,639-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:08:12,647-0600 INFO  Multiplexer No streams
-2013-11-06 00:08:15,234-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:08:21,527-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:08:22,655-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:08:32,663-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:08:42,672-0600 INFO  Multiplexer No streams
-2013-11-06 00:08:50,844-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:08:52,680-0600 INFO  Multiplexer No streams
-2013-11-06 00:08:53,850-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:09:02,688-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:09:12,696-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:09:22,704-0600 INFO  Multiplexer No streams
-2013-11-06 00:09:26,174-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:09:26,454-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:09:32,712-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:09:42,720-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:09:52,728-0600 INFO  Multiplexer No streams
-2013-11-06 00:09:58,497-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:10:02,064-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:10:02,737-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:10:12,745-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:10:22,753-0600 INFO  Multiplexer No streams
-2013-11-06 00:10:30,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:10:32,761-0600 INFO  Multiplexer No streams
-2013-11-06 00:10:37,674-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:10:42,770-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:10:52,778-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:11:02,786-0600 INFO  Multiplexer No streams
-2013-11-06 00:11:03,143-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:11:12,794-0600 INFO  Multiplexer No streams
-2013-11-06 00:11:13,284-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:11:22,802-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:11:32,810-0600 INFO  Multiplexer No streams
-2013-11-06 00:11:35,466-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:11:42,818-0600 INFO  Multiplexer No streams
-2013-11-06 00:11:48,894-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:11:52,826-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:12:02,834-0600 INFO  Multiplexer No streams
-2013-11-06 00:12:07,789-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:12:12,842-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:12:22,850-0600 INFO  Multiplexer No streams
-2013-11-06 00:12:24,504-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:12:32,858-0600 INFO  Multiplexer No streams
-2013-11-06 00:12:40,112-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:12:42,866-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:12:52,874-0600 INFO  Multiplexer No streams
-2013-11-06 00:13:00,114-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:13:02,882-0600 INFO  Multiplexer No streams
-2013-11-06 00:13:12,435-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:13:12,890-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:13:22,898-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:13:32,905-0600 INFO  Multiplexer No streams
-2013-11-06 00:13:35,724-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:13:42,913-0600 INFO  Multiplexer No streams
-2013-11-06 00:13:44,758-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:13:52,921-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:14:02,929-0600 INFO  Multiplexer No streams
-2013-11-06 00:14:11,334-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:14:12,937-0600 INFO  Multiplexer No streams
-2013-11-06 00:14:17,080-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:14:22,945-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:14:32,953-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:14:42,961-0600 INFO  Multiplexer No streams
-2013-11-06 00:14:46,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:14:49,403-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:14:52,969-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:15:02,976-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:15:12,984-0600 INFO  Multiplexer No streams
-2013-11-06 00:15:21,727-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:15:22,554-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:15:22,992-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:15:33,000-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:15:43,008-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:15:53,016-0600 INFO  Multiplexer No streams
-2013-11-06 00:15:54,050-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:15:58,165-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 00:16:03,023-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:16:13,031-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:16:23,039-0600 INFO  Multiplexer No streams
-2013-11-06 00:16:26,373-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:16:33,047-0600 INFO  Multiplexer No streams
-2013-11-06 00:16:33,775-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:16:43,055-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:16:53,062-0600 INFO  Multiplexer No streams
-2013-11-06 00:16:58,696-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:17:03,070-0600 INFO  Multiplexer No streams
-2013-11-06 00:17:09,385-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:17:13,078-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:17:23,086-0600 INFO  Multiplexer No streams
-2013-11-06 00:17:31,019-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:17:33,093-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:17:43,101-0600 INFO  Multiplexer No streams
-2013-11-06 00:17:44,995-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:17:53,109-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:18:03,117-0600 INFO  Multiplexer No streams
-2013-11-06 00:18:03,342-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:18:13,124-0600 INFO  Multiplexer No streams
-2013-11-06 00:18:20,605-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:18:23,132-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:18:33,140-0600 INFO  Multiplexer No streams
-2013-11-06 00:18:35,665-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:18:43,147-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:18:53,155-0600 INFO  Multiplexer No streams
-2013-11-06 00:18:56,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:19:03,162-0600 INFO  Multiplexer No streams
-2013-11-06 00:19:07,988-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:19:13,170-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:19:23,178-0600 INFO  Multiplexer No streams
-2013-11-06 00:19:31,826-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:19:33,186-0600 INFO  Multiplexer No streams
-2013-11-06 00:19:40,311-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:19:43,193-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:19:53,201-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:20:03,209-0600 INFO  Multiplexer No streams
-2013-11-06 00:20:07,436-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:20:12,634-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:20:13,217-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:20:23,225-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:20:33,233-0600 INFO  Multiplexer No streams
-2013-11-06 00:20:43,046-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:20:43,241-0600 INFO  Multiplexer No streams
-2013-11-06 00:20:44,957-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:20:53,248-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:21:03,256-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:21:13,264-0600 INFO  Multiplexer No streams
-2013-11-06 00:21:17,280-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:21:18,656-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:21:23,272-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:21:33,280-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:21:43,288-0600 INFO  Multiplexer No streams
-2013-11-06 00:21:49,603-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:21:53,295-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 00:21:54,265-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:22:03,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:22:13,311-0600 INFO  Multiplexer No streams
-2013-11-06 00:22:21,926-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:22:23,319-0600 INFO  Multiplexer No streams
-2013-11-06 00:22:29,876-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:22:33,327-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:22:43,334-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:22:53,342-0600 INFO  Multiplexer No streams
-2013-11-06 00:22:54,249-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:23:03,350-0600 INFO  Multiplexer No streams
-2013-11-06 00:23:05,486-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:23:13,358-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:23:23,365-0600 INFO  Multiplexer No streams
-2013-11-06 00:23:26,572-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:23:33,373-0600 INFO  Multiplexer No streams
-2013-11-06 00:23:41,096-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:23:43,381-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:23:53,389-0600 INFO  Multiplexer No streams
-2013-11-06 00:23:58,895-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:24:03,397-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:24:13,404-0600 INFO  Multiplexer No streams
-2013-11-06 00:24:16,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:24:23,412-0600 INFO  Multiplexer No streams
-2013-11-06 00:24:31,218-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:24:33,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:24:43,428-0600 INFO  Multiplexer No streams
-2013-11-06 00:24:52,316-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:24:53,436-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:25:03,444-0600 INFO  Multiplexer No streams
-2013-11-06 00:25:03,541-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:25:13,451-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:25:23,459-0600 INFO  Multiplexer No streams
-2013-11-06 00:25:27,926-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:25:33,467-0600 INFO  Multiplexer No streams
-2013-11-06 00:25:35,864-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:25:43,474-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:25:53,482-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:26:03,490-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 00:26:03,535-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 00:26:08,187-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:26:13,498-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:26:23,506-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:26:33,514-0600 INFO  Multiplexer No streams
-2013-11-06 00:26:39,146-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:26:40,510-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:26:43,521-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:26:53,529-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:27:03,537-0600 INFO  Multiplexer No streams
-2013-11-06 00:27:12,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:27:13,544-0600 INFO  Multiplexer No streams
-2013-11-06 00:27:14,756-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:27:23,552-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:27:33,560-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:27:43,567-0600 INFO  Multiplexer No streams
-2013-11-06 00:27:45,156-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:27:50,367-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:27:53,575-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:28:03,583-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:28:13,590-0600 INFO  Multiplexer No streams
-2013-11-06 00:28:17,479-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:28:23,598-0600 INFO  Multiplexer No streams
-2013-11-06 00:28:25,977-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:28:33,606-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:28:43,613-0600 INFO  Multiplexer No streams
-2013-11-06 00:28:49,802-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:28:53,621-0600 INFO  Multiplexer No streams
-2013-11-06 00:29:01,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:29:03,629-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:29:13,636-0600 INFO  Multiplexer No streams
-2013-11-06 00:29:22,125-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:29:23,644-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:29:33,652-0600 INFO  Multiplexer No streams
-2013-11-06 00:29:37,197-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:29:43,659-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:29:53,667-0600 INFO  Multiplexer No streams
-2013-11-06 00:29:54,448-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:30:03,674-0600 INFO  Multiplexer No streams
-2013-11-06 00:30:12,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:30:13,682-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:30:23,690-0600 INFO  Multiplexer No streams
-2013-11-06 00:30:26,772-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:30:33,697-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:30:43,705-0600 INFO  Multiplexer No streams
-2013-11-06 00:30:48,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:30:53,713-0600 INFO  Multiplexer No streams
-2013-11-06 00:30:59,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:31:03,720-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:31:13,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:31:23,735-0600 INFO  Multiplexer No streams
-2013-11-06 00:31:24,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 00:31:31,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:31:33,743-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:31:43,751-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:31:53,758-0600 INFO  Multiplexer No streams
-2013-11-06 00:31:59,638-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:32:03,741-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:32:03,766-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:32:13,773-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:32:23,781-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:32:33,789-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:32:35,248-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:32:36,065-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:32:43,796-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:32:53,804-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:33:03,811-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:33:08,389-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:33:10,858-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:33:13,819-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:33:23,827-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:33:33,834-0600 INFO  Multiplexer No streams
-2013-11-06 00:33:40,712-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:33:43,842-0600 INFO  Multiplexer No streams
-2013-11-06 00:33:46,468-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:33:53,849-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:34:03,857-0600 INFO  Multiplexer No streams
-2013-11-06 00:34:13,035-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:34:13,865-0600 INFO  Multiplexer No streams
-2013-11-06 00:34:22,077-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:34:23,872-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:34:33,880-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:34:43,887-0600 INFO  Multiplexer No streams
-2013-11-06 00:34:45,358-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:34:53,895-0600 INFO  Multiplexer No streams
-2013-11-06 00:34:57,688-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:35:03,903-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:35:13,910-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 00:35:17,682-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 00:35:23,918-0600 INFO  Multiplexer No streams
-2013-11-06 00:35:33,299-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:35:33,926-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:35:43,933-0600 INFO  Multiplexer No streams
-2013-11-06 00:35:50,005-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:35:53,941-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:36:03,948-0600 INFO  Multiplexer No streams
-2013-11-06 00:36:08,909-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:36:13,956-0600 INFO  Multiplexer No streams
-2013-11-06 00:36:22,328-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:36:23,964-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:36:33,971-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:36:43,979-0600 INFO  Multiplexer No streams
-2013-11-06 00:36:44,519-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:36:53,987-0600 INFO  Multiplexer No streams
-2013-11-06 00:36:54,651-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:37:03,994-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:37:14,002-0600 INFO  Multiplexer No streams
-2013-11-06 00:37:20,129-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:37:24,010-0600 INFO  Multiplexer No streams
-2013-11-06 00:37:26,974-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:37:34,018-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:37:44,025-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:37:54,033-0600 INFO  Multiplexer No streams
-2013-11-06 00:37:55,739-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:37:59,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:38:04,041-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:38:14,049-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:38:24,057-0600 INFO  Multiplexer No streams
-2013-11-06 00:38:31,349-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:38:31,619-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:38:34,064-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:38:44,072-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:38:54,080-0600 INFO  Multiplexer No streams
-2013-11-06 00:39:03,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:39:04,088-0600 INFO  Multiplexer No streams
-2013-11-06 00:39:06,959-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:39:14,095-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:39:24,103-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:39:34,111-0600 INFO  Multiplexer No streams
-2013-11-06 00:39:36,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 00:39:42,570-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:39:44,119-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:39:54,127-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:40:04,135-0600 INFO  Multiplexer No streams
-2013-11-06 00:40:08,589-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:40:14,143-0600 INFO  Multiplexer No streams
-2013-11-06 00:40:18,180-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:40:24,151-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:40:34,159-0600 INFO  Multiplexer No streams
-2013-11-06 00:40:40,913-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:40:44,167-0600 INFO  Multiplexer No streams
-2013-11-06 00:40:53,790-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:40:54,175-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:41:04,183-0600 INFO  Multiplexer No streams
-2013-11-06 00:41:13,236-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:41:14,191-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:41:24,199-0600 INFO  Multiplexer No streams
-2013-11-06 00:41:29,400-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:41:34,207-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:41:44,215-0600 INFO  Multiplexer No streams
-2013-11-06 00:41:45,559-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:41:54,223-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:42:04,231-0600 INFO  Multiplexer No streams
-2013-11-06 00:42:05,010-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:42:14,239-0600 INFO  Multiplexer No streams
-2013-11-06 00:42:17,882-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:42:24,248-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:42:34,256-0600 INFO  Multiplexer No streams
-2013-11-06 00:42:40,620-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:42:44,264-0600 INFO  Multiplexer No streams
-2013-11-06 00:42:50,204-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:42:54,273-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:43:04,281-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:43:14,289-0600 INFO  Multiplexer No streams
-2013-11-06 00:43:16,230-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:43:22,528-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:43:24,297-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:43:34,306-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:43:44,314-0600 INFO  Multiplexer No streams
-2013-11-06 00:43:51,840-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:43:54,322-0600 INFO  Multiplexer No streams
-2013-11-06 00:43:54,850-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:44:04,331-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:44:14,339-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:44:24,347-0600 INFO  Multiplexer No streams
-2013-11-06 00:44:27,174-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 00:44:27,449-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:44:34,355-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:44:44,363-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:44:54,371-0600 INFO  Multiplexer No streams
-2013-11-06 00:44:59,498-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 00:45:03,060-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:45:04,379-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:45:14,388-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:45:24,396-0600 INFO  Multiplexer No streams
-2013-11-06 00:45:31,823-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:45:34,404-0600 INFO  Multiplexer No streams
-2013-11-06 00:45:38,670-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:45:44,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:45:54,419-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 00:46:04,145-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:46:04,427-0600 INFO  Multiplexer No streams
-2013-11-06 00:46:14,281-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:46:14,435-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:46:24,443-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:46:34,451-0600 INFO  Multiplexer No streams
-2013-11-06 00:46:36,468-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:46:44,459-0600 INFO  Multiplexer No streams
-2013-11-06 00:46:49,891-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:46:54,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:47:04,474-0600 INFO  Multiplexer No streams
-2013-11-06 00:47:08,792-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:47:14,482-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:47:24,490-0600 INFO  Multiplexer No streams
-2013-11-06 00:47:25,501-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 00:47:34,498-0600 INFO  Multiplexer No streams
-2013-11-06 00:47:41,115-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:47:44,506-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:47:54,514-0600 INFO  Multiplexer No streams
-2013-11-06 00:48:01,112-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 00:48:04,521-0600 INFO  Multiplexer No streams
-2013-11-06 00:48:13,438-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:48:14,529-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:48:24,537-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:48:34,545-0600 INFO  Multiplexer No streams
-2013-11-06 00:48:36,722-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:48:44,553-0600 INFO  Multiplexer No streams
-2013-11-06 00:48:45,761-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:48:54,561-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:49:04,568-0600 INFO  Multiplexer No streams
-2013-11-06 00:49:12,332-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:49:14,576-0600 INFO  Multiplexer No streams
-2013-11-06 00:49:18,084-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:49:24,584-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:49:34,592-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:49:44,599-0600 INFO  Multiplexer No streams
-2013-11-06 00:49:47,942-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:49:50,407-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:49:54,607-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:50:04,615-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:50:14,622-0600 INFO  Multiplexer No streams
-2013-11-06 00:50:22,730-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:50:23,552-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:50:24,630-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:50:34,638-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:50:44,646-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:50:54,653-0600 INFO  Multiplexer No streams
-2013-11-06 00:50:55,053-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:50:59,162-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:51:04,661-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:51:14,669-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:51:24,676-0600 INFO  Multiplexer No streams
-2013-11-06 00:51:27,376-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:51:34,684-0600 INFO  Multiplexer No streams
-2013-11-06 00:51:34,772-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:51:44,692-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:51:54,700-0600 INFO  Multiplexer No streams
-2013-11-06 00:51:59,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:52:04,707-0600 INFO  Multiplexer No streams
-2013-11-06 00:52:10,382-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:52:14,715-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:52:24,723-0600 INFO  Multiplexer No streams
-2013-11-06 00:52:32,022-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:52:34,731-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:52:44,738-0600 INFO  Multiplexer No streams
-2013-11-06 00:52:45,992-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:52:54,747-0600 INFO  Multiplexer No streams
-2013-11-06 00:53:04,346-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:53:04,754-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:53:14,762-0600 INFO  Multiplexer No streams
-2013-11-06 00:53:21,603-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 00:53:24,769-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:53:34,777-0600 INFO  Multiplexer No streams
-2013-11-06 00:53:36,669-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:53:44,785-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:53:54,793-0600 INFO  Multiplexer No streams
-2013-11-06 00:53:57,212-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:54:04,801-0600 INFO  Multiplexer No streams
-2013-11-06 00:54:08,991-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:54:14,809-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:54:24,816-0600 INFO  Multiplexer No streams
-2013-11-06 00:54:32,822-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:54:34,824-0600 INFO  Multiplexer No streams
-2013-11-06 00:54:41,314-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:54:44,832-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:54:54,840-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:55:04,847-0600 INFO  Multiplexer No streams
-2013-11-06 00:55:08,432-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:55:13,637-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:55:14,855-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:55:24,863-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:55:34,871-0600 INFO  Multiplexer No streams
-2013-11-06 00:55:44,042-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:55:44,879-0600 INFO  Multiplexer No streams
-2013-11-06 00:55:45,960-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:55:54,887-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:56:04,895-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:56:14,903-0600 INFO  Multiplexer No streams
-2013-11-06 00:56:18,283-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 00:56:19,652-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:56:24,911-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:56:34,918-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:56:44,926-0600 INFO  Multiplexer No streams
-2013-11-06 00:56:50,606-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:56:54,934-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 00:56:55,263-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 00:57:04,942-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:57:14,949-0600 INFO  Multiplexer No streams
-2013-11-06 00:57:22,929-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:57:24,958-0600 INFO  Multiplexer No streams
-2013-11-06 00:57:30,873-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 00:57:34,966-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:57:44,975-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:57:54,982-0600 INFO  Multiplexer No streams
-2013-11-06 00:57:55,252-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:58:04,989-0600 INFO  Multiplexer No streams
-2013-11-06 00:58:06,483-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:58:14,997-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:58:25,005-0600 INFO  Multiplexer No streams
-2013-11-06 00:58:27,575-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:58:35,013-0600 INFO  Multiplexer No streams
-2013-11-06 00:58:42,092-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:58:45,023-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:58:55,033-0600 INFO  Multiplexer No streams
-2013-11-06 00:58:59,898-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:59:05,043-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:59:15,054-0600 INFO  Multiplexer No streams
-2013-11-06 00:59:17,702-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:59:25,062-0600 INFO  Multiplexer No streams
-2013-11-06 00:59:32,222-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 00:59:35,073-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 00:59:45,084-0600 INFO  Multiplexer No streams
-2013-11-06 00:59:53,312-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 00:59:55,094-0600 INFO  Multiplexer No streams
-2013-11-06 01:00:04,544-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:00:05,105-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:00:15,115-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:00:25,126-0600 INFO  Multiplexer No streams
-2013-11-06 01:00:28,922-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:00:35,136-0600 INFO  Multiplexer No streams
-2013-11-06 01:00:36,868-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 01:00:45,156-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:00:55,174-0600 INFO  Multiplexer No streams
-2013-11-06 01:01:04,533-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:01:05,180-0600 INFO  Multiplexer No streams
-2013-11-06 01:01:09,191-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:01:15,183-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:01:25,188-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:01:35,192-0600 INFO  Multiplexer No streams
-2013-11-06 01:01:40,143-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 01:01:41,515-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 01:01:45,200-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:01:55,218-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:02:05,227-0600 INFO  Multiplexer No streams
-2013-11-06 01:02:13,837-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:02:15,236-0600 INFO  Multiplexer No streams
-2013-11-06 01:02:15,752-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:02:25,245-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:02:35,254-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:02:45,263-0600 INFO  Multiplexer No streams
-2013-11-06 01:02:46,161-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 01:02:51,363-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:02:55,272-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:03:05,281-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:03:15,292-0600 INFO  Multiplexer No streams
-2013-11-06 01:03:18,483-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:03:25,301-0600 INFO  Multiplexer No streams
-2013-11-06 01:03:26,973-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:03:35,311-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:03:45,320-0600 INFO  Multiplexer No streams
-2013-11-06 01:03:50,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:03:55,329-0600 INFO  Multiplexer No streams
-2013-11-06 01:04:02,583-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:04:05,342-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:04:15,352-0600 INFO  Multiplexer No streams
-2013-11-06 01:04:23,130-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:04:25,363-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:04:35,373-0600 INFO  Multiplexer No streams
-2013-11-06 01:04:38,192-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:04:45,382-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:04:55,390-0600 INFO  Multiplexer No streams
-2013-11-06 01:04:55,453-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:05:05,398-0600 INFO  Multiplexer No streams
-2013-11-06 01:05:13,802-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:05:15,405-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:05:25,413-0600 INFO  Multiplexer No streams
-2013-11-06 01:05:27,776-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:05:35,421-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:05:45,430-0600 INFO  Multiplexer No streams
-2013-11-06 01:05:49,413-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:05:55,441-0600 INFO  Multiplexer No streams
-2013-11-06 01:06:00,100-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 01:06:05,452-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:06:15,463-0600 INFO  Multiplexer No streams
-2013-11-06 01:06:25,023-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:06:25,472-0600 INFO  Multiplexer No streams
-2013-11-06 01:06:32,423-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:06:35,482-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:06:45,492-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:06:55,500-0600 INFO  Multiplexer No streams
-2013-11-06 01:07:00,633-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:07:04,746-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:07:05,509-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:07:15,517-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:07:25,526-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:07:35,534-0600 INFO  Multiplexer No streams
-2013-11-06 01:07:36,243-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:07:37,068-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:07:45,542-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:07:55,551-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:08:05,560-0600 INFO  Multiplexer No streams
-2013-11-06 01:08:09,392-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:08:11,853-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:08:15,568-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:08:25,578-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:08:35,587-0600 INFO  Multiplexer No streams
-2013-11-06 01:08:41,715-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:08:45,596-0600 INFO  Multiplexer No streams
-2013-11-06 01:08:47,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:08:55,604-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:09:05,613-0600 INFO  Multiplexer No streams
-2013-11-06 01:09:14,038-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:09:15,621-0600 INFO  Multiplexer No streams
-2013-11-06 01:09:23,073-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:09:25,630-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:09:35,640-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:09:45,650-0600 INFO  Multiplexer No streams
-2013-11-06 01:09:46,360-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:09:55,661-0600 INFO  Multiplexer No streams
-2013-11-06 01:09:58,683-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:10:05,669-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:10:15,679-0600 INFO  Multiplexer No streams
-2013-11-06 01:10:18,683-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:10:25,690-0600 INFO  Multiplexer No streams
-2013-11-06 01:10:34,294-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:10:35,699-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:10:45,709-0600 INFO  Multiplexer No streams
-2013-11-06 01:10:51,006-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:10:55,720-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:11:05,732-0600 INFO  Multiplexer No streams
-2013-11-06 01:11:09,903-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:11:15,742-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 01:11:23,330-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 01:11:25,753-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:11:35,764-0600 INFO  Multiplexer No streams
-2013-11-06 01:11:45,513-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:11:45,775-0600 INFO  Multiplexer No streams
-2013-11-06 01:11:55,652-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:11:55,784-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:12:05,794-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:12:15,804-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:12:21,124-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:12:25,814-0600 INFO  Multiplexer No streams
-2013-11-06 01:12:27,975-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:12:35,824-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:12:45,833-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:12:55,846-0600 INFO  Multiplexer No streams
-2013-11-06 01:12:56,733-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:13:00,299-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:13:05,856-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:13:15,865-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:13:25,874-0600 INFO  Multiplexer No streams
-2013-11-06 01:13:32,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:13:32,621-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:13:35,883-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:13:45,891-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:13:55,902-0600 INFO  Multiplexer No streams
-2013-11-06 01:14:04,945-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:14:05,910-0600 INFO  Multiplexer No streams
-2013-11-06 01:14:07,953-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:14:15,921-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:14:25,930-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:14:35,943-0600 INFO  Multiplexer No streams
-2013-11-06 01:14:37,268-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:14:43,564-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:14:45,956-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:14:55,965-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:15:05,974-0600 INFO  Multiplexer No streams
-2013-11-06 01:15:09,591-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:15:15,984-0600 INFO  Multiplexer No streams
-2013-11-06 01:15:19,173-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:15:25,993-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:15:36,002-0600 INFO  Multiplexer No streams
-2013-11-06 01:15:41,915-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 01:15:46,010-0600 INFO  Multiplexer No streams
-2013-11-06 01:15:54,783-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:15:56,019-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:16:06,027-0600 INFO  Multiplexer No streams
-2013-11-06 01:16:14,237-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:16:16,035-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:16:26,044-0600 INFO  Multiplexer No streams
-2013-11-06 01:16:30,393-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:16:36,056-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:16:46,065-0600 INFO  Multiplexer No streams
-2013-11-06 01:16:46,561-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:16:56,074-0600 INFO  Multiplexer No streams
-2013-11-06 01:17:06,004-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:17:06,083-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:17:16,095-0600 INFO  Multiplexer No streams
-2013-11-06 01:17:18,885-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:17:26,105-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:17:36,114-0600 INFO  Multiplexer No streams
-2013-11-06 01:17:41,613-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:17:46,123-0600 INFO  Multiplexer No streams
-2013-11-06 01:17:51,207-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:17:56,131-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:18:06,141-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:18:16,151-0600 INFO  Multiplexer No streams
-2013-11-06 01:18:17,223-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:18:23,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:18:26,160-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:18:36,169-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:18:46,178-0600 INFO  Multiplexer No streams
-2013-11-06 01:18:52,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:18:55,853-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:18:56,190-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:19:06,203-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:19:16,213-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:19:26,223-0600 INFO  Multiplexer No streams
-2013-11-06 01:19:28,177-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:19:28,443-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:19:36,236-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:19:46,245-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:19:56,252-0600 INFO  Multiplexer No streams
-2013-11-06 01:20:00,501-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:20:04,053-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:20:06,260-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:20:16,267-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:20:26,275-0600 INFO  Multiplexer No streams
-2013-11-06 01:20:32,823-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:20:36,282-0600 INFO  Multiplexer No streams
-2013-11-06 01:20:39,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:20:46,289-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:20:56,297-0600 INFO  Multiplexer No streams
-2013-11-06 01:21:05,146-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:21:06,304-0600 INFO  Multiplexer No streams
-2013-11-06 01:21:15,273-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:21:16,311-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:21:26,319-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:21:36,326-0600 INFO  Multiplexer No streams
-2013-11-06 01:21:37,469-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:21:46,335-0600 INFO  Multiplexer No streams
-2013-11-06 01:21:50,883-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:21:56,343-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:22:06,352-0600 INFO  Multiplexer No streams
-2013-11-06 01:22:09,792-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:22:16,365-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:22:26,366-0600 INFO  Multiplexer No streams
-2013-11-06 01:22:26,493-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:22:36,372-0600 INFO  Multiplexer No streams
-2013-11-06 01:22:42,116-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:22:46,382-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:22:56,385-0600 INFO  Multiplexer No streams
-2013-11-06 01:23:02,104-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:23:06,393-0600 INFO  Multiplexer No streams
-2013-11-06 01:23:14,438-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:23:16,403-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:23:26,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:23:36,422-0600 INFO  Multiplexer No streams
-2013-11-06 01:23:37,714-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:23:46,431-0600 INFO  Multiplexer No streams
-2013-11-06 01:23:46,761-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:23:56,443-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:24:06,455-0600 INFO  Multiplexer No streams
-2013-11-06 01:24:13,324-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:24:16,467-0600 INFO  Multiplexer No streams
-2013-11-06 01:24:19,085-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:24:26,479-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:24:36,490-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:24:46,509-0600 INFO  Multiplexer No streams
-2013-11-06 01:24:48,933-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:24:51,407-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:24:56,527-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:25:06,530-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:25:16,539-0600 INFO  Multiplexer No streams
-2013-11-06 01:25:23,731-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:25:24,543-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:25:26,550-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:25:36,561-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:25:46,571-0600 INFO  Multiplexer No streams
-2013-11-06 01:25:56,053-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:25:56,580-0600 INFO  Multiplexer No streams
-2013-11-06 01:26:00,153-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:26:06,589-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:26:16,597-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:26:26,605-0600 INFO  Multiplexer No streams
-2013-11-06 01:26:28,377-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:26:35,763-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:26:36,619-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:26:46,632-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:26:56,644-0600 INFO  Multiplexer No streams
-2013-11-06 01:27:00,701-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:27:06,657-0600 INFO  Multiplexer No streams
-2013-11-06 01:27:11,374-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:27:16,667-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:27:26,675-0600 INFO  Multiplexer No streams
-2013-11-06 01:27:33,023-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:27:36,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:27:46,694-0600 INFO  Multiplexer No streams
-2013-11-06 01:27:46,984-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:27:56,707-0600 INFO  Multiplexer No streams
-2013-11-06 01:28:05,346-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:28:06,715-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:28:16,722-0600 INFO  Multiplexer No streams
-2013-11-06 01:28:22,594-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:28:26,740-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:28:36,751-0600 INFO  Multiplexer No streams
-2013-11-06 01:28:37,669-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:28:46,761-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:28:56,771-0600 INFO  Multiplexer No streams
-2013-11-06 01:28:58,203-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:29:06,779-0600 INFO  Multiplexer No streams
-2013-11-06 01:29:09,992-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:29:16,787-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:29:26,795-0600 INFO  Multiplexer No streams
-2013-11-06 01:29:33,814-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:29:36,804-0600 INFO  Multiplexer No streams
-2013-11-06 01:29:42,315-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:29:46,813-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:29:56,821-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:30:06,830-0600 INFO  Multiplexer No streams
-2013-11-06 01:30:09,424-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:30:14,639-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:30:16,838-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:30:26,849-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:30:36,868-0600 INFO  Multiplexer No streams
-2013-11-06 01:30:45,034-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:30:46,885-0600 INFO  Multiplexer No streams
-2013-11-06 01:30:46,961-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:30:56,901-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:31:06,905-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:31:16,906-0600 INFO  Multiplexer No streams
-2013-11-06 01:31:19,284-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 01:31:20,644-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:31:26,909-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:31:36,926-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:31:46,940-0600 INFO  Multiplexer No streams
-2013-11-06 01:31:51,608-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:31:56,254-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:31:56,948-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:32:06,956-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:32:16,964-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 01:32:23,931-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:32:26,974-0600 INFO  Multiplexer No streams
-2013-11-06 01:32:31,864-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:32:36,981-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:32:46,988-0600 INFO  Multiplexer No streams
-2013-11-06 01:32:56,253-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:32:56,995-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:33:07,002-0600 INFO  Multiplexer No streams
-2013-11-06 01:33:07,473-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:33:17,009-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:33:27,017-0600 INFO  Multiplexer No streams
-2013-11-06 01:33:28,577-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:33:37,036-0600 INFO  Multiplexer No streams
-2013-11-06 01:33:43,083-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:33:47,049-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:33:57,058-0600 INFO  Multiplexer No streams
-2013-11-06 01:34:00,900-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:34:07,070-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:34:17,081-0600 INFO  Multiplexer No streams
-2013-11-06 01:34:18,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:34:27,092-0600 INFO  Multiplexer No streams
-2013-11-06 01:34:33,223-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:34:37,093-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:34:47,106-0600 INFO  Multiplexer No streams
-2013-11-06 01:34:54,303-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:34:57,116-0600 INFO  Multiplexer No streams
-2013-11-06 01:35:05,546-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:35:07,126-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:35:17,136-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:35:27,144-0600 INFO  Multiplexer No streams
-2013-11-06 01:35:29,913-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:35:37,153-0600 INFO  Multiplexer No streams
-2013-11-06 01:35:37,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:35:47,163-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:35:57,173-0600 INFO  Multiplexer No streams
-2013-11-06 01:36:05,523-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:36:07,185-0600 INFO  Multiplexer No streams
-2013-11-06 01:36:10,191-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:36:17,194-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:36:27,203-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:36:37,213-0600 INFO  Multiplexer No streams
-2013-11-06 01:36:41,133-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:36:42,515-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:36:47,222-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:36:57,232-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:37:07,241-0600 INFO  Multiplexer No streams
-2013-11-06 01:37:14,838-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 01:37:16,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:37:17,251-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:37:27,260-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:37:37,270-0600 INFO  Multiplexer No streams
-2013-11-06 01:37:47,160-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:37:47,280-0600 INFO  Multiplexer No streams
-2013-11-06 01:37:52,353-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:37:57,290-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:38:07,300-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:38:17,310-0600 INFO  Multiplexer No streams
-2013-11-06 01:38:19,484-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:38:27,319-0600 INFO  Multiplexer No streams
-2013-11-06 01:38:27,963-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:38:37,329-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:38:47,339-0600 INFO  Multiplexer No streams
-2013-11-06 01:38:51,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:38:57,349-0600 INFO  Multiplexer No streams
-2013-11-06 01:39:03,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:39:07,358-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:39:17,368-0600 INFO  Multiplexer No streams
-2013-11-06 01:39:24,129-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:39:27,376-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:39:37,388-0600 INFO  Multiplexer No streams
-2013-11-06 01:39:39,184-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:39:47,395-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:39:56,453-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:39:57,404-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:40:07,412-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:40:14,793-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:40:17,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:40:27,427-0600 INFO  Multiplexer No streams
-2013-11-06 01:40:28,776-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:40:37,440-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:40:47,452-0600 INFO  Multiplexer No streams
-2013-11-06 01:40:50,404-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:40:57,455-0600 INFO  Multiplexer No streams
-2013-11-06 01:41:01,099-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:41:07,466-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:41:17,479-0600 INFO  Multiplexer No streams
-2013-11-06 01:41:26,014-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:41:27,493-0600 INFO  Multiplexer No streams
-2013-11-06 01:41:33,422-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:41:37,501-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:41:47,509-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:41:57,517-0600 INFO  Multiplexer No streams
-2013-11-06 01:42:01,623-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 01:42:05,745-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:42:07,525-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:42:17,533-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:42:27,540-0600 INFO  Multiplexer No streams
-2013-11-06 01:42:37,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:42:37,548-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 01:42:38,067-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 01:42:47,556-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:42:57,564-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:43:07,571-0600 INFO  Multiplexer No streams
-2013-11-06 01:43:10,391-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 01:43:12,843-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:43:17,579-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:43:27,587-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:43:37,594-0600 INFO  Multiplexer No streams
-2013-11-06 01:43:42,714-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:43:47,602-0600 INFO  Multiplexer No streams
-2013-11-06 01:43:48,453-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:43:57,610-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:44:07,618-0600 INFO  Multiplexer No streams
-2013-11-06 01:44:15,037-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:44:17,626-0600 INFO  Multiplexer No streams
-2013-11-06 01:44:24,063-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:44:27,633-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:44:37,641-0600 INFO  Multiplexer No streams
-2013-11-06 01:44:47,360-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:44:47,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:44:57,657-0600 INFO  Multiplexer No streams
-2013-11-06 01:44:59,673-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:45:07,665-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:45:17,673-0600 INFO  Multiplexer No streams
-2013-11-06 01:45:19,683-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:45:27,680-0600 INFO  Multiplexer No streams
-2013-11-06 01:45:35,283-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:45:37,688-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:45:47,696-0600 INFO  Multiplexer No streams
-2013-11-06 01:45:52,006-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:45:57,704-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:46:07,712-0600 INFO  Multiplexer No streams
-2013-11-06 01:46:10,893-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:46:17,720-0600 INFO  Multiplexer No streams
-2013-11-06 01:46:24,329-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:46:27,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:46:37,735-0600 INFO  Multiplexer No streams
-2013-11-06 01:46:46,503-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:46:47,743-0600 INFO  Multiplexer No streams
-2013-11-06 01:46:56,652-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:46:57,751-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:47:07,759-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:47:17,767-0600 INFO  Multiplexer No streams
-2013-11-06 01:47:22,113-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:47:27,775-0600 INFO  Multiplexer No streams
-2013-11-06 01:47:28,975-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:47:37,783-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:47:47,791-0600 INFO  Multiplexer No streams
-2013-11-06 01:47:57,723-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:47:57,798-0600 INFO  Multiplexer No streams
-2013-11-06 01:48:01,298-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:48:07,806-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:48:17,814-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:48:27,822-0600 INFO  Multiplexer No streams
-2013-11-06 01:48:33,333-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:48:33,621-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:48:37,830-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:48:47,838-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:48:57,846-0600 INFO  Multiplexer No streams
-2013-11-06 01:49:05,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:49:07,854-0600 INFO  Multiplexer No streams
-2013-11-06 01:49:08,943-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:49:17,862-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:49:27,870-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:49:37,878-0600 INFO  Multiplexer No streams
-2013-11-06 01:49:38,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:49:44,553-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:49:47,885-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:49:57,893-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:50:07,901-0600 INFO  Multiplexer No streams
-2013-11-06 01:50:10,590-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:50:17,909-0600 INFO  Multiplexer No streams
-2013-11-06 01:50:20,163-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:50:27,917-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:50:37,925-0600 INFO  Multiplexer No streams
-2013-11-06 01:50:42,914-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 01:50:47,933-0600 INFO  Multiplexer No streams
-2013-11-06 01:50:55,773-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:50:57,941-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:51:07,949-0600 INFO  Multiplexer No streams
-2013-11-06 01:51:15,236-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:51:17,957-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:51:27,965-0600 INFO  Multiplexer No streams
-2013-11-06 01:51:31,383-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:51:37,973-0600 INFO  Multiplexer No streams
-2013-11-06 01:51:47,559-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:51:47,981-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:51:57,990-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 01:52:06,992-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 01:52:07,997-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:52:18,006-0600 INFO  Multiplexer No streams
-2013-11-06 01:52:19,882-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:52:28,014-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:52:38,022-0600 INFO  Multiplexer No streams
-2013-11-06 01:52:42,603-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:52:48,030-0600 INFO  Multiplexer No streams
-2013-11-06 01:52:52,205-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:52:58,038-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:53:08,048-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:53:18,056-0600 INFO  Multiplexer No streams
-2013-11-06 01:53:18,213-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 01:53:24,528-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:53:28,064-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:53:38,072-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:53:48,079-0600 INFO  Multiplexer No streams
-2013-11-06 01:53:53,824-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:53:56,851-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:53:58,087-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:54:08,095-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:54:18,103-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:54:28,111-0600 INFO  Multiplexer No streams
-2013-11-06 01:54:29,174-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:54:29,434-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:54:38,119-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:54:48,128-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:54:58,136-0600 INFO  Multiplexer No streams
-2013-11-06 01:55:01,497-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:55:05,044-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:55:08,144-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:55:18,153-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:55:28,161-0600 INFO  Multiplexer No streams
-2013-11-06 01:55:33,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:55:38,169-0600 INFO  Multiplexer No streams
-2013-11-06 01:55:40,654-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:55:48,177-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:55:58,185-0600 INFO  Multiplexer No streams
-2013-11-06 01:56:06,143-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:56:08,194-0600 INFO  Multiplexer No streams
-2013-11-06 01:56:16,264-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:56:18,202-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:56:28,209-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:56:38,217-0600 INFO  Multiplexer No streams
-2013-11-06 01:56:38,466-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:56:48,225-0600 INFO  Multiplexer No streams
-2013-11-06 01:56:51,874-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 01:56:58,233-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:57:08,241-0600 INFO  Multiplexer No streams
-2013-11-06 01:57:10,789-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:57:18,249-0600 INFO  Multiplexer No streams
-2013-11-06 01:57:27,484-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:57:28,257-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:57:38,265-0600 INFO  Multiplexer No streams
-2013-11-06 01:57:43,112-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:57:48,273-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:57:58,281-0600 INFO  Multiplexer No streams
-2013-11-06 01:58:03,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:58:08,288-0600 INFO  Multiplexer No streams
-2013-11-06 01:58:15,435-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:58:18,296-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:58:28,304-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:58:38,312-0600 INFO  Multiplexer No streams
-2013-11-06 01:58:38,704-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 01:58:47,757-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 01:58:48,320-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:58:58,328-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:59:08,336-0600 INFO  Multiplexer No streams
-2013-11-06 01:59:14,314-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 01:59:18,343-0600 INFO  Multiplexer No streams
-2013-11-06 01:59:20,081-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 01:59:28,351-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:59:38,359-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 01:59:48,367-0600 INFO  Multiplexer No streams
-2013-11-06 01:59:49,924-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 01:59:52,405-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 01:59:58,375-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:00:08,383-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:00:18,390-0600 INFO  Multiplexer No streams
-2013-11-06 02:00:24,729-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 02:00:25,533-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 02:00:28,398-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:00:38,406-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:00:48,414-0600 INFO  Multiplexer No streams
-2013-11-06 02:00:57,052-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:00:58,422-0600 INFO  Multiplexer No streams
-2013-11-06 02:01:01,144-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:01:08,430-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:01:18,438-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:01:28,446-0600 INFO  Multiplexer No streams
-2013-11-06 02:01:29,375-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:01:36,754-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:01:38,454-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:01:48,461-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:01:58,469-0600 INFO  Multiplexer No streams
-2013-11-06 02:02:01,698-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:02:08,477-0600 INFO  Multiplexer No streams
-2013-11-06 02:02:12,363-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 02:02:18,485-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:02:28,493-0600 INFO  Multiplexer No streams
-2013-11-06 02:02:34,021-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:02:38,501-0600 INFO  Multiplexer No streams
-2013-11-06 02:02:47,974-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:02:48,509-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:02:58,517-0600 INFO  Multiplexer No streams
-2013-11-06 02:03:06,344-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:03:08,525-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:03:18,532-0600 INFO  Multiplexer No streams
-2013-11-06 02:03:23,584-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:03:28,540-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:03:38,548-0600 INFO  Multiplexer No streams
-2013-11-06 02:03:38,667-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:03:48,556-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:03:58,564-0600 INFO  Multiplexer No streams
-2013-11-06 02:03:59,194-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 02:04:08,572-0600 INFO  Multiplexer No streams
-2013-11-06 02:04:10,990-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:04:18,580-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:04:28,588-0600 INFO  Multiplexer No streams
-2013-11-06 02:04:34,805-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:04:38,596-0600 INFO  Multiplexer No streams
-2013-11-06 02:04:43,313-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:04:48,604-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:04:58,611-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:05:08,619-0600 INFO  Multiplexer No streams
-2013-11-06 02:05:10,415-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:05:15,636-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:05:18,627-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:05:28,635-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:05:38,643-0600 INFO  Multiplexer No streams
-2013-11-06 02:05:46,025-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:05:47,959-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:05:48,651-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:05:58,658-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:06:08,666-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:06:18,674-0600 INFO  Multiplexer No streams
-2013-11-06 02:06:20,282-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:06:21,635-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:06:28,682-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:06:38,690-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:06:48,698-0600 INFO  Multiplexer No streams
-2013-11-06 02:06:52,605-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:06:57,244-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 02:06:58,705-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:07:08,713-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:07:18,721-0600 INFO  Multiplexer No streams
-2013-11-06 02:07:24,928-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:07:28,729-0600 INFO  Multiplexer No streams
-2013-11-06 02:07:32,855-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:07:38,737-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:07:48,744-0600 INFO  Multiplexer No streams
-2013-11-06 02:07:57,251-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:07:58,752-0600 INFO  Multiplexer No streams
-2013-11-06 02:08:08,465-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 02:08:08,760-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:08:18,768-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:08:28,775-0600 INFO  Multiplexer No streams
-2013-11-06 02:08:29,574-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:08:38,783-0600 INFO  Multiplexer No streams
-2013-11-06 02:08:44,075-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:08:48,791-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:08:58,799-0600 INFO  Multiplexer No streams
-2013-11-06 02:09:01,897-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:09:08,807-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:09:18,815-0600 INFO  Multiplexer No streams
-2013-11-06 02:09:19,685-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:09:28,822-0600 INFO  Multiplexer No streams
-2013-11-06 02:09:34,220-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:09:38,830-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:09:48,838-0600 INFO  Multiplexer No streams
-2013-11-06 02:09:55,295-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 02:09:58,845-0600 INFO  Multiplexer No streams
-2013-11-06 02:10:06,543-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:10:08,853-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:10:18,861-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:10:28,868-0600 INFO  Multiplexer No streams
-2013-11-06 02:10:30,906-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:10:38,866-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:10:38,876-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:10:48,884-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:10:58,892-0600 INFO  Multiplexer No streams
-2013-11-06 02:11:06,516-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:11:08,899-0600 INFO  Multiplexer No streams
-2013-11-06 02:11:11,189-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:11:18,907-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:11:28,915-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:11:38,922-0600 INFO  Multiplexer No streams
-2013-11-06 02:11:42,125-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 02:11:43,512-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:11:48,930-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:11:58,938-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:12:08,945-0600 INFO  Multiplexer No streams
-2013-11-06 02:12:15,835-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:12:17,736-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:12:18,953-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:12:28,961-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:12:38,968-0600 INFO  Multiplexer No streams
-2013-11-06 02:12:48,158-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:12:48,976-0600 INFO  Multiplexer No streams
-2013-11-06 02:12:53,346-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:12:58,984-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:13:08,991-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:13:18,999-0600 INFO  Multiplexer No streams
-2013-11-06 02:13:20,481-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:13:28,956-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:13:29,006-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:13:39,014-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:13:49,022-0600 INFO  Multiplexer No streams
-2013-11-06 02:13:52,804-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:13:59,029-0600 INFO  Multiplexer No streams
-2013-11-06 02:14:04,566-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:14:09,037-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:14:19,044-0600 INFO  Multiplexer No streams
-2013-11-06 02:14:25,127-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:14:29,052-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:14:39,059-0600 INFO  Multiplexer No streams
-2013-11-06 02:14:40,176-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:14:49,067-0600 INFO  Multiplexer No streams
-2013-11-06 02:14:57,450-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:14:59,075-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:15:09,082-0600 INFO  Multiplexer No streams
-2013-11-06 02:15:15,786-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:15:19,090-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:15:29,097-0600 INFO  Multiplexer No streams
-2013-11-06 02:15:29,773-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:15:39,105-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:15:49,112-0600 INFO  Multiplexer No streams
-2013-11-06 02:15:51,396-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:15:59,120-0600 INFO  Multiplexer No streams
-2013-11-06 02:16:02,096-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:16:09,128-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:16:19,135-0600 INFO  Multiplexer No streams
-2013-11-06 02:16:27,006-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:16:29,143-0600 INFO  Multiplexer No streams
-2013-11-06 02:16:34,419-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:16:39,150-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:16:49,158-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:16:59,165-0600 INFO  Multiplexer No streams
-2013-11-06 02:17:02,616-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 02:17:06,742-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:17:09,173-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:17:19,180-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:17:29,188-0600 INFO  Multiplexer No streams
-2013-11-06 02:17:38,226-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:17:39,065-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:17:39,196-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:17:49,203-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:17:59,211-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:18:09,218-0600 INFO  Multiplexer No streams
-2013-11-06 02:18:11,388-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:18:13,836-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:18:19,226-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:18:29,234-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:18:39,242-0600 INFO  Multiplexer No streams
-2013-11-06 02:18:43,711-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:18:49,249-0600 INFO  Multiplexer No streams
-2013-11-06 02:18:49,446-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:18:59,257-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:19:09,265-0600 INFO  Multiplexer No streams
-2013-11-06 02:19:16,034-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:19:19,273-0600 INFO  Multiplexer No streams
-2013-11-06 02:19:25,056-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:19:29,281-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:19:39,289-0600 INFO  Multiplexer No streams
-2013-11-06 02:19:48,357-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:19:49,297-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:19:59,305-0600 INFO  Multiplexer No streams
-2013-11-06 02:20:00,666-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:20:09,313-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:20:19,321-0600 INFO  Multiplexer No streams
-2013-11-06 02:20:20,680-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:20:29,330-0600 INFO  Multiplexer No streams
-2013-11-06 02:20:36,276-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:20:39,338-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:20:49,346-0600 INFO  Multiplexer No streams
-2013-11-06 02:20:53,003-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:20:59,354-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:21:09,362-0600 INFO  Multiplexer No streams
-2013-11-06 02:21:11,886-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:21:19,370-0600 INFO  Multiplexer No streams
-2013-11-06 02:21:25,326-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:21:29,379-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:21:39,387-0600 INFO  Multiplexer No streams
-2013-11-06 02:21:47,496-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:21:49,395-0600 INFO  Multiplexer No streams
-2013-11-06 02:21:57,649-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:21:59,403-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:22:09,411-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:22:19,419-0600 INFO  Multiplexer No streams
-2013-11-06 02:22:23,106-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:22:29,427-0600 INFO  Multiplexer No streams
-2013-11-06 02:22:29,972-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:22:39,435-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:22:49,443-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 02:22:58,715-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:22:59,452-0600 INFO  Multiplexer No streams
-2013-11-06 02:23:02,295-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:23:09,460-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:23:19,468-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:23:29,476-0600 INFO  Multiplexer No streams
-2013-11-06 02:23:34,326-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:23:34,618-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:23:39,484-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:23:49,492-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:23:59,500-0600 INFO  Multiplexer No streams
-2013-11-06 02:24:06,941-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:24:09,508-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 02:24:09,936-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:24:19,516-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:24:29,524-0600 INFO  Multiplexer No streams
-2013-11-06 02:24:39,264-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:24:39,532-0600 INFO  Multiplexer No streams
-2013-11-06 02:24:45,546-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:24:49,540-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:24:59,549-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:25:09,557-0600 INFO  Multiplexer No streams
-2013-11-06 02:25:11,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:25:19,565-0600 INFO  Multiplexer No streams
-2013-11-06 02:25:21,156-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:25:29,573-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:25:39,581-0600 INFO  Multiplexer No streams
-2013-11-06 02:25:43,911-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:25:49,589-0600 INFO  Multiplexer No streams
-2013-11-06 02:25:56,766-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:25:59,597-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:26:09,605-0600 INFO  Multiplexer No streams
-2013-11-06 02:26:16,234-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:26:19,613-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:26:29,621-0600 INFO  Multiplexer No streams
-2013-11-06 02:26:32,376-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:26:39,629-0600 INFO  Multiplexer No streams
-2013-11-06 02:26:48,557-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:26:49,637-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:26:59,645-0600 INFO  Multiplexer No streams
-2013-11-06 02:27:07,986-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:27:09,653-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:27:19,661-0600 INFO  Multiplexer No streams
-2013-11-06 02:27:20,880-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:27:29,670-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:27:39,677-0600 INFO  Multiplexer No streams
-2013-11-06 02:27:43,596-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:27:49,686-0600 INFO  Multiplexer No streams
-2013-11-06 02:27:53,203-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:27:59,694-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:28:09,702-0600 INFO  Multiplexer No streams
-2013-11-06 02:28:19,206-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:28:19,710-0600 INFO  Multiplexer No streams
-2013-11-06 02:28:25,526-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:28:29,718-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:28:39,726-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:28:49,734-0600 INFO  Multiplexer No streams
-2013-11-06 02:28:54,816-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:28:57,849-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:28:59,742-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:29:09,750-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:29:19,758-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:29:29,766-0600 INFO  Multiplexer No streams
-2013-11-06 02:29:30,172-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:29:30,426-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:29:39,774-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:29:49,782-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:29:59,790-0600 INFO  Multiplexer No streams
-2013-11-06 02:30:02,495-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:30:06,037-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:30:09,798-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:30:19,806-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:30:29,814-0600 INFO  Multiplexer No streams
-2013-11-06 02:30:34,818-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:30:39,822-0600 INFO  Multiplexer No streams
-2013-11-06 02:30:41,646-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:30:49,830-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:30:59,838-0600 INFO  Multiplexer No streams
-2013-11-06 02:31:07,141-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:31:09,846-0600 INFO  Multiplexer No streams
-2013-11-06 02:31:17,257-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:31:19,854-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:31:29,862-0600 INFO  Multiplexer No streams
-2013-11-06 02:31:39,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:31:39,870-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:31:49,878-0600 INFO  Multiplexer No streams
-2013-11-06 02:31:52,867-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:31:59,886-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:32:09,894-0600 INFO  Multiplexer No streams
-2013-11-06 02:32:11,787-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:32:19,902-0600 INFO  Multiplexer No streams
-2013-11-06 02:32:28,477-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:32:29,909-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:32:39,917-0600 INFO  Multiplexer No streams
-2013-11-06 02:32:44,110-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:32:49,925-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:32:59,933-0600 INFO  Multiplexer No streams
-2013-11-06 02:33:04,087-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:33:09,941-0600 INFO  Multiplexer No streams
-2013-11-06 02:33:16,433-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:33:19,949-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:33:29,956-0600 INFO  Multiplexer No streams
-2013-11-06 02:33:39,697-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:33:39,964-0600 INFO  Multiplexer No streams
-2013-11-06 02:33:48,756-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:33:49,972-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:33:59,980-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:34:09,988-0600 INFO  Multiplexer No streams
-2013-11-06 02:34:15,307-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:34:19,995-0600 INFO  Multiplexer No streams
-2013-11-06 02:34:21,079-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:34:30,003-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:34:40,011-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:34:50,019-0600 INFO  Multiplexer No streams
-2013-11-06 02:34:50,917-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 02:34:53,402-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:35:00,027-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:35:10,034-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:35:20,042-0600 INFO  Multiplexer No streams
-2013-11-06 02:35:25,725-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:35:26,527-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:35:30,050-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:35:40,058-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:35:50,066-0600 INFO  Multiplexer No streams
-2013-11-06 02:35:58,048-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:36:00,074-0600 INFO  Multiplexer No streams
-2013-11-06 02:36:02,137-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:36:10,081-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:36:20,089-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:36:30,097-0600 INFO  Multiplexer No streams
-2013-11-06 02:36:30,371-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:36:37,747-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:36:40,105-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:36:50,113-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:37:00,121-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 02:37:02,694-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:37:10,129-0600 INFO  Multiplexer No streams
-2013-11-06 02:37:13,357-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:37:20,137-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:37:30,144-0600 INFO  Multiplexer No streams
-2013-11-06 02:37:35,017-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:37:40,152-0600 INFO  Multiplexer No streams
-2013-11-06 02:37:48,967-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:37:50,160-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:38:00,168-0600 INFO  Multiplexer No streams
-2013-11-06 02:38:07,340-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:38:10,176-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:38:20,184-0600 INFO  Multiplexer No streams
-2013-11-06 02:38:24,577-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:38:30,192-0600 INFO  Multiplexer No streams
-2013-11-06 02:38:39,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:38:40,199-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:38:50,207-0600 INFO  Multiplexer No streams
-2013-11-06 02:39:00,187-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:39:00,215-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:39:10,223-0600 INFO  Multiplexer No streams
-2013-11-06 02:39:11,987-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:39:20,230-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:39:30,238-0600 INFO  Multiplexer No streams
-2013-11-06 02:39:35,796-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:39:40,246-0600 INFO  Multiplexer No streams
-2013-11-06 02:39:44,310-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:39:50,254-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:40:00,262-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:40:10,269-0600 INFO  Multiplexer No streams
-2013-11-06 02:40:11,407-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 02:40:16,633-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:40:20,277-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:40:30,285-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:40:40,293-0600 INFO  Multiplexer No streams
-2013-11-06 02:40:47,017-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 02:40:48,956-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:40:50,301-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:41:00,308-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:41:10,316-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:41:20,324-0600 INFO  Multiplexer No streams
-2013-11-06 02:41:21,279-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 02:41:22,627-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:41:30,332-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:41:40,339-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:41:50,347-0600 INFO  Multiplexer No streams
-2013-11-06 02:41:53,602-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 02:41:58,237-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:42:00,355-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:42:10,363-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:42:20,371-0600 INFO  Multiplexer No streams
-2013-11-06 02:42:25,925-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:42:30,379-0600 INFO  Multiplexer No streams
-2013-11-06 02:42:33,846-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:42:40,387-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:42:50,395-0600 INFO  Multiplexer No streams
-2013-11-06 02:42:58,248-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:43:00,403-0600 INFO  Multiplexer No streams
-2013-11-06 02:43:09,457-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:43:10,410-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:43:20,418-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:43:30,426-0600 INFO  Multiplexer No streams
-2013-11-06 02:43:30,572-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:43:40,434-0600 INFO  Multiplexer No streams
-2013-11-06 02:43:45,067-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:43:50,442-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:44:00,450-0600 INFO  Multiplexer No streams
-2013-11-06 02:44:02,896-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:44:10,458-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:44:20,466-0600 INFO  Multiplexer No streams
-2013-11-06 02:44:20,676-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:44:30,474-0600 INFO  Multiplexer No streams
-2013-11-06 02:44:35,219-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:44:40,482-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:44:50,490-0600 INFO  Multiplexer No streams
-2013-11-06 02:44:56,287-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:45:00,498-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:45:07,542-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:45:10,506-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:45:20,514-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:45:30,522-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 02:45:31,898-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 02:45:39,865-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:45:40,531-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:45:50,539-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:46:00,547-0600 INFO  Multiplexer No streams
-2013-11-06 02:46:07,507-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:46:10,555-0600 INFO  Multiplexer No streams
-2013-11-06 02:46:12,189-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:46:20,563-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:46:30,571-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:46:40,579-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:46:43,117-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:46:44,512-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:46:50,587-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:47:00,595-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:47:10,602-0600 INFO  Multiplexer No streams
-2013-11-06 02:47:16,836-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:47:18,727-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:47:20,610-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:47:30,618-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:47:40,625-0600 INFO  Multiplexer No streams
-2013-11-06 02:47:49,159-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:47:50,633-0600 INFO  Multiplexer No streams
-2013-11-06 02:47:54,337-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:48:00,641-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:48:10,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:48:20,656-0600 INFO  Multiplexer No streams
-2013-11-06 02:48:21,482-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:48:29,947-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:48:30,664-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:48:40,671-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:48:50,679-0600 INFO  Multiplexer No streams
-2013-11-06 02:48:53,805-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:49:00,687-0600 INFO  Multiplexer No streams
-2013-11-06 02:49:05,557-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:49:10,695-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:49:20,702-0600 INFO  Multiplexer No streams
-2013-11-06 02:49:26,128-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:49:30,710-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:49:40,718-0600 INFO  Multiplexer No streams
-2013-11-06 02:49:41,167-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:49:50,726-0600 INFO  Multiplexer No streams
-2013-11-06 02:49:58,451-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:50:00,733-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:50:10,741-0600 INFO  Multiplexer No streams
-2013-11-06 02:50:16,777-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:50:20,749-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:50:30,757-0600 INFO  Multiplexer No streams
-2013-11-06 02:50:30,774-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:50:40,765-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:50:50,772-0600 INFO  Multiplexer No streams
-2013-11-06 02:50:52,387-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:51:00,780-0600 INFO  Multiplexer No streams
-2013-11-06 02:51:03,097-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:51:10,788-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:51:20,796-0600 INFO  Multiplexer No streams
-2013-11-06 02:51:27,997-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:51:30,804-0600 INFO  Multiplexer No streams
-2013-11-06 02:51:35,420-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:51:40,811-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:51:50,819-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:52:00,827-0600 INFO  Multiplexer No streams
-2013-11-06 02:52:03,606-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 02:52:07,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:52:10,835-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:52:20,843-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:52:30,851-0600 INFO  Multiplexer No streams
-2013-11-06 02:52:39,217-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:52:40,066-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:52:40,858-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:52:50,867-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:53:00,874-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:53:10,882-0600 INFO  Multiplexer No streams
-2013-11-06 02:53:12,389-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:53:14,826-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:53:20,891-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:53:30,898-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:53:40,906-0600 INFO  Multiplexer No streams
-2013-11-06 02:53:44,712-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:53:50,437-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:53:50,914-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:54:00,922-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:54:10,930-0600 INFO  Multiplexer No streams
-2013-11-06 02:54:17,035-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:54:20,938-0600 INFO  Multiplexer No streams
-2013-11-06 02:54:26,046-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:54:30,946-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:54:40,954-0600 INFO  Multiplexer No streams
-2013-11-06 02:54:49,358-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:54:50,962-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:55:00,970-0600 INFO  Multiplexer No streams
-2013-11-06 02:55:01,657-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:55:10,978-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:55:20,986-0600 INFO  Multiplexer No streams
-2013-11-06 02:55:21,682-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:55:30,994-0600 INFO  Multiplexer No streams
-2013-11-06 02:55:37,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:55:41,002-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:55:51,011-0600 INFO  Multiplexer No streams
-2013-11-06 02:55:54,005-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:56:01,019-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:56:11,027-0600 INFO  Multiplexer No streams
-2013-11-06 02:56:12,877-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:56:21,035-0600 INFO  Multiplexer No streams
-2013-11-06 02:56:26,328-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:56:31,043-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:56:41,051-0600 INFO  Multiplexer No streams
-2013-11-06 02:56:48,486-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:56:51,059-0600 INFO  Multiplexer No streams
-2013-11-06 02:56:58,651-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:57:01,067-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:57:11,075-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:57:21,083-0600 INFO  Multiplexer No streams
-2013-11-06 02:57:24,097-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:57:30,974-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:57:31,091-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:57:41,099-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:57:51,107-0600 INFO  Multiplexer No streams
-2013-11-06 02:57:59,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:58:01,115-0600 INFO  Multiplexer No streams
-2013-11-06 02:58:03,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:58:11,123-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:58:21,131-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:58:31,139-0600 INFO  Multiplexer No streams
-2013-11-06 02:58:35,317-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 02:58:35,621-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 02:58:41,147-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:58:51,155-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:59:01,163-0600 INFO  Multiplexer No streams
-2013-11-06 02:59:07,943-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 02:59:10,926-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 02:59:11,171-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:59:21,179-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 02:59:31,187-0600 INFO  Multiplexer No streams
-2013-11-06 02:59:40,266-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 02:59:41,195-0600 INFO  Multiplexer No streams
-2013-11-06 02:59:46,537-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 02:59:51,203-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:00:01,211-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:00:11,219-0600 INFO  Multiplexer No streams
-2013-11-06 03:00:12,589-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:00:21,227-0600 INFO  Multiplexer No streams
-2013-11-06 03:00:22,147-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:00:31,235-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:00:41,243-0600 INFO  Multiplexer No streams
-2013-11-06 03:00:44,913-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:00:51,251-0600 INFO  Multiplexer No streams
-2013-11-06 03:00:57,757-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:01:01,259-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:01:11,267-0600 INFO  Multiplexer No streams
-2013-11-06 03:01:17,235-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:01:21,275-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:01:31,283-0600 INFO  Multiplexer No streams
-2013-11-06 03:01:33,366-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:01:41,291-0600 INFO  Multiplexer No streams
-2013-11-06 03:01:49,558-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:01:51,299-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:02:01,308-0600 INFO  Multiplexer No streams
-2013-11-06 03:02:08,977-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:02:11,316-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:02:21,324-0600 INFO  Multiplexer No streams
-2013-11-06 03:02:21,881-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:02:31,331-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:02:41,340-0600 INFO  Multiplexer No streams
-2013-11-06 03:02:44,586-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:02:51,348-0600 INFO  Multiplexer No streams
-2013-11-06 03:02:54,204-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:03:01,356-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:03:11,364-0600 INFO  Multiplexer No streams
-2013-11-06 03:03:20,197-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:03:21,372-0600 INFO  Multiplexer No streams
-2013-11-06 03:03:26,527-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:03:31,380-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:03:41,388-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:03:51,396-0600 INFO  Multiplexer No streams
-2013-11-06 03:03:55,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:03:58,850-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:04:01,404-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:04:11,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:04:21,420-0600 INFO  Multiplexer No streams
-2013-11-06 03:04:31,173-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:04:31,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:04:31,428-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:04:41,436-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:04:51,444-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:05:01,452-0600 INFO  Multiplexer No streams
-2013-11-06 03:05:03,496-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:05:07,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:05:11,460-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:05:21,468-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:05:31,476-0600 INFO  Multiplexer No streams
-2013-11-06 03:05:35,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:05:41,484-0600 INFO  Multiplexer No streams
-2013-11-06 03:05:42,636-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:05:51,492-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:06:01,500-0600 INFO  Multiplexer No streams
-2013-11-06 03:06:08,143-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:06:11,507-0600 INFO  Multiplexer No streams
-2013-11-06 03:06:18,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:06:21,516-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:06:31,524-0600 INFO  Multiplexer No streams
-2013-11-06 03:06:40,466-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:06:41,532-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:06:51,540-0600 INFO  Multiplexer No streams
-2013-11-06 03:06:53,856-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:07:01,548-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:07:11,556-0600 INFO  Multiplexer No streams
-2013-11-06 03:07:12,789-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:07:21,564-0600 INFO  Multiplexer No streams
-2013-11-06 03:07:29,467-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:07:31,572-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:07:41,580-0600 INFO  Multiplexer No streams
-2013-11-06 03:07:45,112-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:07:51,588-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:08:01,597-0600 INFO  Multiplexer No streams
-2013-11-06 03:08:05,077-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:08:11,605-0600 INFO  Multiplexer No streams
-2013-11-06 03:08:17,435-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:08:21,613-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:08:31,621-0600 INFO  Multiplexer No streams
-2013-11-06 03:08:40,688-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:08:41,629-0600 INFO  Multiplexer No streams
-2013-11-06 03:08:49,758-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:08:51,637-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:09:01,645-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:09:11,653-0600 INFO  Multiplexer No streams
-2013-11-06 03:09:16,298-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:09:21,661-0600 INFO  Multiplexer No streams
-2013-11-06 03:09:22,081-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:09:31,668-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:09:41,677-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:09:51,684-0600 INFO  Multiplexer No streams
-2013-11-06 03:09:51,909-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:09:54,404-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:10:01,692-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:10:11,700-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:10:21,708-0600 INFO  Multiplexer No streams
-2013-11-06 03:10:26,727-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:10:27,519-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:10:31,716-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:10:41,724-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:10:51,732-0600 INFO  Multiplexer No streams
-2013-11-06 03:10:59,050-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:11:01,740-0600 INFO  Multiplexer No streams
-2013-11-06 03:11:03,129-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:11:11,748-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:11:21,756-0600 INFO  Multiplexer No streams
-2013-11-06 03:11:31,373-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:11:31,764-0600 INFO  Multiplexer No streams
-2013-11-06 03:11:38,738-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:11:41,772-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:11:51,780-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:12:01,788-0600 INFO  Multiplexer No streams
-2013-11-06 03:12:03,697-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:12:11,796-0600 INFO  Multiplexer No streams
-2013-11-06 03:12:14,349-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:12:21,804-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:12:31,812-0600 INFO  Multiplexer No streams
-2013-11-06 03:12:36,020-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:12:41,820-0600 INFO  Multiplexer No streams
-2013-11-06 03:12:49,959-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:12:51,828-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:13:01,836-0600 INFO  Multiplexer No streams
-2013-11-06 03:13:08,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:13:11,844-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:13:21,852-0600 INFO  Multiplexer No streams
-2013-11-06 03:13:25,570-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:13:31,860-0600 INFO  Multiplexer No streams
-2013-11-06 03:13:40,666-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:13:41,867-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:13:51,875-0600 INFO  Multiplexer No streams
-2013-11-06 03:14:01,180-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:14:01,883-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:14:11,891-0600 INFO  Multiplexer No streams
-2013-11-06 03:14:12,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:14:21,899-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:14:31,907-0600 INFO  Multiplexer No streams
-2013-11-06 03:14:36,790-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:14:41,915-0600 INFO  Multiplexer No streams
-2013-11-06 03:14:45,312-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:14:51,923-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:15:01,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:15:11,939-0600 INFO  Multiplexer No streams
-2013-11-06 03:15:12,400-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:15:17,635-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:15:21,947-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:15:31,955-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:15:41,963-0600 INFO  Multiplexer No streams
-2013-11-06 03:15:48,010-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:15:49,958-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:15:51,971-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:16:01,979-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:16:11,987-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:16:21,995-0600 INFO  Multiplexer No streams
-2013-11-06 03:16:22,281-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:16:23,619-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:16:32,002-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:16:42,010-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:16:52,018-0600 INFO  Multiplexer No streams
-2013-11-06 03:16:54,604-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:16:59,230-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:17:02,026-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:17:12,034-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:17:22,042-0600 INFO  Multiplexer No streams
-2013-11-06 03:17:26,927-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:17:32,050-0600 INFO  Multiplexer No streams
-2013-11-06 03:17:34,839-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:17:42,058-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:17:52,066-0600 INFO  Multiplexer No streams
-2013-11-06 03:17:59,249-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:18:02,074-0600 INFO  Multiplexer No streams
-2013-11-06 03:18:10,450-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:18:12,076-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:18:22,084-0600 INFO  Multiplexer No streams
-2013-11-06 03:18:31,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:18:32,092-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:18:42,100-0600 INFO  Multiplexer No streams
-2013-11-06 03:18:46,060-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:18:52,108-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:19:02,116-0600 INFO  Multiplexer No streams
-2013-11-06 03:19:03,895-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:19:12,124-0600 INFO  Multiplexer No streams
-2013-11-06 03:19:21,670-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:19:22,132-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:19:32,140-0600 INFO  Multiplexer No streams
-2013-11-06 03:19:36,219-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:19:42,148-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:19:52,157-0600 INFO  Multiplexer No streams
-2013-11-06 03:19:57,280-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:20:02,164-0600 INFO  Multiplexer No streams
-2013-11-06 03:20:08,542-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:20:12,173-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:20:22,181-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:20:32,189-0600 INFO  Multiplexer No streams
-2013-11-06 03:20:32,890-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:20:40,865-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:20:42,197-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:20:52,205-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:21:02,213-0600 INFO  Multiplexer No streams
-2013-11-06 03:21:08,500-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:21:12,221-0600 INFO  Multiplexer No streams
-2013-11-06 03:21:13,188-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:21:22,229-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:21:32,237-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:21:42,245-0600 INFO  Multiplexer No streams
-2013-11-06 03:21:44,110-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:21:45,511-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:21:52,253-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:22:02,261-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:22:12,269-0600 INFO  Multiplexer No streams
-2013-11-06 03:22:17,834-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:22:19,720-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:22:22,277-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:22:32,285-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:22:42,292-0600 INFO  Multiplexer No streams
-2013-11-06 03:22:50,157-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:22:52,300-0600 INFO  Multiplexer No streams
-2013-11-06 03:22:55,330-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:23:02,308-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:23:12,316-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:23:22,324-0600 INFO  Multiplexer No streams
-2013-11-06 03:23:22,480-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:23:30,940-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:23:32,331-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:23:42,339-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:23:52,347-0600 INFO  Multiplexer No streams
-2013-11-06 03:23:54,803-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:24:02,355-0600 INFO  Multiplexer No streams
-2013-11-06 03:24:06,549-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:24:12,363-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:24:22,371-0600 INFO  Multiplexer No streams
-2013-11-06 03:24:27,126-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:24:32,379-0600 INFO  Multiplexer No streams
-2013-11-06 03:24:42,160-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:24:42,387-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:24:52,395-0600 INFO  Multiplexer No streams
-2013-11-06 03:24:59,449-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:25:02,403-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:25:12,411-0600 INFO  Multiplexer No streams
-2013-11-06 03:25:17,770-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:25:22,419-0600 INFO  Multiplexer No streams
-2013-11-06 03:25:31,773-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:25:32,427-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:25:42,435-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:25:52,443-0600 INFO  Multiplexer No streams
-2013-11-06 03:25:53,380-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:26:02,452-0600 INFO  Multiplexer No streams
-2013-11-06 03:26:04,095-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:26:12,460-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:26:22,468-0600 INFO  Multiplexer No streams
-2013-11-06 03:26:28,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:26:32,476-0600 INFO  Multiplexer No streams
-2013-11-06 03:26:36,418-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 03:26:42,484-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:26:52,492-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:27:02,500-0600 INFO  Multiplexer No streams
-2013-11-06 03:27:04,600-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:27:08,741-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:27:12,509-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:27:22,517-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:27:32,525-0600 INFO  Multiplexer No streams
-2013-11-06 03:27:40,211-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:27:41,064-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:27:42,533-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:27:52,541-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:28:02,550-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:28:12,558-0600 INFO  Multiplexer No streams
-2013-11-06 03:28:13,387-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:28:15,821-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:28:22,565-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:28:32,574-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:28:42,582-0600 INFO  Multiplexer No streams
-2013-11-06 03:28:45,710-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:28:51,431-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:28:52,590-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:29:02,598-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:29:12,607-0600 INFO  Multiplexer No streams
-2013-11-06 03:29:18,033-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:29:22,615-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 03:29:27,041-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:29:32,624-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:29:42,633-0600 INFO  Multiplexer No streams
-2013-11-06 03:29:50,356-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:29:52,643-0600 INFO  Multiplexer No streams
-2013-11-06 03:30:02,652-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:30:02,660-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:30:12,666-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:30:22,669-0600 INFO  Multiplexer No streams
-2013-11-06 03:30:22,679-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:30:32,670-0600 INFO  Multiplexer No streams
-2013-11-06 03:30:38,262-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:30:42,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:30:52,690-0600 INFO  Multiplexer No streams
-2013-11-06 03:30:55,003-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:31:02,703-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:31:12,713-0600 INFO  Multiplexer No streams
-2013-11-06 03:31:13,872-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:31:22,723-0600 INFO  Multiplexer No streams
-2013-11-06 03:31:27,327-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:31:32,733-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:31:42,744-0600 INFO  Multiplexer No streams
-2013-11-06 03:31:49,482-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:31:52,756-0600 INFO  Multiplexer No streams
-2013-11-06 03:31:59,649-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:32:02,766-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:32:12,776-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:32:22,785-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:32:25,092-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 03:32:31,972-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:32:32,793-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:32:42,801-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:32:52,809-0600 INFO  Multiplexer No streams
-2013-11-06 03:33:00,702-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:33:02,817-0600 INFO  Multiplexer No streams
-2013-11-06 03:33:04,295-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:33:12,825-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:33:22,832-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:33:32,843-0600 INFO  Multiplexer No streams
-2013-11-06 03:33:36,312-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:33:36,618-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:33:42,855-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:33:52,871-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:34:02,879-0600 INFO  Multiplexer No streams
-2013-11-06 03:34:08,941-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:34:11,922-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:34:12,889-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:34:22,896-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:34:32,904-0600 INFO  Multiplexer No streams
-2013-11-06 03:34:41,264-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:34:42,912-0600 INFO  Multiplexer No streams
-2013-11-06 03:34:47,532-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:34:52,922-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:35:02,930-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:35:12,938-0600 INFO  Multiplexer No streams
-2013-11-06 03:35:13,588-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:35:22,947-0600 INFO  Multiplexer No streams
-2013-11-06 03:35:23,142-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:35:32,955-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:35:42,962-0600 INFO  Multiplexer No streams
-2013-11-06 03:35:45,910-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:35:52,970-0600 INFO  Multiplexer No streams
-2013-11-06 03:35:58,752-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:36:02,978-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:36:12,986-0600 INFO  Multiplexer No streams
-2013-11-06 03:36:18,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:36:22,994-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:36:33,003-0600 INFO  Multiplexer No streams
-2013-11-06 03:36:34,363-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:36:43,013-0600 INFO  Multiplexer No streams
-2013-11-06 03:36:50,556-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:36:53,023-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:37:03,033-0600 INFO  Multiplexer No streams
-2013-11-06 03:37:09,972-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:37:13,044-0600 INFO  Multiplexer No streams
-2013-11-06 03:37:22,879-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:37:23,054-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:37:33,064-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:37:43,072-0600 INFO  Multiplexer No streams
-2013-11-06 03:37:45,583-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:37:53,082-0600 INFO  Multiplexer No streams
-2013-11-06 03:37:55,203-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:38:03,092-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:38:13,102-0600 INFO  Multiplexer No streams
-2013-11-06 03:38:21,192-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:38:23,111-0600 INFO  Multiplexer No streams
-2013-11-06 03:38:27,525-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:38:33,121-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:38:43,130-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:38:53,140-0600 INFO  Multiplexer No streams
-2013-11-06 03:38:56,802-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:38:59,848-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:39:03,150-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:39:13,159-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:39:23,169-0600 INFO  Multiplexer No streams
-2013-11-06 03:39:32,172-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
-2013-11-06 03:39:32,416-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
-No streams
-2013-11-06 03:39:33,179-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:39:43,188-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:39:53,198-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:40:03,206-0600 INFO  Multiplexer No streams
-2013-11-06 03:40:04,495-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 03:40:08,023-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:40:13,216-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:40:23,227-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:40:33,241-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 03:40:36,818-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:40:43,251-0600 INFO  Multiplexer No streams
-2013-11-06 03:40:43,634-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:40:53,259-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:41:03,270-0600 INFO  Multiplexer No streams
-2013-11-06 03:41:09,141-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:41:13,278-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 03:41:19,245-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:41:23,286-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:41:33,295-0600 INFO  Multiplexer No streams
-2013-11-06 03:41:41,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:41:43,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:41:53,311-0600 INFO  Multiplexer No streams
-2013-11-06 03:41:54,854-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:42:03,318-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:42:13,326-0600 INFO  Multiplexer No streams
-2013-11-06 03:42:13,788-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:42:23,335-0600 INFO  Multiplexer No streams
-2013-11-06 03:42:30,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:42:33,343-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:42:43,350-0600 INFO  Multiplexer No streams
-2013-11-06 03:42:46,111-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:42:53,359-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:43:03,366-0600 INFO  Multiplexer No streams
-2013-11-06 03:43:06,075-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:43:13,374-0600 INFO  Multiplexer No streams
-2013-11-06 03:43:18,434-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:43:23,383-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:43:33,390-0600 INFO  Multiplexer No streams
-2013-11-06 03:43:41,685-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:43:43,398-0600 INFO  Multiplexer No streams
-2013-11-06 03:43:50,757-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:43:53,405-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:44:03,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:44:13,420-0600 INFO  Multiplexer No streams
-2013-11-06 03:44:17,295-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:44:23,079-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:44:23,427-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:44:33,434-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:44:43,442-0600 INFO  Multiplexer No streams
-2013-11-06 03:44:52,905-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:44:53,450-0600 INFO  Multiplexer No streams
-2013-11-06 03:44:55,403-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:45:03,458-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:45:13,466-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:45:23,473-0600 INFO  Multiplexer No streams
-2013-11-06 03:45:27,725-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:45:28,516-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:45:33,481-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:45:43,489-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:45:53,497-0600 INFO  Multiplexer No streams
-2013-11-06 03:46:00,048-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:46:03,505-0600 INFO  Multiplexer No streams
-2013-11-06 03:46:04,125-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:46:13,513-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:46:23,520-0600 INFO  Multiplexer No streams
-2013-11-06 03:46:32,371-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:46:33,528-0600 INFO  Multiplexer No streams
-2013-11-06 03:46:39,736-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:46:43,536-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:46:53,544-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:47:03,552-0600 INFO  Multiplexer No streams
-2013-11-06 03:47:04,694-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:47:13,559-0600 INFO  Multiplexer No streams
-2013-11-06 03:47:15,346-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:47:23,567-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:47:33,575-0600 INFO  Multiplexer No streams
-2013-11-06 03:47:37,017-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:47:43,583-0600 INFO  Multiplexer No streams
-2013-11-06 03:47:50,956-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:47:53,591-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:48:03,598-0600 INFO  Multiplexer No streams
-2013-11-06 03:48:09,340-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:48:13,606-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:48:23,614-0600 INFO  Multiplexer No streams
-2013-11-06 03:48:26,566-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:48:33,622-0600 INFO  Multiplexer No streams
-2013-11-06 03:48:41,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:48:43,630-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:48:53,637-0600 INFO  Multiplexer No streams
-2013-11-06 03:49:02,176-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:49:03,645-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:49:13,653-0600 INFO  Multiplexer No streams
-2013-11-06 03:49:13,986-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:49:23,661-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:49:33,669-0600 INFO  Multiplexer No streams
-2013-11-06 03:49:37,787-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:49:43,677-0600 INFO  Multiplexer No streams
-2013-11-06 03:49:46,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:49:53,685-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:50:03,693-0600 INFO  Multiplexer No streams
-2013-11-06 03:50:13,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:50:13,701-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:50:18,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:50:23,709-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:50:33,717-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:50:43,725-0600 INFO  Multiplexer No streams
-2013-11-06 03:50:49,007-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:50:50,955-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:50:53,734-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:51:03,742-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:51:13,750-0600 INFO  Multiplexer No streams
-2013-11-06 03:51:23,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:51:23,758-0600 INFO  Multiplexer No streams
-2013-11-06 03:51:24,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:51:33,766-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:51:43,774-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:51:53,782-0600 INFO  Multiplexer No streams
-2013-11-06 03:51:55,602-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:52:00,227-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:52:03,790-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:52:13,798-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:52:23,807-0600 INFO  Multiplexer No streams
-2013-11-06 03:52:27,926-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:52:33,815-0600 INFO  Multiplexer No streams
-2013-11-06 03:52:35,837-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:52:43,823-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:52:53,831-0600 INFO  Multiplexer No streams
-2013-11-06 03:53:00,249-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:53:03,839-0600 INFO  Multiplexer No streams
-2013-11-06 03:53:11,448-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:53:13,847-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:53:23,855-0600 INFO  Multiplexer No streams
-2013-11-06 03:53:32,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:53:33,863-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:53:43,871-0600 INFO  Multiplexer No streams
-2013-11-06 03:53:47,059-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:53:53,879-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:54:03,888-0600 INFO  Multiplexer No streams
-2013-11-06 03:54:04,895-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:54:13,896-0600 INFO  Multiplexer No streams
-2013-11-06 03:54:22,668-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 03:54:23,904-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:54:33,912-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 03:54:37,220-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 03:54:43,920-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:54:53,927-0600 INFO  Multiplexer No streams
-2013-11-06 03:54:58,279-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:55:03,935-0600 INFO  Multiplexer No streams
-2013-11-06 03:55:09,542-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:55:13,943-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:55:23,951-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 03:55:33,890-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:55:33,959-0600 INFO  Multiplexer No streams
-2013-11-06 03:55:41,865-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:55:43,967-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:55:53,974-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:56:03,982-0600 INFO  Multiplexer No streams
-2013-11-06 03:56:09,499-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:56:13,990-0600 INFO  Multiplexer No streams
-2013-11-06 03:56:14,188-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:56:23,998-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:56:34,006-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:56:44,014-0600 INFO  Multiplexer No streams
-2013-11-06 03:56:45,109-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:56:46,511-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 03:56:54,022-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:57:04,030-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:57:14,038-0600 INFO  Multiplexer No streams
-2013-11-06 03:57:18,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 03:57:20,719-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:57:24,046-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:57:34,054-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:57:44,062-0600 INFO  Multiplexer No streams
-2013-11-06 03:57:51,157-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 03:57:54,070-0600 INFO  Multiplexer No streams
-2013-11-06 03:57:56,329-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:58:04,078-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:58:14,087-0600 INFO  Multiplexer No streams
-2013-11-06 03:58:23,479-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:58:24,095-0600 INFO  Multiplexer No streams
-2013-11-06 03:58:31,939-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:58:34,103-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:58:44,111-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:58:54,119-0600 INFO  Multiplexer No streams
-2013-11-06 03:58:55,802-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:59:04,127-0600 INFO  Multiplexer No streams
-2013-11-06 03:59:07,549-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:59:14,135-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:59:24,143-0600 INFO  Multiplexer No streams
-2013-11-06 03:59:28,125-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:59:34,151-0600 INFO  Multiplexer No streams
-2013-11-06 03:59:43,159-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 03:59:44,160-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 03:59:54,168-0600 INFO  Multiplexer No streams
-2013-11-06 04:00:00,448-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:00:04,176-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:00:14,184-0600 INFO  Multiplexer No streams
-2013-11-06 04:00:18,769-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:00:24,192-0600 INFO  Multiplexer No streams
-2013-11-06 04:00:32,771-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:00:34,200-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:00:44,209-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:00:54,217-0600 INFO  Multiplexer No streams
-2013-11-06 04:00:54,379-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:01:04,225-0600 INFO  Multiplexer No streams
-2013-11-06 04:01:05,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:01:14,233-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:01:24,242-0600 INFO  Multiplexer No streams
-2013-11-06 04:01:29,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:01:34,250-0600 INFO  Multiplexer No streams
-2013-11-06 04:01:37,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:01:44,258-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:01:54,266-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:02:04,274-0600 INFO  Multiplexer No streams
-2013-11-06 04:02:05,599-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:02:09,741-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:02:14,283-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:02:24,291-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:02:34,299-0600 INFO  Multiplexer No streams
-2013-11-06 04:02:41,209-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:02:42,063-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:02:44,307-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:02:54,315-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:03:04,323-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:03:14,331-0600 INFO  Multiplexer No streams
-2013-11-06 04:03:14,386-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:03:16,819-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:03:24,339-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:03:34,347-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:03:44,356-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 19ms
-2013-11-06 04:03:46,727-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 19ms
-2013-11-06 04:03:52,429-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 04:03:54,364-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:04:04,372-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:04:14,380-0600 INFO  Multiplexer No streams
-2013-11-06 04:04:19,032-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:04:24,388-0600 INFO  Multiplexer No streams
-2013-11-06 04:04:28,040-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:04:34,396-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:04:44,404-0600 INFO  Multiplexer No streams
-2013-11-06 04:04:51,355-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:04:54,412-0600 INFO  Multiplexer No streams
-2013-11-06 04:05:03,651-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:05:04,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:05:14,428-0600 INFO  Multiplexer No streams
-2013-11-06 04:05:23,678-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:05:24,436-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:05:34,444-0600 INFO  Multiplexer No streams
-2013-11-06 04:05:39,260-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:05:44,452-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:05:54,460-0600 INFO  Multiplexer No streams
-2013-11-06 04:05:56,001-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:06:04,468-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:06:14,476-0600 INFO  Multiplexer No streams
-2013-11-06 04:06:14,870-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:06:24,484-0600 INFO  Multiplexer No streams
-2013-11-06 04:06:28,324-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:06:34,492-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:06:44,500-0600 INFO  Multiplexer No streams
-2013-11-06 04:06:50,480-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:06:54,508-0600 INFO  Multiplexer No streams
-2013-11-06 04:07:00,648-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:07:04,516-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:07:14,524-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:07:24,532-0600 INFO  Multiplexer No streams
-2013-11-06 04:07:26,090-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:07:32,970-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:07:34,540-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:07:44,548-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:07:54,557-0600 INFO  Multiplexer No streams
-2013-11-06 04:08:01,701-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:08:04,565-0600 INFO  Multiplexer No streams
-2013-11-06 04:08:05,293-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:08:14,573-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:08:24,582-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:08:34,590-0600 INFO  Multiplexer No streams
-2013-11-06 04:08:37,310-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 04:08:37,616-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:08:44,598-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:08:54,606-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:09:04,614-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 04:09:09,940-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 04:09:12,921-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:09:14,623-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:09:24,631-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:09:34,639-0600 INFO  Multiplexer No streams
-2013-11-06 04:09:42,263-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:09:44,647-0600 INFO  Multiplexer No streams
-2013-11-06 04:09:48,531-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:09:54,656-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:10:04,664-0600 INFO  Multiplexer No streams
-2013-11-06 04:10:14,586-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:10:14,672-0600 INFO  Multiplexer No streams
-2013-11-06 04:10:24,141-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:10:24,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:10:34,688-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:10:44,696-0600 INFO  Multiplexer No streams
-2013-11-06 04:10:46,909-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:10:54,704-0600 INFO  Multiplexer No streams
-2013-11-06 04:10:59,751-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:11:04,712-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:11:14,720-0600 INFO  Multiplexer No streams
-2013-11-06 04:11:19,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 04:11:24,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:11:34,736-0600 INFO  Multiplexer No streams
-2013-11-06 04:11:35,361-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:11:44,745-0600 INFO  Multiplexer No streams
-2013-11-06 04:11:51,555-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:11:54,753-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:12:04,761-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 174ms
-2013-11-06 04:12:11,144-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 174ms
-No streams
-2013-11-06 04:12:14,769-0600 INFO  Multiplexer No streams
-2013-11-06 04:12:23,878-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 04:12:24,777-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:12:34,785-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:12:44,793-0600 INFO  Multiplexer No streams
-2013-11-06 04:12:46,581-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:12:54,801-0600 INFO  Multiplexer No streams
-2013-11-06 04:12:56,201-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:13:04,809-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:13:14,818-0600 INFO  Multiplexer No streams
-2013-11-06 04:13:22,191-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 04:13:24,826-0600 INFO  Multiplexer No streams
-2013-11-06 04:13:28,524-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:13:34,834-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:13:44,842-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:13:54,850-0600 INFO  Multiplexer No streams
-2013-11-06 04:13:57,802-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:14:00,847-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 04:14:04,858-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:14:14,866-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:14:24,874-0600 INFO  Multiplexer No streams
-2013-11-06 04:14:33,169-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 6ms
-2013-11-06 04:14:33,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 6ms
-No streams
-2013-11-06 04:14:34,882-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:14:44,890-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:14:54,898-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:15:04,906-0600 INFO  Multiplexer No streams
-2013-11-06 04:15:05,492-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:15:09,022-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:15:14,914-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:15:24,922-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:15:34,930-0600 INFO  Multiplexer No streams
-2013-11-06 04:15:37,815-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:15:44,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:15:44,938-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:15:54,946-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:16:04,954-0600 INFO  Multiplexer No streams
-2013-11-06 04:16:10,138-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:16:14,962-0600 INFO  Multiplexer No streams
-2013-11-06 04:16:20,243-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:16:24,970-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:16:34,978-0600 INFO  Multiplexer No streams
-2013-11-06 04:16:42,461-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:16:44,986-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:16:54,994-0600 INFO  Multiplexer No streams
-2013-11-06 04:16:55,853-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:17:05,002-0600 INFO  Multiplexer No streams
-2013-11-06 04:17:14,785-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:17:15,010-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:17:25,018-0600 INFO  Multiplexer No streams
-2013-11-06 04:17:31,463-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:17:35,027-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:17:45,035-0600 INFO  Multiplexer No streams
-2013-11-06 04:17:47,107-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:17:55,043-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:18:05,052-0600 INFO  Multiplexer No streams
-2013-11-06 04:18:07,073-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:18:15,060-0600 INFO  Multiplexer No streams
-2013-11-06 04:18:19,430-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:18:25,068-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:18:35,076-0600 INFO  Multiplexer No streams
-2013-11-06 04:18:42,683-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:18:45,084-0600 INFO  Multiplexer No streams
-2013-11-06 04:18:51,753-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:18:55,092-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:19:05,100-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:19:15,109-0600 INFO  Multiplexer No streams
-2013-11-06 04:19:18,293-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:19:24,076-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:19:25,117-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:19:35,126-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:19:45,134-0600 INFO  Multiplexer No streams
-2013-11-06 04:19:53,903-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:19:55,142-0600 INFO  Multiplexer No streams
-2013-11-06 04:19:56,399-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:20:05,150-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:20:15,158-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:20:25,166-0600 INFO  Multiplexer No streams
-2013-11-06 04:20:28,722-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:20:29,514-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:20:35,175-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:20:45,183-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:20:55,192-0600 INFO  Multiplexer No streams
-2013-11-06 04:21:01,046-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:21:05,123-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:21:05,200-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:21:15,208-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:21:25,216-0600 INFO  Multiplexer No streams
-2013-11-06 04:21:33,369-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:21:35,224-0600 INFO  Multiplexer No streams
-2013-11-06 04:21:40,733-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 04:21:45,233-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:21:55,241-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:22:05,250-0600 INFO  Multiplexer No streams
-2013-11-06 04:22:05,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:22:15,258-0600 INFO  Multiplexer No streams
-2013-11-06 04:22:16,344-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:22:25,266-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:22:35,275-0600 INFO  Multiplexer No streams
-2013-11-06 04:22:38,017-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:22:45,283-0600 INFO  Multiplexer No streams
-2013-11-06 04:22:51,954-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:22:55,291-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:23:05,299-0600 INFO  Multiplexer No streams
-2013-11-06 04:23:10,339-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:23:15,307-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:23:25,314-0600 INFO  Multiplexer No streams
-2013-11-06 04:23:27,564-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:23:35,322-0600 INFO  Multiplexer No streams
-2013-11-06 04:23:42,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:23:45,330-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:23:55,338-0600 INFO  Multiplexer No streams
-2013-11-06 04:24:03,174-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:24:05,346-0600 INFO  Multiplexer No streams
-2013-11-06 04:24:14,986-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:24:15,354-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:24:25,362-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:24:35,370-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-2013-11-06 04:24:38,785-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-No streams
-2013-11-06 04:24:45,377-0600 INFO  Multiplexer No streams
-2013-11-06 04:24:47,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:24:55,385-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:25:05,393-0600 INFO  Multiplexer No streams
-2013-11-06 04:25:14,394-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:25:15,401-0600 INFO  Multiplexer No streams
-2013-11-06 04:25:19,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:25:25,409-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:25:35,417-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:25:45,424-0600 INFO  Multiplexer No streams
-2013-11-06 04:25:50,005-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 04:25:51,955-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:25:55,432-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:26:05,440-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:26:15,449-0600 INFO  Multiplexer No streams
-2013-11-06 04:26:24,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:26:25,457-0600 INFO  Multiplexer No streams
-2013-11-06 04:26:25,614-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:26:35,465-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:26:45,473-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:26:55,481-0600 INFO  Multiplexer No streams
-2013-11-06 04:26:56,601-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:27:01,224-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:27:05,489-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:27:15,497-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:27:25,506-0600 INFO  Multiplexer No streams
-2013-11-06 04:27:28,925-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:27:35,514-0600 INFO  Multiplexer No streams
-2013-11-06 04:27:36,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 04:27:45,523-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:27:55,531-0600 INFO  Multiplexer No streams
-2013-11-06 04:28:01,248-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:28:05,539-0600 INFO  Multiplexer No streams
-2013-11-06 04:28:12,444-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:28:15,547-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:28:25,556-0600 INFO  Multiplexer No streams
-2013-11-06 04:28:33,571-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:28:35,564-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:28:45,572-0600 INFO  Multiplexer No streams
-2013-11-06 04:28:48,055-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:28:55,581-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:29:05,589-0600 INFO  Multiplexer No streams
-2013-11-06 04:29:05,894-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:29:15,598-0600 INFO  Multiplexer No streams
-2013-11-06 04:29:23,664-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:29:25,606-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:29:35,614-0600 INFO  Multiplexer No streams
-2013-11-06 04:29:38,217-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:29:45,622-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:29:55,631-0600 INFO  Multiplexer No streams
-2013-11-06 04:29:59,274-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:30:05,639-0600 INFO  Multiplexer No streams
-2013-11-06 04:30:10,540-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:30:15,647-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:30:25,656-0600 INFO  Multiplexer No streams
-2013-11-06 04:30:34,884-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:30:35,664-0600 INFO  Multiplexer No streams
-2013-11-06 04:30:42,863-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:30:45,672-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:30:55,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:31:05,689-0600 INFO  Multiplexer No streams
-2013-11-06 04:31:10,494-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 04:31:15,186-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 04:31:15,697-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:31:25,705-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:31:35,714-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:31:45,722-0600 INFO  Multiplexer No streams
-2013-11-06 04:31:46,104-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:31:47,509-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:31:55,730-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:32:05,738-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:32:15,746-0600 INFO  Multiplexer No streams
-2013-11-06 04:32:19,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:32:21,714-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:32:25,754-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:32:35,763-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:32:45,771-0600 INFO  Multiplexer No streams
-2013-11-06 04:32:52,157-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:32:55,779-0600 INFO  Multiplexer No streams
-2013-11-06 04:32:57,325-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:33:05,787-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:33:15,796-0600 INFO  Multiplexer No streams
-2013-11-06 04:33:24,481-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:33:25,804-0600 INFO  Multiplexer No streams
-2013-11-06 04:33:32,934-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:33:35,812-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:33:45,820-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:33:55,828-0600 INFO  Multiplexer No streams
-2013-11-06 04:33:56,805-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:34:05,836-0600 INFO  Multiplexer No streams
-2013-11-06 04:34:08,544-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:34:15,844-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:34:25,853-0600 INFO  Multiplexer No streams
-2013-11-06 04:34:29,129-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:34:35,861-0600 INFO  Multiplexer No streams
-2013-11-06 04:34:44,154-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:34:45,869-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:34:55,877-0600 INFO  Multiplexer No streams
-2013-11-06 04:35:01,453-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 04:35:05,886-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:35:15,894-0600 INFO  Multiplexer No streams
-2013-11-06 04:35:19,764-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:35:25,902-0600 INFO  Multiplexer No streams
-2013-11-06 04:35:33,778-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 04:35:35,911-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:35:45,919-0600 INFO  Multiplexer No streams
-2013-11-06 04:35:55,374-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:35:55,927-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:36:05,935-0600 INFO  Multiplexer No streams
-2013-11-06 04:36:06,100-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 04:36:15,943-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:36:25,952-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 04:36:30,984-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 04:36:35,960-0600 INFO  Multiplexer No streams
-2013-11-06 04:36:38,423-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:36:45,968-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:36:55,976-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:37:05,985-0600 INFO  Multiplexer No streams
-2013-11-06 04:37:06,595-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:37:10,747-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 04:37:15,993-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:37:26,001-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:37:36,009-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 5ms
-2013-11-06 04:37:42,209-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 5ms
-2013-11-06 04:37:43,069-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:37:46,018-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:37:56,026-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:38:06,034-0600 INFO  Multiplexer No streams
-2013-11-06 04:38:15,392-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:38:16,042-0600 INFO  Multiplexer No streams
-2013-11-06 04:38:17,815-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:38:26,050-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:38:36,059-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:38:46,067-0600 INFO  Multiplexer No streams
-2013-11-06 04:38:47,716-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 04:38:53,425-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:38:56,075-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:39:06,083-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:39:16,092-0600 INFO  Multiplexer No streams
-2013-11-06 04:39:20,038-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:39:26,100-0600 INFO  Multiplexer No streams
-2013-11-06 04:39:29,035-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:39:36,108-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:39:46,116-0600 INFO  Multiplexer No streams
-2013-11-06 04:39:52,361-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:39:56,124-0600 INFO  Multiplexer No streams
-2013-11-06 04:40:04,645-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:40:06,132-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:40:16,141-0600 INFO  Multiplexer No streams
-2013-11-06 04:40:24,685-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 04:40:26,149-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:40:36,157-0600 INFO  Multiplexer No streams
-2013-11-06 04:40:40,256-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:40:46,165-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:40:56,173-0600 INFO  Multiplexer No streams
-2013-11-06 04:40:57,007-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:41:06,182-0600 INFO  Multiplexer No streams
-2013-11-06 04:41:15,865-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:41:16,190-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:41:26,198-0600 INFO  Multiplexer No streams
-2013-11-06 04:41:29,331-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 04:41:36,206-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:41:46,214-0600 INFO  Multiplexer No streams
-2013-11-06 04:41:51,475-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:41:56,222-0600 INFO  Multiplexer No streams
-2013-11-06 04:42:01,653-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:42:06,230-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:42:16,238-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:42:26,246-0600 INFO  Multiplexer No streams
-2013-11-06 04:42:27,085-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:42:33,977-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:42:36,254-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:42:46,263-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:42:56,271-0600 INFO  Multiplexer No streams
-2013-11-06 04:43:02,696-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:43:06,280-0600 INFO  Multiplexer No streams
-2013-11-06 04:43:06,300-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:43:16,288-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:43:26,296-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:43:36,304-0600 INFO  Multiplexer No streams
-2013-11-06 04:43:38,305-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:43:38,622-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:43:46,312-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:43:56,321-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:44:06,329-0600 INFO  Multiplexer No streams
-2013-11-06 04:44:10,945-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 04:44:13,915-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 04:44:16,337-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:44:26,346-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:44:36,354-0600 INFO  Multiplexer No streams
-2013-11-06 04:44:43,268-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:44:46,362-0600 INFO  Multiplexer No streams
-2013-11-06 04:44:49,525-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:44:56,370-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:45:06,378-0600 INFO  Multiplexer No streams
-2013-11-06 04:45:15,591-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:45:16,387-0600 INFO  Multiplexer No streams
-2013-11-06 04:45:25,136-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:45:26,395-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:45:36,403-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:45:46,412-0600 INFO  Multiplexer No streams
-2013-11-06 04:45:47,915-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 04:45:56,420-0600 INFO  Multiplexer No streams
-2013-11-06 04:46:00,745-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:46:06,428-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:46:16,436-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 04:46:20,238-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 04:46:26,444-0600 INFO  Multiplexer No streams
-2013-11-06 04:46:36,355-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:46:36,452-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:46:46,460-0600 INFO  Multiplexer No streams
-2013-11-06 04:46:52,560-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:46:56,469-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:47:06,477-0600 INFO  Multiplexer No streams
-2013-11-06 04:47:11,965-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:47:16,485-0600 INFO  Multiplexer No streams
-2013-11-06 04:47:24,883-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:47:26,493-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:47:36,501-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:47:46,509-0600 INFO  Multiplexer No streams
-2013-11-06 04:47:47,575-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:47:56,517-0600 INFO  Multiplexer No streams
-2013-11-06 04:47:57,206-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:48:06,525-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:48:16,533-0600 INFO  Multiplexer No streams
-2013-11-06 04:48:23,185-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:48:26,541-0600 INFO  Multiplexer No streams
-2013-11-06 04:48:29,529-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:48:36,549-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:48:46,557-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:48:56,566-0600 INFO  Multiplexer No streams
-2013-11-06 04:48:58,795-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:49:01,852-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:49:06,574-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:49:16,582-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:49:26,590-0600 INFO  Multiplexer No streams
-2013-11-06 04:49:34,175-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:49:34,405-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:49:36,598-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:49:46,606-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:49:56,614-0600 INFO  Multiplexer No streams
-2013-11-06 04:50:06,498-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:50:06,622-0600 INFO  Multiplexer No streams
-2013-11-06 04:50:10,015-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:50:16,630-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:50:26,638-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:50:36,647-0600 INFO  Multiplexer No streams
-2013-11-06 04:50:38,822-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 04:50:45,625-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:50:46,654-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:50:56,662-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:51:06,671-0600 INFO  Multiplexer No streams
-2013-11-06 04:51:11,144-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:51:16,678-0600 INFO  Multiplexer No streams
-2013-11-06 04:51:21,235-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:51:26,686-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:51:36,695-0600 INFO  Multiplexer No streams
-2013-11-06 04:51:43,467-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:51:46,703-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:51:56,711-0600 INFO  Multiplexer No streams
-2013-11-06 04:51:56,845-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:52:06,719-0600 INFO  Multiplexer No streams
-2013-11-06 04:52:15,790-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:52:16,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:52:26,736-0600 INFO  Multiplexer No streams
-2013-11-06 04:52:32,455-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:52:36,744-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:52:46,752-0600 INFO  Multiplexer No streams
-2013-11-06 04:52:48,113-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:52:56,761-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:53:06,769-0600 INFO  Multiplexer No streams
-2013-11-06 04:53:08,065-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 04:53:16,777-0600 INFO  Multiplexer No streams
-2013-11-06 04:53:20,436-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:53:26,785-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:53:36,793-0600 INFO  Multiplexer No streams
-2013-11-06 04:53:43,675-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:53:46,801-0600 INFO  Multiplexer No streams
-2013-11-06 04:53:52,759-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:53:56,809-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:54:06,817-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:54:16,826-0600 INFO  Multiplexer No streams
-2013-11-06 04:54:19,285-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:54:25,082-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:54:26,834-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:54:36,842-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:54:46,850-0600 INFO  Multiplexer No streams
-2013-11-06 04:54:54,895-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:54:56,858-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:54:57,405-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:55:06,866-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:55:16,875-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:55:26,883-0600 INFO  Multiplexer No streams
-2013-11-06 04:55:29,729-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 8ms
-2013-11-06 04:55:30,512-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 8ms
-No streams
-2013-11-06 04:55:36,891-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:55:46,899-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:55:56,907-0600 INFO  Multiplexer No streams
-2013-11-06 04:56:02,051-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:56:06,115-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:56:06,915-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:56:16,923-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:56:26,932-0600 INFO  Multiplexer No streams
-2013-11-06 04:56:34,374-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:56:36,940-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 04:56:41,725-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:56:46,948-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:56:56,955-0600 INFO  Multiplexer No streams
-2013-11-06 04:57:06,697-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:57:06,964-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:57:16,972-0600 INFO  Multiplexer No streams
-2013-11-06 04:57:17,336-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:57:26,980-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:57:36,988-0600 INFO  Multiplexer No streams
-2013-11-06 04:57:39,020-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:57:46,996-0600 INFO  Multiplexer No streams
-2013-11-06 04:57:52,946-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:57:57,004-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:58:07,012-0600 INFO  Multiplexer No streams
-2013-11-06 04:58:11,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:58:17,020-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:58:27,028-0600 INFO  Multiplexer No streams
-2013-11-06 04:58:28,556-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:58:37,036-0600 INFO  Multiplexer No streams
-2013-11-06 04:58:43,666-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:58:47,044-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:58:57,052-0600 INFO  Multiplexer No streams
-2013-11-06 04:59:04,166-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:59:07,061-0600 INFO  Multiplexer No streams
-2013-11-06 04:59:15,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:59:17,069-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:59:27,077-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 04:59:37,084-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-2013-11-06 04:59:39,778-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-No streams
-2013-11-06 04:59:47,092-0600 INFO  Multiplexer No streams
-2013-11-06 04:59:48,312-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 04:59:57,101-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:00:07,109-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 05:00:15,387-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:00:17,117-0600 INFO  Multiplexer No streams
-2013-11-06 05:00:20,635-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:00:27,125-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:00:37,133-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:00:47,141-0600 INFO  Multiplexer No streams
-2013-11-06 05:00:50,996-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 05:00:52,960-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 05:00:57,151-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:01:07,159-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:01:17,168-0600 INFO  Multiplexer No streams
-2013-11-06 05:01:25,281-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:01:26,606-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:01:27,176-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:01:37,184-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:01:47,192-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:01:57,201-0600 INFO  Multiplexer No streams
-2013-11-06 05:01:57,604-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:02:02,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:02:07,209-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:02:17,217-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:02:27,226-0600 INFO  Multiplexer No streams
-2013-11-06 05:02:29,927-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:02:37,234-0600 INFO  Multiplexer No streams
-2013-11-06 05:02:37,826-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:02:47,242-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:02:57,250-0600 INFO  Multiplexer No streams
-2013-11-06 05:03:02,250-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:03:07,258-0600 INFO  Multiplexer No streams
-2013-11-06 05:03:13,436-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:03:17,266-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:03:27,274-0600 INFO  Multiplexer No streams
-2013-11-06 05:03:34,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:03:37,282-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:03:47,290-0600 INFO  Multiplexer No streams
-2013-11-06 05:03:49,046-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:03:57,299-0600 INFO  Multiplexer No streams
-2013-11-06 05:04:06,896-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:04:07,307-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:04:17,315-0600 INFO  Multiplexer No streams
-2013-11-06 05:04:24,656-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:04:27,323-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:04:37,331-0600 INFO  Multiplexer No streams
-2013-11-06 05:04:39,219-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:04:47,339-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:04:57,347-0600 INFO  Multiplexer No streams
-2013-11-06 05:05:00,266-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:05:07,355-0600 INFO  Multiplexer No streams
-2013-11-06 05:05:11,542-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:05:17,363-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:05:27,371-0600 INFO  Multiplexer No streams
-2013-11-06 05:05:35,876-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:05:37,380-0600 INFO  Multiplexer No streams
-2013-11-06 05:05:43,865-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:05:47,388-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:05:57,396-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:06:07,404-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 05:06:11,487-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 05:06:16,188-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:06:17,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:06:27,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:06:37,428-0600 INFO  Multiplexer No streams
-2013-11-06 05:06:47,096-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:06:47,436-0600 INFO  Multiplexer No streams
-2013-11-06 05:06:48,511-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:06:57,444-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:07:07,453-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:07:17,461-0600 INFO  Multiplexer No streams
-2013-11-06 05:07:20,835-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 05:07:22,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:07:27,469-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:07:37,477-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:07:47,485-0600 INFO  Multiplexer No streams
-2013-11-06 05:07:53,157-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:07:57,493-0600 INFO  Multiplexer No streams
-2013-11-06 05:07:58,317-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:08:07,501-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:08:17,510-0600 INFO  Multiplexer No streams
-2013-11-06 05:08:25,480-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:08:27,518-0600 INFO  Multiplexer No streams
-2013-11-06 05:08:33,926-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:08:37,526-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:08:47,534-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:08:57,543-0600 INFO  Multiplexer No streams
-2013-11-06 05:08:57,803-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:09:07,551-0600 INFO  Multiplexer No streams
-2013-11-06 05:09:09,537-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:09:17,559-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:09:27,567-0600 INFO  Multiplexer No streams
-2013-11-06 05:09:30,126-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:09:37,575-0600 INFO  Multiplexer No streams
-2013-11-06 05:09:45,146-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:09:47,582-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:09:57,589-0600 INFO  Multiplexer No streams
-2013-11-06 05:10:02,449-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:10:07,598-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:10:17,606-0600 INFO  Multiplexer No streams
-2013-11-06 05:10:20,757-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:10:27,614-0600 INFO  Multiplexer No streams
-2013-11-06 05:10:34,772-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:10:37,623-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:10:47,631-0600 INFO  Multiplexer No streams
-2013-11-06 05:10:56,366-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:10:57,639-0600 INFO  Multiplexer No streams
-2013-11-06 05:11:07,095-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:11:07,647-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:11:17,655-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:11:27,663-0600 INFO  Multiplexer No streams
-2013-11-06 05:11:31,976-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:11:37,672-0600 INFO  Multiplexer No streams
-2013-11-06 05:11:39,418-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:11:47,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:11:57,688-0600 INFO  Multiplexer No streams
-2013-11-06 05:12:07,586-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 05:12:07,696-0600 INFO  Multiplexer No streams
-2013-11-06 05:12:11,742-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 05:12:17,704-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:12:27,713-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:12:37,721-0600 INFO  Multiplexer No streams
-2013-11-06 05:12:43,197-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:12:44,064-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:12:47,729-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:12:57,737-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:13:07,745-0600 INFO  Multiplexer No streams
-2013-11-06 05:13:16,387-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:13:17,753-0600 INFO  Multiplexer No streams
-2013-11-06 05:13:18,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:13:27,761-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:13:37,769-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:13:47,777-0600 INFO  Multiplexer No streams
-2013-11-06 05:13:48,710-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:13:54,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:13:57,785-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:14:07,793-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:14:17,802-0600 INFO  Multiplexer No streams
-2013-11-06 05:14:21,033-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:14:27,810-0600 INFO  Multiplexer No streams
-2013-11-06 05:14:30,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:14:37,818-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:14:47,826-0600 INFO  Multiplexer No streams
-2013-11-06 05:14:53,356-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:14:57,834-0600 INFO  Multiplexer No streams
-2013-11-06 05:15:05,638-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:15:07,842-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:15:17,850-0600 INFO  Multiplexer No streams
-2013-11-06 05:15:25,679-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:15:27,858-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:15:37,866-0600 INFO  Multiplexer No streams
-2013-11-06 05:15:41,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:15:47,874-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:15:57,883-0600 INFO  Multiplexer No streams
-2013-11-06 05:15:58,002-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:16:07,891-0600 INFO  Multiplexer No streams
-2013-11-06 05:16:16,857-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:16:17,899-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:16:27,907-0600 INFO  Multiplexer No streams
-2013-11-06 05:16:30,325-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:16:37,915-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:16:47,923-0600 INFO  Multiplexer No streams
-2013-11-06 05:16:52,467-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:16:57,931-0600 INFO  Multiplexer No streams
-2013-11-06 05:17:02,648-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:17:07,939-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:17:17,947-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:17:27,955-0600 INFO  Multiplexer No streams
-2013-11-06 05:17:28,077-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:17:34,971-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:17:37,963-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:17:47,971-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:17:57,979-0600 INFO  Multiplexer No streams
-2013-11-06 05:18:03,688-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 05:18:07,294-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:18:07,987-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:18:17,995-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:18:28,003-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:18:38,011-0600 INFO  Multiplexer No streams
-2013-11-06 05:18:39,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 05:18:39,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:18:48,018-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:18:58,027-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:19:08,035-0600 INFO  Multiplexer No streams
-2013-11-06 05:19:11,940-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 05:19:14,907-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:19:18,043-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:19:28,051-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:19:38,059-0600 INFO  Multiplexer No streams
-2013-11-06 05:19:44,263-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:19:48,067-0600 INFO  Multiplexer No streams
-2013-11-06 05:19:50,517-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:19:58,075-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:20:08,084-0600 INFO  Multiplexer No streams
-2013-11-06 05:20:16,586-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:20:18,092-0600 INFO  Multiplexer No streams
-2013-11-06 05:20:26,127-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:20:28,100-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:20:38,108-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:20:48,116-0600 INFO  Multiplexer No streams
-2013-11-06 05:20:48,909-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:20:58,124-0600 INFO  Multiplexer No streams
-2013-11-06 05:21:01,737-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:21:08,133-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:21:18,141-0600 INFO  Multiplexer No streams
-2013-11-06 05:21:21,232-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:21:28,149-0600 INFO  Multiplexer No streams
-2013-11-06 05:21:37,347-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:21:38,157-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:21:48,165-0600 INFO  Multiplexer No streams
-2013-11-06 05:21:53,555-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:21:58,173-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:22:08,181-0600 INFO  Multiplexer No streams
-2013-11-06 05:22:12,958-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 05:22:18,189-0600 INFO  Multiplexer No streams
-2013-11-06 05:22:25,878-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:22:28,197-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:22:38,205-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:22:48,213-0600 INFO  Multiplexer No streams
-2013-11-06 05:22:48,567-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:22:58,201-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:22:58,222-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:23:08,230-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:23:18,237-0600 INFO  Multiplexer No streams
-2013-11-06 05:23:24,177-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:23:28,246-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 05:23:30,523-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 05:23:38,254-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:23:48,262-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:23:58,270-0600 INFO  Multiplexer No streams
-2013-11-06 05:23:59,787-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:24:02,848-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:24:08,278-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:24:18,286-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:24:28,294-0600 INFO  Multiplexer No streams
-2013-11-06 05:24:35,171-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:24:35,396-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 05:24:38,302-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:24:48,310-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:24:58,318-0600 INFO  Multiplexer No streams
-2013-11-06 05:25:07,494-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:25:08,326-0600 INFO  Multiplexer No streams
-2013-11-06 05:25:11,007-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:25:18,334-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:25:28,342-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:25:38,350-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 05:25:39,818-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 05:25:46,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:25:48,358-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:25:58,366-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:26:08,374-0600 INFO  Multiplexer No streams
-2013-11-06 05:26:12,140-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:26:18,382-0600 INFO  Multiplexer No streams
-2013-11-06 05:26:22,229-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 05:26:28,390-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:26:38,399-0600 INFO  Multiplexer No streams
-2013-11-06 05:26:44,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:26:48,406-0600 INFO  Multiplexer No streams
-2013-11-06 05:26:57,837-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:26:58,414-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:27:08,422-0600 INFO  Multiplexer No streams
-2013-11-06 05:27:16,786-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:27:18,430-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:27:28,438-0600 INFO  Multiplexer No streams
-2013-11-06 05:27:33,447-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:27:38,446-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:27:48,454-0600 INFO  Multiplexer No streams
-2013-11-06 05:27:49,109-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:27:58,462-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:28:08,470-0600 INFO  Multiplexer No streams
-2013-11-06 05:28:09,057-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:28:18,478-0600 INFO  Multiplexer No streams
-2013-11-06 05:28:21,432-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:28:28,487-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:28:38,495-0600 INFO  Multiplexer No streams
-2013-11-06 05:28:44,667-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:28:48,502-0600 INFO  Multiplexer No streams
-2013-11-06 05:28:53,755-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:28:58,510-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:29:08,519-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:29:18,526-0600 INFO  Multiplexer No streams
-2013-11-06 05:29:20,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 05:29:26,078-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:29:28,534-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:29:38,542-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:29:48,551-0600 INFO  Multiplexer No streams
-2013-11-06 05:29:55,888-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:29:58,401-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:29:58,559-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:30:08,567-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:30:18,575-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:30:28,583-0600 INFO  Multiplexer No streams
-2013-11-06 05:30:30,724-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 7ms
-2013-11-06 05:30:31,504-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 7ms
-No streams
-2013-11-06 05:30:38,592-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:30:48,600-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:30:58,608-0600 INFO  Multiplexer No streams
-2013-11-06 05:31:03,047-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:31:07,108-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:31:08,616-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:31:18,624-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:31:28,632-0600 INFO  Multiplexer No streams
-2013-11-06 05:31:35,370-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:31:38,640-0600 INFO  Multiplexer No streams
-2013-11-06 05:31:42,718-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:31:48,648-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:31:58,656-0600 INFO  Multiplexer No streams
-2013-11-06 05:32:07,694-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:32:08,664-0600 INFO  Multiplexer No streams
-2013-11-06 05:32:18,328-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 05:32:18,672-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:32:28,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:32:38,688-0600 INFO  Multiplexer No streams
-2013-11-06 05:32:40,016-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:32:48,696-0600 INFO  Multiplexer No streams
-2013-11-06 05:32:53,939-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:32:58,704-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:33:08,712-0600 INFO  Multiplexer No streams
-2013-11-06 05:33:12,339-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:33:18,720-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:33:28,728-0600 INFO  Multiplexer No streams
-2013-11-06 05:33:29,549-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:33:38,736-0600 INFO  Multiplexer No streams
-2013-11-06 05:33:44,662-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:33:48,745-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:33:58,752-0600 INFO  Multiplexer No streams
-2013-11-06 05:34:05,159-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 05:34:08,761-0600 INFO  Multiplexer No streams
-2013-11-06 05:34:16,985-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:34:18,769-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:34:28,777-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:34:38,785-0600 INFO  Multiplexer No streams
-2013-11-06 05:34:40,770-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:34:48,793-0600 INFO  Multiplexer No streams
-2013-11-06 05:34:49,308-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:34:58,801-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:35:08,810-0600 INFO  Multiplexer No streams
-2013-11-06 05:35:16,381-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 05:35:18,818-0600 INFO  Multiplexer No streams
-2013-11-06 05:35:21,631-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:35:28,826-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:35:38,835-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:35:48,843-0600 INFO  Multiplexer No streams
-2013-11-06 05:35:51,990-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:35:53,954-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:35:58,851-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:36:08,860-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:36:18,868-0600 INFO  Multiplexer No streams
-2013-11-06 05:36:26,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:36:27,600-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:36:28,876-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:36:38,884-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:36:48,892-0600 INFO  Multiplexer No streams
-2013-11-06 05:36:58,600-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:36:58,900-0600 INFO  Multiplexer No streams
-2013-11-06 05:37:03,210-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:37:08,907-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:37:18,915-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:37:28,923-0600 INFO  Multiplexer No streams
-2013-11-06 05:37:30,923-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:37:38,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:37:38,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:37:48,938-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:37:58,946-0600 INFO  Multiplexer No streams
-2013-11-06 05:38:03,246-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:38:08,954-0600 INFO  Multiplexer No streams
-2013-11-06 05:38:14,430-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:38:18,962-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:38:28,970-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 05:38:35,569-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:38:38,977-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:38:48,985-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-2013-11-06 05:38:50,043-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 05:38:58,993-0600 INFO  Multiplexer No streams
-2013-11-06 05:39:07,892-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:39:09,001-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:39:19,008-0600 INFO  Multiplexer No streams
-2013-11-06 05:39:25,650-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:39:29,016-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:39:39,024-0600 INFO  Multiplexer No streams
-2013-11-06 05:39:40,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 05:39:49,033-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:39:59,041-0600 INFO  Multiplexer No streams
-2013-11-06 05:40:01,260-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:40:09,048-0600 INFO  Multiplexer No streams
-2013-11-06 05:40:12,538-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:40:19,056-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:40:29,064-0600 INFO  Multiplexer No streams
-2013-11-06 05:40:36,870-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:40:39,072-0600 INFO  Multiplexer No streams
-2013-11-06 05:40:44,861-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:40:49,080-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:40:59,087-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:41:09,095-0600 INFO  Multiplexer No streams
-2013-11-06 05:41:12,480-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:41:17,184-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:41:19,103-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:41:29,111-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:41:39,119-0600 INFO  Multiplexer No streams
-2013-11-06 05:41:48,090-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:41:49,127-0600 INFO  Multiplexer No streams
-2013-11-06 05:41:49,507-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:41:59,135-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:42:09,143-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:42:19,151-0600 INFO  Multiplexer No streams
-2013-11-06 05:42:21,831-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 05:42:23,700-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:42:29,159-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:42:39,167-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:42:49,175-0600 INFO  Multiplexer No streams
-2013-11-06 05:42:54,155-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:42:59,183-0600 INFO  Multiplexer No streams
-2013-11-06 05:42:59,310-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:43:09,191-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:43:19,199-0600 INFO  Multiplexer No streams
-2013-11-06 05:43:26,478-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:43:29,207-0600 INFO  Multiplexer No streams
-2013-11-06 05:43:34,920-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:43:39,215-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:43:49,223-0600 INFO  Multiplexer No streams
-2013-11-06 05:43:58,802-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:43:59,231-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:44:09,239-0600 INFO  Multiplexer No streams
-2013-11-06 05:44:10,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:44:19,247-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:44:29,255-0600 INFO  Multiplexer No streams
-2013-11-06 05:44:31,125-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:44:39,262-0600 INFO  Multiplexer No streams
-2013-11-06 05:44:46,140-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:44:49,271-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:44:59,279-0600 INFO  Multiplexer No streams
-2013-11-06 05:45:03,448-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:45:09,287-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:45:19,294-0600 INFO  Multiplexer No streams
-2013-11-06 05:45:21,750-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:45:29,302-0600 INFO  Multiplexer No streams
-2013-11-06 05:45:35,771-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:45:39,311-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:45:49,319-0600 INFO  Multiplexer No streams
-2013-11-06 05:45:57,360-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:45:59,328-0600 INFO  Multiplexer No streams
-2013-11-06 05:46:08,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:46:09,336-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:46:19,344-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:46:29,352-0600 INFO  Multiplexer No streams
-2013-11-06 05:46:32,970-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:46:39,360-0600 INFO  Multiplexer No streams
-2013-11-06 05:46:40,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:46:49,368-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:46:59,376-0600 INFO  Multiplexer No streams
-2013-11-06 05:47:08,580-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:47:09,385-0600 INFO  Multiplexer No streams
-2013-11-06 05:47:12,740-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:47:19,393-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:47:29,401-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:47:39,409-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 05:47:44,193-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 05:47:45,064-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:47:49,417-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:47:59,425-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:48:09,433-0600 INFO  Multiplexer No streams
-2013-11-06 05:48:17,386-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:48:19,441-0600 INFO  Multiplexer No streams
-2013-11-06 05:48:19,802-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:48:29,449-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:48:39,458-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:48:49,466-0600 INFO  Multiplexer No streams
-2013-11-06 05:48:49,710-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 05:48:55,412-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 05:48:59,473-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:49:09,481-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:49:19,490-0600 INFO  Multiplexer No streams
-2013-11-06 05:49:22,034-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 05:49:29,498-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 05:49:31,021-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:49:39,506-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:49:49,515-0600 INFO  Multiplexer No streams
-2013-11-06 05:49:54,355-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:49:59,523-0600 INFO  Multiplexer No streams
-2013-11-06 05:50:06,631-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:50:09,531-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:50:19,539-0600 INFO  Multiplexer No streams
-2013-11-06 05:50:26,678-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:50:29,547-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:50:39,555-0600 INFO  Multiplexer No streams
-2013-11-06 05:50:42,241-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:50:49,563-0600 INFO  Multiplexer No streams
-2013-11-06 05:50:59,001-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:50:59,571-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:51:09,579-0600 INFO  Multiplexer No streams
-2013-11-06 05:51:17,851-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:51:19,587-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:51:29,595-0600 INFO  Multiplexer No streams
-2013-11-06 05:51:31,324-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:51:39,603-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:51:49,611-0600 INFO  Multiplexer No streams
-2013-11-06 05:51:53,461-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:51:59,619-0600 INFO  Multiplexer No streams
-2013-11-06 05:52:03,647-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:52:09,628-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:52:19,635-0600 INFO  Multiplexer No streams
-2013-11-06 05:52:29,071-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:52:29,643-0600 INFO  Multiplexer No streams
-2013-11-06 05:52:35,970-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:52:39,651-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:52:49,659-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:52:59,667-0600 INFO  Multiplexer No streams
-2013-11-06 05:53:04,681-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:53:08,293-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:53:09,677-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:53:19,685-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:53:29,692-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:53:39,701-0600 INFO  Multiplexer No streams
-2013-11-06 05:53:40,291-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:53:40,616-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 05:53:49,709-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:53:59,718-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:54:09,726-0600 INFO  Multiplexer No streams
-2013-11-06 05:54:12,940-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:54:15,901-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:54:19,734-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:54:29,742-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:54:39,750-0600 INFO  Multiplexer No streams
-2013-11-06 05:54:45,264-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:54:49,758-0600 INFO  Multiplexer No streams
-2013-11-06 05:54:51,511-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:54:59,766-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:55:09,774-0600 INFO  Multiplexer No streams
-2013-11-06 05:55:17,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:55:19,782-0600 INFO  Multiplexer No streams
-2013-11-06 05:55:27,121-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:55:29,789-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:55:39,798-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:55:49,806-0600 INFO  Multiplexer No streams
-2013-11-06 05:55:49,910-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:55:59,814-0600 INFO  Multiplexer No streams
-2013-11-06 05:56:02,731-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:56:09,822-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:56:19,830-0600 INFO  Multiplexer No streams
-2013-11-06 05:56:22,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:56:29,838-0600 INFO  Multiplexer No streams
-2013-11-06 05:56:38,341-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:56:39,846-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:56:49,854-0600 INFO  Multiplexer No streams
-2013-11-06 05:56:54,556-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:56:59,863-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:57:09,871-0600 INFO  Multiplexer No streams
-2013-11-06 05:57:13,952-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:57:19,879-0600 INFO  Multiplexer No streams
-2013-11-06 05:57:26,879-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:57:29,888-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:57:39,896-0600 INFO  Multiplexer No streams
-2013-11-06 05:57:49,561-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:57:49,905-0600 INFO  Multiplexer No streams
-2013-11-06 05:57:59,202-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:57:59,913-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:58:09,921-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:58:19,929-0600 INFO  Multiplexer No streams
-2013-11-06 05:58:25,171-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:58:29,937-0600 INFO  Multiplexer No streams
-2013-11-06 05:58:31,525-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 05:58:39,945-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:58:49,957-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:58:59,969-0600 INFO  Multiplexer No streams
-2013-11-06 05:59:00,781-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:59:03,848-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 05:59:09,980-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:59:19,992-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:59:30,003-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:59:36,171-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 05:59:36,391-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 05:59:40,013-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 05:59:50,025-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:00:00,036-0600 INFO  Multiplexer No streams
-2013-11-06 06:00:08,495-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:00:10,047-0600 INFO  Multiplexer No streams
-2013-11-06 06:00:12,001-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:00:20,058-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:00:30,068-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:00:40,079-0600 INFO  Multiplexer No streams
-2013-11-06 06:00:40,819-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:00:47,612-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:00:50,092-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:01:00,104-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:01:10,116-0600 INFO  Multiplexer No streams
-2013-11-06 06:01:13,141-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:01:20,127-0600 INFO  Multiplexer No streams
-2013-11-06 06:01:23,222-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:01:30,147-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:01:40,162-0600 INFO  Multiplexer No streams
-2013-11-06 06:01:45,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:01:50,178-0600 INFO  Multiplexer No streams
-2013-11-06 06:01:58,832-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:02:00,181-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:02:10,196-0600 INFO  Multiplexer No streams
-2013-11-06 06:02:17,788-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:02:20,212-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:02:30,231-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:02:34,441-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:02:40,240-0600 INFO  Multiplexer No streams
-2013-11-06 06:02:50,111-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:02:50,250-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:03:00,258-0600 INFO  Multiplexer No streams
-2013-11-06 06:03:10,051-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:03:10,269-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:03:20,282-0600 INFO  Multiplexer No streams
-2013-11-06 06:03:22,434-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:03:30,292-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:03:40,300-0600 INFO  Multiplexer No streams
-2013-11-06 06:03:45,661-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:03:50,308-0600 INFO  Multiplexer No streams
-2013-11-06 06:03:54,757-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:04:00,316-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:04:10,326-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:04:20,336-0600 INFO  Multiplexer No streams
-2013-11-06 06:04:21,271-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:04:27,079-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:04:30,345-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:04:40,354-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:04:50,364-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:04:56,882-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:04:59,403-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:05:00,373-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:05:10,383-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:05:20,394-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:05:30,402-0600 INFO  Multiplexer No streams
-2013-11-06 06:05:31,725-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-2013-11-06 06:05:32,493-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-No streams
-2013-11-06 06:05:40,411-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:05:50,421-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:06:00,431-0600 INFO  Multiplexer No streams
-2013-11-06 06:06:04,049-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:06:08,101-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:06:10,442-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:06:20,451-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:06:30,452-0600 INFO  Multiplexer No streams
-2013-11-06 06:06:36,372-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:06:40,465-0600 INFO  Multiplexer No streams
-2013-11-06 06:06:43,711-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:06:50,475-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:07:00,485-0600 INFO  Multiplexer No streams
-2013-11-06 06:07:08,695-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:07:10,493-0600 INFO  Multiplexer No streams
-2013-11-06 06:07:19,322-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:07:20,503-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:07:30,505-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:07:40,510-0600 INFO  Multiplexer No streams
-2013-11-06 06:07:41,018-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:07:50,530-0600 INFO  Multiplexer No streams
-2013-11-06 06:07:54,932-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:08:00,534-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:08:10,542-0600 INFO  Multiplexer No streams
-2013-11-06 06:08:13,341-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:08:20,553-0600 INFO  Multiplexer No streams
-2013-11-06 06:08:30,541-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:08:30,561-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:08:40,569-0600 INFO  Multiplexer No streams
-2013-11-06 06:08:45,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:08:50,578-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:09:00,587-0600 INFO  Multiplexer No streams
-2013-11-06 06:09:06,152-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 06:09:10,595-0600 INFO  Multiplexer No streams
-2013-11-06 06:09:17,987-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:09:20,604-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:09:30,612-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:09:40,622-0600 INFO  Multiplexer No streams
-2013-11-06 06:09:41,763-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:09:50,310-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:09:50,630-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:10:00,639-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:10:10,648-0600 INFO  Multiplexer No streams
-2013-11-06 06:10:17,373-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:10:20,657-0600 INFO  Multiplexer No streams
-2013-11-06 06:10:22,633-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:10:30,666-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:10:40,679-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:10:50,688-0600 INFO  Multiplexer No streams
-2013-11-06 06:10:52,983-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:10:54,956-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:11:00,699-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:11:10,710-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:11:20,719-0600 INFO  Multiplexer No streams
-2013-11-06 06:11:27,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:11:28,593-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:11:30,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:11:40,738-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:11:50,748-0600 INFO  Multiplexer No streams
-2013-11-06 06:11:59,602-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:12:00,758-0600 INFO  Multiplexer No streams
-2013-11-06 06:12:04,202-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:12:10,768-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:12:20,777-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:12:30,788-0600 INFO  Multiplexer No streams
-2013-11-06 06:12:31,925-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:12:39,812-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:12:40,799-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:12:50,808-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:13:00,817-0600 INFO  Multiplexer No streams
-2013-11-06 06:13:04,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:13:10,827-0600 INFO  Multiplexer No streams
-2013-11-06 06:13:15,423-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:13:20,835-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:13:30,844-0600 INFO  Multiplexer No streams
-2013-11-06 06:13:36,571-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:13:40,852-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:13:50,862-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 06:13:51,033-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 06:14:00,872-0600 INFO  Multiplexer No streams
-2013-11-06 06:14:08,894-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:14:10,882-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:14:20,893-0600 INFO  Multiplexer No streams
-2013-11-06 06:14:26,642-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:14:30,909-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:14:40,923-0600 INFO  Multiplexer No streams
-2013-11-06 06:14:41,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:14:50,934-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:15:00,942-0600 INFO  Multiplexer No streams
-2013-11-06 06:15:02,252-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:15:10,951-0600 INFO  Multiplexer No streams
-2013-11-06 06:15:13,540-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:15:20,961-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:15:30,970-0600 INFO  Multiplexer No streams
-2013-11-06 06:15:37,863-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:15:40,979-0600 INFO  Multiplexer No streams
-2013-11-06 06:15:45,864-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:15:50,988-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:16:00,997-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:16:11,004-0600 INFO  Multiplexer No streams
-2013-11-06 06:16:13,472-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:16:18,187-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:16:21,013-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:16:31,022-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:16:41,032-0600 INFO  Multiplexer No streams
-2013-11-06 06:16:49,083-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:16:50,509-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:16:51,043-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:17:01,051-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:17:11,060-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:17:21,069-0600 INFO  Multiplexer No streams
-2013-11-06 06:17:22,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:17:24,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:17:31,078-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:17:41,086-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:17:51,094-0600 INFO  Multiplexer No streams
-2013-11-06 06:17:55,156-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:18:00,303-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 06:18:01,102-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:18:11,109-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:18:21,118-0600 INFO  Multiplexer No streams
-2013-11-06 06:18:27,479-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:18:31,125-0600 INFO  Multiplexer No streams
-2013-11-06 06:18:35,912-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:18:41,134-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:18:51,142-0600 INFO  Multiplexer No streams
-2013-11-06 06:18:59,801-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:19:01,153-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:19:11,162-0600 INFO  Multiplexer No streams
-2013-11-06 06:19:11,522-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:19:21,172-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:19:31,182-0600 INFO  Multiplexer No streams
-2013-11-06 06:19:32,124-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:19:41,194-0600 INFO  Multiplexer No streams
-2013-11-06 06:19:47,133-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:19:51,205-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:20:01,215-0600 INFO  Multiplexer No streams
-2013-11-06 06:20:04,448-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:20:11,223-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:20:21,232-0600 INFO  Multiplexer No streams
-2013-11-06 06:20:22,742-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:20:31,242-0600 INFO  Multiplexer No streams
-2013-11-06 06:20:36,770-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:20:41,252-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:20:51,262-0600 INFO  Multiplexer No streams
-2013-11-06 06:20:58,353-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:21:01,272-0600 INFO  Multiplexer No streams
-2013-11-06 06:21:09,093-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:21:11,280-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:21:21,289-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:21:31,298-0600 INFO  Multiplexer No streams
-2013-11-06 06:21:33,963-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:21:41,306-0600 INFO  Multiplexer No streams
-2013-11-06 06:21:41,416-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:21:51,315-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:22:01,324-0600 INFO  Multiplexer No streams
-2013-11-06 06:22:09,572-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:22:11,334-0600 INFO  Multiplexer No streams
-2013-11-06 06:22:13,740-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:22:21,344-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:22:31,355-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:22:41,364-0600 INFO  Multiplexer No streams
-2013-11-06 06:22:45,183-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:22:46,064-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:22:51,373-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:23:01,383-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:23:11,393-0600 INFO  Multiplexer No streams
-2013-11-06 06:23:18,387-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:23:20,792-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:23:21,403-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:23:31,413-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:23:41,422-0600 INFO  Multiplexer No streams
-2013-11-06 06:23:50,710-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:23:51,432-0600 INFO  Multiplexer No streams
-2013-11-06 06:23:56,403-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:24:01,441-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:24:11,449-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:24:21,458-0600 INFO  Multiplexer No streams
-2013-11-06 06:24:23,033-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:24:31,468-0600 INFO  Multiplexer No streams
-2013-11-06 06:24:32,013-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:24:41,477-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:24:51,487-0600 INFO  Multiplexer No streams
-2013-11-06 06:24:55,357-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:25:01,496-0600 INFO  Multiplexer No streams
-2013-11-06 06:25:07,623-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:25:11,505-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:25:21,514-0600 INFO  Multiplexer No streams
-2013-11-06 06:25:27,679-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:25:31,523-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:25:41,533-0600 INFO  Multiplexer No streams
-2013-11-06 06:25:43,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:25:51,541-0600 INFO  Multiplexer No streams
-2013-11-06 06:26:00,003-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:26:01,551-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:26:11,560-0600 INFO  Multiplexer No streams
-2013-11-06 06:26:18,843-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:26:21,568-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:26:31,576-0600 INFO  Multiplexer No streams
-2013-11-06 06:26:32,325-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:26:41,586-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:26:51,595-0600 INFO  Multiplexer No streams
-2013-11-06 06:26:54,453-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:27:01,603-0600 INFO  Multiplexer No streams
-2013-11-06 06:27:04,648-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:27:11,612-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:27:21,621-0600 INFO  Multiplexer No streams
-2013-11-06 06:27:30,063-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:27:31,631-0600 INFO  Multiplexer No streams
-2013-11-06 06:27:36,972-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:27:41,639-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:27:51,647-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:28:01,656-0600 INFO  Multiplexer No streams
-2013-11-06 06:28:05,673-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:28:09,295-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:28:11,665-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:28:21,673-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:28:31,682-0600 INFO  Multiplexer No streams
-2013-11-06 06:28:41,284-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:28:41,618-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:28:41,690-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:28:51,697-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:29:01,706-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:29:11,714-0600 INFO  Multiplexer No streams
-2013-11-06 06:29:13,941-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:29:16,893-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:29:21,722-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:29:31,729-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:29:41,738-0600 INFO  Multiplexer No streams
-2013-11-06 06:29:46,264-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:29:51,745-0600 INFO  Multiplexer No streams
-2013-11-06 06:29:52,503-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:30:01,753-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:30:11,761-0600 INFO  Multiplexer No streams
-2013-11-06 06:30:18,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:30:21,769-0600 INFO  Multiplexer No streams
-2013-11-06 06:30:28,113-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:30:31,777-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:30:41,786-0600 INFO  Multiplexer No streams
-2013-11-06 06:30:50,910-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:30:51,794-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:31:01,802-0600 INFO  Multiplexer No streams
-2013-11-06 06:31:03,724-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:31:11,810-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:31:21,818-0600 INFO  Multiplexer No streams
-2013-11-06 06:31:23,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:31:31,827-0600 INFO  Multiplexer No streams
-2013-11-06 06:31:39,333-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:31:41,834-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:31:51,843-0600 INFO  Multiplexer No streams
-2013-11-06 06:31:55,556-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:32:01,851-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:32:11,859-0600 INFO  Multiplexer No streams
-2013-11-06 06:32:14,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:32:21,867-0600 INFO  Multiplexer No streams
-2013-11-06 06:32:27,879-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:32:31,876-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:32:41,884-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 06:32:50,554-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 06:32:51,892-0600 INFO  Multiplexer No streams
-2013-11-06 06:33:00,202-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:33:01,900-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:33:11,908-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:33:21,916-0600 INFO  Multiplexer No streams
-2013-11-06 06:33:26,164-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:33:31,924-0600 INFO  Multiplexer No streams
-2013-11-06 06:33:32,525-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:33:41,932-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:33:51,940-0600 INFO  Multiplexer No streams
-2013-11-06 06:34:01,774-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:34:01,949-0600 INFO  Multiplexer No streams
-2013-11-06 06:34:04,848-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:34:11,957-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:34:21,965-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:34:31,974-0600 INFO  Multiplexer No streams
-2013-11-06 06:34:37,171-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:34:37,384-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:34:41,982-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:34:51,992-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:35:02,000-0600 INFO  Multiplexer No streams
-2013-11-06 06:35:09,494-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:35:12,008-0600 INFO  Multiplexer No streams
-2013-11-06 06:35:12,994-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:35:22,017-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:35:32,025-0600 INFO  Multiplexer No streams
-2013-11-06 06:35:41,817-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:35:42,035-0600 INFO  Multiplexer No streams
-2013-11-06 06:35:48,604-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:35:52,043-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:36:02,051-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:36:12,060-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-2013-11-06 06:36:14,143-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 06:36:22,068-0600 INFO  Multiplexer No streams
-2013-11-06 06:36:24,215-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:36:32,076-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:36:42,084-0600 INFO  Multiplexer No streams
-2013-11-06 06:36:46,463-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:36:52,093-0600 INFO  Multiplexer No streams
-2013-11-06 06:36:59,824-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:37:02,101-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:37:12,109-0600 INFO  Multiplexer No streams
-2013-11-06 06:37:18,786-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:37:22,118-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:37:32,126-0600 INFO  Multiplexer No streams
-2013-11-06 06:37:35,434-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:37:42,135-0600 INFO  Multiplexer No streams
-2013-11-06 06:37:51,109-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:37:52,143-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:38:02,151-0600 INFO  Multiplexer No streams
-2013-11-06 06:38:11,044-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:38:12,159-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:38:22,167-0600 INFO  Multiplexer No streams
-2013-11-06 06:38:23,432-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:38:32,175-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:38:42,183-0600 INFO  Multiplexer No streams
-2013-11-06 06:38:46,654-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:38:52,191-0600 INFO  Multiplexer No streams
-2013-11-06 06:38:55,755-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:39:02,200-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:39:12,208-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:39:22,217-0600 INFO  Multiplexer No streams
-2013-11-06 06:39:22,264-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:39:28,078-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:39:32,225-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:39:42,234-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:39:52,242-0600 INFO  Multiplexer No streams
-2013-11-06 06:39:57,875-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:40:00,401-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:40:02,250-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:40:12,258-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:40:22,267-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:40:32,275-0600 INFO  Multiplexer No streams
-2013-11-06 06:40:32,724-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:40:33,485-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 06:40:42,283-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:40:52,292-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:41:02,300-0600 INFO  Multiplexer No streams
-2013-11-06 06:41:05,047-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:41:09,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:41:12,308-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:41:22,316-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:41:32,328-0600 INFO  Multiplexer No streams
-2013-11-06 06:41:37,370-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:41:42,336-0600 INFO  Multiplexer No streams
-2013-11-06 06:41:44,704-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:41:52,344-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:42:02,352-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:42:09,694-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:42:12,361-0600 INFO  Multiplexer No streams
-2013-11-06 06:42:20,314-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:42:22,369-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:42:32,377-0600 INFO  Multiplexer No streams
-2013-11-06 06:42:42,016-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:42:42,385-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:42:52,393-0600 INFO  Multiplexer No streams
-2013-11-06 06:42:55,924-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:43:02,401-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:43:12,410-0600 INFO  Multiplexer No streams
-2013-11-06 06:43:14,340-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:43:22,418-0600 INFO  Multiplexer No streams
-2013-11-06 06:43:31,534-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:43:32,426-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:43:42,434-0600 INFO  Multiplexer No streams
-2013-11-06 06:43:46,662-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:43:52,442-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:44:02,450-0600 INFO  Multiplexer No streams
-2013-11-06 06:44:07,144-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:44:12,459-0600 INFO  Multiplexer No streams
-2013-11-06 06:44:18,986-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:44:22,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:44:32,475-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:44:42,483-0600 INFO  Multiplexer No streams
-2013-11-06 06:44:42,755-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:44:51,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:44:52,494-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:45:02,502-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:45:12,510-0600 INFO  Multiplexer No streams
-2013-11-06 06:45:18,365-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:45:22,519-0600 INFO  Multiplexer No streams
-2013-11-06 06:45:23,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:45:32,527-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:45:42,536-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:45:52,544-0600 INFO  Multiplexer No streams
-2013-11-06 06:45:53,975-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:45:55,954-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:46:02,553-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:46:12,561-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:46:22,569-0600 INFO  Multiplexer No streams
-2013-11-06 06:46:28,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 06:46:29,586-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:46:32,579-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:46:42,587-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:46:52,595-0600 INFO  Multiplexer No streams
-2013-11-06 06:47:00,600-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:47:02,603-0600 INFO  Multiplexer No streams
-2013-11-06 06:47:05,196-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:47:12,611-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:47:22,620-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:47:32,629-0600 INFO  Multiplexer No streams
-2013-11-06 06:47:32,923-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:47:40,806-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:47:42,637-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:47:52,645-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:48:02,653-0600 INFO  Multiplexer No streams
-2013-11-06 06:48:05,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:48:12,661-0600 INFO  Multiplexer No streams
-2013-11-06 06:48:16,416-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:48:22,669-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:48:32,678-0600 INFO  Multiplexer No streams
-2013-11-06 06:48:37,569-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:48:42,686-0600 INFO  Multiplexer No streams
-2013-11-06 06:48:52,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:48:52,694-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:49:02,702-0600 INFO  Multiplexer No streams
-2013-11-06 06:49:09,892-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:49:12,710-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:49:22,718-0600 INFO  Multiplexer No streams
-2013-11-06 06:49:27,636-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:49:32,726-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:49:42,215-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:49:42,734-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:49:52,742-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:50:02,750-0600 INFO  Multiplexer No streams
-2013-11-06 06:50:03,246-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:50:12,759-0600 INFO  Multiplexer No streams
-2013-11-06 06:50:14,539-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:50:22,767-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:50:32,775-0600 INFO  Multiplexer No streams
-2013-11-06 06:50:38,857-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:50:42,783-0600 INFO  Multiplexer No streams
-2013-11-06 06:50:46,861-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:50:52,792-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:51:02,800-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:51:12,808-0600 INFO  Multiplexer No streams
-2013-11-06 06:51:14,466-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:51:19,184-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:51:22,816-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:51:32,824-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:51:42,833-0600 INFO  Multiplexer No streams
-2013-11-06 06:51:50,076-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:51:51,507-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:51:52,841-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:52:02,849-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:52:12,858-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:52:22,866-0600 INFO  Multiplexer No streams
-2013-11-06 06:52:23,830-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:52:25,686-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:52:32,874-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:52:42,883-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:52:52,891-0600 INFO  Multiplexer No streams
-2013-11-06 06:52:56,153-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:53:01,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:53:02,899-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:53:12,907-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:53:22,916-0600 INFO  Multiplexer No streams
-2013-11-06 06:53:28,476-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:53:32,924-0600 INFO  Multiplexer No streams
-2013-11-06 06:53:36,906-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:53:42,932-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:53:52,940-0600 INFO  Multiplexer No streams
-2013-11-06 06:54:00,799-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:54:02,949-0600 INFO  Multiplexer No streams
-2013-11-06 06:54:12,516-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:54:12,957-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:54:22,965-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:54:32,973-0600 INFO  Multiplexer No streams
-2013-11-06 06:54:33,122-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:54:42,981-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:54:48,126-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:54:52,989-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:55:02,997-0600 INFO  Multiplexer No streams
-2013-11-06 06:55:05,446-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:55:13,006-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:55:23,014-0600 INFO  Multiplexer No streams
-2013-11-06 06:55:23,737-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:55:33,022-0600 INFO  Multiplexer No streams
-2013-11-06 06:55:37,769-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:55:43,031-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:55:53,039-0600 INFO  Multiplexer No streams
-2013-11-06 06:55:59,347-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:56:03,047-0600 INFO  Multiplexer No streams
-2013-11-06 06:56:10,092-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:56:13,056-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:56:23,064-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:56:33,072-0600 INFO  Multiplexer No streams
-2013-11-06 06:56:34,957-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
-2013-11-06 06:56:42,414-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
-No streams
-2013-11-06 06:56:43,081-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:56:53,089-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:57:03,097-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 17ms
-2013-11-06 06:57:10,583-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 17ms
-No streams
-2013-11-06 06:57:13,106-0600 INFO  Multiplexer No streams
-2013-11-06 06:57:14,738-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:57:23,114-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:57:33,122-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:57:43,130-0600 INFO  Multiplexer No streams
-2013-11-06 06:57:46,177-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:57:47,062-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 06:57:53,139-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:58:03,147-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:58:13,156-0600 INFO  Multiplexer No streams
-2013-11-06 06:58:19,384-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 06:58:21,787-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:58:23,164-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:58:33,172-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:58:43,180-0600 INFO  Multiplexer No streams
-2013-11-06 06:58:51,707-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:58:53,189-0600 INFO  Multiplexer No streams
-2013-11-06 06:58:57,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 06:59:03,197-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:59:13,205-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:59:23,214-0600 INFO  Multiplexer No streams
-2013-11-06 06:59:24,030-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 06:59:33,007-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 06:59:33,222-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:59:43,230-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 06:59:53,239-0600 INFO  Multiplexer No streams
-2013-11-06 06:59:56,353-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:00:03,247-0600 INFO  Multiplexer No streams
-2013-11-06 07:00:08,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:00:13,255-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:00:23,263-0600 INFO  Multiplexer No streams
-2013-11-06 07:00:28,677-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:00:33,272-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:00:43,280-0600 INFO  Multiplexer No streams
-2013-11-06 07:00:44,228-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:00:53,288-0600 INFO  Multiplexer No streams
-2013-11-06 07:01:01,000-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:01:03,297-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:01:13,305-0600 INFO  Multiplexer No streams
-2013-11-06 07:01:19,838-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:01:23,313-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:01:33,321-0600 INFO  Multiplexer No streams
-2013-11-06 07:01:33,322-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:01:43,330-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:01:53,338-0600 INFO  Multiplexer No streams
-2013-11-06 07:01:55,447-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:02:03,346-0600 INFO  Multiplexer No streams
-2013-11-06 07:02:05,646-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:02:13,355-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:02:23,363-0600 INFO  Multiplexer No streams
-2013-11-06 07:02:31,057-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:02:33,371-0600 INFO  Multiplexer No streams
-2013-11-06 07:02:37,968-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:02:43,379-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:02:53,387-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:03:03,396-0600 INFO  Multiplexer No streams
-2013-11-06 07:03:06,667-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:03:10,292-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:03:13,404-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:03:23,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:03:33,420-0600 INFO  Multiplexer No streams
-2013-11-06 07:03:42,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:03:42,614-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:03:43,428-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:03:53,436-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:04:03,445-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:04:13,453-0600 INFO  Multiplexer No streams
-2013-11-06 07:04:14,937-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:04:17,887-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:04:23,461-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:04:33,469-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:04:43,477-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:04:47,260-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:04:53,485-0600 INFO  Multiplexer No streams
-2013-11-06 07:04:53,497-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:05:03,493-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:05:13,502-0600 INFO  Multiplexer No streams
-2013-11-06 07:05:19,584-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:05:23,510-0600 INFO  Multiplexer No streams
-2013-11-06 07:05:29,107-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:05:33,519-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:05:43,527-0600 INFO  Multiplexer No streams
-2013-11-06 07:05:51,907-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:05:53,536-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:06:03,544-0600 INFO  Multiplexer No streams
-2013-11-06 07:06:04,717-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:06:13,552-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:06:23,560-0600 INFO  Multiplexer No streams
-2013-11-06 07:06:24,230-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:06:33,568-0600 INFO  Multiplexer No streams
-2013-11-06 07:06:40,327-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:06:43,577-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:06:53,585-0600 INFO  Multiplexer No streams
-2013-11-06 07:06:56,553-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:07:03,593-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:07:13,602-0600 INFO  Multiplexer No streams
-2013-11-06 07:07:15,937-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:07:23,610-0600 INFO  Multiplexer No streams
-2013-11-06 07:07:28,876-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:07:33,618-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:07:43,626-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:07:51,547-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:07:53,635-0600 INFO  Multiplexer No streams
-2013-11-06 07:08:01,199-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:08:03,643-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:08:13,651-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:08:23,660-0600 INFO  Multiplexer No streams
-2013-11-06 07:08:27,157-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 07:08:33,521-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:08:33,668-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:08:43,676-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:08:53,684-0600 INFO  Multiplexer No streams
-2013-11-06 07:09:02,768-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:09:03,693-0600 INFO  Multiplexer No streams
-2013-11-06 07:09:05,845-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:09:13,701-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:09:23,709-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:09:33,717-0600 INFO  Multiplexer No streams
-2013-11-06 07:09:38,167-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:09:38,378-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:09:43,726-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:09:53,734-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:10:03,743-0600 INFO  Multiplexer No streams
-2013-11-06 07:10:10,490-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:10:13,751-0600 INFO  Multiplexer No streams
-2013-11-06 07:10:13,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:10:23,759-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:10:33,767-0600 INFO  Multiplexer No streams
-2013-11-06 07:10:42,814-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:10:43,775-0600 INFO  Multiplexer No streams
-2013-11-06 07:10:49,599-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:10:53,783-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:11:03,791-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:11:13,800-0600 INFO  Multiplexer No streams
-2013-11-06 07:11:15,137-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:11:23,808-0600 INFO  Multiplexer No streams
-2013-11-06 07:11:25,209-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:11:33,816-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:11:43,825-0600 INFO  Multiplexer No streams
-2013-11-06 07:11:47,459-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:11:53,833-0600 INFO  Multiplexer No streams
-2013-11-06 07:12:00,819-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:12:03,841-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:12:13,849-0600 INFO  Multiplexer No streams
-2013-11-06 07:12:19,782-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:12:23,858-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:12:33,866-0600 INFO  Multiplexer No streams
-2013-11-06 07:12:36,429-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:12:43,874-0600 INFO  Multiplexer No streams
-2013-11-06 07:12:52,105-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:12:53,883-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:13:03,891-0600 INFO  Multiplexer No streams
-2013-11-06 07:13:12,039-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:13:13,899-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:13:23,907-0600 INFO  Multiplexer No streams
-2013-11-06 07:13:24,428-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:13:33,916-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:13:43,924-0600 INFO  Multiplexer No streams
-2013-11-06 07:13:47,649-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:13:53,932-0600 INFO  Multiplexer No streams
-2013-11-06 07:13:56,751-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:14:03,941-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:14:13,949-0600 INFO  Multiplexer No streams
-2013-11-06 07:14:23,259-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:14:23,957-0600 INFO  Multiplexer No streams
-2013-11-06 07:14:29,074-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:14:33,965-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:14:43,974-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:14:53,982-0600 INFO  Multiplexer No streams
-2013-11-06 07:14:58,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:15:01,398-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:15:03,990-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:15:13,998-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:15:24,006-0600 INFO  Multiplexer No streams
-2013-11-06 07:15:33,721-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:15:34,015-0600 INFO  Multiplexer No streams
-2013-11-06 07:15:34,480-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:15:44,023-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:15:54,031-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:16:04,039-0600 INFO  Multiplexer No streams
-2013-11-06 07:16:06,043-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:16:10,089-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:16:14,048-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:16:24,056-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:16:34,064-0600 INFO  Multiplexer No streams
-2013-11-06 07:16:38,366-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:16:44,072-0600 INFO  Multiplexer No streams
-2013-11-06 07:16:45,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:16:54,080-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:17:04,088-0600 INFO  Multiplexer No streams
-2013-11-06 07:17:10,690-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:17:14,097-0600 INFO  Multiplexer No streams
-2013-11-06 07:17:21,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:17:24,105-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:17:34,112-0600 INFO  Multiplexer No streams
-2013-11-06 07:17:43,013-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:17:44,121-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:17:54,128-0600 INFO  Multiplexer No streams
-2013-11-06 07:17:56,919-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:18:04,136-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:18:14,145-0600 INFO  Multiplexer No streams
-2013-11-06 07:18:15,336-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:18:24,153-0600 INFO  Multiplexer No streams
-2013-11-06 07:18:32,529-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:18:34,162-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:18:44,170-0600 INFO  Multiplexer No streams
-2013-11-06 07:18:47,660-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:18:54,178-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:19:04,186-0600 INFO  Multiplexer No streams
-2013-11-06 07:19:08,139-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:19:14,195-0600 INFO  Multiplexer No streams
-2013-11-06 07:19:19,984-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:19:24,203-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:19:34,211-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 07:19:43,751-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:19:44,220-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 07:19:52,306-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:19:54,228-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:20:04,236-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:20:14,244-0600 INFO  Multiplexer No streams
-2013-11-06 07:20:19,359-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:20:24,252-0600 INFO  Multiplexer No streams
-2013-11-06 07:20:24,630-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:20:34,261-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:20:44,269-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:20:54,277-0600 INFO  Multiplexer No streams
-2013-11-06 07:20:54,969-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:20:56,953-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:21:04,285-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:21:14,293-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:21:24,301-0600 INFO  Multiplexer No streams
-2013-11-06 07:21:29,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:21:30,579-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:21:34,310-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:21:44,318-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:21:54,326-0600 INFO  Multiplexer No streams
-2013-11-06 07:22:01,601-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:22:04,334-0600 INFO  Multiplexer No streams
-2013-11-06 07:22:06,189-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:22:14,342-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:22:24,351-0600 INFO  Multiplexer No streams
-2013-11-06 07:22:33,924-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:22:34,358-0600 INFO  Multiplexer No streams
-2013-11-06 07:22:41,799-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:22:44,366-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:22:54,375-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:23:04,383-0600 INFO  Multiplexer No streams
-2013-11-06 07:23:06,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:23:14,391-0600 INFO  Multiplexer No streams
-2013-11-06 07:23:17,409-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:23:24,399-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:23:34,408-0600 INFO  Multiplexer No streams
-2013-11-06 07:23:38,571-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:23:44,416-0600 INFO  Multiplexer No streams
-2013-11-06 07:23:53,020-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:23:54,424-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:24:04,432-0600 INFO  Multiplexer No streams
-2013-11-06 07:24:10,893-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:24:14,440-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:24:24,448-0600 INFO  Multiplexer No streams
-2013-11-06 07:24:28,629-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:24:34,456-0600 INFO  Multiplexer No streams
-2013-11-06 07:24:43,217-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:24:44,465-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:24:54,473-0600 INFO  Multiplexer No streams
-2013-11-06 07:25:04,239-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:25:04,480-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:25:14,488-0600 INFO  Multiplexer No streams
-2013-11-06 07:25:15,540-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:25:24,497-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:25:34,505-0600 INFO  Multiplexer No streams
-2013-11-06 07:25:39,850-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:25:44,513-0600 INFO  Multiplexer No streams
-2013-11-06 07:25:47,863-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:25:54,521-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:26:04,529-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:26:14,537-0600 INFO  Multiplexer No streams
-2013-11-06 07:26:15,459-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:26:20,186-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:26:24,545-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:26:34,554-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:26:44,562-0600 INFO  Multiplexer No streams
-2013-11-06 07:26:51,069-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:26:52,509-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:26:54,570-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:27:04,578-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:27:14,586-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:27:24,594-0600 INFO  Multiplexer No streams
-2013-11-06 07:27:24,832-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:27:26,679-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:27:34,602-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:27:44,610-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:27:54,618-0600 INFO  Multiplexer No streams
-2013-11-06 07:27:57,155-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:28:02,290-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:28:04,626-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:28:14,633-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:28:24,642-0600 INFO  Multiplexer No streams
-2013-11-06 07:28:29,478-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:28:34,649-0600 INFO  Multiplexer No streams
-2013-11-06 07:28:37,899-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:28:44,657-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:28:54,665-0600 INFO  Multiplexer No streams
-2013-11-06 07:29:01,801-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:29:04,673-0600 INFO  Multiplexer No streams
-2013-11-06 07:29:13,509-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:29:14,681-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:29:24,689-0600 INFO  Multiplexer No streams
-2013-11-06 07:29:34,124-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:29:34,697-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:29:44,705-0600 INFO  Multiplexer No streams
-2013-11-06 07:29:49,119-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:29:54,713-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:30:04,721-0600 INFO  Multiplexer No streams
-2013-11-06 07:30:06,448-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:30:14,729-0600 INFO  Multiplexer No streams
-2013-11-06 07:30:24,729-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:30:24,737-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:30:34,745-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 6ms
-2013-11-06 07:30:38,775-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 6ms
-No streams
-2013-11-06 07:30:44,753-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:30:54,762-0600 INFO  Multiplexer No streams
-2013-11-06 07:31:00,339-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:31:04,770-0600 INFO  Multiplexer No streams
-2013-11-06 07:31:11,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:31:14,778-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:31:24,786-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:31:34,794-0600 INFO  Multiplexer No streams
-2013-11-06 07:31:35,949-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:31:43,416-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:31:44,802-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:31:54,810-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:32:04,818-0600 INFO  Multiplexer No streams
-2013-11-06 07:32:11,560-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:32:14,827-0600 INFO  Multiplexer No streams
-2013-11-06 07:32:15,739-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:32:24,835-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:32:34,843-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:32:44,851-0600 INFO  Multiplexer No streams
-2013-11-06 07:32:47,169-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:32:48,062-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:32:54,860-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:33:04,868-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:33:14,876-0600 INFO  Multiplexer No streams
-2013-11-06 07:33:20,385-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:33:22,778-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:33:24,885-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:33:34,893-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:33:44,902-0600 INFO  Multiplexer No streams
-2013-11-06 07:33:52,708-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:33:54,910-0600 INFO  Multiplexer No streams
-2013-11-06 07:33:58,389-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:34:04,918-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:34:14,927-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:34:24,935-0600 INFO  Multiplexer No streams
-2013-11-06 07:34:25,031-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:34:33,999-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:34:34,943-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:34:44,951-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:34:54,960-0600 INFO  Multiplexer No streams
-2013-11-06 07:34:57,354-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:35:04,968-0600 INFO  Multiplexer No streams
-2013-11-06 07:35:09,609-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:35:14,976-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:35:24,984-0600 INFO  Multiplexer No streams
-2013-11-06 07:35:29,678-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:35:34,993-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:35:45,001-0600 INFO  Multiplexer No streams
-2013-11-06 07:35:45,220-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:35:55,009-0600 INFO  Multiplexer No streams
-2013-11-06 07:36:02,001-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:36:05,018-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:36:15,026-0600 INFO  Multiplexer No streams
-2013-11-06 07:36:20,830-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:36:25,035-0600 INFO  Multiplexer No streams
-2013-11-06 07:36:34,323-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:36:35,043-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:36:45,051-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:36:55,059-0600 INFO  Multiplexer No streams
-2013-11-06 07:36:56,440-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:37:05,068-0600 INFO  Multiplexer No streams
-2013-11-06 07:37:06,646-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:37:15,076-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:37:25,084-0600 INFO  Multiplexer No streams
-2013-11-06 07:37:32,049-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:37:35,092-0600 INFO  Multiplexer No streams
-2013-11-06 07:37:38,969-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:37:45,100-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:37:55,108-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:38:05,116-0600 INFO  Multiplexer No streams
-2013-11-06 07:38:07,659-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 17ms
-2013-11-06 07:38:11,308-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 17ms
-No streams
-2013-11-06 07:38:15,124-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:38:25,132-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:38:35,141-0600 INFO  Multiplexer No streams
-2013-11-06 07:38:43,269-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:38:43,615-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:38:45,149-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:38:55,157-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:39:05,166-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:39:15,174-0600 INFO  Multiplexer No streams
-2013-11-06 07:39:15,938-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:39:18,879-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:39:25,182-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:39:35,191-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:39:45,199-0600 INFO  Multiplexer No streams
-2013-11-06 07:39:48,261-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:39:54,489-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:39:55,207-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:40:05,216-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:40:15,225-0600 INFO  Multiplexer No streams
-2013-11-06 07:40:20,585-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:40:25,235-0600 INFO  Multiplexer No streams
-2013-11-06 07:40:30,100-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:40:35,243-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:40:45,251-0600 INFO  Multiplexer No streams
-2013-11-06 07:40:52,907-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:40:55,260-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:41:05,268-0600 INFO  Multiplexer No streams
-2013-11-06 07:41:05,709-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:41:15,276-0600 INFO  Multiplexer No streams
-2013-11-06 07:41:25,230-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:41:25,284-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:41:35,292-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 07:41:41,321-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 07:41:45,301-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:41:55,309-0600 INFO  Multiplexer No streams
-2013-11-06 07:41:57,553-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:42:05,317-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:42:15,325-0600 INFO  Multiplexer No streams
-2013-11-06 07:42:16,929-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:42:25,333-0600 INFO  Multiplexer No streams
-2013-11-06 07:42:29,876-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:42:35,341-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:42:45,349-0600 INFO  Multiplexer No streams
-2013-11-06 07:42:52,539-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:42:55,357-0600 INFO  Multiplexer No streams
-2013-11-06 07:43:02,200-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:43:05,365-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:43:15,373-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:43:25,381-0600 INFO  Multiplexer No streams
-2013-11-06 07:43:28,149-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:43:34,522-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:43:35,389-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:43:45,397-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:43:55,406-0600 INFO  Multiplexer No streams
-2013-11-06 07:44:03,759-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:44:05,414-0600 INFO  Multiplexer No streams
-2013-11-06 07:44:06,845-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:44:15,422-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:44:25,431-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:44:35,439-0600 INFO  Multiplexer No streams
-2013-11-06 07:44:39,168-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:44:39,370-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:44:45,447-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:44:55,456-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:45:05,464-0600 INFO  Multiplexer No streams
-2013-11-06 07:45:11,491-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:45:14,979-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:45:15,472-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:45:25,480-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:45:35,489-0600 INFO  Multiplexer No streams
-2013-11-06 07:45:43,814-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:45:45,497-0600 INFO  Multiplexer No streams
-2013-11-06 07:45:50,589-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:45:55,505-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:46:05,513-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:46:15,521-0600 INFO  Multiplexer No streams
-2013-11-06 07:46:16,137-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:46:25,529-0600 INFO  Multiplexer No streams
-2013-11-06 07:46:26,199-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:46:35,538-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:46:45,546-0600 INFO  Multiplexer No streams
-2013-11-06 07:46:48,460-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:46:55,554-0600 INFO  Multiplexer No streams
-2013-11-06 07:47:01,809-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:47:05,562-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:47:15,570-0600 INFO  Multiplexer No streams
-2013-11-06 07:47:20,783-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:47:25,578-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:47:35,586-0600 INFO  Multiplexer No streams
-2013-11-06 07:47:37,419-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:47:45,594-0600 INFO  Multiplexer No streams
-2013-11-06 07:47:53,106-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:47:55,602-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:48:05,610-0600 INFO  Multiplexer No streams
-2013-11-06 07:48:13,030-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:48:15,618-0600 INFO  Multiplexer No streams
-2013-11-06 07:48:25,429-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:48:25,626-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:48:35,634-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:48:45,641-0600 INFO  Multiplexer No streams
-2013-11-06 07:48:48,639-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:48:55,649-0600 INFO  Multiplexer No streams
-2013-11-06 07:48:57,752-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:49:05,657-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:49:15,665-0600 INFO  Multiplexer No streams
-2013-11-06 07:49:24,249-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:49:25,673-0600 INFO  Multiplexer No streams
-2013-11-06 07:49:30,075-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:49:35,681-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:49:45,688-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:49:55,696-0600 INFO  Multiplexer No streams
-2013-11-06 07:49:59,859-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:50:02,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:50:05,704-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:50:15,712-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:50:25,720-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 07:50:34,722-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 07:50:35,469-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:50:35,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:50:45,735-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:50:55,743-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:51:05,751-0600 INFO  Multiplexer No streams
-2013-11-06 07:51:07,045-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 07:51:11,079-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:51:15,759-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:51:25,767-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:51:35,775-0600 INFO  Multiplexer No streams
-2013-11-06 07:51:39,367-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:51:45,783-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
-2013-11-06 07:51:46,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
-No streams
-2013-11-06 07:51:55,791-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:52:05,799-0600 INFO  Multiplexer No streams
-2013-11-06 07:52:11,691-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:52:15,807-0600 INFO  Multiplexer No streams
-2013-11-06 07:52:22,299-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:52:25,815-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:52:35,823-0600 INFO  Multiplexer No streams
-2013-11-06 07:52:44,013-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:52:45,831-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:52:55,839-0600 INFO  Multiplexer No streams
-2013-11-06 07:52:57,909-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:53:05,846-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:53:15,854-0600 INFO  Multiplexer No streams
-2013-11-06 07:53:16,336-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:53:25,862-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 07:53:33,519-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:53:35,870-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:53:45,878-0600 INFO  Multiplexer No streams
-2013-11-06 07:53:48,659-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:53:55,886-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:54:05,893-0600 INFO  Multiplexer No streams
-2013-11-06 07:54:09,130-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:54:15,901-0600 INFO  Multiplexer No streams
-2013-11-06 07:54:20,982-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:54:25,909-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:54:35,917-0600 INFO  Multiplexer No streams
-2013-11-06 07:54:44,741-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:54:45,925-0600 INFO  Multiplexer No streams
-2013-11-06 07:54:53,305-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:54:55,933-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:55:05,940-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:55:15,948-0600 INFO  Multiplexer No streams
-2013-11-06 07:55:20,351-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:55:25,629-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:55:25,956-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:55:35,964-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:55:45,972-0600 INFO  Multiplexer No streams
-2013-11-06 07:55:55,961-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:55:55,979-0600 INFO  Multiplexer No streams
-2013-11-06 07:55:57,951-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:56:05,987-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:56:15,995-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:56:26,003-0600 INFO  Multiplexer No streams
-2013-11-06 07:56:30,274-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 07:56:31,571-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:56:36,011-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:56:46,019-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:56:56,027-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 07:57:02,597-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:57:06,034-0600 INFO  Multiplexer No streams
-2013-11-06 07:57:07,182-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:57:16,042-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:57:26,050-0600 INFO  Multiplexer No streams
-2013-11-06 07:57:34,920-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:57:36,058-0600 INFO  Multiplexer No streams
-2013-11-06 07:57:42,792-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:57:46,066-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:57:56,074-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:58:06,082-0600 INFO  Multiplexer No streams
-2013-11-06 07:58:07,243-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:58:16,090-0600 INFO  Multiplexer No streams
-2013-11-06 07:58:18,402-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 07:58:26,098-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:58:36,106-0600 INFO  Multiplexer No streams
-2013-11-06 07:58:39,566-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:58:46,115-0600 INFO  Multiplexer No streams
-2013-11-06 07:58:54,014-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 07:58:56,123-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:59:06,131-0600 INFO  Multiplexer No streams
-2013-11-06 07:59:11,889-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:59:16,140-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:59:26,148-0600 INFO  Multiplexer No streams
-2013-11-06 07:59:29,623-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 07:59:36,156-0600 INFO  Multiplexer No streams
-2013-11-06 07:59:44,212-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 07:59:46,165-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 07:59:56,173-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 08:00:05,234-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:00:06,181-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:00:16,189-0600 INFO  Multiplexer No streams
-2013-11-06 08:00:16,535-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:00:26,197-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:00:36,205-0600 INFO  Multiplexer No streams
-2013-11-06 08:00:40,844-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:00:46,213-0600 INFO  Multiplexer No streams
-2013-11-06 08:00:48,858-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:00:56,221-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:01:06,229-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:01:16,238-0600 INFO  Multiplexer No streams
-2013-11-06 08:01:16,454-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:01:21,181-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:01:26,246-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:01:36,254-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:01:46,262-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-2013-11-06 08:01:52,067-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-2013-11-06 08:01:53,504-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:01:56,271-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:02:06,279-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:02:16,287-0600 INFO  Multiplexer No streams
-2013-11-06 08:02:25,827-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:02:26,295-0600 INFO  Multiplexer No streams
-2013-11-06 08:02:27,674-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:02:36,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:02:46,311-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:02:56,319-0600 INFO  Multiplexer No streams
-2013-11-06 08:02:58,150-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 08:03:03,285-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:03:06,327-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:03:16,335-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:03:26,343-0600 INFO  Multiplexer No streams
-2013-11-06 08:03:30,474-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:03:36,351-0600 INFO  Multiplexer No streams
-2013-11-06 08:03:38,893-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:03:46,359-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:03:56,367-0600 INFO  Multiplexer No streams
-2013-11-06 08:04:02,798-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:04:06,375-0600 INFO  Multiplexer No streams
-2013-11-06 08:04:14,504-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:04:16,383-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:04:26,391-0600 INFO  Multiplexer No streams
-2013-11-06 08:04:35,122-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:04:36,399-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:04:46,407-0600 INFO  Multiplexer No streams
-2013-11-06 08:04:50,114-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:04:56,415-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:05:06,423-0600 INFO  Multiplexer No streams
-2013-11-06 08:05:07,444-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:05:16,430-0600 INFO  Multiplexer No streams
-2013-11-06 08:05:25,724-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:05:26,439-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:05:36,446-0600 INFO  Multiplexer No streams
-2013-11-06 08:05:39,768-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:05:46,455-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:05:56,462-0600 INFO  Multiplexer No streams
-2013-11-06 08:06:01,334-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:06:06,470-0600 INFO  Multiplexer No streams
-2013-11-06 08:06:12,091-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:06:16,478-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:06:26,486-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:06:36,494-0600 INFO  Multiplexer No streams
-2013-11-06 08:06:36,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:06:44,413-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:06:46,502-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:06:56,510-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:07:06,518-0600 INFO  Multiplexer No streams
-2013-11-06 08:07:12,555-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:07:16,526-0600 INFO  Multiplexer No streams
-2013-11-06 08:07:16,736-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:07:26,534-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:07:36,542-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:07:46,550-0600 INFO  Multiplexer No streams
-2013-11-06 08:07:48,164-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 08:07:49,059-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:07:56,558-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:08:06,566-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:08:16,573-0600 INFO  Multiplexer No streams
-2013-11-06 08:08:21,382-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:08:23,775-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:08:26,582-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:08:36,590-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:08:46,598-0600 INFO  Multiplexer No streams
-2013-11-06 08:08:53,705-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:08:56,606-0600 INFO  Multiplexer No streams
-2013-11-06 08:08:59,385-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:09:06,614-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:09:16,622-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:09:26,028-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:09:26,630-0600 INFO  Multiplexer No streams
-2013-11-06 08:09:34,995-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:09:36,638-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:09:46,646-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:09:56,654-0600 INFO  Multiplexer No streams
-2013-11-06 08:09:58,351-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:10:06,662-0600 INFO  Multiplexer No streams
-2013-11-06 08:10:10,606-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:10:16,670-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:10:26,679-0600 INFO  Multiplexer No streams
-2013-11-06 08:10:30,674-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:10:36,687-0600 INFO  Multiplexer No streams
-2013-11-06 08:10:46,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:10:46,695-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:10:56,703-0600 INFO  Multiplexer No streams
-2013-11-06 08:11:02,997-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:11:06,711-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:11:16,719-0600 INFO  Multiplexer No streams
-2013-11-06 08:11:21,827-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:11:26,727-0600 INFO  Multiplexer No streams
-2013-11-06 08:11:35,320-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:11:36,735-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:11:46,743-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:11:56,751-0600 INFO  Multiplexer No streams
-2013-11-06 08:11:57,439-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 08:12:06,760-0600 INFO  Multiplexer No streams
-2013-11-06 08:12:07,643-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:12:16,768-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:12:26,776-0600 INFO  Multiplexer No streams
-2013-11-06 08:12:33,047-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:12:36,784-0600 INFO  Multiplexer No streams
-2013-11-06 08:12:39,966-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:12:46,792-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:12:56,800-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:13:06,808-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:13:08,657-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:13:12,289-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:13:16,816-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:13:26,824-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:13:36,832-0600 INFO  Multiplexer No streams
-2013-11-06 08:13:44,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 08:13:44,612-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:13:46,840-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:13:56,848-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:14:06,856-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:14:16,864-0600 INFO  Multiplexer No streams
-2013-11-06 08:14:16,936-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 08:14:19,877-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:14:26,872-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:14:36,880-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:14:46,888-0600 INFO  Multiplexer No streams
-2013-11-06 08:14:49,259-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 08:14:55,487-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:14:56,896-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:15:06,904-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:15:16,912-0600 INFO  Multiplexer No streams
-2013-11-06 08:15:21,583-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:15:26,920-0600 INFO  Multiplexer No streams
-2013-11-06 08:15:31,098-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:15:36,928-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:15:46,936-0600 INFO  Multiplexer No streams
-2013-11-06 08:15:53,906-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:15:56,944-0600 INFO  Multiplexer No streams
-2013-11-06 08:16:06,707-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:16:06,952-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:16:16,960-0600 INFO  Multiplexer No streams
-2013-11-06 08:16:26,229-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:16:26,968-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:16:36,976-0600 INFO  Multiplexer No streams
-2013-11-06 08:16:42,317-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:16:46,984-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:16:56,992-0600 INFO  Multiplexer No streams
-2013-11-06 08:16:58,552-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:17:07,000-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:17:17,008-0600 INFO  Multiplexer No streams
-2013-11-06 08:17:17,927-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:17:27,016-0600 INFO  Multiplexer No streams
-2013-11-06 08:17:30,876-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:17:37,024-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:17:47,032-0600 INFO  Multiplexer No streams
-2013-11-06 08:17:53,537-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:17:57,040-0600 INFO  Multiplexer No streams
-2013-11-06 08:18:03,200-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:18:07,048-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:18:17,056-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:18:27,064-0600 INFO  Multiplexer No streams
-2013-11-06 08:18:29,147-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 08:18:35,524-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:18:37,072-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:18:47,080-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:18:57,088-0600 INFO  Multiplexer No streams
-2013-11-06 08:19:04,757-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:19:07,096-0600 INFO  Multiplexer No streams
-2013-11-06 08:19:07,847-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:19:17,104-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:19:27,112-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:19:37,120-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-2013-11-06 08:19:40,172-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-2013-11-06 08:19:40,368-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:19:47,128-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:19:57,136-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:20:07,144-0600 INFO  Multiplexer No streams
-2013-11-06 08:20:12,493-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:20:15,977-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:20:17,152-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:20:27,160-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:20:37,168-0600 INFO  Multiplexer No streams
-2013-11-06 08:20:44,817-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:20:47,176-0600 INFO  Multiplexer No streams
-2013-11-06 08:20:51,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:20:57,184-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:21:07,192-0600 INFO  Multiplexer No streams
-2013-11-06 08:21:17,139-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:21:17,200-0600 INFO  Multiplexer No streams
-2013-11-06 08:21:27,196-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:21:27,208-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:21:37,216-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:21:47,224-0600 INFO  Multiplexer No streams
-2013-11-06 08:21:49,462-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:21:57,232-0600 INFO  Multiplexer No streams
-2013-11-06 08:22:02,809-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 08:22:07,240-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:22:17,249-0600 INFO  Multiplexer No streams
-2013-11-06 08:22:21,785-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:22:27,257-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:22:37,265-0600 INFO  Multiplexer No streams
-2013-11-06 08:22:38,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:22:47,273-0600 INFO  Multiplexer No streams
-2013-11-06 08:22:54,108-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:22:57,282-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:23:07,290-0600 INFO  Multiplexer No streams
-2013-11-06 08:23:14,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:23:17,298-0600 INFO  Multiplexer No streams
-2013-11-06 08:23:26,431-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:23:27,307-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:23:37,315-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:23:47,323-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 5ms
-2013-11-06 08:23:49,641-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 5ms
-No streams
-2013-11-06 08:23:57,331-0600 INFO  Multiplexer No streams
-2013-11-06 08:23:58,754-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:24:07,340-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:24:17,348-0600 INFO  Multiplexer No streams
-2013-11-06 08:24:25,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:24:27,356-0600 INFO  Multiplexer No streams
-2013-11-06 08:24:31,077-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:24:37,364-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:24:47,373-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:24:57,380-0600 INFO  Multiplexer No streams
-2013-11-06 08:25:00,857-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:25:03,400-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:25:07,389-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:25:17,397-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:25:27,405-0600 INFO  Multiplexer No streams
-2013-11-06 08:25:35,723-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:25:36,467-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:25:37,413-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:25:47,421-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:25:57,429-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:26:07,437-0600 INFO  Multiplexer No streams
-2013-11-06 08:26:08,046-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:26:12,077-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:26:17,445-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:26:27,453-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:26:37,462-0600 INFO  Multiplexer No streams
-2013-11-06 08:26:40,369-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:26:47,469-0600 INFO  Multiplexer No streams
-2013-11-06 08:26:47,687-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:26:57,477-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:27:07,485-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 08:27:12,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:27:17,493-0600 INFO  Multiplexer No streams
-2013-11-06 08:27:23,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:27:27,501-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:27:37,510-0600 INFO  Multiplexer No streams
-2013-11-06 08:27:45,015-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:27:47,518-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:27:57,525-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 08:27:58,908-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:28:07,533-0600 INFO  Multiplexer No streams
-2013-11-06 08:28:17,338-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:28:17,542-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:28:27,549-0600 INFO  Multiplexer No streams
-2013-11-06 08:28:34,517-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:28:37,558-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:28:47,565-0600 INFO  Multiplexer No streams
-2013-11-06 08:28:49,661-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:28:57,573-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:29:07,581-0600 INFO  Multiplexer No streams
-2013-11-06 08:29:10,127-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:29:17,589-0600 INFO  Multiplexer No streams
-2013-11-06 08:29:21,985-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:29:27,597-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:29:37,605-0600 INFO  Multiplexer No streams
-2013-11-06 08:29:45,737-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:29:47,613-0600 INFO  Multiplexer No streams
-2013-11-06 08:29:54,308-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:29:57,621-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:30:07,629-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:30:17,637-0600 INFO  Multiplexer No streams
-2013-11-06 08:30:21,347-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:30:26,632-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:30:27,645-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:30:37,653-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:30:47,661-0600 INFO  Multiplexer No streams
-2013-11-06 08:30:56,957-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:30:57,670-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 08:30:58,955-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:31:07,678-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:31:17,686-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:31:27,694-0600 INFO  Multiplexer No streams
-2013-11-06 08:31:31,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:31:32,567-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:31:37,703-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:31:47,711-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:31:57,719-0600 INFO  Multiplexer No streams
-2013-11-06 08:32:03,601-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:32:07,728-0600 INFO  Multiplexer No streams
-2013-11-06 08:32:08,181-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 5ms
-No streams
-2013-11-06 08:32:17,730-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:32:27,738-0600 INFO  Multiplexer No streams
-2013-11-06 08:32:35,924-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:32:37,746-0600 INFO  Multiplexer No streams
-2013-11-06 08:32:43,787-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:32:47,754-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:32:57,762-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:33:07,770-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 114ms
-2013-11-06 08:33:08,360-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 114ms
-No streams
-2013-11-06 08:33:17,778-0600 INFO  Multiplexer No streams
-2013-11-06 08:33:19,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:33:27,786-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:33:37,794-0600 INFO  Multiplexer No streams
-2013-11-06 08:33:40,570-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:33:47,802-0600 INFO  Multiplexer No streams
-2013-11-06 08:33:55,008-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:33:57,810-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:34:07,818-0600 INFO  Multiplexer No streams
-2013-11-06 08:34:12,893-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:34:17,826-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:34:27,834-0600 INFO  Multiplexer No streams
-2013-11-06 08:34:30,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:34:37,842-0600 INFO  Multiplexer No streams
-2013-11-06 08:34:45,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:34:47,850-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:34:57,858-0600 INFO  Multiplexer No streams
-2013-11-06 08:35:06,228-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:35:07,867-0600 INFO  Multiplexer No streams
-2013-11-06 08:35:17,539-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:35:17,875-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:35:27,883-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:35:37,891-0600 INFO  Multiplexer No streams
-2013-11-06 08:35:41,839-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:35:47,899-0600 INFO  Multiplexer No streams
-2013-11-06 08:35:49,862-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:35:57,907-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:36:07,915-0600 INFO  Multiplexer No streams
-2013-11-06 08:36:17,449-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:36:17,924-0600 INFO  Multiplexer No streams
-2013-11-06 08:36:22,186-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:36:27,932-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:36:37,940-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:36:47,948-0600 INFO  Multiplexer No streams
-2013-11-06 08:36:53,058-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:36:54,508-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:36:57,956-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:37:07,964-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:37:17,973-0600 INFO  Multiplexer No streams
-2013-11-06 08:37:26,831-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:37:27,980-0600 INFO  Multiplexer No streams
-2013-11-06 08:37:28,668-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:37:37,989-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:37:47,997-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:37:58,005-0600 INFO  Multiplexer No streams
-2013-11-06 08:37:59,154-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:38:04,279-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:38:08,014-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:38:18,022-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:38:28,030-0600 INFO  Multiplexer No streams
-2013-11-06 08:38:31,477-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:38:38,038-0600 INFO  Multiplexer No streams
-2013-11-06 08:38:39,888-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:38:48,046-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:38:58,055-0600 INFO  Multiplexer No streams
-2013-11-06 08:39:03,800-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:39:08,063-0600 INFO  Multiplexer No streams
-2013-11-06 08:39:15,498-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:39:18,071-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:39:28,079-0600 INFO  Multiplexer No streams
-2013-11-06 08:39:36,123-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:39:38,087-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:39:48,095-0600 INFO  Multiplexer No streams
-2013-11-06 08:39:51,108-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:39:58,104-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:40:08,113-0600 INFO  Multiplexer No streams
-2013-11-06 08:40:08,446-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:40:18,122-0600 INFO  Multiplexer No streams
-2013-11-06 08:40:26,720-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:40:28,130-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:40:38,138-0600 INFO  Multiplexer No streams
-2013-11-06 08:40:40,769-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:40:48,146-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:40:58,154-0600 INFO  Multiplexer No streams
-2013-11-06 08:41:02,329-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:41:08,162-0600 INFO  Multiplexer No streams
-2013-11-06 08:41:13,092-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:41:18,170-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:41:28,178-0600 INFO  Multiplexer No streams
-2013-11-06 08:41:37,939-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:41:38,187-0600 INFO  Multiplexer No streams
-2013-11-06 08:41:45,415-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:41:48,194-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:41:58,202-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:42:08,210-0600 INFO  Multiplexer No streams
-2013-11-06 08:42:13,553-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 5ms
-2013-11-06 08:42:17,738-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:42:18,219-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:42:28,226-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:42:38,235-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:42:48,243-0600 INFO  Multiplexer No streams
-2013-11-06 08:42:49,159-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:42:50,061-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:42:58,251-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:43:08,259-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:43:18,267-0600 INFO  Multiplexer No streams
-2013-11-06 08:43:22,384-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:43:24,769-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:43:28,275-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:43:38,283-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:43:48,291-0600 INFO  Multiplexer No streams
-2013-11-06 08:43:54,707-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:43:58,298-0600 INFO  Multiplexer No streams
-2013-11-06 08:44:00,379-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:44:08,306-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:44:18,314-0600 INFO  Multiplexer No streams
-2013-11-06 08:44:27,030-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:44:28,322-0600 INFO  Multiplexer No streams
-2013-11-06 08:44:35,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:44:38,330-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:44:48,338-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:44:58,346-0600 INFO  Multiplexer No streams
-2013-11-06 08:44:59,353-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:45:08,354-0600 INFO  Multiplexer No streams
-2013-11-06 08:45:11,600-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 08:45:18,362-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:45:28,371-0600 INFO  Multiplexer No streams
-2013-11-06 08:45:31,677-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:45:38,379-0600 INFO  Multiplexer No streams
-2013-11-06 08:45:47,209-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:45:48,386-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:45:58,394-0600 INFO  Multiplexer No streams
-2013-11-06 08:46:03,999-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:46:08,402-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:46:18,410-0600 INFO  Multiplexer No streams
-2013-11-06 08:46:22,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:46:28,418-0600 INFO  Multiplexer No streams
-2013-11-06 08:46:36,322-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:46:38,425-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:46:48,433-0600 INFO  Multiplexer No streams
-2013-11-06 08:46:58,429-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 08:46:58,441-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:47:08,449-0600 INFO  Multiplexer No streams
-2013-11-06 08:47:08,645-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:47:18,457-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:47:28,464-0600 INFO  Multiplexer No streams
-2013-11-06 08:47:34,039-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:47:38,472-0600 INFO  Multiplexer No streams
-2013-11-06 08:47:40,968-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:47:48,481-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:47:58,488-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:48:08,497-0600 INFO  Multiplexer No streams
-2013-11-06 08:48:09,649-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:48:13,291-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:48:18,505-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:48:28,513-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:48:38,521-0600 INFO  Multiplexer No streams
-2013-11-06 08:48:45,259-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:48:45,614-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:48:48,530-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:48:58,538-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:49:08,548-0600 INFO  Multiplexer No streams
-2013-11-06 08:49:17,937-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:49:18,556-0600 INFO  Multiplexer No streams
-2013-11-06 08:49:20,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:49:28,564-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:49:38,572-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:49:48,581-0600 INFO  Multiplexer No streams
-2013-11-06 08:49:50,260-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:49:56,478-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:49:58,592-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:50:08,600-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:50:18,608-0600 INFO  Multiplexer No streams
-2013-11-06 08:50:22,583-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:50:28,616-0600 INFO  Multiplexer No streams
-2013-11-06 08:50:32,090-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 08:50:38,624-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:50:48,632-0600 INFO  Multiplexer No streams
-2013-11-06 08:50:54,906-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:50:58,641-0600 INFO  Multiplexer No streams
-2013-11-06 08:51:07,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:51:08,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:51:18,657-0600 INFO  Multiplexer No streams
-2013-11-06 08:51:27,229-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:51:28,665-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:51:38,673-0600 INFO  Multiplexer No streams
-2013-11-06 08:51:43,309-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:51:48,682-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:51:58,690-0600 INFO  Multiplexer No streams
-2013-11-06 08:51:59,552-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:52:08,698-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:52:18,706-0600 INFO  Multiplexer No streams
-2013-11-06 08:52:18,922-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 08:52:28,714-0600 INFO  Multiplexer No streams
-2013-11-06 08:52:31,875-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:52:38,723-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:52:48,731-0600 INFO  Multiplexer No streams
-2013-11-06 08:52:54,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 08:52:58,739-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 08:53:04,198-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 08:53:08,748-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:53:18,756-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:53:28,765-0600 INFO  Multiplexer No streams
-2013-11-06 08:53:30,140-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:53:36,521-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:53:38,773-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:53:48,782-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:53:58,790-0600 INFO  Multiplexer No streams
-2013-11-06 08:54:05,750-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:54:08,798-0600 INFO  Multiplexer No streams
-2013-11-06 08:54:08,844-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:54:18,806-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:54:28,814-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:54:38,822-0600 INFO  Multiplexer No streams
-2013-11-06 08:54:41,167-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:54:41,360-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:54:48,830-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:54:58,838-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:55:08,845-0600 INFO  Multiplexer No streams
-2013-11-06 08:55:13,490-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 08:55:16,970-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:55:18,853-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:55:28,861-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:55:38,870-0600 INFO  Multiplexer No streams
-2013-11-06 08:55:45,813-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:55:48,877-0600 INFO  Multiplexer No streams
-2013-11-06 08:55:52,580-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:55:58,886-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:56:08,894-0600 INFO  Multiplexer No streams
-2013-11-06 08:56:18,136-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:56:18,902-0600 INFO  Multiplexer No streams
-2013-11-06 08:56:28,190-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:56:28,910-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:56:38,918-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:56:48,926-0600 INFO  Multiplexer No streams
-2013-11-06 08:56:50,459-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:56:58,934-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 08:57:03,799-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 08:57:08,943-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:57:18,951-0600 INFO  Multiplexer No streams
-2013-11-06 08:57:22,782-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:57:28,959-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:57:38,967-0600 INFO  Multiplexer No streams
-2013-11-06 08:57:39,410-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:57:48,976-0600 INFO  Multiplexer No streams
-2013-11-06 08:57:55,105-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:57:58,984-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:58:08,992-0600 INFO  Multiplexer No streams
-2013-11-06 08:58:15,020-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:58:19,001-0600 INFO  Multiplexer No streams
-2013-11-06 08:58:27,428-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:58:29,009-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:58:39,017-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:58:49,025-0600 INFO  Multiplexer No streams
-2013-11-06 08:58:50,630-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:58:59,034-0600 INFO  Multiplexer No streams
-2013-11-06 08:58:59,751-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:59:09,042-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:59:19,050-0600 INFO  Multiplexer No streams
-2013-11-06 08:59:26,240-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:59:29,058-0600 INFO  Multiplexer No streams
-2013-11-06 08:59:32,074-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 08:59:39,067-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:59:49,075-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 08:59:59,083-0600 INFO  Multiplexer No streams
-2013-11-06 09:00:01,850-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:00:04,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:00:09,091-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:00:19,099-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:00:29,108-0600 INFO  Multiplexer No streams
-2013-11-06 09:00:36,720-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:00:37,460-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:00:39,116-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:00:49,124-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:00:59,133-0600 INFO  Multiplexer No streams
-2013-11-06 09:01:09,043-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:01:09,141-0600 INFO  Multiplexer No streams
-2013-11-06 09:01:13,070-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:01:19,149-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:01:29,157-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:01:39,165-0600 INFO  Multiplexer No streams
-2013-11-06 09:01:41,366-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:01:48,680-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:01:49,173-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:01:59,181-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:02:09,190-0600 INFO  Multiplexer No streams
-2013-11-06 09:02:13,689-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:02:19,198-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 09:02:24,292-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 09:02:29,206-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:02:39,214-0600 INFO  Multiplexer No streams
-2013-11-06 09:02:46,012-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:02:49,222-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:02:59,230-0600 INFO  Multiplexer No streams
-2013-11-06 09:02:59,900-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:03:09,238-0600 INFO  Multiplexer No streams
-2013-11-06 09:03:18,335-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:03:19,247-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:03:29,255-0600 INFO  Multiplexer No streams
-2013-11-06 09:03:35,510-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:03:39,263-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:03:49,271-0600 INFO  Multiplexer No streams
-2013-11-06 09:03:50,658-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:03:59,279-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:04:09,287-0600 INFO  Multiplexer No streams
-2013-11-06 09:04:11,120-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:04:19,295-0600 INFO  Multiplexer No streams
-2013-11-06 09:04:22,981-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:04:29,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:04:39,311-0600 INFO  Multiplexer No streams
-2013-11-06 09:04:46,730-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:04:49,319-0600 INFO  Multiplexer No streams
-2013-11-06 09:04:55,304-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:04:59,327-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:05:09,335-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:05:19,344-0600 INFO  Multiplexer No streams
-2013-11-06 09:05:22,340-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:05:27,627-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:05:29,352-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:05:39,360-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:05:49,369-0600 INFO  Multiplexer No streams
-2013-11-06 09:05:57,951-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:05:59,377-0600 INFO  Multiplexer No streams
-2013-11-06 09:05:59,950-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:06:09,385-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:06:19,393-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:06:29,401-0600 INFO  Multiplexer No streams
-2013-11-06 09:06:32,273-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:06:33,561-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:06:39,410-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:06:49,418-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:06:59,426-0600 INFO  Multiplexer No streams
-2013-11-06 09:07:04,596-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:07:09,171-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:07:09,435-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:07:19,443-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:07:29,451-0600 INFO  Multiplexer No streams
-2013-11-06 09:07:36,919-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:07:39,460-0600 INFO  Multiplexer No streams
-2013-11-06 09:07:44,781-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:07:49,468-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:07:59,476-0600 INFO  Multiplexer No streams
-2013-11-06 09:08:09,242-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:08:09,484-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:08:19,492-0600 INFO  Multiplexer No streams
-2013-11-06 09:08:20,391-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:08:29,501-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:08:39,509-0600 INFO  Multiplexer No streams
-2013-11-06 09:08:41,565-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:08:49,517-0600 INFO  Multiplexer No streams
-2013-11-06 09:08:56,001-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:08:59,525-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:09:09,534-0600 INFO  Multiplexer No streams
-2013-11-06 09:09:13,888-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:09:19,543-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:09:29,551-0600 INFO  Multiplexer No streams
-2013-11-06 09:09:31,611-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:09:39,559-0600 INFO  Multiplexer No streams
-2013-11-06 09:09:46,211-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:09:49,567-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:09:59,575-0600 INFO  Multiplexer No streams
-2013-11-06 09:10:07,221-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:10:09,584-0600 INFO  Multiplexer No streams
-2013-11-06 09:10:18,534-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:10:19,592-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:10:29,600-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:10:39,608-0600 INFO  Multiplexer No streams
-2013-11-06 09:10:42,831-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:10:49,616-0600 INFO  Multiplexer No streams
-2013-11-06 09:10:50,857-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:10:59,624-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:11:09,632-0600 INFO  Multiplexer No streams
-2013-11-06 09:11:18,441-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:11:19,640-0600 INFO  Multiplexer No streams
-2013-11-06 09:11:23,181-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:11:29,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:11:39,657-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:11:49,665-0600 INFO  Multiplexer No streams
-2013-11-06 09:11:54,050-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 09:11:55,503-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:11:59,673-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:12:09,681-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:12:19,690-0600 INFO  Multiplexer No streams
-2013-11-06 09:12:27,826-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:12:29,663-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 09:12:29,698-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:12:39,706-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:12:49,715-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:12:59,723-0600 INFO  Multiplexer No streams
-2013-11-06 09:13:00,149-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:13:05,272-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:13:09,731-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:13:19,739-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:13:29,747-0600 INFO  Multiplexer No streams
-2013-11-06 09:13:32,472-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:13:39,755-0600 INFO  Multiplexer No streams
-2013-11-06 09:13:40,882-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:13:49,764-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:13:59,772-0600 INFO  Multiplexer No streams
-2013-11-06 09:14:04,795-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:14:09,780-0600 INFO  Multiplexer No streams
-2013-11-06 09:14:16,492-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:14:19,789-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:14:29,797-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:14:37,118-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:14:39,806-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:14:49,814-0600 INFO  Multiplexer No streams
-2013-11-06 09:14:52,101-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 09:14:59,822-0600 INFO  Multiplexer No streams
-2013-11-06 09:15:09,441-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:15:09,831-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:15:19,839-0600 INFO  Multiplexer No streams
-2013-11-06 09:15:27,713-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:15:29,848-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:15:39,856-0600 INFO  Multiplexer No streams
-2013-11-06 09:15:41,764-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:15:49,865-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:15:59,873-0600 INFO  Multiplexer No streams
-2013-11-06 09:16:03,322-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:16:09,882-0600 INFO  Multiplexer No streams
-2013-11-06 09:16:14,087-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:16:19,890-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:16:29,898-0600 INFO  Multiplexer No streams
-2013-11-06 09:16:38,932-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:16:39,906-0600 INFO  Multiplexer No streams
-2013-11-06 09:16:46,410-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:16:49,914-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:16:59,922-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:17:09,930-0600 INFO  Multiplexer No streams
-2013-11-06 09:17:14,544-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 09:17:18,733-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:17:19,938-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:17:29,946-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:17:39,954-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:17:49,962-0600 INFO  Multiplexer No streams
-2013-11-06 09:17:50,152-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:17:51,056-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:17:59,970-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:18:09,977-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:18:19,985-0600 INFO  Multiplexer No streams
-2013-11-06 09:18:23,379-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:18:25,762-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:18:29,993-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:18:40,001-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:18:50,009-0600 INFO  Multiplexer No streams
-2013-11-06 09:18:55,702-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:19:00,017-0600 INFO  Multiplexer No streams
-2013-11-06 09:19:01,372-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:19:10,025-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:19:20,033-0600 INFO  Multiplexer No streams
-2013-11-06 09:19:28,025-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:19:30,040-0600 INFO  Multiplexer No streams
-2013-11-06 09:19:36,982-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:19:40,048-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:19:50,056-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:20:00,064-0600 INFO  Multiplexer No streams
-2013-11-06 09:20:00,348-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:20:10,072-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:20:12,593-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:20:20,079-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:20:30,087-0600 INFO  Multiplexer No streams
-2013-11-06 09:20:32,672-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:20:40,095-0600 INFO  Multiplexer No streams
-2013-11-06 09:20:48,202-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:20:50,103-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:21:00,111-0600 INFO  Multiplexer No streams
-2013-11-06 09:21:04,994-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:21:10,119-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:21:20,127-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 09:21:23,813-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:21:30,134-0600 INFO  Multiplexer No streams
-2013-11-06 09:21:37,317-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:21:40,142-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:21:50,150-0600 INFO  Multiplexer No streams
-2013-11-06 09:21:59,423-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:22:00,157-0600 INFO  Multiplexer No streams
-2013-11-06 09:22:09,640-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:22:10,165-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:22:20,172-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:22:30,180-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-2013-11-06 09:22:35,036-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 09:22:40,188-0600 INFO  Multiplexer No streams
-2013-11-06 09:22:41,963-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:22:50,196-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:23:00,203-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:23:10,216-0600 INFO  Multiplexer No streams
-2013-11-06 09:23:10,643-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:23:14,286-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:23:20,224-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:23:30,232-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:23:40,240-0600 INFO  Multiplexer No streams
-2013-11-06 09:23:46,253-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:23:46,609-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:23:50,248-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:24:00,258-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:24:10,266-0600 INFO  Multiplexer No streams
-2013-11-06 09:24:18,932-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:24:20,274-0600 INFO  Multiplexer No streams
-2013-11-06 09:24:21,863-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:24:30,282-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:24:40,290-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:24:50,299-0600 INFO  Multiplexer No streams
-2013-11-06 09:24:51,255-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:24:57,473-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:25:00,307-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:25:10,315-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:25:20,324-0600 INFO  Multiplexer No streams
-2013-11-06 09:25:23,578-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:25:30,332-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-2013-11-06 09:25:33,084-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-No streams
-2013-11-06 09:25:40,340-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:25:50,348-0600 INFO  Multiplexer No streams
-2013-11-06 09:25:55,901-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:26:00,356-0600 INFO  Multiplexer No streams
-2013-11-06 09:26:08,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:26:10,364-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:26:20,372-0600 INFO  Multiplexer No streams
-2013-11-06 09:26:28,224-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:26:30,380-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:26:40,388-0600 INFO  Multiplexer No streams
-2013-11-06 09:26:44,303-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:26:50,396-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:27:00,405-0600 INFO  Multiplexer No streams
-2013-11-06 09:27:00,547-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:27:10,413-0600 INFO  Multiplexer No streams
-2013-11-06 09:27:19,913-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:27:20,421-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:27:30,429-0600 INFO  Multiplexer No streams
-2013-11-06 09:27:32,871-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:27:40,438-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:27:50,446-0600 INFO  Multiplexer No streams
-2013-11-06 09:27:55,523-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:28:00,454-0600 INFO  Multiplexer No streams
-2013-11-06 09:28:05,195-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:28:10,462-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:28:20,470-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:28:30,478-0600 INFO  Multiplexer No streams
-2013-11-06 09:28:31,133-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 09:28:37,518-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 09:28:40,487-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:28:50,495-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:29:00,504-0600 INFO  Multiplexer No streams
-2013-11-06 09:29:06,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:29:09,842-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:29:10,512-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:29:20,519-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:29:30,527-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:29:40,534-0600 INFO  Multiplexer No streams
-2013-11-06 09:29:42,165-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:29:42,354-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:29:50,542-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:30:00,550-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:30:10,558-0600 INFO  Multiplexer No streams
-2013-11-06 09:30:14,488-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:30:17,963-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:30:20,565-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:30:30,574-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:30:40,582-0600 INFO  Multiplexer No streams
-2013-11-06 09:30:46,812-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:30:50,589-0600 INFO  Multiplexer No streams
-2013-11-06 09:30:53,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:31:00,597-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:31:10,605-0600 INFO  Multiplexer No streams
-2013-11-06 09:31:19,134-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:31:20,613-0600 INFO  Multiplexer No streams
-2013-11-06 09:31:29,183-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:31:30,621-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:31:40,629-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:31:50,637-0600 INFO  Multiplexer No streams
-2013-11-06 09:31:51,457-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:32:00,645-0600 INFO  Multiplexer No streams
-2013-11-06 09:32:04,793-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:32:10,656-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:32:20,665-0600 INFO  Multiplexer No streams
-2013-11-06 09:32:23,780-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:32:30,673-0600 INFO  Multiplexer No streams
-2013-11-06 09:32:40,406-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 09:32:40,681-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:32:50,689-0600 INFO  Multiplexer No streams
-2013-11-06 09:32:56,103-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:33:00,698-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:33:10,706-0600 INFO  Multiplexer No streams
-2013-11-06 09:33:16,013-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:33:20,714-0600 INFO  Multiplexer No streams
-2013-11-06 09:33:28,426-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:33:30,722-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:33:40,730-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:33:50,738-0600 INFO  Multiplexer No streams
-2013-11-06 09:33:51,624-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 09:34:00,749-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:34:00,752-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:34:10,760-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:34:20,768-0600 INFO  Multiplexer No streams
-2013-11-06 09:34:27,234-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:34:30,776-0600 INFO  Multiplexer No streams
-2013-11-06 09:34:33,072-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:34:40,785-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:34:50,793-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:35:00,801-0600 INFO  Multiplexer No streams
-2013-11-06 09:35:02,844-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:35:05,395-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:35:10,809-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:35:20,817-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:35:30,826-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 120ms
-2013-11-06 09:35:37,837-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 120ms
-No streams
-2013-11-06 09:35:40,834-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2525ms
-2013-11-06 09:35:40,978-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2525ms
-No streams
-2013-11-06 09:35:50,845-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:36:00,853-0600 INFO  Multiplexer No streams
-2013-11-06 09:36:10,041-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:36:10,861-0600 INFO  Multiplexer No streams
-2013-11-06 09:36:14,064-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:36:20,869-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:36:30,872-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:36:40,880-0600 INFO  Multiplexer No streams
-2013-11-06 09:36:42,364-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:36:49,674-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:36:50,889-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:37:00,897-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:37:10,905-0600 INFO  Multiplexer No streams
-2013-11-06 09:37:14,687-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:37:20,913-0600 INFO  Multiplexer No streams
-2013-11-06 09:37:25,284-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 09:37:30,921-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:37:40,929-0600 INFO  Multiplexer No streams
-2013-11-06 09:37:47,010-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:37:50,936-0600 INFO  Multiplexer No streams
-2013-11-06 09:38:00,896-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:38:00,944-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:38:10,952-0600 INFO  Multiplexer No streams
-2013-11-06 09:38:19,333-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:38:20,960-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:38:30,967-0600 INFO  Multiplexer No streams
-2013-11-06 09:38:36,505-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:38:40,975-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:38:50,983-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-2013-11-06 09:38:51,657-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-No streams
-2013-11-06 09:39:00,991-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:39:10,998-0600 INFO  Multiplexer No streams
-2013-11-06 09:39:12,116-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:39:21,006-0600 INFO  Multiplexer No streams
-2013-11-06 09:39:23,979-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:39:31,014-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:39:41,022-0600 INFO  Multiplexer No streams
-2013-11-06 09:39:47,726-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:39:51,029-0600 INFO  Multiplexer No streams
-2013-11-06 09:39:56,302-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:40:01,038-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:40:11,045-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:40:21,053-0600 INFO  Multiplexer No streams
-2013-11-06 09:40:23,337-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 09:40:28,625-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:40:31,061-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:40:41,068-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:40:51,076-0600 INFO  Multiplexer No streams
-2013-11-06 09:40:58,946-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:41:00,948-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:41:01,084-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:41:11,092-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:41:21,100-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:41:31,108-0600 INFO  Multiplexer No streams
-2013-11-06 09:41:33,271-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:41:34,556-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:41:41,116-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:41:51,124-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:42:01,132-0600 INFO  Multiplexer No streams
-2013-11-06 09:42:05,594-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 8ms
-2013-11-06 09:42:10,173-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 8ms
-No streams
-2013-11-06 09:42:11,140-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:42:21,148-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:42:31,156-0600 INFO  Multiplexer No streams
-2013-11-06 09:42:37,917-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:42:41,164-0600 INFO  Multiplexer No streams
-2013-11-06 09:42:45,779-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 09:42:51,172-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:43:01,181-0600 INFO  Multiplexer No streams
-2013-11-06 09:43:10,240-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:43:11,189-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:43:21,197-0600 INFO  Multiplexer No streams
-2013-11-06 09:43:21,386-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:43:31,205-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:43:41,214-0600 INFO  Multiplexer No streams
-2013-11-06 09:43:42,563-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:43:51,222-0600 INFO  Multiplexer No streams
-2013-11-06 09:43:56,996-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:44:01,230-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:44:11,239-0600 INFO  Multiplexer No streams
-2013-11-06 09:44:14,886-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:44:21,247-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:44:31,255-0600 INFO  Multiplexer No streams
-2013-11-06 09:44:32,606-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:44:41,264-0600 INFO  Multiplexer No streams
-2013-11-06 09:44:47,209-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:44:51,273-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:45:01,281-0600 INFO  Multiplexer No streams
-2013-11-06 09:45:08,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:45:11,289-0600 INFO  Multiplexer No streams
-2013-11-06 09:45:19,532-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:45:21,298-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:45:31,306-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:45:41,314-0600 INFO  Multiplexer No streams
-2013-11-06 09:45:43,826-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:45:51,322-0600 INFO  Multiplexer No streams
-2013-11-06 09:45:51,855-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:46:01,330-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:46:11,339-0600 INFO  Multiplexer No streams
-2013-11-06 09:46:19,436-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:46:21,347-0600 INFO  Multiplexer No streams
-2013-11-06 09:46:24,178-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:46:31,355-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:46:41,363-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:46:51,371-0600 INFO  Multiplexer No streams
-2013-11-06 09:46:55,046-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 09:46:56,501-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:47:01,379-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:47:11,388-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:47:21,396-0600 INFO  Multiplexer No streams
-2013-11-06 09:47:28,824-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:47:30,656-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:47:31,404-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:47:41,412-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:47:51,421-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 20ms
-2013-11-06 09:48:01,166-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 20ms
-No streams
-2013-11-06 09:48:01,429-0600 INFO  Multiplexer No streams
-2013-11-06 09:48:06,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:48:11,437-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:48:21,445-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:48:31,453-0600 INFO  Multiplexer No streams
-2013-11-06 09:48:33,470-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:48:41,461-0600 INFO  Multiplexer No streams
-2013-11-06 09:48:41,876-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:48:51,470-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:49:01,479-0600 INFO  Multiplexer No streams
-2013-11-06 09:49:05,793-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:49:11,487-0600 INFO  Multiplexer No streams
-2013-11-06 09:49:17,486-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:49:21,495-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:49:31,503-0600 INFO  Multiplexer No streams
-2013-11-06 09:49:38,116-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:49:41,511-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:49:51,519-0600 INFO  Multiplexer No streams
-2013-11-06 09:49:53,096-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:50:01,527-0600 INFO  Multiplexer No streams
-2013-11-06 09:50:10,439-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:50:11,536-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:50:21,543-0600 INFO  Multiplexer No streams
-2013-11-06 09:50:28,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:50:31,552-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:50:41,560-0600 INFO  Multiplexer No streams
-2013-11-06 09:50:42,762-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:50:51,568-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:51:01,576-0600 INFO  Multiplexer No streams
-2013-11-06 09:51:04,316-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:51:11,584-0600 INFO  Multiplexer No streams
-2013-11-06 09:51:15,085-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:51:21,593-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:51:31,601-0600 INFO  Multiplexer No streams
-2013-11-06 09:51:39,926-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:51:41,609-0600 INFO  Multiplexer No streams
-2013-11-06 09:51:47,408-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:51:51,617-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:52:01,625-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:52:11,633-0600 INFO  Multiplexer No streams
-2013-11-06 09:52:15,537-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:52:19,731-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:52:21,641-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:52:31,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:52:41,657-0600 INFO  Multiplexer No streams
-2013-11-06 09:52:51,149-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 09:52:51,665-0600 INFO  Multiplexer No streams
-2013-11-06 09:52:52,054-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:53:01,673-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:53:11,683-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:53:21,691-0600 INFO  Multiplexer No streams
-2013-11-06 09:53:24,377-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:53:26,756-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:53:31,699-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:53:41,707-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:53:51,715-0600 INFO  Multiplexer No streams
-2013-11-06 09:53:56,700-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:54:01,723-0600 INFO  Multiplexer No streams
-2013-11-06 09:54:02,366-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:54:11,731-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:54:21,740-0600 INFO  Multiplexer No streams
-2013-11-06 09:54:29,023-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:54:31,747-0600 INFO  Multiplexer No streams
-2013-11-06 09:54:37,976-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:54:41,755-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:54:51,763-0600 INFO  Multiplexer No streams
-2013-11-06 09:55:01,346-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:55:01,771-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:55:11,779-0600 INFO  Multiplexer No streams
-2013-11-06 09:55:13,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:55:21,787-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:55:31,795-0600 INFO  Multiplexer No streams
-2013-11-06 09:55:33,669-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:55:41,803-0600 INFO  Multiplexer No streams
-2013-11-06 09:55:49,196-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:55:51,811-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:56:01,819-0600 INFO  Multiplexer No streams
-2013-11-06 09:56:05,992-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:56:11,827-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:56:21,835-0600 INFO  Multiplexer No streams
-2013-11-06 09:56:24,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 09:56:31,843-0600 INFO  Multiplexer No streams
-2013-11-06 09:56:38,315-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:56:41,851-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:56:51,859-0600 INFO  Multiplexer No streams
-2013-11-06 09:57:00,416-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:57:01,866-0600 INFO  Multiplexer No streams
-2013-11-06 09:57:10,638-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:57:11,874-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:57:21,882-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:57:31,890-0600 INFO  Multiplexer No streams
-2013-11-06 09:57:36,026-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:57:41,898-0600 INFO  Multiplexer No streams
-2013-11-06 09:57:42,961-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:57:51,906-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:58:01,914-0600 INFO  Multiplexer No streams
-2013-11-06 09:58:11,636-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:58:11,923-0600 INFO  Multiplexer No streams
-2013-11-06 09:58:15,284-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:58:21,931-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:58:31,939-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:58:41,947-0600 INFO  Multiplexer No streams
-2013-11-06 09:58:47,246-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:58:47,607-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 09:58:51,955-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:59:01,963-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:59:11,971-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:59:19,931-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 09:59:21,978-0600 INFO  Multiplexer No streams
-2013-11-06 09:59:22,856-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 09:59:31,986-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:59:41,994-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 09:59:52,002-0600 INFO  Multiplexer No streams
-2013-11-06 09:59:52,254-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 09:59:58,466-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:00:02,010-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:00:12,017-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:00:22,025-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:00:24,578-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:00:32,033-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 11ms
-2013-11-06 10:00:34,086-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 11ms
-No streams
-2013-11-06 10:00:42,041-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:00:52,049-0600 INFO  Multiplexer No streams
-2013-11-06 10:00:56,900-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:01:02,057-0600 INFO  Multiplexer No streams
-2013-11-06 10:01:09,686-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:01:12,065-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:01:22,072-0600 INFO  Multiplexer No streams
-2013-11-06 10:01:29,223-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:01:32,081-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:01:42,088-0600 INFO  Multiplexer No streams
-2013-11-06 10:01:45,296-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:01:52,096-0600 INFO  Multiplexer No streams
-2013-11-06 10:02:01,546-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:02:02,104-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:02:12,112-0600 INFO  Multiplexer No streams
-2013-11-06 10:02:20,906-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:02:22,120-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:02:32,127-0600 INFO  Multiplexer No streams
-2013-11-06 10:02:33,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:02:42,135-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:02:52,143-0600 INFO  Multiplexer No streams
-2013-11-06 10:02:56,519-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 10:03:02,151-0600 INFO  Multiplexer No streams
-2013-11-06 10:03:06,192-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:03:12,159-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:03:22,167-0600 INFO  Multiplexer No streams
-2013-11-06 10:03:32,126-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:03:32,175-0600 INFO  Multiplexer No streams
-2013-11-06 10:03:38,515-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:03:42,182-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:03:52,190-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:04:02,199-0600 INFO  Multiplexer No streams
-2013-11-06 10:04:07,736-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 10:04:10,838-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:04:12,207-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:04:22,215-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:04:32,223-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:04:42,231-0600 INFO  Multiplexer No streams
-2013-11-06 10:04:43,161-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:04:43,347-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:04:52,239-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:05:02,247-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:05:12,256-0600 INFO  Multiplexer No streams
-2013-11-06 10:05:15,484-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:05:18,957-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:05:22,264-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:05:32,272-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:05:42,280-0600 INFO  Multiplexer No streams
-2013-11-06 10:05:47,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:05:52,289-0600 INFO  Multiplexer No streams
-2013-11-06 10:05:54,566-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:06:02,297-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:06:12,306-0600 INFO  Multiplexer No streams
-2013-11-06 10:06:20,130-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:06:22,313-0600 INFO  Multiplexer No streams
-2013-11-06 10:06:30,176-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:06:32,321-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:06:42,329-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:06:52,337-0600 INFO  Multiplexer No streams
-2013-11-06 10:06:52,454-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:07:02,345-0600 INFO  Multiplexer No streams
-2013-11-06 10:07:05,786-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:07:12,356-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:07:22,366-0600 INFO  Multiplexer No streams
-2013-11-06 10:07:24,777-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:07:32,376-0600 INFO  Multiplexer No streams
-2013-11-06 10:07:41,396-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:07:42,386-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:07:52,395-0600 INFO  Multiplexer No streams
-2013-11-06 10:07:57,099-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:08:02,406-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:08:12,415-0600 INFO  Multiplexer No streams
-2013-11-06 10:08:17,006-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:08:22,423-0600 INFO  Multiplexer No streams
-2013-11-06 10:08:29,422-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:08:32,435-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:08:42,447-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:08:52,461-0600 INFO  Multiplexer No streams
-2013-11-06 10:08:52,617-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:09:01,745-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:09:02,478-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:09:12,491-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:09:22,500-0600 INFO  Multiplexer No streams
-2013-11-06 10:09:28,227-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:09:32,510-0600 INFO  Multiplexer No streams
-2013-11-06 10:09:34,069-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:09:42,520-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:09:52,530-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:10:02,539-0600 INFO  Multiplexer No streams
-2013-11-06 10:10:03,836-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:10:06,391-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:10:12,549-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:10:22,558-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:10:32,567-0600 INFO  Multiplexer No streams
-2013-11-06 10:10:38,714-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:10:39,447-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:10:42,577-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:10:52,588-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:11:02,598-0600 INFO  Multiplexer No streams
-2013-11-06 10:11:11,038-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:11:12,608-0600 INFO  Multiplexer No streams
-2013-11-06 10:11:15,057-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:11:22,618-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:11:32,628-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:11:42,639-0600 INFO  Multiplexer No streams
-2013-11-06 10:11:43,361-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:11:50,667-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:11:52,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:12:02,657-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:12:12,666-0600 INFO  Multiplexer No streams
-2013-11-06 10:12:15,684-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-No streams
-2013-11-06 10:12:22,674-0600 INFO  Multiplexer No streams
-2013-11-06 10:12:26,276-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:12:32,684-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:12:42,693-0600 INFO  Multiplexer No streams
-2013-11-06 10:12:48,006-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:12:52,701-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 95ms
-2013-11-06 10:13:01,980-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 95ms
-No streams
-2013-11-06 10:13:02,709-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:13:12,717-0600 INFO  Multiplexer No streams
-2013-11-06 10:13:20,329-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:13:22,725-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:13:32,733-0600 INFO  Multiplexer No streams
-2013-11-06 10:13:37,496-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:13:42,741-0600 INFO  Multiplexer No streams
-2013-11-06 10:13:52,652-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:13:52,749-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:14:02,757-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:14:12,765-0600 INFO  Multiplexer No streams
-2013-11-06 10:14:13,106-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:14:22,773-0600 INFO  Multiplexer No streams
-2013-11-06 10:14:24,975-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:14:32,781-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:14:42,789-0600 INFO  Multiplexer No streams
-2013-11-06 10:14:48,716-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:14:52,801-0600 INFO  Multiplexer No streams
-2013-11-06 10:14:57,298-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:15:02,809-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:15:12,816-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:15:22,824-0600 INFO  Multiplexer No streams
-2013-11-06 10:15:24,327-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:15:29,622-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:15:32,832-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:15:42,840-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:15:52,848-0600 INFO  Multiplexer No streams
-2013-11-06 10:15:59,936-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:16:01,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:16:02,855-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:16:12,863-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:16:22,871-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:16:32,879-0600 INFO  Multiplexer No streams
-2013-11-06 10:16:34,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:16:35,546-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:16:42,887-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:16:52,895-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:17:02,903-0600 INFO  Multiplexer No streams
-2013-11-06 10:17:06,590-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:17:11,157-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:17:12,911-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:17:22,919-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:17:32,927-0600 INFO  Multiplexer No streams
-2013-11-06 10:17:38,913-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:17:42,935-0600 INFO  Multiplexer No streams
-2013-11-06 10:17:46,766-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:17:52,943-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:18:02,951-0600 INFO  Multiplexer No streams
-2013-11-06 10:18:11,236-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:18:12,959-0600 INFO  Multiplexer No streams
-2013-11-06 10:18:22,376-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:18:22,967-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:18:32,974-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:18:42,982-0600 INFO  Multiplexer No streams
-2013-11-06 10:18:43,559-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:18:52,990-0600 INFO  Multiplexer No streams
-2013-11-06 10:18:57,986-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:19:02,998-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:19:13,006-0600 INFO  Multiplexer No streams
-2013-11-06 10:19:15,882-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:19:23,015-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:19:33,023-0600 INFO  Multiplexer No streams
-2013-11-06 10:19:33,596-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:19:43,031-0600 INFO  Multiplexer No streams
-2013-11-06 10:19:48,205-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:19:53,039-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:20:03,047-0600 INFO  Multiplexer No streams
-2013-11-06 10:20:09,206-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:20:13,056-0600 INFO  Multiplexer No streams
-2013-11-06 10:20:20,528-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:20:23,065-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:20:33,073-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:20:43,081-0600 INFO  Multiplexer No streams
-2013-11-06 10:20:44,816-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:20:52,851-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:20:53,089-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:21:03,097-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:21:13,106-0600 INFO  Multiplexer No streams
-2013-11-06 10:21:20,427-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:21:23,114-0600 INFO  Multiplexer No streams
-2013-11-06 10:21:25,174-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:21:33,122-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:21:43,130-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:21:53,138-0600 INFO  Multiplexer No streams
-2013-11-06 10:21:56,037-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 10:21:57,497-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:22:03,146-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:22:13,155-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:22:23,163-0600 INFO  Multiplexer No streams
-2013-11-06 10:22:29,821-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-2013-11-06 10:22:31,647-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:22:33,171-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:22:43,179-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:22:53,188-0600 INFO  Multiplexer No streams
-2013-11-06 10:23:02,143-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:23:03,196-0600 INFO  Multiplexer No streams
-2013-11-06 10:23:07,260-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 10:23:13,204-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:23:23,212-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:23:33,220-0600 INFO  Multiplexer No streams
-2013-11-06 10:23:34,466-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:23:42,867-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:23:43,228-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:23:53,236-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:24:03,245-0600 INFO  Multiplexer No streams
-2013-11-06 10:24:06,789-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:24:13,253-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 10:24:18,478-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:24:23,261-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:24:33,269-0600 INFO  Multiplexer No streams
-2013-11-06 10:24:39,112-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:24:43,278-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:24:53,286-0600 INFO  Multiplexer No streams
-2013-11-06 10:24:54,088-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:25:03,294-0600 INFO  Multiplexer No streams
-2013-11-06 10:25:11,435-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:25:13,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:25:23,311-0600 INFO  Multiplexer No streams
-2013-11-06 10:25:29,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:25:33,319-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:25:43,327-0600 INFO  Multiplexer No streams
-2013-11-06 10:25:43,758-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:25:53,335-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:26:03,343-0600 INFO  Multiplexer No streams
-2013-11-06 10:26:05,308-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:26:13,351-0600 INFO  Multiplexer No streams
-2013-11-06 10:26:16,081-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:26:23,359-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:26:33,367-0600 INFO  Multiplexer No streams
-2013-11-06 10:26:40,918-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:26:43,375-0600 INFO  Multiplexer No streams
-2013-11-06 10:26:48,404-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:26:53,382-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:27:03,390-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:27:13,398-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:27:16,529-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:27:20,727-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:27:23,406-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:27:33,413-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:27:43,422-0600 INFO  Multiplexer No streams
-2013-11-06 10:27:52,138-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 10:27:53,050-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:27:53,429-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:28:03,437-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:28:13,446-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:28:23,454-0600 INFO  Multiplexer No streams
-2013-11-06 10:28:25,373-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:28:27,748-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:28:33,462-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:28:43,470-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:28:53,478-0600 INFO  Multiplexer No streams
-2013-11-06 10:28:57,696-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:29:03,358-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:29:03,486-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:29:13,494-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:29:23,503-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 10:29:30,019-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:29:33,511-0600 INFO  Multiplexer No streams
-2013-11-06 10:29:38,968-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:29:43,519-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:29:53,527-0600 INFO  Multiplexer No streams
-2013-11-06 10:30:02,342-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:30:03,535-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:30:13,543-0600 INFO  Multiplexer No streams
-2013-11-06 10:30:14,579-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:30:23,552-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:30:33,560-0600 INFO  Multiplexer No streams
-2013-11-06 10:30:34,665-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:30:43,568-0600 INFO  Multiplexer No streams
-2013-11-06 10:30:50,188-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:30:53,576-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:31:03,584-0600 INFO  Multiplexer No streams
-2013-11-06 10:31:06,988-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:31:13,592-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:31:23,599-0600 INFO  Multiplexer No streams
-2013-11-06 10:31:25,799-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:31:33,608-0600 INFO  Multiplexer No streams
-2013-11-06 10:31:39,311-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:31:43,616-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:31:53,624-0600 INFO  Multiplexer No streams
-2013-11-06 10:32:01,408-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:32:03,632-0600 INFO  Multiplexer No streams
-2013-11-06 10:32:11,634-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:32:13,640-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:32:23,648-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:32:33,656-0600 INFO  Multiplexer No streams
-2013-11-06 10:32:37,018-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:32:43,664-0600 INFO  Multiplexer No streams
-2013-11-06 10:32:43,957-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:32:53,672-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:33:03,680-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-2013-11-06 10:33:12,631-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 10:33:13,688-0600 INFO  Multiplexer No streams
-2013-11-06 10:33:16,280-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:33:23,696-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:33:33,705-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:33:43,713-0600 INFO  Multiplexer No streams
-2013-11-06 10:33:48,238-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:33:48,603-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:33:53,721-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:34:03,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:34:13,737-0600 INFO  Multiplexer No streams
-2013-11-06 10:34:20,927-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:34:23,745-0600 INFO  Multiplexer No streams
-2013-11-06 10:34:23,848-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:34:33,753-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:34:43,761-0600 INFO  Multiplexer No streams
-2013-11-06 10:34:53,249-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:34:53,770-0600 INFO  Multiplexer No streams
-2013-11-06 10:34:59,458-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:35:03,778-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:35:13,786-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:35:23,794-0600 INFO  Multiplexer No streams
-2013-11-06 10:35:25,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:35:33,803-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-2013-11-06 10:35:35,069-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-No streams
-2013-11-06 10:35:43,811-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:35:53,819-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 10:35:57,896-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 10:36:03,827-0600 INFO  Multiplexer No streams
-2013-11-06 10:36:10,678-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:36:13,835-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:36:23,843-0600 INFO  Multiplexer No streams
-2013-11-06 10:36:30,219-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:36:33,851-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:36:43,859-0600 INFO  Multiplexer No streams
-2013-11-06 10:36:46,288-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:36:53,867-0600 INFO  Multiplexer No streams
-2013-11-06 10:37:02,542-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 10:37:03,875-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:37:13,883-0600 INFO  Multiplexer No streams
-2013-11-06 10:37:21,898-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:37:23,891-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:37:33,898-0600 INFO  Multiplexer No streams
-2013-11-06 10:37:34,867-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:37:43,906-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:37:53,914-0600 INFO  Multiplexer No streams
-2013-11-06 10:37:57,508-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:38:03,922-0600 INFO  Multiplexer No streams
-2013-11-06 10:38:07,191-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:38:13,930-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:38:23,938-0600 INFO  Multiplexer No streams
-2013-11-06 10:38:33,118-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:38:33,946-0600 INFO  Multiplexer No streams
-2013-11-06 10:38:39,515-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:38:43,953-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:38:53,961-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:39:03,969-0600 INFO  Multiplexer No streams
-2013-11-06 10:39:08,728-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:39:11,839-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:39:13,977-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:39:23,985-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:39:33,993-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:39:44,001-0600 INFO  Multiplexer No streams
-2013-11-06 10:39:44,162-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:39:44,338-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:39:54,009-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:40:04,017-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:40:14,025-0600 INFO  Multiplexer No streams
-2013-11-06 10:40:16,486-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:40:19,948-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:40:24,033-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:40:34,041-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:40:44,049-0600 INFO  Multiplexer No streams
-2013-11-06 10:40:48,809-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:40:54,057-0600 INFO  Multiplexer No streams
-2013-11-06 10:40:55,559-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:41:04,065-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:41:14,074-0600 INFO  Multiplexer No streams
-2013-11-06 10:41:21,132-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:41:24,082-0600 INFO  Multiplexer No streams
-2013-11-06 10:41:31,168-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:41:34,089-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:41:44,097-0600 INFO  Multiplexer No streams
-2013-11-06 10:41:53,455-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:41:54,106-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:42:04,114-0600 INFO  Multiplexer No streams
-2013-11-06 10:42:06,778-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:42:14,122-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:42:24,130-0600 INFO  Multiplexer No streams
-2013-11-06 10:42:25,779-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:42:34,141-0600 INFO  Multiplexer No streams
-2013-11-06 10:42:42,388-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:42:44,149-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:42:54,157-0600 INFO  Multiplexer No streams
-2013-11-06 10:42:58,102-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:43:04,166-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:43:14,174-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 3ms
-2013-11-06 10:43:18,000-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 3ms
-No streams
-2013-11-06 10:43:24,182-0600 INFO  Multiplexer No streams
-2013-11-06 10:43:30,425-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:43:34,190-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:43:44,198-0600 INFO  Multiplexer No streams
-2013-11-06 10:43:53,609-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-No streams
-2013-11-06 10:43:54,206-0600 INFO  Multiplexer No streams
-2013-11-06 10:44:02,748-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:44:04,214-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:44:14,222-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:44:24,230-0600 INFO  Multiplexer No streams
-2013-11-06 10:44:29,218-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:44:34,238-0600 INFO  Multiplexer No streams
-2013-11-06 10:44:35,072-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 10:44:44,246-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:44:54,254-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:45:04,262-0600 INFO  Multiplexer No streams
-2013-11-06 10:45:04,828-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:45:07,394-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 10:45:14,270-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:45:24,278-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:45:34,286-0600 INFO  Multiplexer No streams
-2013-11-06 10:45:39,719-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:45:40,438-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:45:44,293-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:45:54,301-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:46:04,309-0600 INFO  Multiplexer No streams
-2013-11-06 10:46:12,042-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:46:14,317-0600 INFO  Multiplexer No streams
-2013-11-06 10:46:16,048-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:46:24,325-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:46:34,333-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:46:44,341-0600 INFO  Multiplexer No streams
-2013-11-06 10:46:44,365-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 10:46:51,659-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:46:54,349-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:47:04,357-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:47:14,365-0600 INFO  Multiplexer No streams
-2013-11-06 10:47:16,689-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:47:24,372-0600 INFO  Multiplexer No streams
-2013-11-06 10:47:27,269-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:47:34,380-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:47:44,388-0600 INFO  Multiplexer No streams
-2013-11-06 10:47:49,013-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:47:54,396-0600 INFO  Multiplexer No streams
-2013-11-06 10:48:02,880-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 2ms
-No streams
-2013-11-06 10:48:04,404-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:48:14,413-0600 INFO  Multiplexer No streams
-2013-11-06 10:48:21,336-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:48:24,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:48:34,428-0600 INFO  Multiplexer No streams
-2013-11-06 10:48:38,489-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:48:44,436-0600 INFO  Multiplexer No streams
-2013-11-06 10:48:53,660-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:48:54,444-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:49:04,452-0600 INFO  Multiplexer No streams
-2013-11-06 10:49:14,099-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:49:14,459-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:49:24,467-0600 INFO  Multiplexer No streams
-2013-11-06 10:49:25,983-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:49:34,475-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:49:44,483-0600 INFO  Multiplexer No streams
-2013-11-06 10:49:49,709-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:49:54,491-0600 INFO  Multiplexer No streams
-2013-11-06 10:49:58,305-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 10:50:04,499-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:50:14,507-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:50:24,515-0600 INFO  Multiplexer No streams
-2013-11-06 10:50:25,320-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:50:30,629-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:50:34,523-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:50:44,531-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:50:54,539-0600 INFO  Multiplexer No streams
-2013-11-06 10:51:00,929-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:51:02,954-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:51:04,546-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:51:14,554-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:51:24,562-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:51:34,570-0600 INFO  Multiplexer No streams
-2013-11-06 10:51:35,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:51:36,539-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:51:44,578-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:51:54,586-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:52:04,594-0600 INFO  Multiplexer No streams
-2013-11-06 10:52:07,600-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 4ms
-2013-11-06 10:52:12,152-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 4ms
-No streams
-2013-11-06 10:52:14,602-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:52:24,610-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:52:34,620-0600 INFO  Multiplexer No streams
-2013-11-06 10:52:39,923-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:52:44,627-0600 INFO  Multiplexer No streams
-2013-11-06 10:52:47,760-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:52:54,634-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:53:04,642-0600 INFO  Multiplexer No streams
-2013-11-06 10:53:12,246-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:53:14,649-0600 INFO  Multiplexer No streams
-2013-11-06 10:53:23,372-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 10:53:24,657-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:53:34,665-0600 INFO  Multiplexer No streams
-2013-11-06 10:53:44,568-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:53:44,673-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:53:54,681-0600 INFO  Multiplexer No streams
-2013-11-06 10:53:58,979-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:54:04,689-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:54:14,697-0600 INFO  Multiplexer No streams
-2013-11-06 10:54:16,892-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:54:24,705-0600 INFO  Multiplexer No streams
-2013-11-06 10:54:34,589-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:54:34,713-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:54:44,721-0600 INFO  Multiplexer No streams
-2013-11-06 10:54:49,215-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:54:54,729-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:55:04,737-0600 INFO  Multiplexer No streams
-2013-11-06 10:55:10,199-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:55:14,745-0600 INFO  Multiplexer No streams
-2013-11-06 10:55:21,538-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:55:24,752-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:55:34,760-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:55:44,768-0600 INFO  Multiplexer No streams
-2013-11-06 10:55:45,810-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:55:53,861-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:55:54,776-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:56:04,784-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:56:14,792-0600 INFO  Multiplexer No streams
-2013-11-06 10:56:21,420-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:56:24,800-0600 INFO  Multiplexer No streams
-2013-11-06 10:56:26,184-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 10:56:34,808-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:56:44,816-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:56:54,824-0600 INFO  Multiplexer No streams
-2013-11-06 10:56:57,029-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:56:58,506-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:57:04,832-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:57:14,840-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:57:24,848-0600 INFO  Multiplexer No streams
-2013-11-06 10:57:30,829-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 10:57:32,639-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:57:34,855-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:57:44,863-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:57:54,871-0600 INFO  Multiplexer No streams
-2013-11-06 10:58:03,152-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:58:04,879-0600 INFO  Multiplexer No streams
-2013-11-06 10:58:08,249-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:58:14,887-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:58:24,895-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:58:34,903-0600 INFO  Multiplexer No streams
-2013-11-06 10:58:35,476-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 10:58:43,859-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:58:44,911-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:58:54,919-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:59:04,927-0600 INFO  Multiplexer No streams
-2013-11-06 10:59:07,798-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:59:14,935-0600 INFO  Multiplexer No streams
-2013-11-06 10:59:19,469-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 10:59:24,942-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:59:34,950-0600 INFO  Multiplexer No streams
-2013-11-06 10:59:40,121-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 10:59:44,958-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 10:59:54,966-0600 INFO  Multiplexer No streams
-2013-11-06 10:59:55,079-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:00:04,974-0600 INFO  Multiplexer No streams
-2013-11-06 11:00:12,444-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:00:14,983-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:00:24,990-0600 INFO  Multiplexer No streams
-2013-11-06 11:00:30,691-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:00:34,998-0600 INFO  Multiplexer No streams
-2013-11-06 11:00:44,768-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:00:45,006-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:00:55,014-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:01:05,022-0600 INFO  Multiplexer No streams
-2013-11-06 11:01:06,300-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:01:15,030-0600 INFO  Multiplexer No streams
-2013-11-06 11:01:17,090-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:01:25,038-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:01:35,045-0600 INFO  Multiplexer No streams
-2013-11-06 11:01:41,911-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:01:45,054-0600 INFO  Multiplexer No streams
-2013-11-06 11:01:49,414-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:01:55,062-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:02:05,070-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:02:15,078-0600 INFO  Multiplexer No streams
-2013-11-06 11:02:17,520-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:02:21,737-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:02:25,086-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:02:35,094-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:02:45,102-0600 INFO  Multiplexer No streams
-2013-11-06 11:02:53,130-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:02:54,060-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:02:55,109-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:03:05,117-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:03:15,125-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:03:25,133-0600 INFO  Multiplexer No streams
-2013-11-06 11:03:26,382-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:03:28,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 11:03:35,140-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:03:45,148-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:03:55,156-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:03:58,705-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:04:04,350-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:04:05,164-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:04:15,172-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:04:25,180-0600 INFO  Multiplexer No streams
-2013-11-06 11:04:31,028-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:04:35,188-0600 INFO  Multiplexer No streams
-2013-11-06 11:04:39,960-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:04:45,196-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:04:55,205-0600 INFO  Multiplexer No streams
-2013-11-06 11:05:03,351-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:05:05,213-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:05:15,221-0600 INFO  Multiplexer No streams
-2013-11-06 11:05:15,570-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:05:25,229-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:05:35,237-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:05:35,675-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:05:45,245-0600 INFO  Multiplexer No streams
-2013-11-06 11:05:51,180-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:05:55,253-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:06:05,261-0600 INFO  Multiplexer No streams
-2013-11-06 11:06:07,997-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:06:15,269-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:06:25,276-0600 INFO  Multiplexer No streams
-2013-11-06 11:06:26,791-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:06:35,284-0600 INFO  Multiplexer No streams
-2013-11-06 11:06:40,320-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:06:45,292-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:06:55,300-0600 INFO  Multiplexer No streams
-2013-11-06 11:07:02,400-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:07:05,308-0600 INFO  Multiplexer No streams
-2013-11-06 11:07:12,643-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:07:15,316-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:07:25,324-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:07:35,332-0600 INFO  Multiplexer No streams
-2013-11-06 11:07:38,010-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:07:44,966-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:07:45,340-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:07:55,348-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:08:05,356-0600 INFO  Multiplexer No streams
-2013-11-06 11:08:13,620-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:08:15,364-0600 INFO  Multiplexer No streams
-2013-11-06 11:08:17,289-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:08:25,372-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:08:35,380-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:08:45,388-0600 INFO  Multiplexer No streams
-2013-11-06 11:08:49,230-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:08:49,612-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:08:55,396-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:09:05,404-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:09:15,412-0600 INFO  Multiplexer No streams
-2013-11-06 11:09:21,935-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:09:24,840-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:09:25,420-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:09:35,428-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:09:45,436-0600 INFO  Multiplexer No streams
-2013-11-06 11:09:54,258-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:09:55,444-0600 INFO  Multiplexer No streams
-2013-11-06 11:10:00,450-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:10:05,452-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:10:15,460-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:10:25,468-0600 INFO  Multiplexer No streams
-2013-11-06 11:10:26,582-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:10:35,475-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 11:10:36,062-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 11:10:45,483-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:10:55,491-0600 INFO  Multiplexer No streams
-2013-11-06 11:10:58,904-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:11:05,499-0600 INFO  Multiplexer No streams
-2013-11-06 11:11:11,670-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:11:15,507-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:11:25,515-0600 INFO  Multiplexer No streams
-2013-11-06 11:11:31,228-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:11:35,523-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:11:45,531-0600 INFO  Multiplexer No streams
-2013-11-06 11:11:47,280-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:11:55,539-0600 INFO  Multiplexer No streams
-2013-11-06 11:12:03,550-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:12:05,548-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:12:15,555-0600 INFO  Multiplexer No streams
-2013-11-06 11:12:22,890-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:12:25,564-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:12:35,571-0600 INFO  Multiplexer No streams
-2013-11-06 11:12:35,874-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:12:45,583-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:12:55,591-0600 INFO  Multiplexer No streams
-2013-11-06 11:12:58,500-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:13:05,599-0600 INFO  Multiplexer No streams
-2013-11-06 11:13:08,196-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:13:15,608-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:13:25,616-0600 INFO  Multiplexer No streams
-2013-11-06 11:13:34,110-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-No streams
-2013-11-06 11:13:35,624-0600 INFO  Multiplexer No streams
-2013-11-06 11:13:40,519-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:13:45,632-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:13:55,640-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:14:05,648-0600 INFO  Multiplexer No streams
-2013-11-06 11:14:09,720-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:14:12,843-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:14:15,656-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:14:25,664-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:14:35,672-0600 INFO  Multiplexer No streams
-2013-11-06 11:14:45,166-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:14:45,331-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:14:45,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:14:55,689-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:15:05,697-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:15:15,705-0600 INFO  Multiplexer No streams
-2013-11-06 11:15:17,488-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:15:20,940-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:15:25,714-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:15:35,722-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:15:45,730-0600 INFO  Multiplexer No streams
-2013-11-06 11:15:49,812-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:15:55,739-0600 INFO  Multiplexer No streams
-2013-11-06 11:15:56,551-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:16:05,747-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:16:15,756-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 11:16:22,136-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 11:16:25,764-0600 INFO  Multiplexer No streams
-2013-11-06 11:16:32,160-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:16:35,772-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:16:45,780-0600 INFO  Multiplexer No streams
-2013-11-06 11:16:54,458-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:16:55,789-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:17:05,797-0600 INFO  Multiplexer No streams
-2013-11-06 11:17:07,770-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:17:15,805-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:17:25,813-0600 INFO  Multiplexer No streams
-2013-11-06 11:17:26,780-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:17:35,821-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-11-06 11:17:43,380-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 11:17:45,829-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:17:55,837-0600 INFO  Multiplexer No streams
-2013-11-06 11:17:59,104-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:18:05,846-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:18:15,854-0600 INFO  Multiplexer No streams
-2013-11-06 11:18:18,991-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:18:25,865-0600 INFO  Multiplexer No streams
-2013-11-06 11:18:31,426-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:18:35,873-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:18:45,881-0600 INFO  Multiplexer No streams
-2013-11-06 11:18:54,603-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-No streams
-2013-11-06 11:18:55,889-0600 INFO  Multiplexer No streams
-2013-11-06 11:19:03,748-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-No streams
-2013-11-06 11:19:05,897-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:19:15,905-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:19:25,914-0600 INFO  Multiplexer No streams
-2013-11-06 11:19:30,211-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:19:35,922-0600 INFO  Multiplexer No streams
-2013-11-06 11:19:36,072-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:19:45,930-0600 INFO  Multiplexer No streams
-Shutting down service...
-Shutting down blocks
-2013-11-06 11:19:52,259-0600 INFO  BlockQueueProcessor Shutting down blocks
-Shutting down block Block crush.mcs.anl.gov (1x4611686018427388.000s)
-2013-11-06 11:19:52,260-0600 INFO  Block Shutting down block Block crush.mcs.anl.gov (1x4611686018427388.000s)
-Failed to send remote log message: BLOCK_SHUTDOWN id=crush.mcs.anl.gov
-org.globus.cog.coaster.channels.ChannelException: Channel died and no contact available
-	at org.globus.cog.coaster.channels.ChannelManager.connect(ChannelManager.java:234)
-	at org.globus.cog.coaster.channels.ChannelManager.reserveChannel(ChannelManager.java:255)
-	at org.globus.cog.coaster.channels.ChannelManager.reserveChannel(ChannelManager.java:226)
-	at org.globus.cog.abstraction.coaster.rlog.RemoteLogger.log(RemoteLogger.java:34)
-	at org.globus.cog.abstraction.coaster.service.job.manager.Block.shutdown(Block.java:283)
-	at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdownBlocks(BlockQueueProcessor.java:807)
-	at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdown(BlockQueueProcessor.java:796)
-	at org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.shutdown(JobQueue.java:119)
-	at org.globus.cog.abstraction.coaster.service.CoasterService.shutdown(CoasterService.java:303)
-	at org.globus.cog.abstraction.coaster.service.CoasterPersistentService$2.run(CoasterPersistentService.java:236)
-2013-11-06 11:19:52,260-0600 WARN  RemoteLogger Failed to send remote log message: BLOCK_SHUTDOWN id=crush.mcs.anl.gov
-Adding short shutdown watchdog: count = 1, workers = 1, now = true
-2013-11-06 11:19:52,262-0600 INFO  Block Adding short shutdown watchdog: count = 1, workers = 1, now = true
-Average utilization: 10.05%
-2013-11-06 11:19:52,262-0600 INFO  Block Average utilization: 10.05%
-Failed to send remote log message: BLOCK_UTILIZATION id=crush.mcs.anl.gov, u=10.05
-	at org.globus.cog.abstraction.coaster.service.job.manager.Block.shutdown(Block.java:317)
-2013-11-06 11:19:52,262-0600 WARN  RemoteLogger Failed to send remote log message: BLOCK_UTILIZATION id=crush.mcs.anl.gov, u=10.05
-Shutting down block Block grind.mcs.anl.gov (1x4611686018427388.000s)
-2013-11-06 11:19:52,262-0600 INFO  Block Shutting down block Block grind.mcs.anl.gov (1x4611686018427388.000s)
-Failed to send remote log message: BLOCK_SHUTDOWN id=grind.mcs.anl.gov
-2013-11-06 11:19:52,262-0600 WARN  RemoteLogger Failed to send remote log message: BLOCK_SHUTDOWN id=grind.mcs.anl.gov
-2013-11-06 11:19:52,263-0600 INFO  Block Adding short shutdown watchdog: count = 1, workers = 1, now = true
-Average utilization: 10.12%
-2013-11-06 11:19:52,263-0600 INFO  Block Average utilization: 10.12%
-Node [crush] 0 shut down successfully
-2013-11-06 11:19:52,263-0600 INFO  Node Node [crush] 0 shut down successfully
-crush.mcs.anl.gov-000000: Channel shut down
-2013-11-06 11:19:52,264-0600 INFO  AbstractTCPChannel crush.mcs.anl.gov-000000: Channel shut down
-MetaChannel [context: worker-1, boundTo: TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]] binding to NullChannel
-2013-11-06 11:19:52,264-0600 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]] binding to NullChannel
-Using threaded sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-06 11:19:52,264-0600 INFO  AbstractStreamCoasterChannel Using threaded sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-crush.mcs.anl.gov-000000: Channel terminated
-2013-11-06 11:19:52,264-0600 INFO  AbstractTCPChannel crush.mcs.anl.gov-000000: Channel terminated
-Failed to send remote log message: WORKER_SHUTDOWN blockid=crush.mcs.anl.gov
-	at org.globus.cog.abstraction.coaster.service.job.manager.Node.replyReceived(Node.java:110)
-	at org.globus.cog.coaster.commands.Command.receiveCompleted(Command.java:181)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleReply(AbstractCoasterChannel.java:425)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:234)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
-2013-11-06 11:19:52,264-0600 WARN  RemoteLogger Failed to send remote log message: WORKER_SHUTDOWN blockid=crush.mcs.anl.gov
-Node [grind] 0 shut down successfully
-2013-11-06 11:19:52,264-0600 INFO  Node Node [grind] 0 shut down successfully
-grind.mcs.anl.gov-000000: Channel shut down
-2013-11-06 11:19:52,265-0600 INFO  AbstractTCPChannel grind.mcs.anl.gov-000000: Channel shut down
-MetaChannel [context: worker-2, boundTo: TCPChannel [type: server, contact: grind.mcs.anl.gov-000000]] binding to NullChannel
-2013-11-06 11:19:52,265-0600 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: TCPChannel [type: server, contact: grind.mcs.anl.gov-000000]] binding to NullChannel
-grind.mcs.anl.gov-000000: Channel terminated
-2013-11-06 11:19:52,265-0600 INFO  AbstractTCPChannel grind.mcs.anl.gov-000000: Channel terminated
-Failed to send remote log message: WORKER_SHUTDOWN blockid=grind.mcs.anl.gov
-2013-11-06 11:19:52,265-0600 WARN  RemoteLogger Failed to send remote log message: WORKER_SHUTDOWN blockid=grind.mcs.anl.gov
-Failed to send remote log message: BLOCK_UTILIZATION id=grind.mcs.anl.gov, u=10.12
-2013-11-06 11:19:52,265-0600 WARN  RemoteLogger Failed to send remote log message: BLOCK_UTILIZATION id=grind.mcs.anl.gov, u=10.12
-Shutdown sequence completed
-2013-11-06 11:19:52,266-0600 INFO  CoasterService Shutdown sequence completed
-Running /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/coaster-service -nosec -port 53001 -localportfile /tmp/tmp.UbM76n032n -passive
-Switching log to: cps-2013-11-06_11-19-56.log
-2013-11-06 11:19:56,077-0600 WARN  CoasterPersistentService Switching log to: cps-2013-11-06_11-19-56.log
-Local contacts: [http://140.221.8.81:36437]
-2013-11-06 11:19:56,107-0600 INFO  Settings Local contacts: [http://140.221.8.81:36437]
-Starting... id=1106-1911560
-2013-11-06 11:19:56,120-0600 INFO  BlockQueueProcessor Starting... id=1106-1911560
-Started local service: http://140.221.8.81:36437
-2013-11-06 11:19:56,121-0600 INFO  CoasterService Started local service: http://140.221.8.81:36437
-Started coaster service: http://140.221.8.81:53001
-2013-11-06 11:19:56,121-0600 INFO  CoasterService Started coaster service: http://140.221.8.81:53001
-Worker connection URL: http://140.221.8.81:36437
-Running ssh yadunand at crush.mcs.anl.gov mkdir -p /homes/yadunand
-Running scp /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/worker.pl yadunand at crush.mcs.anl.gov:/homes/yadunand
-Running ssh yadunand at crush.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:36437 crush.mcs.anl.gov /homes/yadunand/logs
-Running ssh yadunand at grind.mcs.anl.gov mkdir -p /homes/yadunand
-Running scp /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/worker.pl yadunand at grind.mcs.anl.gov:/homes/yadunand
-Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-11-06 11:19:58,142-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.62:40901]
-2013-11-06 11:19:58,146-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.62:40901]
-Received registration: blockid = crush.mcs.anl.gov, url = crush
-2013-11-06 11:19:58,151-0600 INFO  LocalTCPService Received registration: blockid = crush.mcs.anl.gov, url = crush
-MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:40901]
-2013-11-06 11:19:58,163-0600 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:40901]
-2013-11-06 11:19:58,166-0600 DEBUG Cpu worker started: block=crush.mcs.anl.gov host=crush id=0
-2013-11-06 11:19:58,166-0600 DEBUG Cpu ready for work: block=crush.mcs.anl.gov id=0
-Started CPU 0:1383758398s
-2013-11-06 11:19:58,168-0600 INFO  Block Started CPU 0:1383758398s
-Started worker crush.mcs.anl.gov:000000
-2013-11-06 11:19:58,168-0600 INFO  Block Started worker crush.mcs.anl.gov:000000
-2013-11-06 11:19:58,168-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-06 11:19:58,168-0600 INFO  AbstractStreamCoasterChannel Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-11-06 11:19:58,169-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-Handler(tag: 32, REGISTER) unregistering (send)
-2013-11-06 11:19:58,172-0600 INFO  RequestHandler Handler(tag: 32, REGISTER) unregistering (send)
-Running ssh yadunand at grind.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:36437 grind.mcs.anl.gov /homes/yadunand/logs
-Adjusting buffer size to 8650752 for 2 sockets
-2013-11-06 11:19:58,850-0600 INFO  TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
-2013-11-06 11:19:58,850-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.74:51796]
-2013-11-06 11:19:58,851-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.74:51796]
-Received registration: blockid = grind.mcs.anl.gov, url = grind
-2013-11-06 11:19:58,851-0600 INFO  LocalTCPService Received registration: blockid = grind.mcs.anl.gov, url = grind
-MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:51796]
-2013-11-06 11:19:58,851-0600 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:51796]
-2013-11-06 11:19:58,851-0600 DEBUG Cpu worker started: block=grind.mcs.anl.gov host=grind id=0
-2013-11-06 11:19:58,851-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 11:19:58,852-0600 INFO  Block Started CPU 0:1383758398s
-2013-11-06 11:19:58,852-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Started worker grind.mcs.anl.gov:000000
-2013-11-06 11:19:58,852-0600 INFO  Block Started worker grind.mcs.anl.gov:000000
-2013-11-06 11:19:58,852-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Handler(tag: 7333, REGISTER) unregistering (send)
-2013-11-06 11:19:58,852-0600 INFO  RequestHandler Handler(tag: 7333, REGISTER) unregistering (send)
-2013-11-06 11:20:31,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:20:32,288-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:21:08,762-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:21:09,057-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:21:45,235-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:21:46,375-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:22:21,710-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:22:23,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:22:58,183-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:23:01,011-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:23:34,657-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:23:38,329-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:24:11,131-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:24:15,647-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:24:47,606-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:24:52,965-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:25:24,080-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:25:30,283-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:26:00,553-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:26:07,601-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:26:37,027-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:26:44,919-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:27:13,502-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:27:22,237-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:27:49,975-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:27:59,555-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:28:26,449-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:28:36,873-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:29:02,923-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:29:14,191-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:29:39,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:29:51,509-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:30:15,872-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-11-06 11:30:28,827-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:30:52,346-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:31:06,145-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:31:28,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:31:43,463-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:32:05,294-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:32:20,781-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:32:41,768-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:32:58,099-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:33:18,242-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:33:35,417-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:33:54,717-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 11:34:12,735-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 11:34:31,190-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:34:34,308-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36979] for addition
-2013-11-06 11:34:34,311-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36979] for addition
-Multiplexer 0 started
-2013-11-06 11:34:34,311-0600 INFO  Multiplexer Multiplexer 0 started
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36979]
-2013-11-06 11:34:34,311-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36979]
-Multiplexer 1 started
-2013-11-06 11:34:34,311-0600 INFO  Multiplexer Multiplexer 1 started
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--8000
-2013-11-06 11:34:34,333-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--8000
-MetaChannel [context: cps-36979, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36979]
-2013-11-06 11:34:34,333-0600 INFO  MetaChannel MetaChannel [context: cps-36979, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36979]
-Using threaded sender for TCPChannel [type: server, contact: 127.0.0.1:36979]
-2013-11-06 11:34:34,334-0600 INFO  AbstractStreamCoasterChannel Using threaded sender for TCPChannel [type: server, contact: 127.0.0.1:36979]
-Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:34:34,334-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 11:34:34,376-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-org.globus.cog.coaster.ProtocolException: Invalid line:
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler$Helper.scan(SubmitJobHandler.java:312)
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler$Helper.read(SubmitJobHandler.java:270)
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler.read(SubmitJobHandler.java:97)
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler.requestComplete(SubmitJobHandler.java:61)
-	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:173)
-	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
-Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-org.globus.cog.coaster.ProtocolException: Could not deserialize job description
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler.requestComplete(SubmitJobHandler.java:71)
-Caused by: org.globus.cog.coaster.ProtocolException: Invalid line:
-	... 4 more
-2013-11-06 11:34:34,466-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 11:34:34,477-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-Avg stream buf: 0
-2013-11-06 11:34:44,328-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:34:50,053-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:34:54,339-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:35:04,350-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:35:07,664-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:35:14,361-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:35:24,372-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:35:27,371-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:35:34,380-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:35:44,138-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:35:44,388-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:35:54,398-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:36:04,407-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:36:04,689-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:36:14,416-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:36:20,612-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:36:24,425-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:36:34,434-0600 INFO  Multiplexer Avg stream buf: 0
-Notifying commands and handlers about exception
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-113434.459, now=131106-113635.309, channel=TCPChannel [type: server, contact: 127.0.0.1:36979]
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
-	at java.util.TimerThread.mainLoop(Timer.java:534)
-	at java.util.TimerThread.run(Timer.java:484)
-2013-11-06 11:36:35,309-0600 INFO  ChannelContext Notifying commands and handlers about exception
-Channel config: null -> {keepalive=null}
-2013-11-06 11:36:35,309-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36979] handling channel exception
-2013-11-06 11:36:35,309-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36979] handling channel exception
-null: Channel shut down
-2013-11-06 11:36:35,310-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36979, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36979]] binding to NullChannel
-2013-11-06 11:36:35,313-0600 INFO  MetaChannel MetaChannel [context: cps-36979, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36979]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36979]
-2013-11-06 11:36:35,313-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36979]
-2013-11-06 11:36:35,313-0600 INFO  ChannelContext Notifying commands and handlers about exception
-Channel exception handled
-2013-11-06 11:36:35,313-0600 INFO  ChannelManager Channel exception handled
-Channel is closed. Removing.
-2013-11-06 11:36:35,317-0600 INFO  Multiplexer Channel is closed. Removing.
-Exception in channel step
-java.io.IOException: Stream closed.
-	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
-	at java.net.SocketInputStream.available(SocketInputStream.java:234)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
-2013-11-06 11:36:35,317-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:36:35,317-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:36:35,317-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36979] handling channel exception
-Channel already shut down
-2013-11-06 11:36:35,318-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36979]
-2013-11-06 11:36:35,318-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36979]
-2013-11-06 11:36:42,007-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:36:44,443-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:36:54,451-0600 INFO  Multiplexer No streams
-2013-11-06 11:36:57,086-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:37:04,459-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:37:14,467-0600 INFO  Multiplexer No streams
-2013-11-06 11:37:19,326-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 11:37:24,475-0600 INFO  Multiplexer No streams
-2013-11-06 11:37:33,561-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:37:34,483-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:37:44,491-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:37:54,498-0600 INFO  Multiplexer No streams
-2013-11-06 11:37:56,643-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:38:04,506-0600 INFO  Multiplexer No streams
-2013-11-06 11:38:10,035-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:38:14,513-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:38:24,521-0600 INFO  Multiplexer No streams
-2013-11-06 11:38:33,961-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 11:38:34,529-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:38:44,536-0600 INFO  Multiplexer No streams
-2013-11-06 11:38:46,510-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:38:54,544-0600 INFO  Multiplexer No streams
-2013-11-06 11:39:03,519-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36980] for addition
-2013-11-06 11:39:03,519-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36980] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36980]
-2013-11-06 11:39:03,519-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36980]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fff
-2013-11-06 11:39:03,550-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fff
-MetaChannel [context: cps-36980, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36980]
-2013-11-06 11:39:03,550-0600 INFO  MetaChannel MetaChannel [context: cps-36980, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36980]
-2013-11-06 11:39:03,550-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:39:03,591-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-Sender TCPChannel queue size: 0
-2013-11-06 11:39:03,591-0600 INFO  Sender Sender TCPChannel queue size: 0
-	... 4 more
-2013-11-06 11:39:03,672-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-2013-11-06 11:39:03,673-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-Avg stream buf: 0
-2013-11-06 11:39:04,555-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:39:11,280-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:39:14,564-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:39:22,984-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:39:24,573-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:39:34,583-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:39:44,592-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:39:48,597-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:39:54,600-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:39:55,502-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36981] for addition
-2013-11-06 11:39:55,503-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36981] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36981]
-2013-11-06 11:39:55,503-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36981]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffe
-2013-11-06 11:39:55,524-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffe
-MetaChannel [context: cps-36981, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36981]
-2013-11-06 11:39:55,524-0600 INFO  MetaChannel MetaChannel [context: cps-36981, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36981]
-2013-11-06 11:39:55,525-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:39:55,565-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 11:39:55,565-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 11:39:55,653-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 11:39:55,682-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 1.0) submitting urn:job-0-1383759274468-1383759274469: /bin/echo
-2013-11-06 11:39:55,683-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 1.0) submitting urn:job-0-1383759274468-1383759274469: /bin/echo
-2013-11-06 11:39:55,687-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 11:39:55,687-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-LOG: /homes/yadunand/logs/worker-grind.mcs.anl.gov.log
-2013-11-06 11:39:55,696-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7334, JOBSTATUS) unregistering (send)
-2013-11-06 11:39:55,697-0600 INFO  RequestHandler Handler(tag: 7334, JOBSTATUS) unregistering (send)
-2013-11-06 11:39:55,703-0600 DEBUG Cpu Completed
-grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 11:39:55,703-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 11:39:55,703-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7335, JOBSTATUS) unregistering (send)
-2013-11-06 11:39:55,704-0600 INFO  RequestHandler Handler(tag: 7335, JOBSTATUS) unregistering (send)
-2013-11-06 11:39:55,704-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 11:39:55,704-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 11:39:59,458-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:40:04,601-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:40:14,612-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:40:24,623-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:40:25,915-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:40:34,633-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:40:35,934-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-Avg stream buf: 0
-2013-11-06 11:40:44,643-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:40:54,653-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:41:03,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-113903.671, now=131106-114104.519, channel=TCPChannel [type: server, contact: 127.0.0.1:36980]
-2013-11-06 11:41:04,519-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:41:04,520-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36980] handling channel exception
-2013-11-06 11:41:04,520-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36980] handling channel exception
-2013-11-06 11:41:04,520-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36980, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36980]] binding to NullChannel
-2013-11-06 11:41:04,520-0600 INFO  MetaChannel MetaChannel [context: cps-36980, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36980]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36980]
-2013-11-06 11:41:04,520-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36980]
-2013-11-06 11:41:04,520-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:41:04,521-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:41:04,522-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:41:04,522-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:41:04,523-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:41:04,523-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36980] handling channel exception
-2013-11-06 11:41:04,523-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36980]
-2013-11-06 11:41:04,523-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36980]
-Avg stream buf: 0
-2013-11-06 11:41:04,664-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:41:12,406-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:41:14,672-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:41:24,681-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:41:34,690-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:41:40,551-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:41:44,699-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:41:48,880-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:41:54,708-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-113955.645, now=131106-114156.502, channel=TCPChannel [type: server, contact: 127.0.0.1:36981]
-2013-11-06 11:41:56,502-0600 INFO  ChannelContext Notifying commands and handlers about exception
-=> Command(tag: 1, RLOG)
-2013-11-06 11:41:56,502-0600 INFO  ChannelContext => Command(tag: 1, RLOG)
-=> Command(tag: 2, JOBSTATUS)
-2013-11-06 11:41:56,502-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-Client could not properly process notification: null
-2013-11-06 11:41:56,503-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 3, JOBSTATUS)
-2013-11-06 11:41:56,503-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-=> Command(tag: 4, JOBSTATUS)
-2013-11-06 11:41:56,503-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-=> Command(tag: 5, JOBSTATUS)
-2013-11-06 11:41:56,504-0600 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
-2013-11-06 11:41:56,504-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 11:41:56,504-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36981] handling channel exception
-2013-11-06 11:41:56,504-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36981] handling channel exception
-2013-11-06 11:41:56,504-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36981, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36981]] binding to NullChannel
-2013-11-06 11:41:56,505-0600 INFO  MetaChannel MetaChannel [context: cps-36981, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36981]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36981]
-2013-11-06 11:41:56,505-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36981]
-2013-11-06 11:41:56,505-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:41:56,505-0600 INFO  ChannelContext => Command(tag: 1, RLOG)
-2013-11-06 11:41:56,505-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 11:41:56,505-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 11:41:56,505-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 11:41:56,506-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 11:41:56,506-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 11:41:56,506-0600 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
-2013-11-06 11:41:56,506-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:41:56,513-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:41:56,513-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:41:56,514-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:41:56,514-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36981] handling channel exception
-2013-11-06 11:41:56,514-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36981]
-2013-11-06 11:41:56,514-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36981]
-No streams
-2013-11-06 11:42:04,717-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:42:14,726-0600 INFO  Multiplexer No streams
-2013-11-06 11:42:17,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:42:24,734-0600 INFO  Multiplexer No streams
-2013-11-06 11:42:25,354-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:42:34,742-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:42:44,751-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:42:54,759-0600 INFO  Multiplexer No streams
-2013-11-06 11:42:55,187-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:43:01,828-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:43:04,767-0600 INFO  Multiplexer No streams
-2013-11-06 11:43:12,592-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36982] for addition
-2013-11-06 11:43:12,592-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36982] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36982]
-2013-11-06 11:43:12,592-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36982]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffd
-2013-11-06 11:43:12,630-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffd
-MetaChannel [context: cps-36982, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36982]
-2013-11-06 11:43:12,630-0600 INFO  MetaChannel MetaChannel [context: cps-36982, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36982]
-2013-11-06 11:43:12,631-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:43:12,651-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 11:43:12,651-0600 INFO  Sender Sender TCPChannel queue size: 0
-	... 4 more
-2013-11-06 11:43:12,732-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-2013-11-06 11:43:12,733-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-Avg stream buf: 0
-2013-11-06 11:43:14,779-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:43:24,788-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 11:43:32,505-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-Avg stream buf: 0
-2013-11-06 11:43:34,796-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:43:38,302-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:43:44,804-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:43:54,813-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:44:04,821-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:44:09,824-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:44:14,776-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:44:14,829-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:44:24,836-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:44:34,844-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:44:44,852-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:44:47,142-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:44:51,250-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:44:54,860-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:45:04,868-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-114312.731, now=131106-114513.592, channel=TCPChannel [type: server, contact: 127.0.0.1:36982]
-2013-11-06 11:45:13,592-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:45:13,592-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36982] handling channel exception
-2013-11-06 11:45:13,593-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36982] handling channel exception
-2013-11-06 11:45:13,593-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36982, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36982]] binding to NullChannel
-2013-11-06 11:45:13,593-0600 INFO  MetaChannel MetaChannel [context: cps-36982, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36982]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36982]
-2013-11-06 11:45:13,593-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36982]
-2013-11-06 11:45:13,593-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:45:13,593-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:45:13,612-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:45:13,612-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:45:13,612-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:45:13,612-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36982] handling channel exception
-2013-11-06 11:45:13,612-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36982]
-2013-11-06 11:45:13,613-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36982]
-No streams
-2013-11-06 11:45:14,876-0600 INFO  Multiplexer No streams
-2013-11-06 11:45:24,460-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 11:45:24,883-0600 INFO  Multiplexer No streams
-2013-11-06 11:45:27,724-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:45:34,891-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:45:44,898-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:45:54,905-0600 INFO  Multiplexer No streams
-2013-11-06 11:46:01,778-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:46:04,198-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:46:04,913-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:46:14,920-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:46:24,927-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:46:34,935-0600 INFO  Multiplexer No streams
-2013-11-06 11:46:39,096-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 11:46:40,672-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:46:44,942-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:46:54,950-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:47:04,957-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:47:14,964-0600 INFO  Multiplexer No streams
-2013-11-06 11:47:16,414-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:47:17,147-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:47:24,972-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:47:34,979-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:47:44,987-0600 INFO  Multiplexer No streams
-2013-11-06 11:47:53,620-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:47:53,732-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:47:54,996-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:48:05,004-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:48:15,012-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:48:25,020-0600 INFO  Multiplexer No streams
-2013-11-06 11:48:30,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:48:31,050-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:48:35,028-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:48:45,036-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:48:55,044-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:49:05,052-0600 INFO  Multiplexer No streams
-2013-11-06 11:49:06,568-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:49:08,368-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:49:15,060-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:49:25,067-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:49:35,075-0600 INFO  Multiplexer No streams
-2013-11-06 11:49:43,043-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 11:49:45,083-0600 INFO  Multiplexer No streams
-2013-11-06 11:49:45,686-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:49:55,091-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:50:05,099-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:50:15,107-0600 INFO  Multiplexer No streams
-2013-11-06 11:50:19,517-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:50:23,004-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:50:25,115-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:50:35,123-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:50:45,130-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:50:55,138-0600 INFO  Multiplexer No streams
-2013-11-06 11:50:55,991-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:50:57,680-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36983] for addition
-2013-11-06 11:50:57,680-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36983] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36983]
-2013-11-06 11:50:57,680-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36983]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffc
-2013-11-06 11:50:57,706-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffc
-MetaChannel [context: cps-36983, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36983]
-2013-11-06 11:50:57,707-0600 INFO  MetaChannel MetaChannel [context: cps-36983, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36983]
-2013-11-06 11:50:57,707-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:50:57,747-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 11:50:57,747-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-	... 4 more
-2013-11-06 11:50:57,828-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-2013-11-06 11:50:57,829-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 11:51:00,322-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:51:05,150-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:51:15,158-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:51:25,166-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:51:32,464-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:51:35,175-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:51:37,640-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:51:45,183-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:51:55,191-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:52:05,200-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:52:08,939-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 11:52:11,733-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36989] for addition
-2013-11-06 11:52:11,733-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36989] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36989]
-2013-11-06 11:52:11,733-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36989]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffb
-2013-11-06 11:52:11,760-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffb
-MetaChannel [context: cps-36989, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36989]
-2013-11-06 11:52:11,760-0600 INFO  MetaChannel MetaChannel [context: cps-36989, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36989]
-2013-11-06 11:52:11,760-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:52:11,801-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 11:52:11,801-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-	... 4 more
-2013-11-06 11:52:11,882-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-2013-11-06 11:52:11,883-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 11:52:14,958-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:52:15,212-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:52:25,217-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:52:35,218-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:52:45,228-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:52:45,412-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:52:52,276-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:52:55,238-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-115057.828, now=131106-115258.681, channel=TCPChannel [type: server, contact: 127.0.0.1:36983]
-2013-11-06 11:52:58,681-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:52:58,681-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36983] handling channel exception
-2013-11-06 11:52:58,681-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36983] handling channel exception
-2013-11-06 11:52:58,682-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36983, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36983]] binding to NullChannel
-2013-11-06 11:52:58,682-0600 INFO  MetaChannel MetaChannel [context: cps-36983, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36983]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36983]
-2013-11-06 11:52:58,682-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36983]
-2013-11-06 11:52:58,682-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:52:58,682-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:52:58,688-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:52:58,688-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:52:58,688-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:52:58,688-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36983] handling channel exception
-2013-11-06 11:52:58,689-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36983]
-2013-11-06 11:52:58,689-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36983]
-Avg stream buf: 0
-2013-11-06 11:53:05,248-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:53:15,256-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:53:21,886-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:53:25,265-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:53:29,594-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:53:35,273-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:53:45,281-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:53:55,289-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:53:58,360-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:54:05,297-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:54:06,912-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-115211.881, now=131106-115412.734, channel=TCPChannel [type: server, contact: 127.0.0.1:36989]
-2013-11-06 11:54:12,734-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:54:12,734-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36989] handling channel exception
-2013-11-06 11:54:12,734-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36989] handling channel exception
-2013-11-06 11:54:12,735-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36989, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36989]] binding to NullChannel
-2013-11-06 11:54:12,735-0600 INFO  MetaChannel MetaChannel [context: cps-36989, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36989]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36989]
-2013-11-06 11:54:12,735-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36989]
-2013-11-06 11:54:12,735-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:54:12,735-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:54:12,738-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:54:12,738-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:54:12,738-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:54:12,739-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36989] handling channel exception
-2013-11-06 11:54:12,739-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36989]
-2013-11-06 11:54:12,739-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36989]
-No streams
-2013-11-06 11:54:15,306-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:54:25,313-0600 INFO  Multiplexer No streams
-2013-11-06 11:54:34,834-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:54:35,321-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 11:54:44,231-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 11:54:45,328-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:54:55,336-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:55:05,343-0600 INFO  Multiplexer No streams
-2013-11-06 11:55:11,308-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:55:15,351-0600 INFO  Multiplexer No streams
-2013-11-06 11:55:21,548-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 11:55:25,358-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 11:55:35,366-0600 INFO  Multiplexer No streams
-2013-11-06 11:55:37,527-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36990] for addition
-2013-11-06 11:55:37,527-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36990] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36990]
-2013-11-06 11:55:37,527-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36990]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffa
-2013-11-06 11:55:37,552-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ffa
-MetaChannel [context: cps-36990, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36990]
-2013-11-06 11:55:37,552-0600 INFO  MetaChannel MetaChannel [context: cps-36990, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36990]
-Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:55:37,553-0600 INFO  RequestHandler Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-Avg stream buf: 0
-2013-11-06 11:55:45,375-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:55:47,783-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 11:55:55,383-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:55:58,866-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 11:56:03,523-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36991] for addition
-2013-11-06 11:56:03,523-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36991] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36991]
-2013-11-06 11:56:03,524-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36991]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff9
-2013-11-06 11:56:03,546-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff9
-MetaChannel [context: cps-36991, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36991]
-2013-11-06 11:56:03,546-0600 INFO  MetaChannel MetaChannel [context: cps-36991, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36991]
-2013-11-06 11:56:03,546-0600 INFO  RequestHandler Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:56:03,547-0600 INFO  Sender Sender TCPChannel queue size: 0
-Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
-2013-11-06 11:56:03,587-0600 INFO  RequestHandler Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
-2013-11-06 11:56:03,587-0600 INFO  Sender Sender TCPChannel queue size: 0
-Avg stream buf: 0
-2013-11-06 11:56:05,392-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:56:15,401-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 11:56:24,258-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-Avg stream buf: 0
-2013-11-06 11:56:25,410-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:56:35,419-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:56:36,185-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:56:45,428-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:56:55,436-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:57:00,730-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:57:05,445-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:57:13,502-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:57:15,453-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:57:25,461-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:57:35,470-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 11:57:37,205-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-115537.552, now=131106-115738.527, channel=TCPChannel [type: server, contact: 127.0.0.1:36990]
-2013-11-06 11:57:38,527-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:57:38,528-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36990] handling channel exception
-2013-11-06 11:57:38,528-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36990] handling channel exception
-2013-11-06 11:57:38,528-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36990, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36990]] binding to NullChannel
-2013-11-06 11:57:38,528-0600 INFO  MetaChannel MetaChannel [context: cps-36990, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36990]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36990]
-2013-11-06 11:57:38,528-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36990]
-2013-11-06 11:57:38,529-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:57:38,529-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:57:38,538-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:57:38,539-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:57:38,539-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:57:38,539-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36990] handling channel exception
-2013-11-06 11:57:38,539-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36990]
-2013-11-06 11:57:38,539-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36990]
-Avg stream buf: 0
-2013-11-06 11:57:45,479-0600 INFO  Multiplexer Avg stream buf: 0
-Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-11-06 11:57:45,839-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36992] for addition
-2013-11-06 11:57:45,839-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36992] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36992]
-2013-11-06 11:57:45,839-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36992]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff8
-2013-11-06 11:57:45,860-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff8
-MetaChannel [context: cps-36992, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36992]
-2013-11-06 11:57:45,861-0600 INFO  MetaChannel MetaChannel [context: cps-36992, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36992]
-2013-11-06 11:57:45,861-0600 INFO  RequestHandler Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-2013-11-06 11:57:45,901-0600 INFO  RequestHandler Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
-2013-11-06 11:57:45,901-0600 INFO  Sender Sender TCPChannel queue size: 0
-Handler(tag: 17769, SUBMITJOB) unregistering (send)
-2013-11-06 11:57:45,982-0600 INFO  RequestHandler Handler(tag: 17769, SUBMITJOB) unregistering (send)
-2013-11-06 11:57:46,008-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 2.0) submitting urn:job-0-1383759274480-1383759274481: /bin/bash /homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/wrapper.sh
-2013-11-06 11:57:46,008-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 2.0) submitting urn:job-0-1383759274480-1383759274481: /bin/bash /homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/wrapper.sh
-2013-11-06 11:57:46,009-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 11:57:46,009-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 11:57:46,015-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7336, JOBSTATUS) unregistering (send)
-2013-11-06 11:57:46,016-0600 INFO  RequestHandler Handler(tag: 7336, JOBSTATUS) unregistering (send)
-2013-11-06 11:57:50,820-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:57:51,326-0600 DEBUG Cpu Completed
-2013-11-06 11:57:51,326-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 11:57:51,326-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 11:57:51,326-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7337, JOBSTATUS) unregistering (send)
-2013-11-06 11:57:51,326-0600 INFO  RequestHandler Handler(tag: 7337, JOBSTATUS) unregistering (send)
-2013-11-06 11:57:51,326-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 11:57:55,482-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-115603.587, now=131106-115804.523, channel=TCPChannel [type: server, contact: 127.0.0.1:36991]
-2013-11-06 11:58:04,523-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:58:04,523-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36991] handling channel exception
-2013-11-06 11:58:04,524-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36991] handling channel exception
-2013-11-06 11:58:04,524-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36991, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36991]] binding to NullChannel
-2013-11-06 11:58:04,524-0600 INFO  MetaChannel MetaChannel [context: cps-36991, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36991]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36991]
-2013-11-06 11:58:04,524-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36991]
-2013-11-06 11:58:04,524-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:58:04,524-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:58:04,527-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:58:04,527-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:58:04,527-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:58:04,527-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36991] handling channel exception
-2013-11-06 11:58:04,527-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36991]
-2013-11-06 11:58:04,527-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36991]
-Avg stream buf: 0
-2013-11-06 11:58:05,490-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:58:13,679-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 11:58:15,498-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:58:25,507-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:58:28,138-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:58:35,515-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:58:45,524-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 11:58:50,153-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:58:55,533-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:59:05,456-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:59:05,541-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:59:15,550-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 11:59:25,559-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:59:26,626-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:59:35,568-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 11:59:42,774-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 11:59:45,577-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-115745.981, now=131106-115946.839, channel=TCPChannel [type: server, contact: 127.0.0.1:36992]
-2013-11-06 11:59:46,839-0600 INFO  ChannelContext Notifying commands and handlers about exception
-=> Command(tag: 1, JOBSTATUS)
-2013-11-06 11:59:46,840-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 11:59:46,840-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 11:59:46,840-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 11:59:46,840-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 11:59:46,841-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 11:59:46,841-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 11:59:46,841-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36992] handling channel exception
-2013-11-06 11:59:46,841-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36992] handling channel exception
-2013-11-06 11:59:46,841-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36992, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36992]] binding to NullChannel
-2013-11-06 11:59:46,841-0600 INFO  MetaChannel MetaChannel [context: cps-36992, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36992]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36992]
-2013-11-06 11:59:46,842-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36992]
-2013-11-06 11:59:46,842-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 11:59:46,842-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 11:59:46,842-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 11:59:46,842-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 11:59:46,842-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 11:59:46,843-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 11:59:46,843-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 11:59:46,843-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 11:59:46,860-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 11:59:46,860-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 11:59:46,861-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 11:59:46,861-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36992] handling channel exception
-2013-11-06 11:59:46,861-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36992]
-2013-11-06 11:59:46,861-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36992]
-No streams
-2013-11-06 11:59:55,585-0600 INFO  Multiplexer No streams
-2013-11-06 12:00:03,100-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:00:05,593-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:00:15,601-0600 INFO  Multiplexer No streams
-2013-11-06 12:00:20,092-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:00:25,609-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:00:35,617-0600 INFO  Multiplexer No streams
-2013-11-06 12:00:39,574-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:00:42,837-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36993] for addition
-2013-11-06 12:00:42,838-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36993] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36993]
-2013-11-06 12:00:42,838-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36993]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff7
-2013-11-06 12:00:42,878-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff7
-MetaChannel [context: cps-36993, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36993]
-2013-11-06 12:00:42,879-0600 INFO  MetaChannel MetaChannel [context: cps-36993, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36993]
-Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:00:42,879-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:00:42,899-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:00:42,899-0600 INFO  Sender Sender TCPChannel queue size: 0
-org.globus.cog.coaster.ProtocolException: Invalid line:
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler$Helper.scan(SubmitJobHandler.java:312)
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler$Helper.read(SubmitJobHandler.java:270)
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler.read(SubmitJobHandler.java:97)
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler.requestComplete(SubmitJobHandler.java:61)
-	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:173)
-	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
-Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-org.globus.cog.coaster.ProtocolException: Could not deserialize job description
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler.requestComplete(SubmitJobHandler.java:71)
-Caused by: org.globus.cog.coaster.ProtocolException: Invalid line:
-	... 4 more
-2013-11-06 12:00:42,980-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:00:42,981-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-Avg stream buf: 0
-2013-11-06 12:00:45,629-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:00:55,638-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:00:57,410-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:01:05,646-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:01:15,655-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:01:16,049-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:01:25,664-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:01:34,728-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:01:35,610-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36994] for addition
-2013-11-06 12:01:35,610-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36994] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:01:35,610-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36994]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff6
-2013-11-06 12:01:35,640-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff6
-MetaChannel [context: cps-36994, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:01:35,640-0600 INFO  MetaChannel MetaChannel [context: cps-36994, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:01:35,640-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-Avg stream buf: 27
-2013-11-06 12:01:35,681-0600 INFO  Multiplexer Avg stream buf: 27
-2013-11-06 12:01:35,681-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:01:35,681-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:01:35,762-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:01:35,777-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 3.0) submitting urn:job-0-1383759274486-1383759274487: /bin/echo
-2013-11-06 12:01:35,777-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 3.0) submitting urn:job-0-1383759274486-1383759274487: /bin/echo
-2013-11-06 12:01:35,777-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:01:35,778-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:01:35,785-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7338, JOBSTATUS) unregistering (send)
-2013-11-06 12:01:35,785-0600 INFO  RequestHandler Handler(tag: 7338, JOBSTATUS) unregistering (send)
-2013-11-06 12:01:35,788-0600 DEBUG Cpu Completed
-2013-11-06 12:01:35,788-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:01:35,788-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:01:35,788-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7339, JOBSTATUS) unregistering (send)
-2013-11-06 12:01:35,788-0600 INFO  RequestHandler Handler(tag: 7339, JOBSTATUS) unregistering (send)
-2013-11-06 12:01:35,788-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 12:01:45,691-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:01:52,523-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:01:55,699-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:02:05,708-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:02:12,046-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:02:15,716-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:02:25,724-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:02:28,997-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:02:35,732-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:02:39,504-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36995] for addition
-2013-11-06 12:02:39,504-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36995] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:02:39,504-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36995]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff5
-2013-11-06 12:02:39,544-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff5
-MetaChannel [context: cps-36995, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:02:39,544-0600 INFO  MetaChannel MetaChannel [context: cps-36995, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:02:39,544-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:02:39,564-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-Sender TCPChannel queue size: 0
-2013-11-06 12:02:39,564-0600 INFO  Sender Sender TCPChannel queue size: 0
-	at org.globus.cog.abstraction.coaster.service.SubmitJobHandler.read(SubmitJobHandler.java:95)
-	... 4 more
-2013-11-06 12:02:39,645-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-2013-11-06 12:02:39,646-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-Notifying commands and handlers about exception
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-120042.980, now=131106-120243.838, channel=TCPChannel [type: server, contact: 127.0.0.1:36993]
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
-	at java.util.TimerThread.mainLoop(Timer.java:534)
-	at java.util.TimerThread.run(Timer.java:484)
-2013-11-06 12:02:43,838-0600 INFO  ChannelContext Notifying commands and handlers about exception
-Channel config: null -> {keepalive=null}
-2013-11-06 12:02:43,839-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36993] handling channel exception
-2013-11-06 12:02:43,839-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36993] handling channel exception
-null: Channel shut down
-2013-11-06 12:02:43,839-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36993, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36993]] binding to NullChannel
-2013-11-06 12:02:43,839-0600 INFO  MetaChannel MetaChannel [context: cps-36993, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36993]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36993]
-2013-11-06 12:02:43,840-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36993]
-2013-11-06 12:02:43,840-0600 INFO  ChannelContext Notifying commands and handlers about exception
-Channel exception handled
-2013-11-06 12:02:43,840-0600 INFO  ChannelManager Channel exception handled
-Channel is closed. Removing.
-2013-11-06 12:02:43,858-0600 INFO  Multiplexer Channel is closed. Removing.
-Exception in channel step
-java.io.IOException: Stream closed.
-	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
-	at java.net.SocketInputStream.available(SocketInputStream.java:234)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
-2013-11-06 12:02:43,859-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:02:43,859-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:02:43,859-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36993] handling channel exception
-Channel already shut down
-2013-11-06 12:02:43,859-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36993]
-2013-11-06 12:02:43,859-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36993]
-Avg stream buf: 0
-2013-11-06 12:02:45,745-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:02:49,364-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:02:55,753-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 4ms
-2013-11-06 12:03:05,474-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 4ms
-Avg stream buf: 0
-2013-11-06 12:03:05,762-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:03:15,770-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:03:25,779-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:03:26,683-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:03:35,789-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-120135.761, now=131106-120336.610, channel=TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:03:36,610-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:03:36,611-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:03:36,611-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:03:36,611-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:03:36,612-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:03:36,612-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:03:36,612-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:03:36,612-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36994] handling channel exception
-2013-11-06 12:03:36,612-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36994] handling channel exception
-2013-11-06 12:03:36,613-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36994, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36994]] binding to NullChannel
-2013-11-06 12:03:36,613-0600 INFO  MetaChannel MetaChannel [context: cps-36994, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36994]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:03:36,613-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:03:36,613-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:03:36,613-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:03:36,613-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:03:36,613-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:03:36,614-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:03:36,614-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:03:36,614-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:03:36,614-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:03:36,631-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:03:36,631-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:03:36,632-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:03:36,632-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36994] handling channel exception
-2013-11-06 12:03:36,632-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:03:36,632-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36994]
-2013-11-06 12:03:41,946-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 12:03:45,799-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:03:48,640-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36999] for addition
-2013-11-06 12:03:48,641-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:36999] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:36999]
-2013-11-06 12:03:48,641-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:36999]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff4
-2013-11-06 12:03:48,668-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff4
-MetaChannel [context: cps-36999, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36999]
-2013-11-06 12:03:48,668-0600 INFO  MetaChannel MetaChannel [context: cps-36999, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:36999]
-2013-11-06 12:03:48,668-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:03:48,708-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:03:48,708-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:03:48,789-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:03:48,790-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 4.0) submitting urn:job-0-1383759274492-1383759274493: /bin/date
-2013-11-06 12:03:48,790-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 4.0) submitting urn:job-0-1383759274492-1383759274493: /bin/date
-2013-11-06 12:03:48,791-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:03:48,791-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:03:48,797-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7340, JOBSTATUS) unregistering (send)
-2013-11-06 12:03:48,797-0600 INFO  RequestHandler Handler(tag: 7340, JOBSTATUS) unregistering (send)
-2013-11-06 12:03:48,809-0600 DEBUG Cpu Completed
-grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:03:48,809-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:03:48,809-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:03:48,809-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7341, JOBSTATUS) unregistering (send)
-2013-11-06 12:03:48,809-0600 INFO  RequestHandler Handler(tag: 7341, JOBSTATUS) unregistering (send)
-2013-11-06 12:03:48,809-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 12:03:55,809-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:04:04,001-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:04:05,818-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:04:15,827-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:04:18,419-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:04:25,836-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:04:35,845-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-120239.645, now=131106-120440.504, channel=TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:04:40,504-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:04:40,504-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36995] handling channel exception
-2013-11-06 12:04:40,504-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36995] handling channel exception
-2013-11-06 12:04:40,505-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36995, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36995]] binding to NullChannel
-2013-11-06 12:04:40,505-0600 INFO  MetaChannel MetaChannel [context: cps-36995, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36995]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:04:40,505-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:04:40,505-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:04:40,505-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:04:40,519-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:04:40,519-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:04:40,519-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:04:40,519-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36995] handling channel exception
-2013-11-06 12:04:40,519-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:04:40,519-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36995]
-2013-11-06 12:04:41,319-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:04:45,855-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:04:54,893-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:04:55,864-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:05:05,873-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:05:15,881-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:05:18,638-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:05:25,890-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:05:31,368-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 12:05:35,899-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:05:45,908-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-120348.789, now=131106-120549.642, channel=TCPChannel [type: server, contact: 127.0.0.1:36999]
-2013-11-06 12:05:49,642-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:05:49,642-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-Client could not properly process notification: null
-2013-11-06 12:05:49,642-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 2, JOBSTATUS)
-2013-11-06 12:05:49,643-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:05:49,643-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 3, JOBSTATUS)
-2013-11-06 12:05:49,643-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-=> Command(tag: 4, JOBSTATUS)
-2013-11-06 12:05:49,643-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:05:49,643-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:36999] handling channel exception
-2013-11-06 12:05:49,644-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36999] handling channel exception
-2013-11-06 12:05:49,644-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-36999, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36999]] binding to NullChannel
-2013-11-06 12:05:49,644-0600 INFO  MetaChannel MetaChannel [context: cps-36999, boundTo: TCPChannel [type: server, contact: 127.0.0.1:36999]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36999]
-2013-11-06 12:05:49,644-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:36999]
-2013-11-06 12:05:49,644-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:05:49,644-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:05:49,645-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:05:49,645-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:05:49,645-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:05:49,645-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:05:49,645-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:05:49,659-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:05:49,659-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:05:49,659-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:05:49,659-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:36999] handling channel exception
-2013-11-06 12:05:49,659-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36999]
-2013-11-06 12:05:49,660-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:36999]
-No streams
-2013-11-06 12:05:55,917-0600 INFO  Multiplexer No streams
-2013-11-06 12:05:55,955-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:06:05,925-0600 INFO  Multiplexer No streams
-2013-11-06 12:06:07,841-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:06:15,934-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:06:25,942-0600 INFO  Multiplexer No streams
-2013-11-06 12:06:33,273-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:06:35,950-0600 INFO  Multiplexer No streams
-2013-11-06 12:06:44,315-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:06:45,959-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:06:55,967-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:07:05,976-0600 INFO  Multiplexer No streams
-2013-11-06 12:07:10,592-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:07:15,984-0600 INFO  Multiplexer No streams
-2013-11-06 12:07:20,789-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:07:25,992-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:07:36,000-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:07:46,009-0600 INFO  Multiplexer No streams
-2013-11-06 12:07:47,909-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:07:56,017-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:07:57,264-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:08:05,142-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37005] for addition
-2013-11-06 12:08:05,143-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37005] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37005]
-2013-11-06 12:08:05,143-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37005]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff3
-2013-11-06 12:08:05,164-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff3
-MetaChannel [context: cps-37005, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37005]
-2013-11-06 12:08:05,164-0600 INFO  MetaChannel MetaChannel [context: cps-37005, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37005]
-2013-11-06 12:08:05,164-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:08:05,204-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:08:05,204-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:08:05,285-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:08:05,302-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 5.0) submitting urn:job-0-1383759274495-1383759274496: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:08:05,303-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 5.0) submitting urn:job-0-1383759274495-1383759274496: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:08:05,303-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:08:05,303-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:08:05,309-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7342, JOBSTATUS) unregistering (send)
-2013-11-06 12:08:05,309-0600 INFO  RequestHandler Handler(tag: 7342, JOBSTATUS) unregistering (send)
-Avg stream buf: 0
-2013-11-06 12:08:06,027-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:08:07,535-0600 DEBUG Cpu Completed
-2013-11-06 12:08:07,535-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:08:07,536-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:08:07,536-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7343, JOBSTATUS) unregistering (send)
-2013-11-06 12:08:07,536-0600 INFO  RequestHandler Handler(tag: 7343, JOBSTATUS) unregistering (send)
-2013-11-06 12:08:07,536-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 12:08:16,035-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:08:25,227-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:08:26,042-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:08:33,738-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:08:36,050-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:08:46,058-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:08:56,066-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:09:02,545-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:09:06,073-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:09:10,212-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:09:16,081-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:09:26,089-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:09:27,301-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37006] for addition
-2013-11-06 12:09:27,302-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37006] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:09:27,302-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37006]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff2
-2013-11-06 12:09:27,334-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff2
-MetaChannel [context: cps-37006, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:09:27,334-0600 INFO  MetaChannel MetaChannel [context: cps-37006, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:09:27,334-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:09:27,395-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:09:27,395-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:09:27,475-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:09:27,480-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 6.0) submitting urn:job-0-1383759274498-1383759274499: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:09:27,480-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 6.0) submitting urn:job-0-1383759274498-1383759274499: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:09:27,480-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:09:27,480-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:09:27,486-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7344, JOBSTATUS) unregistering (send)
-2013-11-06 12:09:27,487-0600 INFO  RequestHandler Handler(tag: 7344, JOBSTATUS) unregistering (send)
-2013-11-06 12:09:29,508-0600 DEBUG Cpu Completed
-2013-11-06 12:09:29,508-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:09:29,508-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:09:29,508-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7345, JOBSTATUS) unregistering (send)
-2013-11-06 12:09:29,508-0600 INFO  RequestHandler Handler(tag: 7345, JOBSTATUS) unregistering (send)
-2013-11-06 12:09:29,508-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 12:09:36,100-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:09:39,863-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:09:46,109-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:09:46,687-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:09:56,117-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:10:06,126-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-120805.285, now=131106-121006.143, channel=TCPChannel [type: server, contact: 127.0.0.1:37005]
-2013-11-06 12:10:06,143-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:10:06,143-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:10:06,144-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:10:06,144-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:10:06,144-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:10:06,144-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:10:06,145-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:10:06,145-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37005] handling channel exception
-2013-11-06 12:10:06,145-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37005] handling channel exception
-2013-11-06 12:10:06,145-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37005, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37005]] binding to NullChannel
-2013-11-06 12:10:06,145-0600 INFO  MetaChannel MetaChannel [context: cps-37005, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37005]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37005]
-2013-11-06 12:10:06,146-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37005]
-2013-11-06 12:10:06,146-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:10:06,146-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:10:06,146-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:10:06,146-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:10:06,146-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:10:06,146-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:10:06,147-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:10:06,147-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:10:06,147-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:10:06,147-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:10:06,147-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:10:06,147-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37005] handling channel exception
-2013-11-06 12:10:06,148-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37005]
-2013-11-06 12:10:06,148-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37005]
-Avg stream buf: 0
-2013-11-06 12:10:16,136-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:10:17,181-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 12:10:23,161-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 12:10:26,144-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:10:36,152-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:10:46,161-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:10:54,499-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:10:56,169-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:10:59,634-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:11:06,177-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:11:16,185-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:11:26,194-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-120927.475, now=131106-121128.302, channel=TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:11:28,302-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:11:28,303-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:11:28,303-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:11:28,303-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:11:28,303-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:11:28,304-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:11:28,304-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:11:28,304-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37006] handling channel exception
-2013-11-06 12:11:28,304-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37006] handling channel exception
-2013-11-06 12:11:28,304-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37006, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37006]] binding to NullChannel
-2013-11-06 12:11:28,304-0600 INFO  MetaChannel MetaChannel [context: cps-37006, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37006]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:11:28,305-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:11:28,305-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:11:28,305-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:11:28,305-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:11:28,305-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:11:28,305-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:11:28,306-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:11:28,306-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:11:28,306-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:11:28,320-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:11:28,320-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:11:28,320-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:11:28,320-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37006] handling channel exception
-2013-11-06 12:11:28,320-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:11:28,320-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37006]
-2013-11-06 12:11:31,817-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:11:36,108-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:11:36,202-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:11:46,210-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:11:56,217-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:12:06,225-0600 INFO  Multiplexer No streams
-2013-11-06 12:12:09,135-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:12:12,583-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 12:12:16,233-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:12:26,240-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:12:36,248-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:12:46,257-0600 INFO  Multiplexer No streams
-2013-11-06 12:12:46,453-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:12:49,057-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:12:56,266-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:13:06,275-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:13:16,289-0600 INFO  Multiplexer No streams
-2013-11-06 12:13:23,772-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:13:25,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:13:26,290-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:13:36,299-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:13:46,308-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:13:56,314-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:14:01,090-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:14:02,004-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:14:06,326-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:14:16,339-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:14:26,351-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:14:36,362-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 3ms
-2013-11-06 12:14:38,409-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 3ms
-2013-11-06 12:14:38,478-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:14:46,375-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:14:56,389-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:15:06,398-0600 INFO  Multiplexer No streams
-2013-11-06 12:15:14,953-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 12:15:15,726-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:15:16,408-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:15:26,417-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:15:36,427-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:15:46,437-0600 INFO  Multiplexer No streams
-2013-11-06 12:15:51,426-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:15:53,043-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:15:56,447-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:16:06,457-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:16:16,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:16:26,477-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:16:27,901-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:16:30,361-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:16:36,487-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:16:46,497-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:16:56,506-0600 INFO  Multiplexer No streams
-2013-11-06 12:17:04,374-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:17:06,516-0600 INFO  Multiplexer No streams
-2013-11-06 12:17:07,680-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:17:16,526-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:17:26,536-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:17:36,545-0600 INFO  Multiplexer No streams
-2013-11-06 12:17:40,849-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:17:44,997-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:17:46,554-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:17:56,562-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:18:06,569-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:18:16,577-0600 INFO  Multiplexer No streams
-2013-11-06 12:18:17,323-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:18:22,315-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:18:26,585-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:18:36,593-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:18:46,601-0600 INFO  Multiplexer No streams
-2013-11-06 12:18:53,797-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 12:18:56,609-0600 INFO  Multiplexer No streams
-Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-11-06 12:18:57,254-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37028] for addition
-2013-11-06 12:18:57,254-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37028] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37028]
-2013-11-06 12:18:57,254-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37028]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff1
-2013-11-06 12:18:57,293-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff1
-MetaChannel [context: cps-37028, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37028]
-2013-11-06 12:18:57,293-0600 INFO  MetaChannel MetaChannel [context: cps-37028, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37028]
-2013-11-06 12:18:57,293-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:18:57,314-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:18:57,314-0600 INFO  Sender Sender TCPChannel queue size: 0
-	... 4 more
-2013-11-06 12:18:57,395-0600 INFO  RequestReply Handler(tag: 38908, SUBMITJOB) sending error: Could not deserialize job description
-	... 4 more
-2013-11-06 12:18:57,396-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:18:59,634-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:19:06,623-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:19:16,631-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:19:26,640-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:19:30,270-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:19:36,649-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:19:36,951-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:19:45,474-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37034] for addition
-2013-11-06 12:19:45,474-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37034] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37034]
-2013-11-06 12:19:45,474-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37034]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff0
-2013-11-06 12:19:45,495-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7ff0
-MetaChannel [context: cps-37034, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37034]
-2013-11-06 12:19:45,496-0600 INFO  MetaChannel MetaChannel [context: cps-37034, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37034]
-2013-11-06 12:19:45,496-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:19:45,537-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:19:45,537-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:19:45,618-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:19:45,657-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 7.0) submitting urn:job-0-1383759274504-1383759274505: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:19:45,657-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 7.0) submitting urn:job-0-1383759274504-1383759274505: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:19:45,658-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:19:45,658-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:19:45,663-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7346, JOBSTATUS) unregistering (send)
-2013-11-06 12:19:45,663-0600 INFO  RequestHandler Handler(tag: 7346, JOBSTATUS) unregistering (send)
-Avg stream buf: 0
-2013-11-06 12:19:46,661-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:19:47,865-0600 DEBUG Cpu Completed
-2013-11-06 12:19:47,865-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:19:47,865-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:19:47,866-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7347, JOBSTATUS) unregistering (send)
-2013-11-06 12:19:47,866-0600 INFO  RequestHandler Handler(tag: 7347, JOBSTATUS) unregistering (send)
-2013-11-06 12:19:47,866-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:19:47,868-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37035] for addition
-2013-11-06 12:19:47,868-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37035] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37035]
-2013-11-06 12:19:47,868-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37035]
-Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fef
-2013-11-06 12:19:47,905-0600 INFO  ChannelConfigurationHandler Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fef
-MetaChannel [context: cps-37035, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37035]
-2013-11-06 12:19:47,905-0600 INFO  MetaChannel MetaChannel [context: cps-37035, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37035]
-Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:19:47,905-0600 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:19:47,945-0600 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 12:19:48,027-0600 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 12:19:48,066-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 8.0) submitting urn:job-1-1383759274507-1383759274508: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:19:48,066-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 8.0) submitting urn:job-1-1383759274507-1383759274508: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:19:48,067-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:19:48,067-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:19:48,072-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7348, JOBSTATUS) unregistering (send)
-2013-11-06 12:19:48,073-0600 INFO  RequestHandler Handler(tag: 7348, JOBSTATUS) unregistering (send)
-2013-11-06 12:19:50,088-0600 DEBUG Cpu Completed
-2013-11-06 12:19:50,088-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:19:50,088-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:19:50,088-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7349, JOBSTATUS) unregistering (send)
-2013-11-06 12:19:50,088-0600 INFO  RequestHandler Handler(tag: 7349, JOBSTATUS) unregistering (send)
-2013-11-06 12:19:50,088-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:19:50,089-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37036] for addition
-2013-11-06 12:19:50,090-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37036] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37036]
-2013-11-06 12:19:50,090-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37036]
-Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fee
-2013-11-06 12:19:50,113-0600 INFO  ChannelConfigurationHandler Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fee
-MetaChannel [context: cps-37036, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37036]
-2013-11-06 12:19:50,113-0600 INFO  MetaChannel MetaChannel [context: cps-37036, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37036]
-Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:19:50,113-0600 INFO  RequestHandler Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-Avg stream buf: 0
-2013-11-06 12:19:56,679-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:20:06,690-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:20:06,745-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 12:20:14,269-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-Avg stream buf: 0
-2013-11-06 12:20:16,700-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:20:26,709-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:20:36,719-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:20:43,219-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:20:46,729-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:20:51,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:20:56,739-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-121857.394, now=131106-122058.254, channel=TCPChannel [type: server, contact: 127.0.0.1:37028]
-2013-11-06 12:20:58,255-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:20:58,255-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37028] handling channel exception
-2013-11-06 12:20:58,255-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37028] handling channel exception
-2013-11-06 12:20:58,255-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37028, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37028]] binding to NullChannel
-2013-11-06 12:20:58,256-0600 INFO  MetaChannel MetaChannel [context: cps-37028, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37028]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37028]
-2013-11-06 12:20:58,256-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37028]
-2013-11-06 12:20:58,256-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:20:58,256-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:20:58,264-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:20:58,264-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:20:58,265-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:20:58,265-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37028] handling channel exception
-2013-11-06 12:20:58,265-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37028]
-2013-11-06 12:20:58,265-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37028]
-Avg stream buf: 0
-2013-11-06 12:21:06,750-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:21:16,760-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:21:19,693-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:21:26,769-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:21:28,905-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:21:36,778-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-121945.617, now=131106-122146.475, channel=TCPChannel [type: server, contact: 127.0.0.1:37034]
-2013-11-06 12:21:46,475-0600 INFO  ChannelContext Notifying commands and handlers about exception
-=> Command(tag: 1, JOBSTATUS)
-2013-11-06 12:21:46,475-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:21:46,475-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:46,475-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:21:46,476-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:21:46,476-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:46,476-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:21:46,476-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37034] handling channel exception
-2013-11-06 12:21:46,476-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37034] handling channel exception
-2013-11-06 12:21:46,477-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37034, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37034]] binding to NullChannel
-2013-11-06 12:21:46,477-0600 INFO  MetaChannel MetaChannel [context: cps-37034, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37034]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37034]
-2013-11-06 12:21:46,477-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37034]
-2013-11-06 12:21:46,477-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:21:46,477-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:21:46,477-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:46,477-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:21:46,478-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:21:46,478-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:46,478-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:21:46,478-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:21:46,486-0600 INFO  Multiplexer Channel is closed. Removing.
-	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
-2013-11-06 12:21:46,486-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:21:46,486-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:21:46,486-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37034] handling channel exception
-2013-11-06 12:21:46,486-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37034]
-2013-11-06 12:21:46,486-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37034]
-Avg stream buf: 0
-2013-11-06 12:21:46,787-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-121948.026, now=131106-122148.868, channel=TCPChannel [type: server, contact: 127.0.0.1:37035]
-2013-11-06 12:21:48,868-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:21:48,868-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:21:48,868-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:48,868-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:21:48,869-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:48,869-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:21:48,869-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:21:48,870-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37035] handling channel exception
-2013-11-06 12:21:48,870-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37035] handling channel exception
-2013-11-06 12:21:48,870-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37035, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37035]] binding to NullChannel
-2013-11-06 12:21:48,870-0600 INFO  MetaChannel MetaChannel [context: cps-37035, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37035]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37035]
-2013-11-06 12:21:48,870-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37035]
-2013-11-06 12:21:48,870-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:21:48,870-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:21:48,870-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:48,871-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:21:48,871-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:21:48,871-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:21:48,871-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:21:48,871-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:21:48,873-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:21:48,873-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:21:48,874-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:21:48,874-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37035] handling channel exception
-2013-11-06 12:21:48,874-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37035]
-2013-11-06 12:21:48,874-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37035]
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-121950.113, now=131106-122151.089, channel=TCPChannel [type: server, contact: 127.0.0.1:37036]
-2013-11-06 12:21:51,089-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:21:51,089-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37036] handling channel exception
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
-	at java.util.TimerThread.mainLoop(Timer.java:534)
-	at java.util.TimerThread.run(Timer.java:484)
-2013-11-06 12:21:51,089-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37036] handling channel exception
-2013-11-06 12:21:51,090-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37036, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37036]] binding to NullChannel
-2013-11-06 12:21:51,090-0600 INFO  MetaChannel MetaChannel [context: cps-37036, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37036]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37036]
-2013-11-06 12:21:51,090-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37036]
-Notifying commands and handlers about exception
-2013-11-06 12:21:51,090-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:21:51,090-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:21:51,100-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:21:51,100-0600 INFO  Multiplexer Exception in channel step
-Channel config: null -> {keepalive=null}
-2013-11-06 12:21:51,101-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-java.io.IOException: Stream closed.
-	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
-	at java.net.SocketInputStream.available(SocketInputStream.java:234)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
-2013-11-06 12:21:51,101-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37036] handling channel exception
-2013-11-06 12:21:51,101-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37036]
-2013-11-06 12:21:51,101-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37036]
-2013-11-06 12:21:56,167-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:21:56,797-0600 INFO  Multiplexer No streams
-2013-11-06 12:22:01,121-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37037] for addition
-2013-11-06 12:22:01,122-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37037] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37037]
-2013-11-06 12:22:01,122-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37037]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fed
-2013-11-06 12:22:01,150-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fed
-MetaChannel [context: cps-37037, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37037]
-2013-11-06 12:22:01,150-0600 INFO  MetaChannel MetaChannel [context: cps-37037, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37037]
-Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:22:01,150-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:22:01,191-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-Sender TCPChannel queue size: 0
-2013-11-06 12:22:01,191-0600 INFO  Sender Sender TCPChannel queue size: 0
-Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:22:01,271-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:22:01,286-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 9.0) submitting urn:job-0-1383759274510-1383759274511: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:22:01,286-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 9.0) submitting urn:job-0-1383759274510-1383759274511: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:22:01,287-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:22:01,287-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:22:01,293-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7350, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:01,294-0600 INFO  RequestHandler Handler(tag: 7350, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:03,319-0600 DEBUG Cpu Completed
-2013-11-06 12:22:03,319-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:22:03,319-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:22:03,319-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7351, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:03,319-0600 INFO  RequestHandler Handler(tag: 7351, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:03,319-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:22:03,323-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37038] for addition
-2013-11-06 12:22:03,324-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37038] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37038]
-2013-11-06 12:22:03,324-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37038]
-Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fec
-2013-11-06 12:22:03,358-0600 INFO  ChannelConfigurationHandler Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fec
-MetaChannel [context: cps-37038, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37038]
-2013-11-06 12:22:03,358-0600 INFO  MetaChannel MetaChannel [context: cps-37038, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37038]
-2013-11-06 12:22:03,358-0600 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:22:03,399-0600 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:22:03,479-0600 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 12:22:03,520-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 10.0) submitting urn:job-1-1383759274513-1383759274514: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:22:03,520-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 10.0) submitting urn:job-1-1383759274513-1383759274514: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:22:03,521-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:22:03,522-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:22:03,527-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7352, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:03,527-0600 INFO  RequestHandler Handler(tag: 7352, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:05,622-0600 DEBUG Cpu Completed
-2013-11-06 12:22:05,622-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:22:05,622-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7353, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:05,623-0600 INFO  RequestHandler Handler(tag: 7353, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:05,623-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 12:22:05,623-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:22:05,624-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37039] for addition
-2013-11-06 12:22:05,624-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37039] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37039]
-2013-11-06 12:22:05,624-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37039]
-Channel id: channel-3-u29cf5f3a-1422e7ae15d--7feb
-2013-11-06 12:22:05,646-0600 INFO  ChannelConfigurationHandler Channel id: channel-3-u29cf5f3a-1422e7ae15d--7feb
-MetaChannel [context: cps-37039, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37039]
-2013-11-06 12:22:05,646-0600 INFO  MetaChannel MetaChannel [context: cps-37039, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37039]
-2013-11-06 12:22:05,646-0600 INFO  RequestHandler Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-Handler(tag: 42565, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:22:05,687-0600 INFO  RequestHandler Handler(tag: 42565, CONFIGSERVICE) unregistering (send)
-Handler(tag: 42566, SUBMITJOB) unregistering (send)
-2013-11-06 12:22:05,767-0600 INFO  RequestHandler Handler(tag: 42566, SUBMITJOB) unregistering (send)
-2013-11-06 12:22:05,773-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 11.0) submitting urn:job-2-1383759274516-1383759274517: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:22:05,773-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 11.0) submitting urn:job-2-1383759274516-1383759274517: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:22:05,774-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:22:05,774-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:22:05,779-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7354, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:05,779-0600 INFO  RequestHandler Handler(tag: 7354, JOBSTATUS) unregistering (send)
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:22:06,223-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:22:06,810-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:22:07,794-0600 DEBUG Cpu Completed
-grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:22:07,794-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:22:07,794-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7355, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:07,795-0600 INFO  RequestHandler Handler(tag: 7355, JOBSTATUS) unregistering (send)
-2013-11-06 12:22:07,795-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 12:22:07,795-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 12:22:16,821-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:22:26,830-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:22:32,641-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:22:36,840-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:22:43,541-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:22:46,850-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:22:56,859-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:23:06,869-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:23:09,115-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:23:16,878-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:23:20,859-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:23:26,887-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:23:36,896-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:23:45,589-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:23:46,906-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:23:56,915-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:23:58,177-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-122201.271, now=131106-122402.122, channel=TCPChannel [type: server, contact: 127.0.0.1:37037]
-2013-11-06 12:24:02,122-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:24:02,123-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:24:02,123-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:02,123-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-Client could not properly process notification: null
-2013-11-06 12:24:02,123-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:24:02,124-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:24:02,124-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:02,124-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37037] handling channel exception
-2013-11-06 12:24:02,124-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37037] handling channel exception
-null: Channel shut down
-2013-11-06 12:24:02,124-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37037, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37037]] binding to NullChannel
-2013-11-06 12:24:02,124-0600 INFO  MetaChannel MetaChannel [context: cps-37037, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37037]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37037]
-2013-11-06 12:24:02,124-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37037]
-2013-11-06 12:24:02,124-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:24:02,125-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:24:02,125-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 2, JOBSTATUS)
-2013-11-06 12:24:02,125-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-=> Command(tag: 3, JOBSTATUS)
-2013-11-06 12:24:02,125-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-=> Command(tag: 4, JOBSTATUS)
-2013-11-06 12:24:02,125-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-Channel exception handled
-2013-11-06 12:24:02,126-0600 INFO  ChannelManager Channel exception handled
-Channel is closed. Removing.
-2013-11-06 12:24:02,130-0600 INFO  Multiplexer Channel is closed. Removing.
-Exception in channel step
-2013-11-06 12:24:02,130-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:24:02,131-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:24:02,131-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37037] handling channel exception
-Channel already shut down
-2013-11-06 12:24:02,131-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37037]
-2013-11-06 12:24:02,131-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37037]
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-122203.479, now=131106-122404.323, channel=TCPChannel [type: server, contact: 127.0.0.1:37038]
-2013-11-06 12:24:04,323-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:24:04,324-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:24:04,324-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:04,324-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:24:04,324-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:24:04,325-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:24:04,325-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:04,325-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37038] handling channel exception
-2013-11-06 12:24:04,325-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37038] handling channel exception
-2013-11-06 12:24:04,325-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37038, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37038]] binding to NullChannel
-2013-11-06 12:24:04,325-0600 INFO  MetaChannel MetaChannel [context: cps-37038, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37038]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37038]
-2013-11-06 12:24:04,326-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37038]
-2013-11-06 12:24:04,326-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:24:04,326-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:24:04,326-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:04,326-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:24:04,326-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:24:04,327-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:24:04,327-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:04,327-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:24:04,338-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:24:04,338-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:24:04,338-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:24:04,338-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37038] handling channel exception
-2013-11-06 12:24:04,338-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37038]
-2013-11-06 12:24:04,338-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37038]
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-122205.767, now=131106-122406.624, channel=TCPChannel [type: server, contact: 127.0.0.1:37039]
-2013-11-06 12:24:06,624-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:24:06,625-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:24:06,625-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:06,625-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:24:06,625-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:24:06,625-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:24:06,626-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37039] handling channel exception
-2013-11-06 12:24:06,626-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37039] handling channel exception
-2013-11-06 12:24:06,626-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37039, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37039]] binding to NullChannel
-2013-11-06 12:24:06,626-0600 INFO  MetaChannel MetaChannel [context: cps-37039, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37039]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37039]
-2013-11-06 12:24:06,626-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37039]
-2013-11-06 12:24:06,626-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:24:06,626-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:24:06,627-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:24:06,627-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:24:06,627-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:24:06,627-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:24:06,628-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:24:06,645-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:24:06,645-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:24:06,645-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:24:06,645-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37039] handling channel exception
-2013-11-06 12:24:06,645-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37039]
-2013-11-06 12:24:06,645-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37039]
-No streams
-2013-11-06 12:24:06,926-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:24:16,935-0600 INFO  Multiplexer No streams
-2013-11-06 12:24:22,063-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:24:26,943-0600 INFO  Multiplexer No streams
-2013-11-06 12:24:35,495-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:24:36,951-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:24:46,960-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:24:56,968-0600 INFO  Multiplexer No streams
-2013-11-06 12:24:58,537-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:25:06,976-0600 INFO  Multiplexer No streams
-2013-11-06 12:25:12,813-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:25:16,984-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:25:26,993-0600 INFO  Multiplexer No streams
-2013-11-06 12:25:35,012-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:25:37,001-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:25:47,009-0600 INFO  Multiplexer No streams
-2013-11-06 12:25:50,131-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:25:57,017-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:26:07,025-0600 INFO  Multiplexer No streams
-2013-11-06 12:26:11,485-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:26:17,033-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:26:27,041-0600 INFO  Multiplexer No streams
-2013-11-06 12:26:27,449-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:26:37,050-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:26:47,058-0600 INFO  Multiplexer No streams
-2013-11-06 12:26:47,959-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:26:57,066-0600 INFO  Multiplexer No streams
-2013-11-06 12:27:04,768-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:27:07,074-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:27:17,082-0600 INFO  Multiplexer No streams
-2013-11-06 12:27:24,433-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:27:27,090-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:27:37,099-0600 INFO  Multiplexer No streams
-2013-11-06 12:27:42,086-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:27:47,107-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:27:57,115-0600 INFO  Multiplexer No streams
-2013-11-06 12:28:00,907-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:28:01,526-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37046] for addition
-2013-11-06 12:28:01,526-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37046] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37046]
-2013-11-06 12:28:01,526-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37046]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fea
-2013-11-06 12:28:01,548-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fea
-MetaChannel [context: cps-37046, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37046]
-2013-11-06 12:28:01,549-0600 INFO  MetaChannel MetaChannel [context: cps-37046, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37046]
-2013-11-06 12:28:01,549-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:28:01,589-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:28:01,589-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:28:01,670-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:28:01,688-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 12.0) submitting urn:job-0-1383759274519-1383759274520: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:28:01,689-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 12.0) submitting urn:job-0-1383759274519-1383759274520: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:28:01,689-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:28:01,689-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:28:01,695-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7356, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:01,695-0600 INFO  RequestHandler Handler(tag: 7356, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:03,833-0600 DEBUG Cpu Completed
-2013-11-06 12:28:03,833-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:28:03,833-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:28:03,833-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7357, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:03,833-0600 INFO  RequestHandler Handler(tag: 7357, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:03,833-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 12:28:07,126-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:28:17,134-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:28:19,404-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 12:28:24,296-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37047] for addition
-2013-11-06 12:28:24,297-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37047] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:28:24,297-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37047]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe9
-2013-11-06 12:28:24,336-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe9
-MetaChannel [context: cps-37047, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:28:24,336-0600 INFO  MetaChannel MetaChannel [context: cps-37047, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:28:24,336-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:28:24,357-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:28:24,357-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:28:24,437-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:28:24,457-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 13.0) submitting urn:job-0-1383759274522-1383759274523: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:28:24,457-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 13.0) submitting urn:job-0-1383759274522-1383759274523: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:28:24,457-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:28:24,458-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:28:24,463-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7358, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:24,464-0600 INFO  RequestHandler Handler(tag: 7358, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:26,481-0600 DEBUG Cpu Completed
-2013-11-06 12:28:26,481-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:28:26,481-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:28:26,481-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7359, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:26,481-0600 INFO  RequestHandler Handler(tag: 7359, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:26,481-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:28:26,483-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37048] for addition
-2013-11-06 12:28:26,483-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37048] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37048]
-2013-11-06 12:28:26,483-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37048]
-Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fe8
-2013-11-06 12:28:26,504-0600 INFO  ChannelConfigurationHandler Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fe8
-MetaChannel [context: cps-37048, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37048]
-2013-11-06 12:28:26,504-0600 INFO  MetaChannel MetaChannel [context: cps-37048, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37048]
-2013-11-06 12:28:26,504-0600 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:28:26,544-0600 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:28:26,625-0600 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 12:28:26,632-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 14.0) submitting urn:job-1-1383759274525-1383759274526: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:28:26,632-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 14.0) submitting urn:job-1-1383759274525-1383759274526: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:28:26,632-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:28:26,632-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:28:26,638-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7360, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:26,638-0600 INFO  RequestHandler Handler(tag: 7360, JOBSTATUS) unregistering (send)
-Avg stream buf: 0
-2013-11-06 12:28:27,146-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:28:28,652-0600 DEBUG Cpu Completed
-2013-11-06 12:28:28,652-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:28:28,652-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:28:28,652-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7361, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:28,653-0600 INFO  RequestHandler Handler(tag: 7361, JOBSTATUS) unregistering (send)
-2013-11-06 12:28:28,653-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:28:28,653-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37049] for addition
-2013-11-06 12:28:28,654-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37049] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37049]
-2013-11-06 12:28:28,654-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37049]
-Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fe7
-2013-11-06 12:28:28,689-0600 INFO  ChannelConfigurationHandler Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fe7
-MetaChannel [context: cps-37049, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37049]
-2013-11-06 12:28:28,689-0600 INFO  MetaChannel MetaChannel [context: cps-37049, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37049]
-2013-11-06 12:28:28,689-0600 INFO  RequestHandler Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-Avg stream buf: 0
-2013-11-06 12:28:37,154-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:28:37,381-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:28:47,164-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:28:56,722-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:28:57,173-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:29:07,182-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:29:13,855-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:29:17,191-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:29:27,201-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:29:34,040-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:29:37,210-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:29:47,219-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:29:50,329-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:29:57,229-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-122801.669, now=131106-123002.526, channel=TCPChannel [type: server, contact: 127.0.0.1:37046]
-2013-11-06 12:30:02,526-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:02,526-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:30:02,526-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:02,527-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:30:02,527-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:02,527-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:30:02,527-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:30:02,527-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37046] handling channel exception
-2013-11-06 12:30:02,528-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37046] handling channel exception
-2013-11-06 12:30:02,528-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37046, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37046]] binding to NullChannel
-2013-11-06 12:30:02,528-0600 INFO  MetaChannel MetaChannel [context: cps-37046, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37046]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37046]
-2013-11-06 12:30:02,528-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37046]
-2013-11-06 12:30:02,528-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:02,528-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:30:02,528-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:02,529-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:30:02,529-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:02,529-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:30:02,529-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:30:02,529-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:30:02,544-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:30:02,544-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:30:02,544-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:30:02,545-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37046] handling channel exception
-2013-11-06 12:30:02,545-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37046]
-2013-11-06 12:30:02,545-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37046]
-Avg stream buf: 0
-2013-11-06 12:30:07,238-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:30:11,358-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:30:17,247-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-122824.437, now=131106-123025.296, channel=TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:30:25,297-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:25,297-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:30:25,297-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:25,297-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:30:25,298-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:30:25,298-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:25,298-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:30:25,298-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37047] handling channel exception
-2013-11-06 12:30:25,298-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37047] handling channel exception
-2013-11-06 12:30:25,299-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37047, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37047]] binding to NullChannel
-2013-11-06 12:30:25,299-0600 INFO  MetaChannel MetaChannel [context: cps-37047, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37047]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:30:25,299-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:30:25,299-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:25,299-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:30:25,299-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:25,299-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:30:25,300-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:30:25,300-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:25,300-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:30:25,300-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:30:25,311-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:30:25,311-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:30:25,311-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:30:25,311-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37047] handling channel exception
-2013-11-06 12:30:25,312-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:30:25,312-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37047]
-2013-11-06 12:30:26,803-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:30:27,257-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-122826.625, now=131106-123027.483, channel=TCPChannel [type: server, contact: 127.0.0.1:37048]
-2013-11-06 12:30:27,483-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:27,483-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:30:27,483-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:27,484-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:30:27,484-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:27,484-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:30:27,484-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:30:27,485-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37048] handling channel exception
-2013-11-06 12:30:27,485-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37048] handling channel exception
-2013-11-06 12:30:27,485-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37048, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37048]] binding to NullChannel
-2013-11-06 12:30:27,485-0600 INFO  MetaChannel MetaChannel [context: cps-37048, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37048]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37048]
-2013-11-06 12:30:27,485-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37048]
-2013-11-06 12:30:27,485-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:27,486-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:30:27,486-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:30:27,486-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:30:27,486-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:30:27,486-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:30:27,487-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:30:27,498-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:30:27,498-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:30:27,498-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:30:27,498-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37048] handling channel exception
-2013-11-06 12:30:27,499-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37048]
-2013-11-06 12:30:27,499-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37048]
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-122828.689, now=131106-123029.653, channel=TCPChannel [type: server, contact: 127.0.0.1:37049]
-2013-11-06 12:30:29,653-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:29,654-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37049] handling channel exception
-2013-11-06 12:30:29,654-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37049] handling channel exception
-2013-11-06 12:30:29,654-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37049, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37049]] binding to NullChannel
-2013-11-06 12:30:29,654-0600 INFO  MetaChannel MetaChannel [context: cps-37049, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37049]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37049]
-2013-11-06 12:30:29,654-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37049]
-2013-11-06 12:30:29,654-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:30:29,655-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:30:29,665-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:30:29,665-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:30:29,665-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:30:29,665-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37049] handling channel exception
-2013-11-06 12:30:29,666-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37049]
-2013-11-06 12:30:29,666-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37049]
-No streams
-2013-11-06 12:30:37,267-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:30:47,275-0600 INFO  Multiplexer No streams
-2013-11-06 12:30:48,676-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:30:57,283-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:31:03,278-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:31:07,291-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:31:17,299-0600 INFO  Multiplexer No streams
-2013-11-06 12:31:25,994-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:31:27,307-0600 INFO  Multiplexer No streams
-Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-11-06 12:31:33,905-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37051] for addition
-2013-11-06 12:31:33,905-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37051] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37051]
-2013-11-06 12:31:33,905-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37051]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe6
-2013-11-06 12:31:33,927-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe6
-MetaChannel [context: cps-37051, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37051]
-2013-11-06 12:31:33,927-0600 INFO  MetaChannel MetaChannel [context: cps-37051, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37051]
-2013-11-06 12:31:33,927-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:31:33,968-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:31:33,968-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 12:31:34,048-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 12:31:34,063-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 15.0) submitting urn:job-0-1383759274528-1383759274529: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:31:34,063-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 15.0) submitting urn:job-0-1383759274528-1383759274529: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:31:34,064-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:31:34,064-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:31:34,070-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7362, JOBSTATUS) unregistering (send)
-2013-11-06 12:31:34,070-0600 INFO  RequestHandler Handler(tag: 7362, JOBSTATUS) unregistering (send)
-2013-11-06 12:31:36,108-0600 DEBUG Cpu Completed
-2013-11-06 12:31:36,108-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:31:36,108-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:31:36,108-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7363, JOBSTATUS) unregistering (send)
-2013-11-06 12:31:36,108-0600 INFO  RequestHandler Handler(tag: 7363, JOBSTATUS) unregistering (send)
-2013-11-06 12:31:36,108-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:31:36,110-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37052] for addition
-2013-11-06 12:31:36,110-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37052] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37052]
-2013-11-06 12:31:36,110-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37052]
-Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fe5
-2013-11-06 12:31:36,135-0600 INFO  ChannelConfigurationHandler Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fe5
-MetaChannel [context: cps-37052, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37052]
-2013-11-06 12:31:36,135-0600 INFO  MetaChannel MetaChannel [context: cps-37052, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37052]
-Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:31:36,135-0600 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-2013-11-06 12:31:36,175-0600 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 12:31:36,256-0600 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 12:31:36,259-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 16.0) submitting urn:job-1-1383759274531-1383759274532: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:31:36,259-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 16.0) submitting urn:job-1-1383759274531-1383759274532: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 12:31:36,259-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 12:31:36,259-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 12:31:36,267-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7364, JOBSTATUS) unregistering (send)
-2013-11-06 12:31:36,268-0600 INFO  RequestHandler Handler(tag: 7364, JOBSTATUS) unregistering (send)
-Avg stream buf: 0
-2013-11-06 12:31:37,319-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:31:38,279-0600 DEBUG Cpu Completed
-2013-11-06 12:31:38,280-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 12:31:38,280-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 12:31:38,280-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7365, JOBSTATUS) unregistering (send)
-2013-11-06 12:31:38,280-0600 INFO  RequestHandler Handler(tag: 7365, JOBSTATUS) unregistering (send)
-2013-11-06 12:31:38,280-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 12:31:38,281-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37053] for addition
-2013-11-06 12:31:38,282-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:37053] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:37053]
-2013-11-06 12:31:38,282-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:37053]
-Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fe4
-2013-11-06 12:31:38,304-0600 INFO  ChannelConfigurationHandler Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fe4
-MetaChannel [context: cps-37053, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37053]
-2013-11-06 12:31:38,304-0600 INFO  MetaChannel MetaChannel [context: cps-37053, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:37053]
-Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-2013-11-06 12:31:38,305-0600 INFO  RequestHandler Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:31:39,751-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:31:47,331-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:31:57,340-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:32:03,312-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:32:07,349-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 12:32:16,226-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 12:32:17,358-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:32:27,368-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:32:37,377-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 12:32:40,630-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-Avg stream buf: 0
-2013-11-06 12:32:47,386-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:32:52,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:32:57,395-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:33:07,404-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 12:33:17,413-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:33:17,949-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 12:33:27,422-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 12:33:29,173-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-123134.048, now=131106-123334.905, channel=TCPChannel [type: server, contact: 127.0.0.1:37051]
-2013-11-06 12:33:34,905-0600 INFO  ChannelContext Notifying commands and handlers about exception
-=> Command(tag: 1, JOBSTATUS)
-2013-11-06 12:33:34,905-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:33:34,906-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:33:34,906-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:33:34,906-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:33:34,907-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:33:34,907-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:33:34,907-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37051] handling channel exception
-2013-11-06 12:33:34,907-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37051] handling channel exception
-2013-11-06 12:33:34,907-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37051, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37051]] binding to NullChannel
-2013-11-06 12:33:34,907-0600 INFO  MetaChannel MetaChannel [context: cps-37051, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37051]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37051]
-2013-11-06 12:33:34,907-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37051]
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
-	at java.util.TimerThread.mainLoop(Timer.java:534)
-	at java.util.TimerThread.run(Timer.java:484)
-2013-11-06 12:33:34,908-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:33:34,908-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:33:34,908-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:33:34,908-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:33:34,908-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:33:34,908-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:33:34,909-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:33:34,909-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:33:34,924-0600 INFO  Multiplexer Channel is closed. Removing.
-	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
-2013-11-06 12:33:34,924-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:33:34,924-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:33:34,924-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37051] handling channel exception
-java.io.IOException: Stream closed.
-	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
-	at java.net.SocketInputStream.available(SocketInputStream.java:234)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
-2013-11-06 12:33:34,925-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37051]
-2013-11-06 12:33:34,925-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37051]
-Notifying commands and handlers about exception
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-123136.256, now=131106-123337.110, channel=TCPChannel [type: server, contact: 127.0.0.1:37052]
-2013-11-06 12:33:37,110-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:33:37,111-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:33:37,111-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:33:37,111-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:33:37,111-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:33:37,112-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:33:37,112-0600 WARN  TaskNotifier Client could not properly process notification: null
-Channel config: null -> {keepalive=null}
-2013-11-06 12:33:37,112-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37052] handling channel exception
-2013-11-06 12:33:37,112-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37052] handling channel exception
-2013-11-06 12:33:37,112-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37052, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37052]] binding to NullChannel
-2013-11-06 12:33:37,113-0600 INFO  MetaChannel MetaChannel [context: cps-37052, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37052]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37052]
-2013-11-06 12:33:37,113-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37052]
-2013-11-06 12:33:37,113-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:33:37,113-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 12:33:37,113-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:33:37,113-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 12:33:37,113-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 12:33:37,114-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 12:33:37,114-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 12:33:37,114-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:33:37,131-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:33:37,131-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:33:37,131-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:33:37,132-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37052] handling channel exception
-2013-11-06 12:33:37,132-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37052]
-2013-11-06 12:33:37,132-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37052]
-Avg stream buf: 0
-2013-11-06 12:33:37,433-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-123138.304, now=131106-123339.282, channel=TCPChannel [type: server, contact: 127.0.0.1:37053]
-2013-11-06 12:33:39,282-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:33:39,282-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:37053] handling channel exception
-2013-11-06 12:33:39,282-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37053] handling channel exception
-2013-11-06 12:33:39,282-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-37053, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37053]] binding to NullChannel
-2013-11-06 12:33:39,282-0600 INFO  MetaChannel MetaChannel [context: cps-37053, boundTo: TCPChannel [type: server, contact: 127.0.0.1:37053]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37053]
-2013-11-06 12:33:39,283-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:37053]
-2013-11-06 12:33:39,283-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 12:33:39,283-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 12:33:39,298-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 12:33:39,298-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 12:33:39,298-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 12:33:39,299-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:37053] handling channel exception
-2013-11-06 12:33:39,299-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37053]
-2013-11-06 12:33:39,299-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:37053]
-No streams
-2013-11-06 12:33:47,442-0600 INFO  Multiplexer No streams
-2013-11-06 12:33:55,267-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:33:57,450-0600 INFO  Multiplexer No streams
-2013-11-06 12:34:05,647-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:34:07,458-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:34:17,467-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:34:27,475-0600 INFO  Multiplexer No streams
-2013-11-06 12:34:32,584-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 12:34:37,483-0600 INFO  Multiplexer No streams
-2013-11-06 12:34:42,122-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 12:34:47,491-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:34:57,499-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:35:07,507-0600 INFO  Multiplexer No streams
-2013-11-06 12:35:09,903-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:35:17,515-0600 INFO  Multiplexer No streams
-2013-11-06 12:35:18,595-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:35:27,523-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:35:37,531-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 12:35:47,222-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:35:47,539-0600 INFO  Multiplexer No streams
-2013-11-06 12:35:55,070-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:35:57,547-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:36:07,556-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:36:17,564-0600 INFO  Multiplexer No streams
-2013-11-06 12:36:24,539-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:36:27,572-0600 INFO  Multiplexer No streams
-2013-11-06 12:36:31,544-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:36:37,580-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:36:47,588-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:36:57,597-0600 INFO  Multiplexer No streams
-2013-11-06 12:37:01,857-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:37:07,605-0600 INFO  Multiplexer No streams
-2013-11-06 12:37:08,018-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:37:17,613-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:37:27,621-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:37:37,630-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:37:39,175-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:37:44,492-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:37:47,638-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:37:57,646-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:38:07,654-0600 INFO  Multiplexer No streams
-2013-11-06 12:38:16,493-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:38:17,662-0600 INFO  Multiplexer No streams
-2013-11-06 12:38:20,966-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:38:27,671-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:38:37,679-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:38:47,687-0600 INFO  Multiplexer No streams
-2013-11-06 12:38:53,811-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:38:57,440-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:38:57,695-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:39:07,703-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:39:17,711-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:39:27,720-0600 INFO  Multiplexer No streams
-2013-11-06 12:39:31,129-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:39:33,914-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:39:37,728-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:39:47,736-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:39:57,744-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:40:07,752-0600 INFO  Multiplexer No streams
-2013-11-06 12:40:08,447-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 12:40:10,388-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:40:17,760-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:40:27,768-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:40:37,777-0600 INFO  Multiplexer No streams
-2013-11-06 12:40:45,766-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:40:46,862-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:40:47,785-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:40:57,793-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:41:07,801-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:41:17,809-0600 INFO  Multiplexer No streams
-2013-11-06 12:41:23,084-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:41:23,337-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 12:41:27,817-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:41:37,825-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:41:47,833-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:41:57,841-0600 INFO  Multiplexer No streams
-2013-11-06 12:41:59,810-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:42:00,402-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:42:07,849-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:42:17,857-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:42:27,865-0600 INFO  Multiplexer No streams
-2013-11-06 12:42:36,284-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:42:37,720-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:42:37,873-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:42:47,881-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:42:57,889-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:43:07,897-0600 INFO  Multiplexer No streams
-2013-11-06 12:43:12,758-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:43:15,038-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:43:17,905-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:43:27,913-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:43:37,921-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:43:47,929-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 12:43:49,232-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 12:43:52,356-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:43:57,937-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:44:07,945-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:44:17,953-0600 INFO  Multiplexer No streams
-2013-11-06 12:44:25,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:44:27,961-0600 INFO  Multiplexer No streams
-2013-11-06 12:44:29,674-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:44:37,969-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:44:47,977-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:44:57,984-0600 INFO  Multiplexer No streams
-2013-11-06 12:45:02,180-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 12:45:06,991-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 12:45:07,992-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:45:17,999-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:45:28,006-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:45:38,014-0600 INFO  Multiplexer No streams
-2013-11-06 12:45:38,655-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 12:45:44,310-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:45:48,022-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:45:58,029-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:46:08,037-0600 INFO  Multiplexer No streams
-2013-11-06 12:46:15,128-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:46:18,045-0600 INFO  Multiplexer No streams
-2013-11-06 12:46:21,628-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:46:28,052-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:46:38,060-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:46:48,068-0600 INFO  Multiplexer No streams
-2013-11-06 12:46:51,602-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:46:58,075-0600 INFO  Multiplexer No streams
-2013-11-06 12:46:58,946-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:47:08,083-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:47:18,091-0600 INFO  Multiplexer No streams
-2013-11-06 12:47:28,076-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:47:28,098-0600 INFO  Multiplexer No streams
-2013-11-06 12:47:36,263-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 12:47:38,106-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:47:48,114-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:47:58,121-0600 INFO  Multiplexer No streams
-2013-11-06 12:48:04,551-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:48:08,129-0600 INFO  Multiplexer No streams
-2013-11-06 12:48:13,582-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:48:18,136-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:48:28,144-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:48:38,152-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 12:48:41,024-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:48:48,159-0600 INFO  Multiplexer No streams
-2013-11-06 12:48:50,900-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:48:58,167-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:49:08,174-0600 INFO  Multiplexer No streams
-2013-11-06 12:49:17,498-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:49:18,182-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:49:28,190-0600 INFO  Multiplexer No streams
-2013-11-06 12:49:28,218-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:49:38,197-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:49:48,205-0600 INFO  Multiplexer No streams
-2013-11-06 12:49:53,972-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:49:58,212-0600 INFO  Multiplexer No streams
-2013-11-06 12:50:05,536-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:50:08,219-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:50:18,227-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:50:28,235-0600 INFO  Multiplexer No streams
-2013-11-06 12:50:30,446-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:50:38,243-0600 INFO  Multiplexer No streams
-2013-11-06 12:50:42,854-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:50:48,250-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:50:58,258-0600 INFO  Multiplexer No streams
-2013-11-06 12:51:06,920-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:51:08,265-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:51:18,273-0600 INFO  Multiplexer No streams
-2013-11-06 12:51:20,172-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:51:28,280-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:51:38,288-0600 INFO  Multiplexer No streams
-2013-11-06 12:51:43,394-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:51:48,295-0600 INFO  Multiplexer No streams
-2013-11-06 12:51:57,490-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:51:58,303-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:52:08,310-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:52:18,318-0600 INFO  Multiplexer No streams
-2013-11-06 12:52:19,869-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:52:28,326-0600 INFO  Multiplexer No streams
-2013-11-06 12:52:34,808-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:52:38,333-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:52:48,341-0600 INFO  Multiplexer No streams
-2013-11-06 12:52:56,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:52:58,349-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:53:08,356-0600 INFO  Multiplexer No streams
-2013-11-06 12:53:12,126-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:53:18,364-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:53:28,371-0600 INFO  Multiplexer No streams
-2013-11-06 12:53:32,817-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:53:38,379-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:53:48,386-0600 INFO  Multiplexer No streams
-2013-11-06 12:53:49,444-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:53:58,394-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:54:08,401-0600 INFO  Multiplexer No streams
-2013-11-06 12:54:09,291-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:54:18,409-0600 INFO  Multiplexer No streams
-2013-11-06 12:54:26,763-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:54:28,416-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:54:38,424-0600 INFO  Multiplexer No streams
-2013-11-06 12:54:45,766-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:54:48,432-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:54:58,439-0600 INFO  Multiplexer No streams
-2013-11-06 12:55:04,081-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:55:08,447-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:55:18,454-0600 INFO  Multiplexer No streams
-2013-11-06 12:55:22,239-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:55:28,462-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:55:38,469-0600 INFO  Multiplexer No streams
-2013-11-06 12:55:41,399-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:55:48,477-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:55:58,484-0600 INFO  Multiplexer No streams
-2013-11-06 12:55:58,713-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:56:08,492-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:56:18,500-0600 INFO  Multiplexer No streams
-2013-11-06 12:56:18,717-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:56:28,507-0600 INFO  Multiplexer No streams
-2013-11-06 12:56:35,187-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:56:38,515-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:56:48,522-0600 INFO  Multiplexer No streams
-2013-11-06 12:56:56,036-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:56:58,530-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:57:08,537-0600 INFO  Multiplexer No streams
-2013-11-06 12:57:11,662-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:57:18,545-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:57:28,553-0600 INFO  Multiplexer No streams
-2013-11-06 12:57:33,354-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:57:38,562-0600 INFO  Multiplexer No streams
-2013-11-06 12:57:48,137-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:57:48,571-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:57:58,580-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:58:08,588-0600 INFO  Multiplexer No streams
-2013-11-06 12:58:10,672-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:58:18,597-0600 INFO  Multiplexer No streams
-2013-11-06 12:58:24,611-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:58:28,605-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:58:38,614-0600 INFO  Multiplexer No streams
-2013-11-06 12:58:47,991-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:58:48,622-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:58:58,631-0600 INFO  Multiplexer No streams
-2013-11-06 12:59:01,084-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 12:59:08,639-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:59:18,648-0600 INFO  Multiplexer No streams
-2013-11-06 12:59:25,308-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 12:59:28,659-0600 INFO  Multiplexer No streams
-2013-11-06 12:59:37,559-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 12:59:38,670-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:59:48,680-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 12:59:58,691-0600 INFO  Multiplexer No streams
-2013-11-06 13:00:02,626-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:00:08,703-0600 INFO  Multiplexer No streams
-2013-11-06 13:00:14,033-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:00:18,714-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:00:28,725-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:00:38,735-0600 INFO  Multiplexer No streams
-2013-11-06 13:00:39,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:00:48,746-0600 INFO  Multiplexer No streams
-2013-11-06 13:00:50,506-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:00:58,765-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:01:08,781-0600 INFO  Multiplexer No streams
-2013-11-06 13:01:17,263-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:01:18,788-0600 INFO  Multiplexer No streams
-2013-11-06 13:01:26,981-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:01:28,793-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:01:38,797-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:01:48,802-0600 INFO  Multiplexer No streams
-2013-11-06 13:01:54,581-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:01:58,804-0600 INFO  Multiplexer No streams
-2013-11-06 13:02:03,455-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:02:08,806-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:02:18,814-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:02:28,823-0600 INFO  Multiplexer No streams
-2013-11-06 13:02:31,898-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:02:38,831-0600 INFO  Multiplexer No streams
-2013-11-06 13:02:39,929-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:02:48,843-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:02:58,854-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:03:08,864-0600 INFO  Multiplexer No streams
-2013-11-06 13:03:09,216-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:03:16,403-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:03:18,877-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:03:28,887-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:03:38,896-0600 INFO  Multiplexer No streams
-2013-11-06 13:03:46,535-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:03:48,906-0600 INFO  Multiplexer No streams
-2013-11-06 13:03:52,877-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:03:58,914-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:04:08,924-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:04:18,934-0600 INFO  Multiplexer No streams
-2013-11-06 13:04:23,852-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:04:28,943-0600 INFO  Multiplexer No streams
-2013-11-06 13:04:29,352-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:04:38,953-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:04:48,963-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:04:58,975-0600 INFO  Multiplexer No streams
-2013-11-06 13:05:01,170-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:05:05,825-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:05:08,986-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:05:18,998-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:05:29,010-0600 INFO  Multiplexer No streams
-2013-11-06 13:05:38,488-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:05:39,022-0600 INFO  Multiplexer No streams
-2013-11-06 13:05:42,300-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:05:49,032-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:05:59,041-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:06:09,053-0600 INFO  Multiplexer No streams
-2013-11-06 13:06:15,807-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 13:06:18,774-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:06:19,065-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:06:29,078-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:06:39,087-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:06:49,097-0600 INFO  Multiplexer No streams
-2013-11-06 13:06:53,124-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 13:06:55,248-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:06:59,108-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:07:09,116-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:07:19,125-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:07:29,133-0600 INFO  Multiplexer No streams
-2013-11-06 13:07:30,443-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 13:07:31,721-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:07:39,141-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:07:49,149-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:07:59,157-0600 INFO  Multiplexer No streams
-2013-11-06 13:08:07,762-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 13:08:08,195-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:08:09,166-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:08:19,174-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:08:29,183-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:08:39,192-0600 INFO  Multiplexer No streams
-2013-11-06 13:08:44,670-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 13:08:45,079-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:08:49,200-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:08:59,209-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:09:09,217-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:09:19,225-0600 INFO  Multiplexer No streams
-2013-11-06 13:09:21,145-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 13:09:22,397-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:09:29,234-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:09:39,244-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:09:49,253-0600 INFO  Multiplexer No streams
-2013-11-06 13:09:57,618-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:09:59,263-0600 INFO  Multiplexer No streams
-2013-11-06 13:09:59,715-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:10:09,274-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:10:19,282-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:10:29,292-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-2013-11-06 13:10:34,094-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-2013-11-06 13:10:37,033-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:10:39,306-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:10:49,317-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:10:59,327-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:11:09,335-0600 INFO  Multiplexer No streams
-2013-11-06 13:11:10,566-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:11:14,351-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:11:19,342-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:11:29,351-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:11:39,362-0600 INFO  Multiplexer No streams
-2013-11-06 13:11:47,041-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:11:49,375-0600 INFO  Multiplexer No streams
-2013-11-06 13:11:51,670-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:11:59,387-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:12:09,396-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:12:19,406-0600 INFO  Multiplexer No streams
-2013-11-06 13:12:23,514-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:12:28,987-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:12:29,415-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:12:39,426-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:12:49,438-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:12:59,450-0600 INFO  Multiplexer No streams
-2013-11-06 13:12:59,989-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 13:13:06,306-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:13:09,464-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:13:19,479-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:13:29,488-0600 INFO  Multiplexer No streams
-2013-11-06 13:13:36,462-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:13:39,501-0600 INFO  Multiplexer No streams
-2013-11-06 13:13:43,623-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:13:49,515-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:13:59,528-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:14:09,540-0600 INFO  Multiplexer No streams
-2013-11-06 13:14:12,936-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:14:19,550-0600 INFO  Multiplexer No streams
-2013-11-06 13:14:20,942-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:14:29,555-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:14:39,572-0600 INFO  Multiplexer No streams
-2013-11-06 13:14:49,411-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:14:49,590-0600 INFO  Multiplexer No streams
-2013-11-06 13:14:58,260-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:14:59,608-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:15:09,623-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:15:19,625-0600 INFO  Multiplexer No streams
-2013-11-06 13:15:25,885-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:15:29,637-0600 INFO  Multiplexer No streams
-2013-11-06 13:15:35,577-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:15:39,649-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:15:49,662-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:15:59,674-0600 INFO  Multiplexer No streams
-2013-11-06 13:16:02,358-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:16:09,687-0600 INFO  Multiplexer No streams
-2013-11-06 13:16:12,895-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:16:19,698-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:16:29,709-0600 INFO  Multiplexer No streams
-2013-11-06 13:16:38,833-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:16:39,719-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:16:49,730-0600 INFO  Multiplexer No streams
-2013-11-06 13:16:50,213-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:16:59,742-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:17:09,759-0600 INFO  Multiplexer No streams
-2013-11-06 13:17:15,307-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:17:19,772-0600 INFO  Multiplexer No streams
-2013-11-06 13:17:27,532-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:17:29,783-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:17:39,796-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:17:49,808-0600 INFO  Multiplexer No streams
-2013-11-06 13:17:51,781-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:17:59,820-0600 INFO  Multiplexer No streams
-2013-11-06 13:18:04,850-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:18:09,832-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:18:19,841-0600 INFO  Multiplexer No streams
-2013-11-06 13:18:28,255-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:18:29,851-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:18:39,862-0600 INFO  Multiplexer No streams
-2013-11-06 13:18:42,167-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:18:49,872-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:18:59,881-0600 INFO  Multiplexer No streams
-2013-11-06 13:19:04,728-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:19:09,889-0600 INFO  Multiplexer No streams
-2013-11-06 13:19:19,485-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:19:19,896-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:19:29,904-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:19:39,912-0600 INFO  Multiplexer No streams
-2013-11-06 13:19:41,202-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:19:49,920-0600 INFO  Multiplexer No streams
-2013-11-06 13:19:56,803-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:19:59,928-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:20:09,936-0600 INFO  Multiplexer No streams
-2013-11-06 13:20:17,677-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:20:19,944-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:20:29,952-0600 INFO  Multiplexer No streams
-2013-11-06 13:20:34,121-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:20:39,960-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:20:49,968-0600 INFO  Multiplexer No streams
-2013-11-06 13:20:54,150-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:20:59,976-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:21:09,984-0600 INFO  Multiplexer No streams
-2013-11-06 13:21:11,439-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:21:19,992-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:21:30,000-0600 INFO  Multiplexer No streams
-2013-11-06 13:21:30,624-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:21:40,008-0600 INFO  Multiplexer No streams
-2013-11-06 13:21:48,758-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:21:50,016-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:22:00,025-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 13:22:07,099-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:22:10,035-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:22:20,045-0600 INFO  Multiplexer No streams
-2013-11-06 13:22:26,076-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:22:30,060-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:22:40,062-0600 INFO  Multiplexer No streams
-2013-11-06 13:22:43,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:22:50,066-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:23:00,070-0600 INFO  Multiplexer No streams
-2013-11-06 13:23:03,394-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:23:10,072-0600 INFO  Multiplexer No streams
-2013-11-06 13:23:20,047-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:23:20,086-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:23:30,098-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:23:40,107-0600 INFO  Multiplexer No streams
-2013-11-06 13:23:40,711-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:23:50,117-0600 INFO  Multiplexer No streams
-2013-11-06 13:23:56,522-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 3ms
-No streams
-2013-11-06 13:24:00,132-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:24:10,143-0600 INFO  Multiplexer No streams
-2013-11-06 13:24:18,029-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:24:20,155-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:24:30,166-0600 INFO  Multiplexer No streams
-2013-11-06 13:24:32,995-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:24:40,179-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:24:50,196-0600 INFO  Multiplexer No streams
-2013-11-06 13:24:55,348-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:25:00,199-0600 INFO  Multiplexer No streams
-2013-11-06 13:25:09,469-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:25:10,207-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:25:20,215-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:25:30,235-0600 INFO  Multiplexer No streams
-2013-11-06 13:25:32,666-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:25:40,247-0600 INFO  Multiplexer No streams
-2013-11-06 13:25:45,944-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:25:50,256-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:26:00,266-0600 INFO  Multiplexer No streams
-2013-11-06 13:26:09,984-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:26:10,274-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:26:20,283-0600 INFO  Multiplexer No streams
-2013-11-06 13:26:22,418-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:26:30,292-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:26:40,299-0600 INFO  Multiplexer No streams
-2013-11-06 13:26:47,302-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:26:50,307-0600 INFO  Multiplexer No streams
-2013-11-06 13:26:58,891-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:27:00,320-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:27:10,332-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:27:20,348-0600 INFO  Multiplexer No streams
-2013-11-06 13:27:24,620-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:27:30,363-0600 INFO  Multiplexer No streams
-2013-11-06 13:27:35,365-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:27:40,372-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:27:50,381-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:28:00,394-0600 INFO  Multiplexer No streams
-2013-11-06 13:28:01,938-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:28:10,408-0600 INFO  Multiplexer No streams
-2013-11-06 13:28:11,839-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:28:20,423-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:28:30,431-0600 INFO  Multiplexer No streams
-2013-11-06 13:28:39,256-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:28:40,439-0600 INFO  Multiplexer No streams
-2013-11-06 13:28:48,313-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:28:50,451-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:29:00,462-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:29:10,480-0600 INFO  Multiplexer No streams
-2013-11-06 13:29:16,574-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:29:20,483-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:29:24,788-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:29:30,490-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:29:40,500-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:29:50,520-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:29:53,892-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:30:00,539-0600 INFO  Multiplexer No streams
-2013-11-06 13:30:01,262-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:30:10,559-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:30:20,572-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:30:30,581-0600 INFO  Multiplexer No streams
-2013-11-06 13:30:31,210-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 13:30:37,737-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:30:40,589-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:30:50,600-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:31:00,610-0600 INFO  Multiplexer No streams
-2013-11-06 13:31:08,529-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:31:10,619-0600 INFO  Multiplexer No streams
-2013-11-06 13:31:14,211-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:31:20,627-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:31:30,634-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:31:40,642-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 6ms
-2013-11-06 13:31:45,851-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 6ms
-No streams
-2013-11-06 13:31:50,650-0600 INFO  Multiplexer No streams
-2013-11-06 13:31:50,685-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:32:00,657-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:32:10,665-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:32:20,674-0600 INFO  Multiplexer No streams
-2013-11-06 13:32:23,164-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:32:27,159-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:32:30,683-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:32:40,689-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:32:50,697-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 9ms
-2013-11-06 13:33:00,490-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 9ms
-No streams
-2013-11-06 13:33:00,706-0600 INFO  Multiplexer No streams
-2013-11-06 13:33:03,634-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:33:10,718-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:33:20,733-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:33:30,745-0600 INFO  Multiplexer No streams
-2013-11-06 13:33:37,800-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:33:40,107-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:33:40,763-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:33:50,773-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:34:00,784-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:34:10,795-0600 INFO  Multiplexer No streams
-2013-11-06 13:34:15,118-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:34:16,581-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:34:20,804-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:34:30,815-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:34:40,826-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:34:50,836-0600 INFO  Multiplexer No streams
-2013-11-06 13:34:52,437-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 13:34:53,055-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:35:00,847-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:35:10,857-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:35:20,866-0600 INFO  Multiplexer No streams
-2013-11-06 13:35:29,530-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 13:35:29,754-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:35:30,875-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:35:40,885-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:35:50,894-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:36:00,903-0600 INFO  Multiplexer No streams
-2013-11-06 13:36:06,004-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 13:36:07,073-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:36:10,914-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:36:20,924-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:36:30,933-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:36:40,943-0600 INFO  Multiplexer No streams
-2013-11-06 13:36:42,478-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 13:36:44,391-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:36:50,952-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:37:00,962-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:37:10,972-0600 INFO  Multiplexer No streams
-2013-11-06 13:37:18,953-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:37:20,981-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 13:37:21,711-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:37:30,991-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:37:41,000-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:37:51,010-0600 INFO  Multiplexer No streams
-2013-11-06 13:37:55,425-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:37:59,028-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:38:01,020-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:38:11,029-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:38:21,037-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:38:31,049-0600 INFO  Multiplexer No streams
-2013-11-06 13:38:31,899-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:38:36,346-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:38:41,054-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:38:51,064-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:39:01,071-0600 INFO  Multiplexer No streams
-2013-11-06 13:39:08,374-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:39:11,079-0600 INFO  Multiplexer No streams
-2013-11-06 13:39:13,664-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:39:21,087-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:39:31,107-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:39:41,127-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-2013-11-06 13:39:44,849-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 3ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 9ms, rtt: 10ms
-2013-11-06 13:39:50,991-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 9ms, rtt: 10ms
-No streams
-2013-11-06 13:39:51,136-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:40:01,150-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:40:11,162-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:40:21,173-0600 INFO  Multiplexer No streams
-2013-11-06 13:40:21,322-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-2013-11-06 13:40:28,303-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 4ms
-No streams
-2013-11-06 13:40:31,181-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:40:41,188-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:40:51,196-0600 INFO  Multiplexer No streams
-2013-11-06 13:40:57,795-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:41:01,203-0600 INFO  Multiplexer No streams
-2013-11-06 13:41:05,618-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:41:11,210-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:41:21,218-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:41:31,225-0600 INFO  Multiplexer No streams
-2013-11-06 13:41:34,269-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:41:41,233-0600 INFO  Multiplexer No streams
-2013-11-06 13:41:42,937-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:41:51,240-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:42:01,248-0600 INFO  Multiplexer No streams
-2013-11-06 13:42:10,743-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:42:11,255-0600 INFO  Multiplexer No streams
-2013-11-06 13:42:20,255-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:42:21,263-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:42:31,274-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:42:41,282-0600 INFO  Multiplexer No streams
-2013-11-06 13:42:47,217-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:42:51,289-0600 INFO  Multiplexer No streams
-2013-11-06 13:42:57,573-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:43:01,296-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:43:11,304-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:43:21,311-0600 INFO  Multiplexer No streams
-2013-11-06 13:43:23,691-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:43:31,318-0600 INFO  Multiplexer No streams
-2013-11-06 13:43:34,891-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:43:41,325-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:43:51,333-0600 INFO  Multiplexer No streams
-2013-11-06 13:44:00,165-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:44:01,340-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:44:11,347-0600 INFO  Multiplexer No streams
-2013-11-06 13:44:12,209-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:44:21,354-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:44:31,362-0600 INFO  Multiplexer No streams
-2013-11-06 13:44:36,639-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:44:41,369-0600 INFO  Multiplexer No streams
-2013-11-06 13:44:49,527-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:44:51,377-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:45:01,385-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:45:11,392-0600 INFO  Multiplexer No streams
-2013-11-06 13:45:13,114-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:45:21,400-0600 INFO  Multiplexer No streams
-2013-11-06 13:45:26,846-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:45:31,408-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:45:41,415-0600 INFO  Multiplexer No streams
-2013-11-06 13:45:49,587-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:45:51,423-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:46:01,431-0600 INFO  Multiplexer No streams
-2013-11-06 13:46:04,163-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:46:11,438-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:46:21,446-0600 INFO  Multiplexer No streams
-2013-11-06 13:46:26,062-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:46:31,454-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:46:41,462-0600 INFO  Multiplexer No streams
-2013-11-06 13:46:41,481-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:46:51,469-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:47:01,477-0600 INFO  Multiplexer No streams
-2013-11-06 13:47:02,535-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:47:11,485-0600 INFO  Multiplexer No streams
-2013-11-06 13:47:18,799-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:47:21,493-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:47:31,500-0600 INFO  Multiplexer No streams
-2013-11-06 13:47:39,009-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:47:41,508-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:47:51,516-0600 INFO  Multiplexer No streams
-2013-11-06 13:47:56,117-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:48:01,524-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:48:11,532-0600 INFO  Multiplexer No streams
-2013-11-06 13:48:15,483-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:48:21,540-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:48:31,547-0600 INFO  Multiplexer No streams
-2013-11-06 13:48:33,436-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:48:41,555-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:48:51,563-0600 INFO  Multiplexer No streams
-2013-11-06 13:48:51,957-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:49:01,571-0600 INFO  Multiplexer No streams
-2013-11-06 13:49:10,754-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:49:11,579-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:49:21,587-0600 INFO  Multiplexer No streams
-2013-11-06 13:49:28,432-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 13:49:31,594-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:49:41,602-0600 INFO  Multiplexer No streams
-2013-11-06 13:49:48,071-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:49:51,610-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:50:01,618-0600 INFO  Multiplexer No streams
-2013-11-06 13:50:04,905-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:50:11,626-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:50:21,634-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 13:50:25,390-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:50:31,642-0600 INFO  Multiplexer No streams
-2013-11-06 13:50:41,380-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:50:41,650-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:50:51,658-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:51:01,666-0600 INFO  Multiplexer No streams
-2013-11-06 13:51:02,707-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:51:11,674-0600 INFO  Multiplexer No streams
-2013-11-06 13:51:17,854-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:51:21,681-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:51:31,689-0600 INFO  Multiplexer No streams
-2013-11-06 13:51:40,025-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:51:41,697-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:51:51,705-0600 INFO  Multiplexer No streams
-2013-11-06 13:51:54,329-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:52:01,713-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:52:11,721-0600 INFO  Multiplexer No streams
-2013-11-06 13:52:17,343-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:52:21,729-0600 INFO  Multiplexer No streams
-2013-11-06 13:52:30,803-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:52:31,737-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:52:41,744-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:52:51,752-0600 INFO  Multiplexer No streams
-2013-11-06 13:52:54,661-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:53:01,761-0600 INFO  Multiplexer No streams
-2013-11-06 13:53:07,277-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:53:11,769-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:53:21,777-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:53:31,785-0600 INFO  Multiplexer No streams
-2013-11-06 13:53:31,979-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:53:41,793-0600 INFO  Multiplexer No streams
-2013-11-06 13:53:43,751-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:53:51,801-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:54:01,809-0600 INFO  Multiplexer No streams
-2013-11-06 13:54:09,297-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:54:11,817-0600 INFO  Multiplexer No streams
-2013-11-06 13:54:20,225-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:54:21,825-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:54:31,833-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:54:41,841-0600 INFO  Multiplexer No streams
-2013-11-06 13:54:46,615-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:54:51,849-0600 INFO  Multiplexer No streams
-2013-11-06 13:54:56,699-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:55:01,858-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:55:11,866-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:55:21,874-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 13:55:23,934-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 13:55:31,882-0600 INFO  Multiplexer No streams
-2013-11-06 13:55:33,173-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:55:41,891-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:55:51,899-0600 INFO  Multiplexer No streams
-2013-11-06 13:56:01,251-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:56:01,907-0600 INFO  Multiplexer No streams
-2013-11-06 13:56:09,647-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:56:11,916-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:56:21,924-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:56:31,932-0600 INFO  Multiplexer No streams
-2013-11-06 13:56:38,569-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:56:41,941-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-11-06 13:56:46,120-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-No streams
-2013-11-06 13:56:51,949-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:57:01,957-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:57:11,965-0600 INFO  Multiplexer No streams
-2013-11-06 13:57:15,887-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:57:21,974-0600 INFO  Multiplexer No streams
-2013-11-06 13:57:22,595-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:57:31,982-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:57:41,990-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:57:51,998-0600 INFO  Multiplexer No streams
-2013-11-06 13:57:53,205-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 13:57:59,069-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 13:58:02,006-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:58:12,015-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:58:22,023-0600 INFO  Multiplexer No streams
-2013-11-06 13:58:30,523-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:58:32,031-0600 INFO  Multiplexer No streams
-2013-11-06 13:58:35,543-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:58:42,039-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:58:52,047-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 13:59:02,054-0600 INFO  Multiplexer No streams
-2013-11-06 13:59:07,841-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 13:59:12,017-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 13:59:12,062-0600 INFO  Multiplexer No streams
-Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-11-06 13:59:12,170-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40899] for addition
-2013-11-06 13:59:12,171-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40899] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40899]
-2013-11-06 13:59:12,171-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40899]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe3
-2013-11-06 13:59:12,204-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe3
-MetaChannel [context: cps-40899, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40899]
-2013-11-06 13:59:12,204-0600 INFO  MetaChannel MetaChannel [context: cps-40899, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40899]
-Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 13:59:12,204-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-Sender TCPChannel queue size: 0
-2013-11-06 13:59:12,244-0600 INFO  Sender Sender TCPChannel queue size: 0
-Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 13:59:12,245-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 13:59:12,325-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 13:59:12,368-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 17.0) submitting urn:job-0-1383759274534-1383759274535: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 13:59:12,368-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 17.0) submitting urn:job-0-1383759274534-1383759274535: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 13:59:12,369-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 13:59:12,369-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 13:59:12,375-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7366, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:12,375-0600 INFO  RequestHandler Handler(tag: 7366, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:14,449-0600 DEBUG Cpu Completed
-grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 13:59:14,449-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 13:59:14,449-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7367, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:14,449-0600 INFO  RequestHandler Handler(tag: 7367, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:14,449-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 13:59:14,449-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 13:59:14,450-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40900] for addition
-2013-11-06 13:59:14,450-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40900] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40900]
-2013-11-06 13:59:14,450-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40900]
-Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fe2
-2013-11-06 13:59:14,472-0600 INFO  ChannelConfigurationHandler Channel id: channel-2-u29cf5f3a-1422e7ae15d--7fe2
-MetaChannel [context: cps-40900, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40900]
-2013-11-06 13:59:14,472-0600 INFO  MetaChannel MetaChannel [context: cps-40900, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40900]
-Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-2013-11-06 13:59:14,472-0600 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
-Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-2013-11-06 13:59:14,512-0600 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
-Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 13:59:14,593-0600 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
-2013-11-06 13:59:14,599-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 18.0) submitting urn:job-1-1383759274537-1383759274538: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 13:59:14,599-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 18.0) submitting urn:job-1-1383759274537-1383759274538: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 13:59:14,600-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 13:59:14,600-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 13:59:14,607-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7368, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:14,607-0600 INFO  RequestHandler Handler(tag: 7368, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:16,618-0600 DEBUG Cpu Completed
-2013-11-06 13:59:16,618-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 13:59:16,618-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7369, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:16,618-0600 INFO  RequestHandler Handler(tag: 7369, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:16,618-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 13:59:16,618-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-2013-11-06 13:59:16,619-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40901] for addition
-2013-11-06 13:59:16,619-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40901] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40901]
-2013-11-06 13:59:16,620-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40901]
-Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fe1
-2013-11-06 13:59:16,660-0600 INFO  ChannelConfigurationHandler Channel id: channel-3-u29cf5f3a-1422e7ae15d--7fe1
-MetaChannel [context: cps-40901, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40901]
-2013-11-06 13:59:16,660-0600 INFO  MetaChannel MetaChannel [context: cps-40901, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40901]
-Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-2013-11-06 13:59:16,660-0600 INFO  RequestHandler Handler(tag: 42564, CHANNELCONFIG) unregistering (send)
-Handler(tag: 42565, CONFIGSERVICE) unregistering (send)
-2013-11-06 13:59:16,680-0600 INFO  RequestHandler Handler(tag: 42565, CONFIGSERVICE) unregistering (send)
-Handler(tag: 42566, SUBMITJOB) unregistering (send)
-2013-11-06 13:59:16,761-0600 INFO  RequestHandler Handler(tag: 42566, SUBMITJOB) unregistering (send)
-2013-11-06 13:59:16,769-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 19.0) submitting urn:job-2-1383759274540-1383759274541: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 13:59:16,769-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 19.0) submitting urn:job-2-1383759274540-1383759274541: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/branches/issue-503/code/tests/coasters/wrapper.sh
-2013-11-06 13:59:16,769-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 13:59:16,769-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 13:59:16,775-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7370, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:16,776-0600 INFO  RequestHandler Handler(tag: 7370, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:18,791-0600 DEBUG Cpu Completed
-2013-11-06 13:59:18,791-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 13:59:18,791-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 13:59:18,791-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7371, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:18,791-0600 INFO  RequestHandler Handler(tag: 7371, JOBSTATUS) unregistering (send)
-2013-11-06 13:59:18,791-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 13:59:22,076-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 13:59:32,086-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 13:59:42,095-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 13:59:45,160-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 13:59:48,492-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 13:59:52,104-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:00:02,113-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:00:12,122-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:00:22,131-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:00:22,477-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:00:24,966-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:00:32,141-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:00:42,150-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:00:52,159-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:00:59,796-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:01:01,440-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:01:02,169-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:01:12,178-0600 INFO  Multiplexer Avg stream buf: 0
-Notifying commands and handlers about exception
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-135912.325, now=131106-140113.172, channel=TCPChannel [type: server, contact: 127.0.0.1:40899]
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
-	at java.util.TimerThread.mainLoop(Timer.java:534)
-	at java.util.TimerThread.run(Timer.java:484)
-2013-11-06 14:01:13,172-0600 INFO  ChannelContext Notifying commands and handlers about exception
-=> Command(tag: 1, JOBSTATUS)
-2013-11-06 14:01:13,172-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-Client could not properly process notification: null
-2013-11-06 14:01:13,172-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 2, JOBSTATUS)
-2013-11-06 14:01:13,172-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-=> Command(tag: 3, JOBSTATUS)
-2013-11-06 14:01:13,173-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:01:13,173-0600 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 4, JOBSTATUS)
-2013-11-06 14:01:13,173-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-Channel config: null -> {keepalive=null}
-2013-11-06 14:01:13,173-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40899] handling channel exception
-2013-11-06 14:01:13,173-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40899] handling channel exception
-null: Channel shut down
-2013-11-06 14:01:13,174-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40899, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40899]] binding to NullChannel
-2013-11-06 14:01:13,174-0600 INFO  MetaChannel MetaChannel [context: cps-40899, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40899]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40899]
-2013-11-06 14:01:13,174-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40899]
-2013-11-06 14:01:13,174-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:01:13,174-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:01:13,174-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:13,174-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:01:13,175-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:13,175-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:01:13,175-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-Channel exception handled
-2013-11-06 14:01:13,175-0600 INFO  ChannelManager Channel exception handled
-Channel is closed. Removing.
-2013-11-06 14:01:13,181-0600 INFO  Multiplexer Channel is closed. Removing.
-Exception in channel step
-java.io.IOException: Stream closed.
-	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
-	at java.net.SocketInputStream.available(SocketInputStream.java:234)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
-	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
-2013-11-06 14:01:13,181-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:01:13,181-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:01:13,181-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40899] handling channel exception
-Channel already shut down
-2013-11-06 14:01:13,181-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40899]
-2013-11-06 14:01:13,182-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40899]
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-135914.593, now=131106-140115.450, channel=TCPChannel [type: server, contact: 127.0.0.1:40900]
-2013-11-06 14:01:15,450-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:01:15,450-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:01:15,450-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:15,450-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:01:15,451-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:15,451-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:01:15,451-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:01:15,451-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40900] handling channel exception
-2013-11-06 14:01:15,451-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40900] handling channel exception
-2013-11-06 14:01:15,452-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40900, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40900]] binding to NullChannel
-2013-11-06 14:01:15,452-0600 INFO  MetaChannel MetaChannel [context: cps-40900, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40900]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40900]
-2013-11-06 14:01:15,452-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40900]
-2013-11-06 14:01:15,452-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:01:15,452-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:01:15,452-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:15,452-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:01:15,453-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:01:15,453-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:15,453-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:01:15,453-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:01:15,468-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:01:15,468-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:01:15,469-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:01:15,469-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40900] handling channel exception
-2013-11-06 14:01:15,469-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40900]
-2013-11-06 14:01:15,469-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40900]
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-135916.760, now=131106-140117.620, channel=TCPChannel [type: server, contact: 127.0.0.1:40901]
-2013-11-06 14:01:17,620-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:01:17,620-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:01:17,620-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:17,620-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:01:17,621-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:01:17,621-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:17,621-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:01:17,621-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40901] handling channel exception
-2013-11-06 14:01:17,621-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40901] handling channel exception
-2013-11-06 14:01:17,622-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40901, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40901]] binding to NullChannel
-2013-11-06 14:01:17,622-0600 INFO  MetaChannel MetaChannel [context: cps-40901, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40901]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40901]
-2013-11-06 14:01:17,622-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40901]
-2013-11-06 14:01:17,622-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:01:17,622-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:01:17,622-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:17,622-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:01:17,622-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:01:17,623-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:01:17,623-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:01:17,623-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:01:17,635-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:01:17,635-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:01:17,636-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:01:17,636-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40901] handling channel exception
-2013-11-06 14:01:17,636-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40901]
-2013-11-06 14:01:17,636-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40901]
-No streams
-2013-11-06 14:01:22,189-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:01:32,197-0600 INFO  Multiplexer No streams
-2013-11-06 14:01:37,113-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:01:37,914-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 14:01:42,205-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:01:52,213-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:02:02,221-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:02:12,229-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
-2013-11-06 14:02:14,392-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
-2013-11-06 14:02:14,431-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:02:16,727-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40903] for addition
-2013-11-06 14:02:16,727-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40903] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40903]
-2013-11-06 14:02:16,727-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40903]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe0
-2013-11-06 14:02:16,762-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fe0
-MetaChannel [context: cps-40903, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40903]
-2013-11-06 14:02:16,763-0600 INFO  MetaChannel MetaChannel [context: cps-40903, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40903]
-2013-11-06 14:02:16,763-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 14:02:16,803-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 14:02:16,803-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 14:02:16,884-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 14:02:16,893-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 20.0) submitting urn:job-0-1383759274543-1383759274544: /bin/echo
-2013-11-06 14:02:16,893-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 20.0) submitting urn:job-0-1383759274543-1383759274544: /bin/echo
-2013-11-06 14:02:16,894-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 14:02:16,894-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 14:02:16,900-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7372, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:16,900-0600 INFO  RequestHandler Handler(tag: 7372, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:16,919-0600 DEBUG Cpu Completed
-2013-11-06 14:02:16,919-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 14:02:16,919-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 14:02:16,919-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7373, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:16,919-0600 INFO  RequestHandler Handler(tag: 7373, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:16,919-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 14:02:22,239-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:02:25,463-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40904] for addition
-2013-11-06 14:02:25,464-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40904] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40904]
-2013-11-06 14:02:25,464-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40904]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdf
-2013-11-06 14:02:25,492-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdf
-MetaChannel [context: cps-40904, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40904]
-2013-11-06 14:02:25,492-0600 INFO  MetaChannel MetaChannel [context: cps-40904, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40904]
-2013-11-06 14:02:25,492-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 14:02:25,533-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 14:02:25,613-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 14:02:25,630-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 21.0) submitting urn:job-0-1383759274546-1383759274547: /bin/echo
-2013-11-06 14:02:25,630-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 21.0) submitting urn:job-0-1383759274546-1383759274547: /bin/echo
-2013-11-06 14:02:25,631-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 14:02:25,631-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 14:02:25,638-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7374, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:25,638-0600 INFO  RequestHandler Handler(tag: 7374, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:25,640-0600 DEBUG Cpu Completed
-2013-11-06 14:02:25,640-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 14:02:25,640-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7375, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:25,640-0600 INFO  RequestHandler Handler(tag: 7375, JOBSTATUS) unregistering (send)
-2013-11-06 14:02:25,641-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 14:02:25,641-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 14:02:32,253-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:02:42,262-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 14:02:50,863-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 14:02:51,749-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:02:52,271-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:03:02,280-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:03:12,288-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:03:22,297-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:03:27,336-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:03:29,067-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:03:32,307-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:03:32,483-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40905] for addition
-2013-11-06 14:03:32,483-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40905] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40905]
-2013-11-06 14:03:32,483-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40905]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fde
-2013-11-06 14:03:32,508-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fde
-MetaChannel [context: cps-40905, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40905]
-2013-11-06 14:03:32,508-0600 INFO  MetaChannel MetaChannel [context: cps-40905, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40905]
-2013-11-06 14:03:32,508-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 14:03:32,549-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 14:03:32,549-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 14:03:32,629-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 14:03:32,671-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 22.0) submitting urn:job-0-1383759274549-1383759274550: /bin/echo
-2013-11-06 14:03:32,671-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 22.0) submitting urn:job-0-1383759274549-1383759274550: /bin/echo
-2013-11-06 14:03:32,672-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 14:03:32,672-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 14:03:32,678-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7376, JOBSTATUS) unregistering (send)
-2013-11-06 14:03:32,678-0600 INFO  RequestHandler Handler(tag: 7376, JOBSTATUS) unregistering (send)
-2013-11-06 14:03:32,680-0600 DEBUG Cpu Completed
-2013-11-06 14:03:32,680-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 14:03:32,680-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7377, JOBSTATUS) unregistering (send)
-2013-11-06 14:03:32,681-0600 INFO  RequestHandler Handler(tag: 7377, JOBSTATUS) unregistering (send)
-2013-11-06 14:03:32,681-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 14:03:32,681-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 14:03:42,318-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:03:52,327-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:04:02,337-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:04:03,810-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:04:06,385-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:04:10,904-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40906] for addition
-2013-11-06 14:04:10,904-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40906] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40906]
-2013-11-06 14:04:10,904-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40906]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdd
-2013-11-06 14:04:10,942-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdd
-MetaChannel [context: cps-40906, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40906]
-2013-11-06 14:04:10,943-0600 INFO  MetaChannel MetaChannel [context: cps-40906, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40906]
-2013-11-06 14:04:10,943-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 14:04:10,963-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 14:04:10,963-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 14:04:11,044-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 14:04:11,075-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 23.0) submitting urn:job-0-1383759274552-1383759274553: /bin/echo
-2013-11-06 14:04:11,075-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 23.0) submitting urn:job-0-1383759274552-1383759274553: /bin/echo
-2013-11-06 14:04:11,076-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 14:04:11,076-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 14:04:11,083-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7378, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:11,083-0600 INFO  RequestHandler Handler(tag: 7378, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:11,085-0600 DEBUG Cpu Completed
-2013-11-06 14:04:11,085-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 14:04:11,085-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7379, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:11,085-0600 INFO  RequestHandler Handler(tag: 7379, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:11,085-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 14:04:11,085-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 14:04:12,348-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-140216.883, now=131106-140417.727, channel=TCPChannel [type: server, contact: 127.0.0.1:40903]
-2013-11-06 14:04:17,727-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:04:17,728-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:04:17,728-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:04:17,728-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:04:17,728-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:04:17,729-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:04:17,729-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:04:17,729-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40903] handling channel exception
-2013-11-06 14:04:17,729-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40903] handling channel exception
-2013-11-06 14:04:17,729-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40903, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40903]] binding to NullChannel
-2013-11-06 14:04:17,729-0600 INFO  MetaChannel MetaChannel [context: cps-40903, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40903]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40903]
-2013-11-06 14:04:17,729-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40903]
-2013-11-06 14:04:17,729-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:04:17,730-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:04:17,730-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:04:17,730-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:04:17,730-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:04:17,730-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:04:17,731-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:04:17,744-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:04:17,744-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:04:17,744-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:04:17,744-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40903] handling channel exception
-2013-11-06 14:04:17,744-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40903]
-2013-11-06 14:04:17,745-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40903]
-Avg stream buf: 0
-2013-11-06 14:04:22,358-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:04:23,298-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40907] for addition
-2013-11-06 14:04:23,298-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40907] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:04:23,299-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40907]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdc
-2013-11-06 14:04:23,322-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdc
-MetaChannel [context: cps-40907, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:04:23,322-0600 INFO  MetaChannel MetaChannel [context: cps-40907, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:04:23,322-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 14:04:23,383-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 14:04:23,383-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 14:04:23,464-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 14:04:23,500-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 24.0) submitting urn:job-0-1383759274555-1383759274556: /bin/echo
-2013-11-06 14:04:23,500-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 24.0) submitting urn:job-0-1383759274555-1383759274556: /bin/echo
-2013-11-06 14:04:23,501-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 14:04:23,501-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 14:04:23,509-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7380, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:23,509-0600 INFO  RequestHandler Handler(tag: 7380, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:23,512-0600 DEBUG Cpu Completed
-2013-11-06 14:04:23,512-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 14:04:23,512-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7381, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:23,512-0600 INFO  RequestHandler Handler(tag: 7381, JOBSTATUS) unregistering (send)
-2013-11-06 14:04:23,512-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 14:04:23,512-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-140225.613, now=131106-140426.464, channel=TCPChannel [type: server, contact: 127.0.0.1:40904]
-2013-11-06 14:04:26,464-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:04:26,464-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:04:26,464-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:04:26,465-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:04:26,465-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:04:26,465-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:04:26,465-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:04:26,466-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40904] handling channel exception
-2013-11-06 14:04:26,466-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40904] handling channel exception
-2013-11-06 14:04:26,466-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40904, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40904]] binding to NullChannel
-2013-11-06 14:04:26,466-0600 INFO  MetaChannel MetaChannel [context: cps-40904, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40904]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40904]
-2013-11-06 14:04:26,466-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40904]
-2013-11-06 14:04:26,466-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:04:26,466-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:04:26,466-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:04:26,467-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:04:26,467-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:04:26,467-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:04:26,467-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:04:26,467-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:04:26,473-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:04:26,473-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:04:26,474-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:04:26,474-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40904] handling channel exception
-2013-11-06 14:04:26,474-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40904]
-2013-11-06 14:04:26,474-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40904]
-Avg stream buf: 0
-2013-11-06 14:04:32,371-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:04:40,284-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:04:42,380-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:04:43,703-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:04:52,389-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:05:02,399-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:05:12,408-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:05:16,759-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 14:05:21,021-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:05:22,417-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:05:32,426-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-140332.629, now=131106-140533.483, channel=TCPChannel [type: server, contact: 127.0.0.1:40905]
-2013-11-06 14:05:33,483-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:05:33,484-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:05:33,484-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:05:33,484-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:05:33,484-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:05:33,485-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:05:33,485-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:05:33,485-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40905] handling channel exception
-2013-11-06 14:05:33,485-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40905] handling channel exception
-2013-11-06 14:05:33,485-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40905, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40905]] binding to NullChannel
-2013-11-06 14:05:33,485-0600 INFO  MetaChannel MetaChannel [context: cps-40905, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40905]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40905]
-2013-11-06 14:05:33,485-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40905]
-2013-11-06 14:05:33,485-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:05:33,486-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:05:33,486-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:05:33,486-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:05:33,486-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:05:33,486-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:05:33,487-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:05:33,490-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:05:33,490-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:05:33,490-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:05:33,490-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40905] handling channel exception
-2013-11-06 14:05:33,490-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40905]
-2013-11-06 14:05:33,490-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40905]
-Avg stream buf: 0
-2013-11-06 14:05:42,436-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:05:52,445-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:05:53,233-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 14:05:58,339-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:06:02,454-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-140411.044, now=131106-140611.904, channel=TCPChannel [type: server, contact: 127.0.0.1:40906]
-2013-11-06 14:06:11,904-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:06:11,904-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:06:11,904-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:11,904-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:06:11,905-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:06:11,905-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:11,905-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:06:11,905-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40906] handling channel exception
-2013-11-06 14:06:11,905-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40906] handling channel exception
-2013-11-06 14:06:11,905-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40906, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40906]] binding to NullChannel
-2013-11-06 14:06:11,906-0600 INFO  MetaChannel MetaChannel [context: cps-40906, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40906]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40906]
-2013-11-06 14:06:11,906-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40906]
-2013-11-06 14:06:11,906-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:06:11,906-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:06:11,906-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:11,906-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:06:11,906-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:06:11,907-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:06:11,907-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:11,907-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:06:11,921-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:06:11,921-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:06:11,922-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:06:11,922-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40906] handling channel exception
-2013-11-06 14:06:11,922-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40906]
-2013-11-06 14:06:11,922-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40906]
-Avg stream buf: 0
-2013-11-06 14:06:12,464-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:06:22,472-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-140423.464, now=131106-140624.298, channel=TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:06:24,298-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:06:24,298-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:06:24,298-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:24,299-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:06:24,299-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:24,299-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:06:24,299-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:06:24,299-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40907] handling channel exception
-2013-11-06 14:06:24,299-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40907] handling channel exception
-2013-11-06 14:06:24,300-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40907, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40907]] binding to NullChannel
-2013-11-06 14:06:24,300-0600 INFO  MetaChannel MetaChannel [context: cps-40907, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40907]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:06:24,300-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:06:24,300-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:06:24,300-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:06:24,300-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:24,300-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:06:24,301-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:06:24,301-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:06:24,301-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:06:24,301-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:06:24,318-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:06:24,318-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:06:24,318-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:06:24,318-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40907] handling channel exception
-2013-11-06 14:06:24,318-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:06:24,318-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40907]
-2013-11-06 14:06:29,706-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 14:06:32,481-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 14:06:35,657-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-No streams
-2013-11-06 14:06:42,489-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:06:52,497-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:07:02,506-0600 INFO  Multiplexer No streams
-2013-11-06 14:07:06,180-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 14:07:12,514-0600 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-11-06 14:07:12,975-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 14:07:22,522-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:07:32,530-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:07:42,539-0600 INFO  Multiplexer No streams
-2013-11-06 14:07:42,654-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 14:07:50,294-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-No streams
-2013-11-06 14:07:52,548-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:08:02,557-0600 INFO  Multiplexer No streams
-No streams
-2013-11-06 14:08:12,566-0600 INFO  Multiplexer No streams
-2013-11-06 14:08:19,128-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-No streams
-2013-11-06 14:08:22,575-0600 INFO  Multiplexer No streams
-2013-11-06 14:08:27,612-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-No streams
-2013-11-06 14:08:32,590-0600 INFO  Multiplexer No streams
-2013-11-06 14:08:41,336-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40918] for addition
-2013-11-06 14:08:41,336-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40918] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40918]
-2013-11-06 14:08:41,336-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40918]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdb
-2013-11-06 14:08:41,359-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fdb
-MetaChannel [context: cps-40918, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40918]
-2013-11-06 14:08:41,359-0600 INFO  MetaChannel MetaChannel [context: cps-40918, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40918]
-2013-11-06 14:08:41,359-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 14:08:41,400-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 14:08:41,400-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 14:08:41,481-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 14:08:41,511-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 25.0) submitting urn:job-0-1383759274558-1383759274559: /bin/echo
-2013-11-06 14:08:41,511-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 25.0) submitting urn:job-0-1383759274558-1383759274559: /bin/echo
-2013-11-06 14:08:41,512-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 14:08:41,512-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 14:08:41,519-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7382, JOBSTATUS) unregistering (send)
-2013-11-06 14:08:41,519-0600 INFO  RequestHandler Handler(tag: 7382, JOBSTATUS) unregistering (send)
-2013-11-06 14:08:41,522-0600 DEBUG Cpu Completed
-2013-11-06 14:08:41,522-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 14:08:41,522-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-2013-11-06 14:08:41,522-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-Handler(tag: 7383, JOBSTATUS) unregistering (send)
-2013-11-06 14:08:41,522-0600 INFO  RequestHandler Handler(tag: 7383, JOBSTATUS) unregistering (send)
-2013-11-06 14:08:41,522-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 14:08:42,605-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:08:52,612-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-11-06 14:08:55,604-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 14:09:02,622-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:09:04,929-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:09:12,635-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:09:22,649-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:09:32,078-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:09:32,665-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:09:42,247-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:09:42,680-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:09:48,612-0600 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40919] for addition
-2013-11-06 14:09:48,613-0600 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 127.0.0.1:40919] for addition
-Channel started: TCPChannel [type: server, contact: 127.0.0.1:40919]
-2013-11-06 14:09:48,613-0600 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 127.0.0.1:40919]
-Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fda
-2013-11-06 14:09:48,645-0600 INFO  ChannelConfigurationHandler Channel id: channel-1-u29cf5f3a-1422e7ae15d--7fda
-MetaChannel [context: cps-40919, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40919]
-2013-11-06 14:09:48,645-0600 INFO  MetaChannel MetaChannel [context: cps-40919, boundTo: null] binding to TCPChannel [type: server, contact: 127.0.0.1:40919]
-2013-11-06 14:09:48,645-0600 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
-2013-11-06 14:09:48,705-0600 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-11-06 14:09:48,705-0600 INFO  Sender Sender TCPChannel queue size: 0
-2013-11-06 14:09:48,786-0600 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-11-06 14:09:48,817-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 1
-grind.mcs.anl.gov:0 (quality: 26.0) submitting urn:job-0-1383759274561-1383759274562: /bin/echo
-2013-11-06 14:09:48,817-0600 INFO  Cpu grind.mcs.anl.gov:0 (quality: 26.0) submitting urn:job-0-1383759274561-1383759274562: /bin/echo
-2013-11-06 14:09:48,818-0600 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
-2013-11-06 14:09:48,818-0600 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-2013-11-06 14:09:48,827-0600 DEBUG Cpu Active workerid=grind.mcs.anl.gov:000000
-Handler(tag: 7384, JOBSTATUS) unregistering (send)
-2013-11-06 14:09:48,827-0600 INFO  RequestHandler Handler(tag: 7384, JOBSTATUS) unregistering (send)
-2013-11-06 14:09:48,829-0600 DEBUG Cpu Completed
-2013-11-06 14:09:48,829-0600 INFO  Cpu grind.mcs.anl.gov:0 jobTerminated
-2013-11-06 14:09:48,829-0600 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Handler(tag: 7385, JOBSTATUS) unregistering (send)
-2013-11-06 14:09:48,829-0600 INFO  RequestHandler Handler(tag: 7385, JOBSTATUS) unregistering (send)
-2013-11-06 14:09:48,829-0600 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
-2013-11-06 14:09:48,829-0600 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Avg stream buf: 0
-2013-11-06 14:09:52,682-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:10:02,696-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-11-06 14:10:08,551-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:10:12,706-0600 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-11-06 14:10:19,566-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 14:10:22,722-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:10:32,731-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-140841.480, now=131106-141042.336, channel=TCPChannel [type: server, contact: 127.0.0.1:40918]
-2013-11-06 14:10:42,336-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:10:42,336-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:10:42,336-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:10:42,337-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:10:42,337-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:10:42,337-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:10:42,337-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:10:42,338-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40918] handling channel exception
-2013-11-06 14:10:42,338-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40918] handling channel exception
-2013-11-06 14:10:42,338-0600 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-40918, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40918]] binding to NullChannel
-2013-11-06 14:10:42,338-0600 INFO  MetaChannel MetaChannel [context: cps-40918, boundTo: TCPChannel [type: server, contact: 127.0.0.1:40918]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40918]
-2013-11-06 14:10:42,338-0600 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 127.0.0.1:40918]
-2013-11-06 14:10:42,338-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:10:42,339-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:10:42,339-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:10:42,339-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:10:42,339-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:10:42,339-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:10:42,340-0600 INFO  ChannelManager Channel exception handled
-2013-11-06 14:10:42,340-0600 INFO  Multiplexer Channel is closed. Removing.
-2013-11-06 14:10:42,341-0600 INFO  Multiplexer Exception in channel step
-2013-11-06 14:10:42,341-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-11-06 14:10:42,341-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40918] handling channel exception
-2013-11-06 14:10:42,341-0600 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40918]
-2013-11-06 14:10:42,341-0600 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 127.0.0.1:40918]
-Avg stream buf: 0
-2013-11-06 14:10:42,743-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:10:45,026-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-Avg stream buf: 0
-2013-11-06 14:10:52,752-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:10:56,884-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:11:02,762-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:11:12,772-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:11:21,500-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:11:22,781-0600 INFO  Multiplexer Avg stream buf: 0
-Avg stream buf: 0
-2013-11-06 14:11:32,792-0600 INFO  Multiplexer Avg stream buf: 0
-2013-11-06 14:11:34,202-0600 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-Avg stream buf: 0
-2013-11-06 14:11:42,802-0600 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131106-140948.786, now=131106-141149.613, channel=TCPChannel [type: server, contact: 127.0.0.1:40919]
-2013-11-06 14:11:49,613-0600 INFO  ChannelContext Notifying commands and handlers about exception
-2013-11-06 14:11:49,613-0600 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-11-06 14:11:49,613-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:11:49,614-0600 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-11-06 14:11:49,614-0600 WARN  TaskNotifier Client could not properly process notification: null
-2013-11-06 14:11:49,614-0600 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-11-06 14:11:49,614-0600 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-11-06 14:11:49,615-0600 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 127.0.0.1:40919] handling channel exception
-2013-11-06 14:11:49,615-0600 INFO  ChannelManager TCPChannel [type: server, contact: 127.0.0.1:40919] handling channel exception
