[Swift-commit] r7290 - trunk/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Nov 13 22:53:24 CST 2013
Author: davidk
Date: 2013-11-13 22:53:24 -0600 (Wed, 13 Nov 2013)
New Revision: 7290
Added:
   trunk/bin/swift-workers
Log:
Initial commit of swift-workers script
Added: trunk/bin/swift-workers
--- trunk/bin/swift-workers	                        (rev 0)
+++ trunk/bin/swift-workers	2013-11-14 04:53:24 UTC (rev 7290)
@@ -0,0 +1,188 @@
+#!/bin/bash
+export SWIFT_BIN="$( cd "$( dirname "$0" )" && pwd )"
+export SERVICE_DIR="$HOME/.swift/service"
+# Report a problem and exit
+crash()
+   MSG=$1
+   echo ${MSG} >&2
+   exit 1
+# Print usage
+usage()
+   crash "$( basename $0 ) [ -start | -stop ] [ -service servicename ]"
+# Return current timestamp
+get_timestamp()
+   date +"%b %d %H:%M:%S "
+# Write command to log, run command, wait for completion
+run_command()
+   command="$@"
+   echo "$( get_timestamp ) Running command $command" >> $LOG
+   $command 2>&1 | tee -a $LOG
+# Write command to log, run in background, return PID
+run_command_bg()
+   command="$@"
+   echo "$( get_timestamp ) Running background command $command" >> $LOG
+   $command >> $LOG 2>&1 &
+   echo $!
+verify_files_exist()
+   for file in "$@"
+   do
+      if [ ! -f "$file" ]; then
+         crash "File $file does not exist. Service is in a corrupt state, please stop and restart"
+      fi
+   done
+# Kill all children processes
+nicely_kill_all_children()
+   PID=$1
+   ps -u $USER -o "pid,ppid"|sed 1d | while read PROC
+   do
+      PROC_PID=$( echo $PROC | awk '{print $1}' )
+      PROC_PPID=$( echo $PROC | awk '{print $2}' )
+      if [ $PROC_PPID == $PID ]; then
+         nice_kill $PROC_PID 5
+      fi
+   done
+   nice_kill $PID 5
+# Try to nicely kill a process before giving it a SIGKILL
+nice_kill()
+   pid=$1
+   grace=$2
+   run_command kill $pid &>/dev/null
+   count=0
+   while ps -p $pid &>/dev/null
+   do
+      sleep 1
+      (( count++ ))
+      if [ "$count" -ge "$grace" ]; then
+         run_command kill -9 $pid
+      fi
+   done
+# Start SSH workers
+start-workers-ssh()
+   for MACHINE in $WORKER_HOSTS
+   do
+      # Enable ssh tunneling if needed
+      if [ "$SSH_TUNNELING" != "no" ]; then
+         run_command_bg ssh -N -T -R *:$LOCAL_PORT:localhost:$LOCAL_PORT "$WORKER_USERNAME@$MACHINE"
+      fi
+      # Connect directly
+      run_command ssh $WORKER_USERNAME@$MACHINE mkdir -p $WORKER_LOCATION
+      run_command scp $WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION
+      echo Starting worker on $MACHINE
+      run_command_bg ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/worker.pl $WORKERURL $MACHINE $WORKER_LOG_DIR"
+   done
+   return 0
+# Start local workers
+start-workers-local()
+   for service in $SERVICE
+   do
+      echo Connecting local workers to service $service
+      service="$SERVICE_DIR/$service"
+      verify_files_exist $service/worker.path $service/worker.url
+      LOG=$service/workers.log
+      WORKER=$( cat $service/worker.path )
+      WORKERURL=$( cat $service/worker.url )
+      WORKERPID=$( run_command_bg $WORKER $WORKERURL $WORKER_LOG $WORKER_LOG_DIR )
+      echo $WORKERPID >> $service/worker.pid
+   done
+# Start condor workers
+start-workers-scheduler()
+   echo Starting workers
+   run_command $SCHEDULER_COMMAND
+# Print a list of services
+get_services()
+   find $SERVICE_DIR -mindepth 1 -maxdepth 1 -type d 2>/dev/null | sort -n
+# Stop worker processes
+stop_workers()
+   if [ ! -d "$SERVICE_DIR/$SERVICE" ]; then
+      crash "Service $SERVICE does not work"
+   fi
+   echo Stopping service $SERVICE
+   verify_files_exist "$SERVICE_DIR/$SERVICE/worker.pid"
+   nicely_kill_all_children $( cat $SERVICE_DIR/$SERVICE/worker.pid )
+   rm $SERVICE_DIR/$SERVICE/worker.pid
+# Parse command line arguments
+START=0;STOP=0
+while [ $# -gt 0 ]; do
+   case $1 in
+      -conf) CMDLN_CONF=$2; shift 2;;
+      -start) START=1; shift;;
+      -stop) STOP=1; shift;;
+      -service) SERVICE=$2; shift 2;;
+      *) echo "Do not recognize command line option: $1" 1>&2; exit 1;;
+   esac
+done
+if [ -z "$SERVICE" ] || [ $(($START+$STOP)) != 1 ]; then
+   usage
+fi
+# Defaults for worker logging
+WORKER_LOG="worker.log"
+WORKER_LOG_DIR="NOLOGGING"
+WORKER_LOGGING_LEVEL="OFF"
+# Import settings
+if [ -f "$CMDLN_CONF" ]; then
+   CONFIG_FILE=$CMDLN_CONF
+elif [ -f "coaster-service.conf" ]; then
+   CONFIG_FILE="coaster-service.conf"
+fi
+if [ -f "$CONFIG_FILE" ]; then
+   echo "Configuration: $CONFIG_FILE"
+   source $CONFIG_FILE
+fi
+if [ "$START" -eq 1 ]; then
+   case $WORKER_MODE in
+      ssh) start-workers-ssh;;
+      local) start-workers-local;;
+      scheduler) start-workers-scheduler;;
+      *) crash "Unknown WORKER_MODE";;
+  esac
+elif [ "$STOP" -eq 1 ]; then
+   stop_workers
+fi
Property changes on: trunk/bin/swift-workers
___________________________________________________________________
Added: svn:executable
