[Swift-commit] r7310 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Nov 22 22:03:07 CST 2013
Author: hategan
Date: 2013-11-22 22:03:07 -0600 (Fri, 22 Nov 2013)
New Revision: 7310
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
Log:
shorten progress lines a bit
Modified: trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2013-11-23 04:02:37 UTC (rev 7309)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2013-11-23 04:03:07 UTC (rev 7310)
@@ -66,7 +66,7 @@
     //formatter for timestamp against std.err lines
 	public static SimpleDateFormat formatter =
-		new SimpleDateFormat("E, dd MMM yyyy HH:mm:ss Z");
+		new SimpleDateFormat("E, dd MMM yyyy HH:mm:ssZ");
 	public static final int MIN_PERIOD_MS = 1000;
 	public static final int MAX_PERIOD_MS = 30000;
@@ -351,7 +351,6 @@
 			// pretty form - first the preferred order listed elements,
 			// and then anything remaining
 			System.err.print(prefix);
-			System.err.print(" ");
 			System.err.print(formatter.format(now));
 			for (int pos = 0; pos < preferredOutputOrder.length; pos++) {
