[Swift-commit] r7309 - trunk/src/org/griphyn/vdl/util
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Nov 22 22:02:38 CST 2013
Author: hategan
Date: 2013-11-22 22:02:37 -0600 (Fri, 22 Nov 2013)
New Revision: 7309
Modified:
   trunk/src/org/griphyn/vdl/util/VDL2Config.java
Log:
shorten progress lines a bit
Modified: trunk/src/org/griphyn/vdl/util/VDL2Config.java
--- trunk/src/org/griphyn/vdl/util/VDL2Config.java	2013-11-23 04:00:19 UTC (rev 7308)
+++ trunk/src/org/griphyn/vdl/util/VDL2Config.java	2013-11-23 04:02:37 UTC (rev 7309)
@@ -121,7 +121,7 @@
 		put("use.provider.staging", "false", ConfigPropertyType.BOOLEAN);
 		put("use.wrapper.staging", "false", ConfigPropertyType.BOOLEAN);
 		put("ticker.date.format", "", ConfigPropertyType.STRING);
-		put("ticker.prefix", "Progress:  time:", ConfigPropertyType.STRING);
+		put("ticker.prefix", "Progress: ", ConfigPropertyType.STRING);
 		put(VDL2ConfigProperties.FILE_GC_ENABLED, "true", ConfigPropertyType.BOOLEAN);
 		put(VDL2ConfigProperties.DM_CHECKER, "on", ConfigPropertyType.ONOFF);
