[Swift-commit] r7282 - in trunk: . bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu Nov 7 11:50:08 CST 2013
Author: davidk
Date: 2013-11-07 11:50:08 -0600 (Thu, 07 Nov 2013)
New Revision: 7282
Added:
   trunk/bin/apptimes
Modified:
   trunk/build.xml
Log:
apptimes script to plot run times of apps based on info files in *.d directories
Added: trunk/bin/apptimes
--- trunk/bin/apptimes	                        (rev 0)
+++ trunk/bin/apptimes	2013-11-07 17:50:08 UTC (rev 7282)
@@ -0,0 +1,40 @@
+#!/bin/bash
+crash()
+   MSG=$1
+   echo ${MSG}  >&2
+   exit 1
+usage()
+   crash "Usage: $0 </path/to/*.d>"
+if [ -z "$1" ]; then
+   usage
+fi
+directory=$1
+if [ ! -d "$directory" ]; then
+   crash "Directory $directory does not exist"
+fi
+cat <<'EOF'
+set terminal png large size 1024,768
+set output "apptimes.png"
+set ylabel "Runtime (seconds)"
+set xlabel "Task"
+set key off
+plot "apptimes.data"
+EOF
+) > apptimes.gp
+grep APP_ $directory/* | cut -d: -f3 | cut -d, -f1 | sort -n > apptimes.data
+gnuplot apptimes.gp || crash "Error running gnuplot"
+rm apptimes.gp apptimes.data
+echo "Output image: apptimes.png"
Property changes on: trunk/bin/apptimes
___________________________________________________________________
Added: svn:executable
Modified: trunk/build.xml
--- trunk/build.xml	2013-11-07 17:28:18 UTC (rev 7281)
+++ trunk/build.xml	2013-11-07 17:50:08 UTC (rev 7282)
@@ -85,6 +85,7 @@
 		<chmod perm="+x">
 			<fileset dir="${dist.dir}/bin">
+                                <include name="apptimes"/>
 				<include name="gensites"/>
                                 <include name="nswift"/>
 				<include name="start-coaster-service"/>
