[Swift-commit] r7281 - SwiftApps
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Nov 7 11:28:18 CST 2013
Author: ketan
Date: 2013-11-07 11:28:18 -0600 (Thu, 07 Nov 2013)
New Revision: 7281
Added:
   SwiftApps/README.OSDC
   SwiftApps/tc.data
Log:
Added: SwiftApps/README.OSDC
--- SwiftApps/README.OSDC	                        (rev 0)
+++ SwiftApps/README.OSDC	2013-11-07 17:28:18 UTC (rev 7281)
@@ -0,0 +1,34 @@
+This README documents the process of running the EPlus computations via Swift. The ~swift script for the computations is sweep1.swift. The prerequisites and preparation of run is described in the following points:
+-- Access to OSDC
+-- Swift installed: On OSDC Swift installation is available are /glusterfs/users/swiftlang/kmaheshwari/swift-0.94.1
+   Add the bin dir of above installation to your PATH: export PATH=/glusterfs/users/swiftlang/kmaheshwari/swift-0.94.1/bin:$PATH
+-- Create compute instances from a snapshot/image which has the current EPlus directory and the following libraries installed:
+ glibc-static, glibc.i686, libgcc_s.so.1, libstdc++.so.6
+-- To install the above libraries on an instance use yum: yum -y install glibc-static glibc.i686 libgcc_s.so.1 libstdc++.so.6
+-- The compute nodes must also have the nodejs and nodejs module xml2json installed. The nodejs package can be installed by copying and untarring the node-v0.10.20-linux-x64.tar.gz package from /glusterfs/users/swiftlang/kmaheshwari on OSDC
+-- The xml2json package is already installed in the EPlus/examples directory. On compute instances, set the NODE_PATH environment variable to make the module available:
+ export NODE_PATH=$HOME/EPlus/example/node_modules
+-- Add the ip addresses of currently running instances to a file called hosts.txt. for example, if the ips are 172.16.1.9 and 172.16.1.16. The hosts.txt will look like:
+172.16.1.9 172.16.1.16
+ To run the application on OSDC instances from OSDC login node follow the steps below:
+step0. Change to the EPlus/examples directory:
+ cd ~/EPlus/examples
+step1. Run the setup script as follows:
+ ./setup
+ This script will start the coaster service on login node and worker agents on compute nodes
+step2. Run the Swift script as follows:
+swift -sites.file sites.xml -tc.file tc.data -config cf sweep1.swift
+step3. Once complete, clean the log files and stop the coaster service as follows:
+  ./cleanup
Added: SwiftApps/tc.data
--- SwiftApps/tc.data	                        (rev 0)
+++ SwiftApps/tc.data	2013-11-07 17:28:18 UTC (rev 7281)
@@ -0,0 +1,22 @@
+persistent-coasters cat /bin/cat null null null
+persistent-coasters bash /bin/bash null null null
+persistent-coasters echo /bin/echo null null null
+persistent-coasters sh /bin/sh null null null
