[Swift-commit] r6387 - in branches/release-0.94/src/org/griphyn/vdl: engine mapping mapping/file
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Mar 17 02:49:58 CDT 2013
Author: hategan
Date: 2013-03-17 02:49:58 -0500 (Sun, 17 Mar 2013)
New Revision: 6387
Modified:
   branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/Mapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/MapperFactory.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/CSVMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/file/TestMapper.java
Log:
added compile-time validation of mapper parameters
Modified: branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java
--- branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/engine/Karajan.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -64,6 +64,7 @@
 import org.griphyn.vdl.engine.VariableScope.WriteType;
 import org.griphyn.vdl.karajan.CompilationException;
 import org.griphyn.vdl.karajan.Loader;
+import org.griphyn.vdl.mapping.MapperFactory;
 import org.griphyn.vdl.toolkit.VDLt2VDLx;
 import org.griphyn.vdl.type.NoSuchTypeException;
 import org.safehaus.uuid.UUIDGenerator;
@@ -465,7 +466,9 @@
 			if (mapping != null) {
 				StringTemplate mappingST = new StringTemplate("mapping");
-				mappingST.setAttribute("descriptor", mapping.getDescriptor());
+				String mapperType = mapping.getDescriptor();
+				mappingST.setAttribute("descriptor", mapperType);
+				checkMapperParams(mapperType, mapping);
 				for (int i = 0; i < mapping.sizeOfParamArray(); i++) {
 					Param param = mapping.getParamArray(i);
 					mappingST.setAttribute("params", mappingParameter(param, scope));
@@ -491,6 +494,27 @@
 		scope.bodyTemplate.setAttribute("declarations", variableST);
+    private void checkMapperParams(String mapperType, Mapping mapping) throws CompilationException {
+        if (!MapperFactory.isValidMapperType(mapperType)) {
+            throw new CompilationException("Unknown mapper type: '" + mapperType + "'");
+        Set<String> validParams = MapperFactory.getValidParams(mapperType);
+        if (validParams == null && mapping.sizeOfParamArray() > 0) {
+            throw new CompilationException(mapperType + " does not support any parameters");
+        if (validParams.contains("*")) {
+            // mapper accepts any parameter (e.g. external_mapper)
+            return;
+        for (int i = 0; i < mapping.sizeOfParamArray(); i++) {
+            Param param = mapping.getParamArray(i);
+            if (!validParams.contains(param.getName())) {
+                throw new CompilationException(mapperType + " does not support a '" + param.getName() + "' parameter");
     private StringTemplate mappingParameter(Param param, VariableScope scope) throws CompilationException {
         StringTemplate paramST = template("vdl_parameter");
         paramST.setAttribute("name", param.getName());
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -17,6 +17,9 @@
 package org.griphyn.vdl.mapping;
+import java.util.HashSet;
+import java.util.Set;
 import org.apache.log4j.Logger;
 import org.griphyn.vdl.mapping.file.FileGarbageCollector;
@@ -30,8 +33,26 @@
 	public static final Logger logger = Logger.getLogger(AbstractMapper.class);
 	public static final MappingParam PARAM_INPUT = new MappingParam("input", Boolean.FALSE);
-	protected MappingParamSet params;
+	protected void getValidMappingParams(Set<String> s) {
+	    addParams(s, PARAM_INPUT);
+	protected void addParams(Set<String> s, MappingParam... params) {
+	    for (MappingParam p : params) {
+	        s.add(p.getName());
+    @Override
+    public final Set<String> getSupportedParamNames() {
+        Set<String> s = new HashSet<String>();
+        getValidMappingParams(s);
+        return s;
+    protected MappingParamSet params;
 	public synchronized void setParam(MappingParam param, Object value) {
 		if (params == null) {
 			params = new MappingParamSet();
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/Mapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/Mapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/Mapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -18,6 +18,7 @@
 import java.util.Collection;
 /** This interface must be implemented by a Java class that represents
     a Swift mapper between SwiftScript variables and external data
@@ -80,4 +81,6 @@
     boolean isPersistent(Path path);
+    Set<String> getSupportedParamNames();
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/MapperFactory.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/MapperFactory.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/MapperFactory.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -22,6 +22,7 @@
 import java.util.HashMap;
 import java.util.Map;
 import org.griphyn.vdl.mapping.file.AirsnMapper;
 import org.griphyn.vdl.mapping.file.ArrayFileMapper;
@@ -38,11 +39,14 @@
 import org.griphyn.vdl.mapping.file.TestMapper;
 public class MapperFactory {
-	private static Map<String,Class<Mapper>> mappers =
-	    new HashMap<String,Class<Mapper>>();
+	private static Map<String, Class<? extends Mapper>> mappers;
+	private static Map<String, Set<String>> validParams;
 	static {
+	    mappers = new HashMap<String, Class<? extends Mapper>>();
+	    validParams = new HashMap<String, Set<String>>();
 		// the following are general purpose file mappers
 		registerMapper("simple_mapper", SimpleFileMapper.class);
 		registerMapper("single_file_mapper", SingleFileMapper.class);
@@ -62,11 +66,10 @@
 		registerMapper("test_mapper", TestMapper.class);
-	public synchronized static Mapper getMapper(String type, MappingParamSet params)
-	throws InvalidMapperException {
-		Class<Mapper> cls = mappers.get(type);
+	public synchronized static Mapper getMapper(String type, MappingParamSet params) throws InvalidMapperException {
+		Class<? extends Mapper> cls = mappers.get(type);
 		if (cls == null) {
-			throw new InvalidMapperException("no such mapper: "+type);
+			throw new InvalidMapperException("No such mapper: "+type);
 		try {
 			Mapper mapper = cls.newInstance();
@@ -77,15 +80,29 @@
 			throw new InvalidMapperException(type + ": " + e.getMessage(), e);
+	public synchronized static boolean isValidMapperType(String type) {
+	    return mappers.containsKey(type);
+    @SuppressWarnings("unchecked")
+    public static void registerMapper(String type, String cls) throws ClassNotFoundException {
+	    registerMapper(type, (Class<? extends Mapper>) MapperFactory.class.getClassLoader().loadClass(cls));
-    public static void registerMapper(String type, String cls)
-	throws ClassNotFoundException {
-	    registerMapper(type, MapperFactory.class.getClassLoader().loadClass(cls));
+    public synchronized static void registerMapper(String type, Class<? extends Mapper> cls) {
+		mappers.put(type, cls);
+		try {
+		    Mapper m = cls.newInstance();
+		    validParams.put(type, m.getSupportedParamNames());
+		catch (Exception e) {
+		    throw new RuntimeException("Cannot instantiate a '" + type + "'", e);
-	@SuppressWarnings("unchecked")
-    public synchronized static void registerMapper(String type,
-	                                               Class<?> cls) {
-		mappers.put(type, (Class<Mapper>) cls);
+    public static Set<String> getValidParams(String type) {
+        return validParams.get(type);
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -25,6 +25,7 @@
 import java.util.Iterator;
 import java.util.List;
 import org.globus.cog.util.Base64;
@@ -71,6 +72,13 @@
 	public static final MappingParam PARAM_PATTERN = new MappingParam("pattern", null);
 	public static final MappingParam PARAM_LOCATION = new MappingParam("location", null);
 	public static final MappingParam PARAM_NOAUTO = new MappingParam("noauto", "false");
+	@Override
+	    addParams(s, PARAM_PREFIX, PARAM_SUFFIX, PARAM_PATTERN, PARAM_LOCATION, PARAM_NOAUTO);
+        super.getValidMappingParams(s);
 	public static final Logger logger = Logger.getLogger(AbstractFileMapper.class);
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -37,6 +37,12 @@
     static Logger logger = Logger.getLogger(ArrayFileMapper.class);
 	public static final MappingParam PARAM_FILES = new MappingParam("files");
+	@Override
+	    addParams(s, PARAM_FILES);
 	public Collection<Path> existing() {
 		List<Path> l = new ArrayList<Path>();
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/CSVMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -27,6 +27,7 @@
 import java.util.StringTokenizer;
 import org.griphyn.vdl.mapping.AbsFile;
@@ -55,7 +56,14 @@
 	public static final MappingParam PARAM_HDELIMITER = new MappingParam("hdelim");
 	/** delimiters between content fields. default is space, tab, comma */
-	public static final MappingParam PARAM_DELIMITER = new MappingParam("delim", " \t,");
+	public static final MappingParam PARAM_DELIMITER = new MappingParam("delim", " \t,");
+	@Override
+	    addParams(s, PARAM_FILE, PARAM_HEADER, PARAM_SKIP, PARAM_HDELIMITER, PARAM_DELIMITER);
 	/** list of column names */
 	private List cols = new ArrayList();
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -35,6 +35,13 @@
 public class ConcurrentMapper extends AbstractFileMapper {
 	public static final MappingParam PARAM_THREAD_PREFIX = new MappingParam("thread_prefix", "");
+	@Override
+	    addParams(s, PARAM_THREAD_PREFIX);
 	private Map<Path, PhysicalFormat> remappedPaths;
 	public ConcurrentMapper() {
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/ExternalMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/ExternalMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -25,7 +25,6 @@
 import java.util.ArrayList;
-import java.util.HashSet;
@@ -44,7 +43,15 @@
 	private Map<Path, AbsFile> map;
 	private Map<String, Path> rmap;
-	public static final MappingParam PARAM_EXEC = new MappingParam("exec");
+	public static final MappingParam PARAM_EXEC = new MappingParam("exec");
+	@Override
+	    addParams(s, PARAM_EXEC);
+	    s.add("*");
 	private static final String[] STRING_ARRAY = new String[0];
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -42,6 +42,14 @@
     an array. */
 public class FixedArrayFileMapper extends AbstractMapper {
+	@Override
 	private List<String> files;
 	public FixedArrayFileMapper() {
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -22,6 +22,7 @@
 import java.util.Collections;
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -36,7 +37,14 @@
 public class RegularExpressionMapper extends AbstractMapper {
 	public static final MappingParam PARAM_SOURCE = new MappingParam("source");
 	public static final MappingParam PARAM_MATCH = new MappingParam("match");
-	public static final MappingParam PARAM_TRANSFORM = new MappingParam("transform");
+	public static final MappingParam PARAM_TRANSFORM = new MappingParam("transform");
+	@Override
+	    addParams(s, PARAM_SOURCE, PARAM_MATCH, PARAM_TRANSFORM);
 	public RegularExpressionMapper() {
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -20,11 +20,20 @@
 package org.griphyn.vdl.mapping.file;
 import org.griphyn.vdl.mapping.MappingParam;
 import org.griphyn.vdl.mapping.MappingParamSet;
 public class SimpleFileMapper extends AbstractFileMapper {
 	public static final MappingParam PARAM_PADDING = new MappingParam("padding", new Integer(4));
+	@Override
+	    addParams(s, PARAM_PADDING);
 	public SimpleFileMapper() {
 		super();
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -20,6 +20,7 @@
 import java.util.Arrays;
 import org.griphyn.vdl.mapping.AbstractMapper;
@@ -32,8 +33,14 @@
 public class SingleFileMapper extends AbstractMapper {
 	public static final MappingParam PARAM_FILE = new MappingParam("file");
+	@Override
+	    addParams(s, PARAM_FILE);
-	public SingleFileMapper() {
+    public SingleFileMapper() {
 		super();
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -21,6 +21,7 @@
@@ -41,7 +42,14 @@
+	@Override
 	public StructuredRegularExpressionMapper() {
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/file/TestMapper.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/file/TestMapper.java	2013-03-17 07:47:59 UTC (rev 6386)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/file/TestMapper.java	2013-03-17 07:49:58 UTC (rev 6387)
@@ -19,6 +19,7 @@
@@ -34,6 +35,12 @@
     public static final MappingParam PARAM_REMAPPABLE = new MappingParam("remappable", false);
     public static final MappingParam PARAM_STATIC = new MappingParam("static", true);
+    @Override
+        addParams(s, PARAM_FILE, PARAM_TEMP, PARAM_REMAPPABLE, PARAM_STATIC);
     private PhysicalFormat remap, map;
     @Override
